    4. MQTT bei Shelly 2PM
    MQTT bei Shelly 2PM
      LaBamba last edited by LaBamba
      @arteck
      @Glasfaser
      @mickym
      Weiss jemand welche Einstellungen bei MQTT und dem neuen Shelly 2PM gemacht werden müssen?
      Dann bekomme ich folgende Fehlermeldung.
      shelly.0
      	2023-09-27 22:46:12.243	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-80646fca50f0"
      shelly.0
      	2023-09-27 22:45:47.623	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-80646fca50f0"
      shelly.0
      	2023-09-27 22:45:47.439	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-80646fca50f0"
      shelly.0
      	2023-09-27 22:44:33.596	error	DB closed
      shelly.0
      	2023-09-27 22:44:33.596	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:629:26) at Socket.emit (node:events:514:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:323:12)
      shelly.0
      	2023-09-27 22:44:33.593	error	unhandled promise rejection: DB closed
      shelly.0
      	2023-09-27 22:44:33.592	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().```
      L Samson71 2 Replies Last reply Reply Quote 0
        LaBamba @LaBamba last edited by LaBamba
        oder die Warnung
        shelly.0
        	2023-09-27 22:55:10.995	warn	[Mqtt.statusNotifications] 192.168.178.69 (shellyplus2pm / shellyplus2pm-80646fca50f0 / shellyplus2pm#80646fca50f0#1): "General Status Notifications" are disabled (see adapter documentation for details)
        shelly.0
        	2023-09-27 22:55:00.142	warn	[Mqtt.statusNotifications] 192.168.178.69 (shellyplus2pm / shellyplus2pm-80646fca50f0 / shellyplus2pm#80646fca50f0#1): "General Status Notifications" are disabled (see adapter documentation for details)
        • mickym
          Ich nutze normales mqtt - und nicht den Shelly Adapter - insofern kann ich Dir da nicht helfen.
          • Samson71
            Samson71 Global Moderator @LaBamba last edited by
            @labamba
            Da fehlt noch der 4. Haken
            L 1 Reply Last reply Reply Quote 3
              LaBamba @Samson71 last edited by LaBamba
              @samson71
              Geht anscheinend nur über eine zweite Instanz. Folglich muss die erste und zweite Generation der Shellys getrennt werden.
              https://www.shelly-support.eu/forum/thread/19205-plus-2pm-werte-werden-nicht-in-iobroker-angezeigt/
              Samson71 1 Reply Last reply Reply Quote 1
              • Samson71
                @labamba
                Logisch, wenn die vorhandene Instanz per CoAP/ColoIT läuft. Trotzdem fehlt dann der 4. Haken. Für eine umfassende Antwort wären aber alle relevanten Informationen notwendig gewesen.
