    4. JavaScript
    5. ecoflow-connector-Script zur dynamischen Leistungsanpassung
      resilient @Waly_de last edited by resilient
      @waly_de
      habe die Namen geändert und auch logM eingeschaltet... folgendes log:
      2023-09-28 11:22:30.842 - info: javascript.0 (490) script.js.ecoflow-connector_v1142: Verbunden mit dem Ecoflow MQTT-Broker
      2023-09-28 11:25:00.517 - info: javascript.0 (490) script.js.ecoflow-connector_v1142: PowerStream [PowerStream] Batterie ist bei 99%: Schalte auf Batterie Prioritätsmodus.
      2023-09-28 11:25:07.357 - info: javascript.0 (490) script.js.ecoflow-connector_v1142: RealPower Set Warte auf aktuelle Daten von: [PowerStream] lezter: 11:24:57 / ACset: 11:25:00
      2023-09-28 11:26:03.857 - info: admin.0 (463) <== Disconnect system.user.admin from ::ffff:192.168.178.77 javascript
      2023-09-28 11:31:51.319 - info: admin.0 (463) ==> Connected system.user.admin from ::ffff:192.168.178.77
      2023-09-28 11:32:44.371 - info: javascript.0 (490) Stop script script.js.ecoflow-connector_v1142
      2023-09-28 11:32:44.372 - info: javascript.0 (490) script.js.ecoflow-connector_v1142: Ecoflow MQTT-Client beendet
      2023-09-28 11:32:44.424 - info: javascript.0 (490) Start javascript script.js.ecoflow-connector_v1142
      2023-09-28 11:32:44.440 - info: javascript.0 (490) script.js.ecoflow-connector_v1142: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2023-09-28 11:32:44.731 - info: javascript.0 (490) script.js.ecoflow-connector_v1142: Verbunden mit dem Ecoflow MQTT-Broker
      2023-09-28 11:32:53.356 - info: admin.0 (463) <== Disconnect system.user.admin from ::ffff:192.168.178.77 javascript
      2023-09-28 11:34:21.212 - info: admin.0 (463) ==> Connected system.user.admin from ::ffff:192.168.178.77
      2023-09-28 11:34:26.839 - info: admin.0 (463) <== Disconnect system.user.admin from ::ffff:192.168.178.77 javascript
      2023-09-28 11:41:33.283 - info: javascript.0 (490) script.js.ecoflow-connector_v1142: PeakSkip Delta: 134
      2023-09-28 11:45:06.641 - info: javascript.0 (490) script.js.ecoflow-connector_v1142: Verbunden mit dem Ecoflow MQTT-Broker
      jetzt kommen Fehler:
      2023-09-28 11:52:43.631 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
      2023-09-28 11:52:53.632 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
      2023-09-28 11:53:02.089 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: PeakSkip Delta: 1431
      2023-09-28 11:53:03.633 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
      2023-09-28 11:53:13.633 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
      2023-09-28 11:53:23.633 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
      das geht eigentlich dauerhaft weiter mit dem selben fehler...
        Waly_de @resilient last edited by
        @resilient history Adapter installiert?
          pasch last edited by
          @waly_de Viel mehr steht leider nicht im Log. Bisher nur:
          2023-09-28 13:56:06.353 - info: javascript.0 (186) Start javascript script.js.ps
          2023-09-28 13:56:06.397 - info: javascript.0 (186) script.js.ps: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          2023-09-28 13:56:06.708 - info: javascript.0 (186) script.js.ps: Verbunden mit dem Ecoflow MQTT-Broker
          2023-09-28 14:08:36.580 - info: javascript.0 (186) script.js.ps: PowerStream [PowerStream] Batterie ist bei 98%: Schalte auf Batterie Prioritätsmodus.
          Irgendwann hatte ich noch ein PeakSkip Delta: 141.
            @waly_de
            hmm... History Adapter war ausgeschaltet weil ich influxdb instaliert hatte... kann das der Grund sein?
            hab jetzt History Adapter an und MinValueMin: 0, auf Echtzeit gestellt jetzt tut sich mehr.... Sind zwar gerade beide Batterien voll deswegen überschuss aber die Meldungen scheinen ok zu sein:
            2023-09-28 12:17:48.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: *************************************
            2023-09-28 12:17:48.336 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Änderung für Einspeisung gesendet PS:[PowerStream1] : 230 W
            2023-09-28 12:17:58.330 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Durchschnitt: PS:[PowerStream1] : -435
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: *************************************
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Lastcutoff: 0
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: gapSumme: -435
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Bedarf : 26
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: totalPV: 470
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: PVBedarf : 26
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: BatBedarf: 0
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: PVfaktor:0.05531914893617021
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Batfaktor:0
            2023-09-28 12:17:58.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: ueberschuss:435
            2023-09-28 12:17:58.337 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Änderung für Einspeisung gesendet PS:[PowerStream1] : 260 W
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Durchschnitt: PS:[PowerStream1] : -430
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: *************************************
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Lastcutoff: 0
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: gapSumme: -430
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Bedarf : 29
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: totalPV: 469
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: PVBedarf : 29
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: BatBedarf: 0
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: PVfaktor:0.06183368869936034
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Batfaktor:0
            2023-09-28 12:18:08.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: ueberschuss:430
            2023-09-28 12:18:08.336 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Änderung für Einspeisung gesendet PS:[PowerStream1] : 290 W
            2023-09-28 12:18:18.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Durchschnitt: PS:[PowerStream1] : -422
            2023-09-28 12:18:18.331 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: *************************************
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Lastcutoff: 0
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: gapSumme: -422
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Bedarf : 29
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: totalPV: 469
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: PVBedarf : 29
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: BatBedarf: 0
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: PVfaktor:0.06183368869936034
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Batfaktor:0
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: ueberschuss:422
            2023-09-28 12:18:18.332 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: *************************************
            sobald ich MinValueMin: 0.5 einstelle statt 0 kommen wieder die Fehler:
            2023-09-28 12:30:31.645 - info: javascript.0 (10357) Stop script script.js.ecoflow-connector_v1142
            2023-09-28 12:30:31.645 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Ecoflow MQTT-Client beendet
            2023-09-28 12:30:31.857 - info: javascript.0 (10357) Start javascript script.js.ecoflow-connector_v1142
            2023-09-28 12:30:31.876 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-09-28 12:30:32.535 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Verbunden mit dem Ecoflow MQTT-Broker
            2023-09-28 12:30:41.874 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
            2023-09-28 12:30:51.872 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
            2023-09-28 12:31:01.873 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
            2023-09-28 12:31:11.874 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
            2023-09-28 12:31:21.875 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
            2023-09-28 12:31:31.875 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
            2023-09-28 12:31:41.876 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
            2023-09-28 12:31:51.876 - info: javascript.0 (10357) script.js.ecoflow-connector_v1142: Fehler beim Abrufen des niedrigsten Werts: Error: No data
            P W 2 Replies Last reply Reply Quote 1
              photon-harvester @resilient last edited by
              könnt ihr mir helfen, diesen Wert aus dem InverterHeartbeat2 so zu editieren, dass eine Kommastelle dargestellt wird. Also nit 7199dW sondern 719.9W oder besser 719.90W?
                @resilient ja, history Adapter muss laufen …
                  @waly_de
                  sieht auf jeden Fall besser aus... aber nur wenn ich MinValueMin: 0 auf Echzeit stelle sonst kommen wieder die fehler:
                    @resilient
                    Script stoppen
                    Realpower object löschen
                    History an
                    Script starten
                    Dann sollte es laufen
                    R M 2 Replies Last reply Reply Quote 0
                      @waly_de
                      tatsächlich jetzt läufts auch mit nicht Echtzeit.... werde noch beobachten wie gut er es regelt wenn er nicht wie gerade voll einpeist...
                      Vielen Dank schon mal für deine Hilfe und das Script, werde dir definitiv was auf Paypal schicken!
                        @resilient prima 👌 freut mich das es läuft!
                          Ich habe jetzt das ganze Objekt 0_userdata.0.ecoflow gelöscht und neu mit dem Skript 1142 angefangen. Leider ohne großen erfolg.
                          2023-09-28 17:01:03.157 - info: javascript.0 (186) Start javascript script.js.ps1142
                          2023-09-28 17:01:03.210 - info: javascript.0 (186) script.js.ps1142: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2023-09-28 17:01:03.376 - info: javascript.0 (186) script.js.ps1142: Neues Writeable angelegt. Gerät:PowerStream Typ:PS Wert: SetDisplayBrightness
                          2023-09-28 17:01:03.378 - info: javascript.0 (186) script.js.ps1142: Neues Writeable angelegt. Gerät:PowerStream Typ:PS Wert: SetPrio
                          2023-09-28 17:01:03.382 - info: javascript.0 (186) script.js.ps1142: Neues Writeable angelegt. Gerät:PowerStream Typ:PS Wert: SetBatLimitLow
                          2023-09-28 17:01:03.384 - info: javascript.0 (186) script.js.ps1142: Neues Writeable angelegt. Gerät:PowerStream Typ:PS Wert: SetBatLimitHigh
                          2023-09-28 17:01:03.385 - info: javascript.0 (186) script.js.ps1142: Neues Writeable angelegt. Gerät:PowerStream Typ:PS Wert: SetAC
                          2023-09-28 17:01:03.537 - info: javascript.0 (186) script.js.ps1142: Verbunden mit dem Ecoflow MQTT-Broker
                          2023-09-28 17:01:13.219 - info: javascript.0 (186) script.js.ps1142: PowerStream [PowerStream] Batteriestand unter Limit:15% (0%). Limitiere Einspeiseleistung auf: 150W
                          2023-09-28 17:08:17.120 - info: javascript.0 (186) script.js.ps1142: Verbunden mit dem Ecoflow MQTT-Broker
                          2023-09-28 17:10:43.382 - info: javascript.0 (186) script.js.ps1142: PowerStream [PowerStream] Batteriestand ist jetzt über Limit:20% (98%). Maximale Einspeisung wieder bei: 600W
                          2023-09-28 17:20:50.530 - info: javascript.0 (186) script.js.ps1142: PeakSkip Delta: 212
                          setAC unter writeables ist auch nach 20 Minuten noch auf null
                          Ich werde später versuchen den Punkt zu finden weshalb setAC nicht gesetzt wird. Vielleicht hab ich ja Glück. 🙂
                            Waly_de @pasch last edited by Waly_de
                            @pasch Ich denke du hast mitgelesen?
                            Bitte prüfe noch mal ob Du den History-Adapter installiert hast und dieses auch läuft.
                            umele P 2 Replies Last reply Reply Quote 0
                            • umele
                              umele @Waly_de last edited by
                              Ich brauche bitte auch noch mal Hilfe.
                              • Das Script Version 1.1.4 läuft auf einem Raspi 4.
                              • Ein PowerStream mit Delta Pro und Zusatzakku.
                              • RealPower wird korrekt angelegt. History aktiv.
                              • 0_userdata.0.ecoflow.app_device_property_HW51ZOxxxxxxxxxxxx.data.InverterHeartbeat.batSoc ist auch nach mehreren Stunden noch auf "0" und entsprechend bekomme ich auch die Nachricht "Batteriestand unter Limit" => entsprechend ist SetAC auch immer = 0
                              • Die Kommunikation an sich klappt - wenn ich die Einspeisung in der App manuell auf z.B. 200 Watt stelle, ist sie eine Minute später wieder auf 0...
                              Was kann ich noch nachprüfen?
                                Waly_de @umele last edited by
                                @umele das sieht nach Kommunikationsproblemen zwischen PS und Delta aus. Der Wert batSoc wird selten, u.U. nur nach Änderung aktualisiert. Das kann also etwas dauern. Wenn er aber immer auf 0 steht, stimmt da was auf der EcoFlow Seite nicht.
                                Die PS muss mit dem Eingang 1 der Delta verbunden sein, der Zusatzakku mit Eingang 2.
                                umele 1 Reply Last reply Reply Quote 0
                                • umele
                                  @waly_de Danke für die schnelle Antwort. Habe gleich mal die Ports geprüft - sieht so aus, als wäre der Zusatzakku auf Port 1. Ich änder das gleich mal und melde mich wieder.
                                  • umele
                                    umele @umele last edited by
                                    @Waly_de - passt 👍
                                    Vielen lieben Dank!!
                                    Das bedeutet dann im Umkehrschluss wohl, dass nur Port 1 ein "echter" Kommunikationsport ist - richtig? Dann muss ich bei einem Firmware-Update PowerStream und Zusatzakku kurzfristig wieder tauschen?
                                    Super Arbeit!!
                                      pasch @Waly_de last edited by
                                      @waly_de Danke das du mich noch mal mit der Nase darauf gestoßen hast. 🙂
                                      Das war auch bei mir die Lösung. Ich hatte es nicht mit meinem Problem in Verbindung gebracht, weil ich keine Fehlermeldung in dieser Richtung bekommen hatte.
                                        kaiausBrieselang last edited by
                                        ich habe mal eine Verständnisfrage:
                                        wozu benötige ich die Parameter:
                                        lowBatLimitPozOn: 30,
                                        lowBatLimitPozOff:40,
                                        lowBatLimit: 150,
                                        Bei mir wird der Akku bis zum letzten % "leer" gezogen. Ich hätte erwartet, dass zumindest ab 30% "nur" noch auf 150W reduziert wird. Das klappt bei mir gar nicht.
                                        Aber ich verstehe auch den Hintergrund nicht so ganz. Warum sollte ich "kurz vor Leer" die Ausgabeleistung "nur" auf 150W (oder einen beliebigen Wert) reduzieren. Entweder ich möchte die volle benötigte Leistung bis zur definierten Restladung haben oder nicht, aber was bringt eine reduzierte Abgabe?
                                        Vielleicht verstehe ich das auch nicht richtig.
                                        Dann habe ich noch eine weitere Frage.
                                        Der Ladestand der Batterie wird ja hier angezeigt:
                                        0_userdata.0.ecoflow.app_device_property_R351xxxxD2Mxxx.data.params.bms_bmsStatus.f32ShowSoc
                                        0_userdata.0.ecoflow.app_device_property_R351xxxxD2Mxxx.data.params.bms_bmsStatus.soc
                                        0_userdata.0.ecoflow.app_device_property_R351xxxxD2Mxxx.data.params.bms_emsStatus.f32LcdShowSoc
                                        0_userdata.0.ecoflow.app_device_property_R351xxxxD2Mxxx.data.params.bms_emsStatus.lcdShowSoc
                                        Aber um an die Werte heran zu kommen muss ich ja den D2M abfragen. Das wiederum erzeugt ja viel Datenstrom.
                                        In den Einstellungen des PS in der APP wird ja auch der Batteriestand angezeigt.
                                        Finde ich vielleicht den Wert irgendwo versteckt in den "userdaten" wieder ohne de D2M abzufragen?
                                        vielen Lieben Dank für eure Hilfe.
                                        Und vor allen für das tolle Script.
                                        gruß Kai
                                          Ponti92 @kaiausBrieselang last edited by
                                          @kaiausbrieselang ja das geht auch über
                                          *.data.InverterHeartbeat.batSoc
                                            Läuft super bisher. 🙂
                                            Mir ist aufgefallen, dass "Other Loads" bei mir oft um 1-3 Watt schwankt. Gibt es die Möglichkeit zu sagen, nur bei Änderungen größer X den neuen Wert setzten? In den Einstellungen habe ich nichts gefunden.
                                            Patrick
                                            1644
                                            729421
