    4. Backitup Restore fehler
      Esmax666 @Glasfaser last edited by
      @glasfaser said in Backitup Restore fehler:
      iob install iobroker.zwave2@3.0.5
      davor muss ich noch iob stoppen oder ?
      • Glasfaser
        Glasfaser @Esmax666 last edited by
        @esmax666
        nein .
          @glasfaser
          am besten direkt
          iob install iobroker.zwave2@3.0.5 --debug
          • Glasfaser
            Glasfaser @Homoran last edited by
            Cannot download
            steht im Log
            aber --debug kann auch nicht schaden
              @glasfaser hat funktionniert:
              ich glaube da ist jetzt alles installiert 🙂
              esmax@ubuntu:/opt/iobroker$ iob install iobroker.zwave2@3.0.5 --debug
              NPM version: 9.6.7
              npm install iobroker.zwave2@3.0.5 --unsafe-perm --prefix "/opt/iobroker" (System call)
              added 126 packages in 32s
              133 packages are looking for funding
                run `npm fund` for details
              host.ubuntu install adapter zwave2@3.0.5
              upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
              upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
              upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
              upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
              upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
              upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
              upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
              upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
              upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
              upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
              upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
              upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
              upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js.map build/chunk-O2LXFUUG.js.map application/json
              upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js build/chunk-O2LXFUUG.js application/javascript
              upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js.map build/chunk-JKKDWOF2.js.map application/json
              upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js build/chunk-JKKDWOF2.js application/javascript
              upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js.map build/chunk-6B3WJWGE.js.map application/json
              upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js build/chunk-6B3WJWGE.js application/javascript
              upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
              host.ubuntu object system.adapter.zwave2 created/updated
              Update "system.adapter.zwave2.0"
              • Glasfaser
                Glasfaser last edited by Glasfaser
                @esmax666 sagte in Backitup Restore fehler:
                dann zeige mal
                iob diag
                in der Full Version
                  Esmax666 @Glasfaser last edited by Homoran
                  iob diag
                  Copy text starting here:
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                   Static hostname: ubuntu
                         Icon name: computer
                        Machine ID: 965a81734c8d402ab05ca26017c6e6a9
                           Boot ID: a39af5905d2248f68505f9914e186102
                  Operating System: Ubuntu 23.04
                            Kernel: Linux 6.2.0-1004-raspi
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.4
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   21:22:07 up  3:53,  2 users,  load average: 0.41, 0.34, 0.24
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  Other values than 0x0 hint to temperature/voltage problems
                  temp=52.1'C
                  volt=0.8820V
                  The systems needs to be REBOOTED!
                  *** Time and Time Zones ***
                                 Local time: Wed 2023-09-27 21:22:07 CEST
                             Universal time: Wed 2023-09-27 19:22:07 UTC
                                   RTC time: n/a
                                  Time zone: Europe/Paris (CEST, +0200)
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  esmax
                  /home/esmax
                  esmax adm dialout cdrom sudo audio video plugdev games users input render netdev gpio spi i2c iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            8.2G        1.4G        1.7G        3.3M        5.4G        6.8G
                  Swap:             0B          0B          0B
                  Total:          8.2G        1.4G        1.7G
                           7809 M total memory
                           1290 M used memory
                           1197 M active memory
                           4363 M inactive memory
                           1647 M free memory
                            195 M buffer memory
                           4992 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  Filesystem     Type   Size  Used Avail Use% Mounted on
                  tmpfs          tmpfs  781M  3.2M  778M   1% /run
                  /dev/mmcblk0p2 ext4    59G  5.2G   51G  10% /
                  tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
                  tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
                  /dev/mmcblk0p1 vfat   253M  151M  102M  60% /boot/firmware
                  tmpfs          tmpfs  781M  4.0K  781M   1% /run/user/1000
                  [Wed Sep 27 17:28:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
                  [Wed Sep 27 17:28:35 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                  [Wed Sep 27 17:28:35 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
                  [Wed Sep 27 17:28:37 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
                  [Wed Sep 27 17:28:47 2023] EXT4-fs (mmcblk0p2): resizing filesystem from 979920 to 15526139 blocks
                  [Wed Sep 27 17:28:48 2023] EXT4-fs (mmcblk0p2): resized filesystem to 15526139
                  Show mounted filesystems (real ones only):
                  TARGET              SOURCE         FSTYPE   OPTIONS
                  /                   /dev/mmcblk0p2 ext4     rw,relatime,discard,errors=remount-ro,commit=30
                  |-/snap/core22/611  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
                  |-/snap/lxd/24646   /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
                  |-/snap/snapd/18600 /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
                  |-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  |-/snap/lxd/25755   /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
                  `-/snap/core22/867  /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
                  /var:
                  924M    /var/
                  677M    /var/lib
                  505M    /var/lib/snapd
                  504M    /var/lib/snapd/snaps
                  220M    /var/cache
                  Archived and active journals take up 25.9M in the file system.
                  /opt/iobroker/backups:
                  4.5M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  110M    /opt/iobroker/iobroker-data/
                  83M     /opt/iobroker/iobroker-data/files
                  27M     /opt/iobroker/iobroker-data/files/javascript.admin
                  15M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                  8.0M    /opt/iobroker/iobroker-data/objects.json.bak
                  4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                  4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.17.1
                  /usr/bin/node           v18.17.1
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Installed: 18.17.1-deb-1nodesource1
                    Candidate: 18.17.1-deb-1nodesource1
                    Version table:
                   *** 18.17.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x lunar/main arm64 Packages
                          100 /var/lib/dpkg/status
                       18.13.0+dfsg1-1ubuntu2 500
                          500 http://ports.ubuntu.com/ubuntu-ports lunar/universe arm64 Packages
                  No problems detected
                  npm ERR! code ELSPROBLEMS
                  npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                  npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
                  npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
                  npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
                  npm ERR! invalid: @types/node@12.20.55 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                  npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/usb/node_modules/node-addon-api
                  npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T19_22_14_366Z-debug-0.log
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: file
                  States  type: file
                  No configuration change needed.
                  Multihost discovery server: disabled
                  Discovery authentication:   enabled
                  Persistent activation:      disabled
                  Objects:                    file on 127.0.0.1
                  States:                     file on 127.0.0.1
                  Core adapters versions
                  js-controller:  3.3.22
                  admin:          5.2.1
                  javascript:     5.2.13
                  Adapters from github:   0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.alexa2.0                 : alexa2                : ubuntu                                   - disabled
                  + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
                    system.adapter.cloud.0                  : cloud                 : ubuntu                                   - disabled
                    system.adapter.discovery.0              : discovery             : ubuntu                                   - disabled
                    system.adapter.flot.0                   : flot                  : ubuntu                                   - disabled
                  + system.adapter.heatingcontrol.0         : heatingcontrol        : ubuntu                                   -  enabled
                  + system.adapter.history.0                : history               : ubuntu                                   -  enabled
                    system.adapter.ical.0                   : ical                  : ubuntu                                   -  enabled
                    system.adapter.info.0                   : info                  : ubuntu                                   - disabled
                    system.adapter.iot.0                    : iot                   : ubuntu                                   - disabled
                  + system.adapter.javascript.0             : javascript            : ubuntu                                   -  enabled
                    system.adapter.linkeddevices.0          : linkeddevices         : ubuntu                                   - disabled
                    system.adapter.mobile.0                 : mobile                : ubuntu                                   - disabled
                    system.adapter.radar2.0                 : radar2                : ubuntu                                   - disabled
                    system.adapter.rpi2.0                   : rpi2                  : ubuntu                                   - disabled
                  + system.adapter.shuttercontrol.0         : shuttercontrol        : ubuntu                                   -  enabled
                    system.adapter.socketio.0               : socketio              : ubuntu                                   - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                    system.adapter.telegram.0               : telegram              : ubuntu                                   - disabled, port: 8443, bind: 0.0.0.0
                    system.adapter.text2command.0           : text2command          : ubuntu                                   - disabled
                    system.adapter.tr-064.0                 : tr-064                : ubuntu                                   - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : ubuntu                                   - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ubuntu                                   - disabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ubuntu                                   - disabled
                    system.adapter.vis-metro.0              : vis-metro             : ubuntu                                   - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ubuntu                                   - disabled
                    system.adapter.vis.0                    : vis                   : ubuntu                                   - disabled
                  + system.adapter.web.0                    : web                   : ubuntu                                   -  enabled, port: 443, bind: 0.0.0.0, run as: admin
                  + system.adapter.zwave2.0                 : zwave2                : ubuntu                                   -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  stable      : http://download.iobroker.net/sources-dist.json
                  beta        : http://download.iobroker.net/sources-dist-latest.json
                  Active repo: stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  hash unchanged, use cached sources
                  update done
                  Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
                  Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
                  Adapter    "backitup"      : 2.8.1    , installed 2.2.2 [Updateable]
                  Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
                  Adapter    "discovery"     : 3.1.0    , installed 3.1.0
                  Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
                  Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
                  Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
                  Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
                  Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
                  Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
                  Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
                  Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
                  Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
                  Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                  Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
                  Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
                  Adapter    "shuttercontrol": 1.6.2    , installed 1.2.1 [Updateable]
                  Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
                  Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
                  Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
                  Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
                  Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
                  Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
                  Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
                  Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
                  Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                  Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
                  Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
                  Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
                  Adapter    "zwave2"        : 3.0.5    , installed 3.0.5
                  Objects and States
                  Objects:        1829
                  States:         3260
                  Hit:1 http://ports.ubuntu.com/ubuntu-ports lunar InRelease
                  Hit:2 http://ports.ubuntu.com/ubuntu-ports lunar-updates InRelease
                  Hit:3 http://ports.ubuntu.com/ubuntu-ports lunar-backports InRelease
                  Hit:4 http://ports.ubuntu.com/ubuntu-ports lunar-security InRelease
                  Hit:5 https://deb.nodesource.com/node_18.x lunar InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          78134      1/systemd
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        37558      13668/systemd-resol
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       86098      46034/iobroker.js-c
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       86091      46034/iobroker.js-c
                  tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        37560      13668/systemd-resol
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          39954      1/systemd
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          78136      1/systemd
                  tcp6       0      0 :::443                  :::*                    LISTEN      1001       90857      49322/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       84702      46059/io.admin.0
                  udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        37559      13668/systemd-resol
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        37557      13668/systemd-resol
                  udp        0      0 192.168.178.54:68       0.0.0.0:*                           998        52189      37786/systemd-netwo
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          76543      1/systemd
                  udp6       0      0 :::111                  :::*                                0          76545      1/systemd
                  udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        52209      37786/systemd-netwo
                  2023-09-27 21:07:59.781  - info: host.ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-09-27 21:08:09.427  - info: host.ubuntu "system.adapter.ical.0" disabled
                  2023-09-27 21:08:09.428  - info: host.ubuntu stopInstance system.adapter.ical.0 (force=false, process=false)
                  2023-09-27 21:08:09.430  - info: host.ubuntu stopInstance canceled schedule system.adapter.ical.0
                  2023-09-27 21:08:14.720  - info: host.ubuntu "system.adapter.ical.0" enabled
                  2023-09-27 21:08:14.723  - info: host.ubuntu stopInstance system.adapter.ical.0 (force=false, process=false)
                  2023-09-27 21:08:17.803  - info: host.ubuntu instance scheduled system.adapter.ical.0 0,30 * * * *
                  2023-09-27 21:08:17.841  - info: host.ubuntu instance system.adapter.ical.0 started with pid 49431
                  2023-09-27 21:08:19.974  - info: ical.0 (49431) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  2023-09-27 21:08:19.991  - info: ical.0 (49431) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 3.3.22
                  2023-09-27 21:08:20.611  - info: ical.0 (49431) processing URL: calendar1 https://63ea0ab88b/basic.ics
                  2023-09-27 21:08:25.685  - info: ical.0 (49431) Terminated (NO_ERROR): Without reason
                  2023-09-27 21:08:26.285  - info: host.ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-09-27 21:10:00.025  - debug: shuttercontrol.0 (49337) calculate astrodata ...
                  2023-09-27 21:10:00.026  - debug: shuttercontrol.0 (49337) Sun Azimut: 293.5°
                  2023-09-27 21:10:00.027  - debug: shuttercontrol.0 (49337) Sun Elevation: -20.7°
                  2023-09-27 21:15:00.023  - debug: shuttercontrol.0 (49337) calculate astrodata ...
                  2023-09-27 21:15:00.024  - debug: shuttercontrol.0 (49337) Sun Azimut: 294.5°
                  2023-09-27 21:15:00.024  - debug: shuttercontrol.0 (49337) Sun Elevation: -21.5°
                  2023-09-27 21:17:03.503  - debug: zwave2.0 (49299) Node 34: value updated: value_electric_kwh_consumed => 1.02
                  2023-09-27 21:20:00.024  - debug: shuttercontrol.0 (49337) calculate astrodata ...
                  2023-09-27 21:20:00.024  - debug: shuttercontrol.0 (49337) Sun Azimut: 295.6°
                  2023-09-27 21:20:00.025  - debug: shuttercontrol.0 (49337) Sun Elevation: -22.2°
                  2023-09-27 21:21:53.141  - debug: zwave2.0 (49299) Node 5: metadata updated: airTemperature
                  2023-09-27 21:21:53.143  - debug: zwave2.0 (49299) Node 5: value updated: airTemperature => 17.79
                  iob diag has finished.
                  Press any key for a summary
                                       v.2023-06-20
                         Icon name: computer
                      Architecture: arm64
                  Installation:           native
                  Kernel:                 aarch64
                  Userland:               arm64
                  Timezone:               Europe/Paris (CEST, +0200)
                  User-ID:                1000
                  X-Server:               false
                  Boot Target:            graphical.target
                  Pending OS-Updates:     0
                  Pending iob updates:    26
                  Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                  MEMORY:
                  Mem:            8.2G        1.6G        1.5G        3.3M        5.4G        6.6G
                  Swap:             0B          0B          0B
                  Total:          8.2G        1.6G        1.5G
                  Active iob-Instances:   9
                  Active repo: stable
                  ioBroker Core:          js-controller           3.3.22
                                          admin                   5.2.1
                  Objects type: file
                  States  type: file
                  Objects:                1829
                  States:                 3261
                  Size of iob-Database:
                  3.7M    /opt/iobroker/iobroker-data/objects.jsonl
                  832K    /opt/iobroker/iobroker-data/states.json.bak
                  44K     /opt/iobroker/iobroker-data/states.jsonl
                  === Mark text until here for copying ===
                  Glasfaser Thomas Braun simatec 3 Replies Last reply Reply Quote 0
                  • Glasfaser
                    Glasfaser @Esmax666 last edited by Glasfaser
                    @esmax666
                    sieht sehr gut aus .. hast alles gemacht wie beschrieben !
                    jetzt weiter machen , nach der Liste !
                    EDIT
                    aber fange mit dem
                    an !
                      Thomas Braun Most Active @Esmax666 last edited by
                      Meine Gedanken zu dem System, kannst du umsetzen wenn der ioBroker wieder rennt.
                      Ungünstige Wahl für einen längeren Betrieb. Diese Interimsversionen von ubuntu leben nur 9 Monate. Besser ein Debian/Raspberry OS auf die Kiste werfen.
                      Keine Deko, das sollte man tun.
                      Du sitzt in Frankreich?
                      Du hast das System nicht sauber heruntergefahren. IMMER tun.
                      Nicht falsch, aber nicht aktuell. Stell auf das neue nodesource-Repo um.
                      Installier iobroker.javascript nochmal drüber.
                      • simatec
                        simatec Developer Most Active @Esmax666 last edited by
                        @esmax666 wenn alles fertig installiert ist und läuft, dann mache ein Upgrade aller Adapter und vorher js-controller updaten
                        iobroker stop
                        iobroker update
                        iobroker upgrade self
                        iobroker upgrade -y
                        iobroker fix
                        iobroker start
                        • simatec
                          simatec Developer Most Active last edited by simatec
                          @Esmax666
                          Danach richte Backitup ein, damit du jede Nacht ein Backup machst.
                          Am besten auf ein NAS oder wenn du dass nicht hast, nutze einen Clouddienst, den Backitup unterstützt.
                          Im Anschluss noch einen Kalendereintrag, der sich jeden Monat wiederholt, in dem du dein System auf Stand bringst.
                          Immer das System und den iobroker aktuell halten
                            @glasfaser
                            also jscontroler ist jetzt aktualisiert 5.0.12
                            ich kann jetzt weiter weitermachen oder ? weboberfläche geht aber nicht mehr
                            Skript v.2023-06-20
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                     Boot ID: 0c59d3c9640b486fadab37c9e124b76a
                                      Kernel: Linux 6.2.0-1013-raspi
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             23:16:45 up 8 min,  2 users,  load average: 3.57, 1.61, 0.67
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=68.6'C
                            volt=0.9260V
                                           Local time: Wed 2023-09-27 23:16:46 CEST
                                       Universal time: Wed 2023-09-27 21:16:46 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            esmax
                            /home/esmax
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.2G        1.4G        6.4G        3.2M        602M        6.8G
                            Swap:             0B          0B          0B
                            Total:          8.2G        1.4G        6.4G
                                     7809 M total memory
                                     1352 M used memory
                                      283 M active memory
                                     1153 M inactive memory
                                     6148 M free memory
                                       59 M buffer memory
                                      515 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            tmpfs          tmpfs  781M  3.1M  778M   1% /run
                            [Wed Sep 27 23:08:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
                            [Wed Sep 27 23:08:29 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                            [Wed Sep 27 23:08:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
                            [Wed Sep 27 23:08:31 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
                            |-/snap/core22/611  /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/core22/867  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/lxd/24646   /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/lxd/25755   /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/snapd/18600 /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
                            `-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            943M    /var/
                            677M    /var/lib
                            505M    /var/lib/snapd
                            222M    /var/cache
                            Archived and active journals take up 43.0M in the file system.
                            119M    /opt/iobroker/iobroker-data/
                            8.1M    /opt/iobroker/iobroker-data/objects.jsonl
                            8.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                            8.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T21_17_01_730Z-debug-0.log
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                    jsonl on 127.0.0.1
                            States:                     jsonl on 127.0.0.1
                            js-controller:  5.0.12
                            admin:          5.2.1
                            javascript:     5.2.13
                            Adapter State
                            + instance is alive
                            Active repo(s): stable
                            Adapter    "admin"        : 6.10.1   , installed 5.2.1  [Updatable]
                            Adapter    "alexa2"       : 3.25.2   , installed 3.9.3  [Updatable]
                            Adapter    "backitup"     : 2.8.1    , installed 2.2.2  [Updatable]
                            Adapter    "cloud"        : 4.4.1    , installed 4.1.0  [Updatable]
                            Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                            Adapter    "heatingcontrol": 2.11.1  , installed 2.7.2  [Updatable]
                            Adapter    "history"      : 2.2.6    , installed 1.9.14 [Updatable]
                            Adapter    "ical"         : 1.13.3   , installed 1.11.4 [Updatable]
                            Adapter    "info"         : 1.9.26   , installed 1.9.8  [Updatable]
                            Adapter    "iot"          : 1.14.5   , installed 1.8.22 [Updatable]
                            Adapter    "javascript"   : 7.1.4    , installed 5.2.13 [Updatable]
                            Controller "js-controller": 5.0.12   , installed 5.0.12
                            Adapter    "linkeddevices": 1.5.5    , installed 1.4.3  [Updatable]
                            Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
                            Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                            Adapter    "shuttercontrol": 1.6.2   , installed 1.2.1  [Updatable]
                            Adapter    "socketio"     : 6.5.5    , installed 3.1.4  [Updatable]
                            Adapter    "telegram"     : 1.16.0   , installed 1.10.0 [Updatable]
                            Adapter    "text2command" : 3.0.2    , installed 2.1.1  [Updatable]
                            Adapter    "tr-064"       : 4.2.18   , installed 4.2.14 [Updatable]
                            Adapter    "vis"          : 1.4.16   , installed 1.4.5  [Updatable]
                            Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                            Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
                            Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
                            Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                            Adapter    "web"          : 6.1.2    , installed 3.4.9  [Updatable]
                            Objects and States
                            Objects:        4592
                            States:         3264
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17467      1/init
                            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        22635      555/systemd-resolve
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       26995      2351/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27002      2351/iobroker.js-co
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        22633      555/systemd-resolve
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          13962      1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          23620      1/init
                            udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        22634      555/systemd-resolve
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        22632      555/systemd-resolve
                            udp        0      0 192.168.178.54:68       0.0.0.0:*                           998        22809      812/systemd-network
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17468      1/init
                            udp6       0      0 :::111                  :::*                                0          16876      1/init
                            udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        22817      812/systemd-network
                            2023-09-27 23:17:33.462  - info: zwave2.0 (2938) Node 2: ready to use
                            2023-09-27 23:17:33.697  - info: zwave2.0 (2938) Node 2 is alive
                            2023-09-27 23:17:36.082  - info: zwave2.0 (2938) Node 3: ready to use
                            2023-09-27 23:17:36.179  - info: vis.0 (3029) Uploaded. 0
                            2023-09-27 23:17:36.436  - info: zwave2.0 (2938) Node 4: ready to use
                            2023-09-27 23:17:36.695  - info: vis.0 (3029) Terminated (NO_ERROR): Without reason
                            2023-09-27 23:17:37.940  - info: zwave2.0 (2938) Node 5: ready to use
                            2023-09-27 23:17:38.180  - info: zwave2.0 (2938) Node 5 is alive
                            2023-09-27 23:17:40.108  - info: zwave2.0 (2938) Node 7: ready to use
                            2023-09-27 23:17:40.256  - info: zwave2.0 (2938) Node 8: ready to use
                            2023-09-27 23:17:40.402  - info: zwave2.0 (2938) Node 9: ready to use
                            2023-09-27 23:17:41.185  - info: zwave2.0 (2938) Node 22: ready to use
                            2023-09-27 23:17:41.886  - info: zwave2.0 (2938) Node 25: ready to use
                            2023-09-27 23:17:59.738  - info: zwave2.0 (2938) Node 31: ready to use
                            2023-09-27 23:17:59.860  - info: zwave2.0 (2938) Node 31 is alive
                            2023-09-27 23:17:59.876  - info: zwave2.0 (2938) Node 32: ready to use
                            2023-09-27 23:17:59.988  - info: zwave2.0 (2938) Node 32 is alive
                            2023-09-27 23:18:00.067  - info: zwave2.0 (2938) Node 33: ready to use
                            2023-09-27 23:18:00.121  - info: zwave2.0 (2938) Node 34: ready to use
                            2023-09-27 23:18:00.169  - info: zwave2.0 (2938) Node 33 is alive
                            2023-09-27 23:18:00.183  - info: zwave2.0 (2938) Node 34 is alive
                            2023-09-27 23:18:00.390  - info: zwave2.0 (2938) Node 35: ready to use
                            2023-09-27 23:18:00.448  - info: zwave2.0 (2938) Node 35 is alive
                            2023-09-27 23:18:00.478  - info: zwave2.0 (2938) Node 38: ready to use
                            2023-09-27 23:18:00.526  - info: zwave2.0 (2938) Node 38 is alive
                              @esmax666
                              iob update
                              iob upgrade all -y
                              iob start admin
                                Esmax666 @Thomas Braun last edited by
                                @thomas-braun said in Backitup Restore fehler:
                                ich wollte ertmals probieren wie es früher war um weniger Problem zu bekommen 😄
                                ich auch gemacht
                                JA
                                Seltsam ich habe nur gerade heute ubuntu / iobroker installiert ohne das Gerät auszuschalten
                                wie soll ich das machen ?
                                  Esmax666 @Esmax666 last edited by Esmax666
                                  update ist done,
                                  ich glaube da läuft alles wieder richtig, dann mache schnell noch ein backup 😄
                                  Also das wäre noch eventuel zu machen ? Node.js: v18.17.1(18.18.0)
                                  NPM: 9.6.7(9.8.1)
                                  aber wie ?
                                  Skript v.2023-06-20
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                   23:43:46 up 35 min,  2 users,  load average: 0.05, 0.65, 1.10
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=53.0'C
                                  volt=0.8600V
                                                 Local time: Wed 2023-09-27 23:43:46 CEST
                                             Universal time: Wed 2023-09-27 21:43:46 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  esmax
                                  /home/esmax
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            8.2G        1.3G        5.5G        3.3M        1.8G        6.9G
                                  Swap:             0B          0B          0B
                                  Total:          8.2G        1.3G        5.5G
                                           7809 M total memory
                                           1195 M used memory
                                            476 M active memory
                                           1755 M inactive memory
                                           5249 M free memory
                                             97 M buffer memory
                                           1576 M swap cache
                                              0 M total swap
                                              0 M used swap
                                              0 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/mmcblk0p2 ext4    59G  5.5G   51G  10% /
                                  /var:
                                  944M    /var/
                                  677M    /var/lib
                                  505M    /var/lib/snapd
                                  222M    /var/cache
                                  7.6M    /opt/iobroker/backups/
                                  229M    /opt/iobroker/iobroker-data/
                                  192M    /opt/iobroker/iobroker-data/files
                                  52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                  34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                  33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                  19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                                  18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                                  8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                                  8.2M    /opt/iobroker/iobroker-data/objects.jsonl
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.10.1
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Adapter    "admin"        : 6.10.1   , installed 6.10.1
                                  Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                                  Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                                  Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                                  Adapter    "history"      : 2.2.6    , installed 2.2.6
                                  Adapter    "info"         : 1.9.26   , installed 1.9.26
                                  Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                  Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                  Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                                  Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                                  Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                  Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                  Adapter    "text2command" : 3.0.2    , installed 3.0.2
                                  Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                  Adapter    "web"          : 6.1.2    , installed 6.1.2
                                  Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                  Objects and States
                                  Objects:        4615
                                  States:         3306
                                  Pending Updates: 0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       47592      9892/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50371      9892/iobroker.js-co
                                  tcp6       0      0 :::443                  :::*                    LISTEN      1001       47776      10028/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47619      9910/io.admin.0
                                  2023-09-27 23:38:35.483  - info: zwave2.0 (10049) Node 4: ready to use
                                  2023-09-27 23:38:35.521  - info: zwave2.0 (10049) Node 4 is alive
                                  2023-09-27 23:38:37.047  - info: zwave2.0 (10049) Node 5: ready to use
                                  2023-09-27 23:38:37.108  - info: zwave2.0 (10049) Node 5 is alive
                                  2023-09-27 23:38:38.332  - info: zwave2.0 (10049) Node 22: ready to use
                                  2023-09-27 23:38:38.362  - info: zwave2.0 (10049) Node 22 is alive
                                  2023-09-27 23:38:56.528  - info: admin.0 (9910) ==> Connected system.user.admin from ::ffff:192.168.178.39
                                  2023-09-27 23:38:58.724  - info: zwave2.0 (10049) Node 31: ready to use
                                  2023-09-27 23:38:58.754  - info: zwave2.0 (10049) Node 31 is alive
                                  2023-09-27 23:38:58.817  - info: zwave2.0 (10049) Node 32: ready to use
                                  2023-09-27 23:38:58.865  - info: zwave2.0 (10049) Node 33: ready to use
                                  2023-09-27 23:38:58.936  - info: zwave2.0 (10049) Node 34: ready to use
                                  2023-09-27 23:38:58.970  - info: zwave2.0 (10049) Node 32 is alive
                                  2023-09-27 23:38:58.990  - info: zwave2.0 (10049) Node 33 is alive
                                  2023-09-27 23:38:59.014  - info: zwave2.0 (10049) Node 34 is alive
                                  2023-09-27 23:38:59.204  - info: zwave2.0 (10049) Node 35: ready to use
                                  2023-09-27 23:38:59.263  - info: zwave2.0 (10049) Node 35 is alive
                                  2023-09-27 23:38:59.292  - info: zwave2.0 (10049) Node 38: ready to use
                                  2023-09-27 23:38:59.322  - info: zwave2.0 (10049) Node 38 is alive
                                  2023-09-27 23:40:00.027  - debug: shuttercontrol.0 (10013) calculate astrodata ...
                                  2023-09-27 23:40:00.028  - debug: shuttercontrol.0 (10013) Sun Azimut: 331.9°
                                  2023-09-27 23:40:00.029  - debug: shuttercontrol.0 (10013) Sun Elevation: -38.6°
                                  2023-09-27 23:42:25.827  - debug: zwave2.0 (10049) Node 3: metadata updated: airTemperature
                                  2023-09-27 23:42:25.830  - debug: zwave2.0 (10049) Node 3: value updated: airTemperature => 19.37
                                  2023-09-27 23:43:32.756  - debug: zwave2.0 (10049) Node 32: value updated: value_electric_kwh_consumed => 0.5
                                    Schon wieder. Ich vermute dann, das deine SD-Karte krümelig ist.
                                    Wenn du ansonsten das System sauber handelst.
                                      aber wie ?
                                      Schau in meiner Signatur nach dem node-fix-Skript.
                                        krümelig
                                        Sag das nicht lol , ich habe gerade die karte gekauft (SANDISK Elite Extreme)
                                        Thomas Braun ? 2 Replies Last reply Reply Quote 0
                                          @esmax666
                                          Die Meldung mit den orphans ist jedenfalls nicht normal. Kommt wenn dem System abrupt der Strom genommen wird und/oder bei defektem Datenträger.
                                          • simatec
                                            simatec Developer Most Active @Thomas Braun last edited by
                                            @thomas-braun sagte in Backitup Restore fehler:
                                            @Esmax666 Trenne niemals deinen PI einfach vom Strom. Ein OS muss immer sauber heruntergefahren werden.
                                            4697
