    4. Test Adapter MyVBus v0.6.x Latest
      ChrisChros @pdbjjens last edited by ChrisChros
      @pdbjjens Installation hat ohne Probleme funktioniert und der Adapter zeigt an das er verbunden ist.
      Laut Datenaufzeichnung kommen auch werte an, somit sollte alles wie gewohnt laufen.
      Danke.
      myvbus.0
      2023-03-01 15:59:48.599	info	Connection established
      myvbus.0
      2023-03-01 15:59:48.583	info	Wait for Connection...
      myvbus.0
      2023-03-01 15:59:48.581	info	TCP Connection to 10.10.20.6 selected
      myvbus.0
      2023-03-01 15:59:48.480	info	starting. Version 0.2.3 (non-npm: iobroker-community-adapters/ioBroker.myvbus#1f70078181736d48412d671b41c27b618dd71dff) in /opt/iobroker/node_modules/iobroker.myvbus, node: v16.19.0, js-controller: 4.0.24
      host.raspberrypi
      2023-03-01 15:59:44.857	info	instance system.adapter.myvbus.0 started with pid 22014
      host.raspberrypi
      2023-03-01 15:59:42.781	info	iobroker exit 0
      host.raspberrypi
      2023-03-01 15:59:42.424	info	instance system.adapter.myvbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      myvbus.0
      2023-03-01 15:59:41.766	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      myvbus.0
      2023-03-01 15:59:41.765	info	terminating
      myvbus.0
      2023-03-01 15:59:41.764	info	Cleaned up everything...
      host.raspberrypi
      2023-03-01 15:59:41.760	info	stopInstance system.adapter.myvbus.0 send kill signal
      myvbus.0
      2023-03-01 15:59:41.760	info	Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi
      2023-03-01 15:59:41.753	info	stopInstance system.adapter.myvbus.0 (force=false, process=true)
      host.raspberrypi
      2023-03-01 15:59:41.729	info	iobroker Update "system.adapter.myvbus.0"
      host.raspberrypi
      2023-03-01 15:59:41.681	info	iobroker upload [0] myvbus.admin /opt/iobroker/node_modules/iobroker.myvbus/admin/words.js words.js application/javascript
      host.raspberrypi
      2023-03-01 15:59:41.671	info	iobroker upload [1] myvbus.admin /opt/iobroker/node_modules/iobroker.myvbus/admin/style.css style.css text/css
      host.raspberrypi
      2023-03-01 15:59:41.662	info	iobroker upload [2] myvbus.admin /opt/iobroker/node_modules/iobroker.myvbus/admin/myvbus.png myvbus.png image/png
      host.raspberrypi
      2023-03-01 15:59:41.554	info	iobroker upload [3] myvbus.admin /opt/iobroker/node_modules/iobroker.myvbus/admin/index_m.html index_m.html text/html
      host.raspberrypi
      2023-03-01 15:59:41.511	info	iobroker upload [4] myvbus.admin /opt/iobroker/node_modules/iobroker.myvbus/admin/admin.d.ts admin.d.ts video/mp2t
      host.raspberrypi
      2023-03-01 15:59:41.453	info	iobroker 73 packages are looking for funding run `npm fund` for details
      host.raspberrypi
      2023-03-01 15:59:41.449	info	iobroker changed 2 packages in 8s
      host.raspberrypi
      2023-03-01 15:59:41.448	info	iobroker
      host.raspberrypi
      2023-03-01 15:59:39.912	info	iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.myvbus.git
      host.raspberrypi
      2023-03-01 15:59:32.654	info	iobroker Installing iobroker-community-adapters/ioBroker.myvbus#1f70078181736d48412d671b41c27b618dd71dff... (System call)
      host.raspberrypi
      2023-03-01 15:59:32.651	info	iobroker NPM version: 8.19.3
      host.raspberrypi
      2023-03-01 15:59:31.448	info	iobroker install iobroker-community-adapters/ioBroker.myvbus#1f70078181736d48412d671b41c27b618dd71dff
      host.raspberrypi
      2023-03-01 15:59:28.723	info	iobroker url https://github.com/iobroker-community-adapters/ioBroker.myvbus --host raspberrypi --debug
      P 2 Replies Last reply Reply Quote 0
        pdbjjens @ChrisChros last edited by
        @chrischros
        Super, danke, für den Schnelltest. Dann werde ich mal sofort ein neues release machen, damit nicht noch mehr user in dies Problem laufen.
          pdbjjens @ChrisChros last edited by pdbjjens
          @chrischros
          Eine Information für alle, die diesen Thread noch verfolgen:
          Ich habe ein ioBroker.discovery Detektormodul für LAN-basierte VBus-Geräte implementiert. Es kann Instanzen für den myvbus und den resol Adapter erstellen.
          Da mir die notwendige RESOL Hardware fehlt, um alle Varianten durchzutesten, möchte ich an dieser Stelle bitten, die Discovery in Eurer Umgebung auszuprobieren und Probleme hier oder auf der gitHub-Seite https://github.com/ioBroker/ioBroker.discovery zu melden. Über positive Rückmeldungen freue ich mich natürlich auch.
          Achtung: Resol-Geräte, die über serielle Schnittstellen angeschlossen sind (z.B. VBUS/USB) werden nicht detektiert. Daher bitte diesen Test nicht durchführen wenn Ihr einen seriellen VBus-Hardware Adapter habt. Entdeckt werden nur über LAN angeschlossene VBus-Geräte (z.B. VBus/LAN, DL2, KM2, DL3)
          Installation und Bedienung:
          • Die Gerätesuche (ioBroker.discovery) in der v4.2.0 aus dem ioBroker latest repo installieren.
          • Im Tab "Instanzen" den Experten-Modus aktivieren.
          • Auf das "Auge" (Geräte und Dienste finden) klicken.
          • Unter "Folgende Methoden verwenden:" alle Boxen deaktivieren bis auf "vbus".
            "Entdecken" klicken.
          • Nach kurzer Zeit sollten auf der Seite "Instanzen erstellen" Vorschläge für neue myvbus und resol Instanzen erscheinen.
            Achtung: Falls bereits Instanzen des myvbus oder resol Adapters für das gefundene RESOL-Gerät auf Eurem System installiert sind, so werden sie nicht angezeigt. Wenn beispielsweise eine myvbus Instanz existiert, so wird nur die Erstellung einer resol-Instanz vorgeschlagen. Es ist probeweise möglich , die myvbus und die resol Instanzen parallel zu installieren. Daher müsst Ihr für diesen Test nicht eine bereits vorhandene Instanz des jeweils anderen Adapters löschen.
          • Haken in der Spalte "Instance" vor der zu erstellenden myvbus oder resol Instanz setzen.
          • "INSTANZEN ERSTELLEN" klicken.
          • Nach der erfolgten Installation"ABSCHLIESSEN" klicken.
          • Auf dem TAB "Instanzen" sollte nun die neu installierte Instanz erscheinen. Wenn Sie nicht den Status "grün" hat, über den "Schraubenschlüssel" auf der Konfigurationsseite der Instanz das vbus Passwort neu eingeben und "SCHLIESSEN" klicken. Danach sollte die Instanz dann "grün" werden.
            @pdbjjens sagte in Test Adapter MyVBus v0.2.x Latest:
            hab das nun mal ausprobiert, aber ich bekomme RESOL-Gerät angezeigt nach der Suche.
            Bildschirmfoto 2023-09-26 um 22.05.39.png Bildschirmfoto 2023-09-26 um 22.06.21.png
            Habe zwar den vbus-Adapter installiert, aber nach deiner Aussage sollte ja zumindest der RESOL-Adapter angezeigt werden. Auch wenn ich den vbus-Adapter stoppe und dann erst suche bekomme ich ebenfalls nicht den RESOL-Adapter angezeigt.
            Das vbus-Gerät befindet sich im selben subnet wie die iobroker-Instanz, sollte also auch nicht der Grund sein.
              @chrischros said in Test Adapter MyVBus v0.2.x Latest:
              Richtig. Danke für den Test, hast Du evtl. ein debug-log ?
              C 2 Replies Last reply Reply Quote 0
                @pdbjjens hab ich gestern nicht gemacht, kann ich heute Abend gerne nachholen und hochladen.
                  @pdbjjens hier der log von eben:
                  2023-09-27 16:49:53.868 - debug: discovery.0 (2835) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2023-09-27 16:49:53.923 - debug: discovery.0 (2835) Objects client ready ... initialize now
                  2023-09-27 16:49:53.926 - debug: discovery.0 (2835) Objects create System PubSub Client
                  2023-09-27 16:49:53.928 - debug: discovery.0 (2835) Objects create User PubSub Client
                  2023-09-27 16:49:53.970 - debug: discovery.0 (2835) Objects client initialize lua scripts
                  2023-09-27 16:49:53.982 - debug: discovery.0 (2835) Objects connected to redis: 127.0.0.1:9001
                  2023-09-27 16:49:54.017 - debug: discovery.0 (2835) Redis States: Use Redis connection: 127.0.0.1:9000
                  2023-09-27 16:49:54.031 - debug: discovery.0 (2835) States create System PubSub Client
                  2023-09-27 16:49:54.032 - debug: discovery.0 (2835) States create User PubSub Client
                  2023-09-27 16:49:54.101 - debug: discovery.0 (2835) States connected to redis: 127.0.0.1:9000
                  2023-09-27 16:49:54.201 - debug: discovery.0 (2835) Plugin sentry Initialize Plugin (enabled=true)
                  2023-09-27 16:49:54.707 - info: discovery.0 (2835) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.17.1, js-controller: 5.0.12
                  2023-09-27 16:50:21.436 - debug: discovery.0 (2835) Received "listMethods" event
                  2023-09-27 16:50:27.180 - debug: discovery.0 (2835) Received "browse" event
                  2023-09-27 16:50:28.694 - debug: discovery.0 (2835) main.addDevice: ip=10.10.20.6 source=RESOL VBus
                  2023-09-27 16:50:28.695 - info: discovery.0 (2835) Done discovering RESOL VBus devices. 1 packages received
                  2023-09-27 16:50:28.697 - info: discovery.0 (2835) Found 2 addresses
                  2023-09-27 16:50:29.665 - debug: discovery.0 (2835) Test vbus 10.10.20.6 myvbus
                  2023-09-27 16:50:29.680 - debug: discovery.0 (2835) Test vbus 10.10.20.6 resol
                  2023-09-27 16:50:29.706 - debug: discovery.0 (2835) Test once 0.0.0.0 sma-em
                  2023-09-27 16:50:31.715 - debug: discovery.0 (2835) Added suggested adapter: cloud.0
                  2023-09-27 16:50:31.728 - debug: discovery.0 (2835) Added suggested adapter: echarts.0
                  2023-09-27 16:50:31.732 - debug: discovery.0 (2835) Added suggested adapter: iot.0
                  2023-09-27 16:50:31.734 - debug: discovery.0 (2835) Added suggested adapter: iqontrol.0
                  2023-09-27 16:50:31.737 - debug: discovery.0 (2835) Added suggested adapter: jarvis.0
                  2023-09-27 16:50:31.744 - info: discovery.0 (2835) Discovery finished. Found new or modified 5 instances
                  2023-09-27 16:50:31.816 - info: discovery.0 (2835) Discovery finished
                  2023-09-27 16:50:31.818 - debug: discovery.0 (2835) Browse finished
                  Laut Log scheint er auch etwas zu finden, aber der Adapter wird mir nicht angezeigt.
                    Danke für das log; Deine Beobachtung ist richtig. Offenbar verläuft der Test nicht erfolgreich. Um darüber mehr zu erfahren, müsste ich das debug im Detectormodul aktivieren. Das geht aber leider nur durch eine Änderung in den Detektormodulen myvbus.js und resol.js (const debug = true;). Wärst Du bereit, eine entsprechend modifizierte Version des discovery adapters von gitHub zu installieren? Dann würde ich sie demnächst bereitstellen.
                    Noch eine Frage: welches Resol-Gerät hast Du für den LAN-Anschluss?
                      @pdbjjens ich nutze hier einen vbus/Lan-Adapter um die Werte von meiner Steuerung zu bekommen.
                      Bezüglich des Testens kann ich das frühestens am Samstag Abend machen. Wenn das für die i.O. kann ich das gerne die modifizierte Version installieren.
                        @chrischros
                        Danke für die Info und Deine Bereitschaft zum Testen. Ich melde mich hier, sobald die Testversion bereitsteht.
                          pdbjjens @pdbjjens last edited by
                          @ChrisChros
                          Die Debug Version steht zum Test bereit unter https://github.com/pdbjjens/ioBroker.discovery.git
                            Hab nun die Testversion installiert und damit bekomme ich den Resol-Adapter angezeigt.
                            Zusätzlich noch der debug Log:
                            2023-09-29 19:52:36.337 - debug: discovery.0 (26694) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2023-09-29 19:52:36.393 - debug: discovery.0 (26694) Objects client ready ... initialize now
                            2023-09-29 19:52:36.396 - debug: discovery.0 (26694) Objects create System PubSub Client
                            2023-09-29 19:52:36.397 - debug: discovery.0 (26694) Objects create User PubSub Client
                            2023-09-29 19:52:36.436 - debug: discovery.0 (26694) Objects client initialize lua scripts
                            2023-09-29 19:52:36.445 - debug: discovery.0 (26694) Objects connected to redis: 127.0.0.1:9001
                            2023-09-29 19:52:36.477 - debug: discovery.0 (26694) Redis States: Use Redis connection: 127.0.0.1:9000
                            2023-09-29 19:52:36.491 - debug: discovery.0 (26694) States create System PubSub Client
                            2023-09-29 19:52:36.492 - debug: discovery.0 (26694) States create User PubSub Client
                            2023-09-29 19:52:36.559 - debug: discovery.0 (26694) States connected to redis: 127.0.0.1:9000
                            2023-09-29 19:52:36.653 - debug: discovery.0 (26694) Plugin sentry Initialize Plugin (enabled=true)
                            2023-09-29 19:53:41.403 - debug: discovery.0 (26694) Received "listMethods" event
                            2023-09-29 19:53:45.712 - debug: discovery.0 (26694) Received "browse" event
                            2023-09-29 19:53:47.227 - debug: discovery.0 (26694) main.addDevice: ip=XX.XX.XX.X source=RESOL VBus
                            2023-09-29 19:53:47.229 - info: discovery.0 (26694) Done discovering RESOL VBus devices. 1 packages received
                            2023-09-29 19:53:47.231 - info: discovery.0 (26694) Found 2 addresses
                            2023-09-29 19:53:48.166 - debug: discovery.0 (26694) Test vbus XX.XX.XX.X myvbus
                            2023-09-29 19:53:48.168 - debug: discovery.0 (26694) Start detecting VBus device information on XX.XX.XX.X...
                            2023-09-29 19:53:48.169 - debug: discovery.0 (26694) Checking for device information at XX.XX.XX.X:80
                            2023-09-29 19:53:48.182 - debug: discovery.0 (26694) Test vbus XX.XX.XX.X resol
                            2023-09-29 19:53:48.184 - debug: discovery.0 (26694) Start detecting VBus device information on XX.XX.XX.X...
                            2023-09-29 19:53:48.184 - debug: discovery.0 (26694) Checking for device information at XX.XX.XX.X:80
                            2023-09-29 19:53:48.203 - debug: discovery.0 (26694) Device Information of XX.XX.XX.X:80 vendor = "RESOL"
                            product = "VBus/LAN Adapter"
                            serial = "XXX"
                            version = "2.0"
                            build = "rc1-WL-MAR"
                            name = "RESOL-LAN-XXX"
                            features = "vbus"
                            pcbserial = "XXX"
                            2023-09-29 19:53:48.205 - debug: discovery.0 (26694) Parsed Device Information of XX.XX.XX.X {"vendor":"RESOL","product":"VBus/LAN Adapter","serial":"XXX","version":"2.0","build":"rc1-WL-MAR","name":"RESOL-LAN-XXX","features":"vbus","pcbserial":"XXX"}
                            2023-09-29 19:53:48.208 - debug: discovery.0 (26694) Device Information of XX.XX.XX.X:80 vendor = "RESOL"
                            serial = "XXX"
                            version = "2.0"
                            features = "vbus"
                            pcbserial = "XXX"
                            2023-09-29 19:53:48.210 - debug: discovery.0 (26694) Parsed Device Information of XX.XX.XX.X {"vendor":"RESOL","product":"VBus/LAN Adapter","serial":"XXX","version":"2.0","build":"rc1-WL-MAR","name":"RESOL-LAN-XXX","features":"vbus","pcbserial":"XXX"}
                            2023-09-29 19:53:48.210 - debug: discovery.0 (26694) New Device RESOL RESOL-LAN-XXX Type lan found!
                            2023-09-29 19:53:48.211 - debug: discovery.0 (26694) Pushed new VBus device instance on XX.XX.XX.X:80
                            2023-09-29 19:53:48.212 - debug: discovery.0 (26694) Test XX.XX.XX.X resol DETECTED!
                            2023-09-29 19:53:48.219 - debug: discovery.0 (26694) Test once 0.0.0.0 sma-em
                            2023-09-29 19:53:50.227 - debug: discovery.0 (26694) Added suggested adapter: cloud.0
                            2023-09-29 19:53:50.231 - debug: discovery.0 (26694) Added suggested adapter: echarts.0
                            2023-09-29 19:53:50.234 - debug: discovery.0 (26694) Added suggested adapter: iot.0
                            2023-09-29 19:53:50.237 - debug: discovery.0 (26694) Added suggested adapter: iqontrol.0
                            2023-09-29 19:53:50.241 - debug: discovery.0 (26694) Added suggested adapter: jarvis.0
                            2023-09-29 19:53:50.254 - info: discovery.0 (26694) Discovery finished. Found new or modified 6 instances
                            2023-09-29 19:53:50.318 - info: discovery.0 (26694) Discovery finished
                            2023-09-29 19:53:50.320 - debug: discovery.0 (26694) Browse finished
                              @chrischros
                              Super, danke für den Test und das Log. Das hilft mir sehr.
                              Das Problem lag daran, dass der VBUS/Lan Hardware Adapter auf dem http Port (:80) antwortet und nicht auf (:3000). In der Debug-Version habe ich die Abfrage auf Port (:80) ergänzt. Daher wird der ioBroker.resol adapter jetzt gefunden.
                              Hast Du auch probiert, den iobroker.resol adapter über die discovery zu installieren? Gab es dabei irgendwelche Auffälligkeiten (ausser der evtl. notwendigen Passwort-Eingabe)?
                              Weiterhin ist für mich interessant, dass der VBUS/Lan Adapter sich mit product = "VBus/LAN Adapter" identifiziert. Diese Info bräuchte ich auch von anderen VBus-Geräten (DL2,DL3,KM2 usw.) um in der Konfiguration des ioBroker.adapters den Gerätetyp korrekt vorzubelegen.
                              Falls jemand hier mitliest, der ein solches Gerät hat und bereit ist, die Test-Version zu installieren und ein Log zu teilen, wäre das sehr hilfreich für die Verbesserung des discovery-moduls.
                                @chrischros
                                Installieren des Resol-Adapters über discovery scheint zu klappen:
                                resol.0 2023-09-30 15:20:34.787	info	Connection state changed to DISCONNECTED
                                resol.0 2023-09-30 15:20:34.779	info	Connection state changed to CONNECTING
                                resol.0 2023-09-30 15:20:34.777	info	Connection state changed to DISCONNECTED
                                resol.0 2023-09-30 15:20:34.769	info	Connection state changed to CONNECTING
                                resol.0 2023-09-30 15:20:34.768	info	Connection state changed to DISCONNECTED
                                resol.0 2023-09-30 15:20:34.741	info	Connection state changed to CONNECTING
                                resol.0 2023-09-30 15:20:34.740	info	Waiting for Connection...
                                resol.0 2023-09-30 15:20:34.738	info	TCP Connection via LAN to [10.10.20.6:7053] selected
                                resol.0 2023-09-30 15:20:34.703	info	Config seems to be valid for LAN.
                                resol.0 2023-09-30 15:20:34.650	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.resol, node: v18.17.1, js-controller: 5.0.12
                                resol.0 2023-09-30 15:19:58.574	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                resol.0 2023-09-30 15:19:58.568	error	resol.0 already running
                                resol.0 2023-09-30 15:19:47.185	info	Connection state changed to CONNECTING
                                resol.0 2023-09-30 15:19:47.184	info	Waiting for Connection...
                                resol.0 2023-09-30 15:19:47.181	info	TCP Connection via LAN to [10.10.20.6:7053] selected
                                resol.0 2023-09-30 15:19:47.133	info	Config seems to be valid for LAN.
                                resol.0 2023-09-30 15:19:47.072	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.resol, node: v18.17.1, js-controller: 5.0.12
                                  @chrischros
                                  Mir fällt im Log auf, dass der connection state sich dauernd ändert. Wird der Adapterstatus (Quadrat im Instanzen Tab) grün? Werden die Objekte angelegt und aktualisiert?
                                  Ich hatte so ein Verhalten schon mal. Nach nochmaliger Eingabe des vbus-passwords und neustart des resol adapters liefen dann beide ioBroker vbus adapter parallel.
                                  Möglich ist natürlich auch, dass der VBus/LAN Adapter nur eine Connection zur Zeit akzeptiert. Das könnte man testen indem der myvbus adapter pausiert wird.
                                    @pdbjjens ich denke das liegt daran, dass der myvbus noch verbunden war. der vbus/lan Konverter kann wohl nur eine Verbindung aufbauen.
                                    Hatte jetzt auch nicht weiter den resol Adapter getestet, da ich mir dem myvbus bisher alles abgedeckt bekomme.
                                      @chrischros
                                      O.K. Danke jedenfalls für die Mühe. Und ich freue mich natürlich, dass Dir der myvbus adapter gefällt. Mir reicht er ebenfalls völlig aus, da ich nicht die Absicht habe, Parameter des RESOL-Reglers über ioBroker zu ändern.
                                        @chrischros
                                        Mittlerweile kann man die aktualisierte Gerätesuche (ioBroker.discovery) in der v4.2.0 aus dem ioBroker latest repo installieren. Es ist nicht mehr nötig, die Debug Version aus meinem privaten repo https://github.com/pdbjjens/ioBroker.discovery.git zu installieren. Ich bitte daher, die Debug Version zu deinstallieren und durch v4.2.0 aus dem ioBroker latest repo zu ersetzen.
                                          Ich habe soeben ioBroker.mybus v0.3.0 latest zum Testen freigegeben.
                                          Neu: Support für Discovery ab ioBroker.discovery v4.2.0, welches auch ioBroker.resol Discovery unterstützt
                                          Neu: Das Configuration GUI wurde auf JSONconfig umgestellt.
                                          Mono990 1 Reply Last reply Reply Quote 2
                                          • Mono990
                                            Mono990 @pdbjjens last edited by
                                            Hallo
                                            Ich habe mir jetzt auch den KM2 besorgt um meine Daten von der Solarthermie anlage in meiner Vis anzeigen zu lassen.
                                            Dabei habe ich aber leider große Probleme.
                                            Der Adapeter zeigt alles grün an aber es kommen keine Daten rein.
                                            und in der Vis über iframe kann er die seite von Vbus.net nicht anzeigen da die seite Password geschützt ist.
                                            über Http://Login:password@Link klapt es auch nicht
                                            Kann mir jemand helfen das ich das in meiner Vis bekomme?
                                            1.0k
                                            resol vbus
                                            27
                                            381
                                            86107
