    4. [Adapter] cloudfreie Auslesung von Deye-Invertern
    • Rene55
      Rene55 @ralle last edited by
      @ralle Hast du den wirklich über die "Katze" direkt von Github installiert?
        ralle @Rene55 last edited by ralle
        @rene55 said in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
        ja! ich machs jetzt nochmal
        • Rene55
          @ralle Wenn das nicht hilft: Konfiguration sichern, komplett löschen, neu installieren, Instanz erstellen und konfiguration wieder einspielen.
            Hallo nochmal,
            1. wie kann ich die Konfig sichern?
            2. anbei das Installierungslog:
            $ iobroker url https://github.com/raschy/ioBroker.deyeidc --host raspberrypi --debug
            install raschy/ioBroker.deyeidc#13f435f5039df499207f02165ffe3f221eab215c
            NPM version: 8.19.4
            Installing raschy/ioBroker.deyeidc#13f435f5039df499207f02165ffe3f221eab215c... (System call)
            up to date in 12s132 packages are looking for funding run `npm fund` for details
            upload [12] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/deyeidc.png deyeidc.png image/png
            upload [11] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [10] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [9] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [8] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [7] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [6] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [4] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [3] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [2] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [1] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [0] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/jsonConfig.json jsonConfig.json application/json
            Process exited with code 0
            • Rene55
              @ralle So wie ich das sehe, ist das die richtige Version.
              Die Konfiguration kann/muss - solange der Adapter noch nicht gelöscht ist - in 'Instanzen' über den rechten Pfeil exportiert werden.Konfiguration_exportieren.png
                Hi, ein nochmaliges überschreiben brachte nichts, gerade den Adapter gelöscht neu installiert.
                LEIDER OHNE ERFOLG !!
                • Rene55
                  @ralle Hast du den Fehler jetzt in beiden Instanzen?
                    @rene55 nein, nur in der mit dem Relais!
                    • Rene55
                      @ralle Dann vermute ich nur noch, dass die beiden Firmwaren (ohne und mit Relais) etwas unterschiedlich sind. Sonst ist dieser Effekt nicht zu erklären. Ich vermute mal, mein Relais kommt in 40 - 45 Tagen. Dann kann ich mich um eine wirkliche Fehlersuche bemühen. Sorry bis dahin.
                        Ok ich warte, Danke. Übrigens hab ich ein zweites Relais bestellt in München beim Versender , das hat 1 Woche gedauert !
                        • Rene55
                          @ralle Oh, das geht auch? Ich hatte nur das Kontaktformular von Deye über meinen Fachhändler bekommen.
                            info@safetytaxfree.com , Mail und im Anhang die Rechnung des BKW und die Anzahl am Relai, mit der Bitte um Versendung.....
                            • Rene55
                              @ralle Danke für die Info. Versuch ich morgen auch, vielleicht gehts dann schneller. (Man bekommt ja eh keine Nachricht, ob da schon was unterwegs ist)
                                MPF @Rene55 last edited by
                                @rene55 ich habe 2 Relais hier liegen, verzichte aber vorerst auf einen Einbau. Es gibt Probleme beim Verbinden mit dem WR und wieder zusätzlichen Stromverbrauch.
                                • Rene55
                                  Rene55 @MPF last edited by
                                  @mpf Danke für die Warnung, nutzt mir aber nix. Wenn ich den Fehler fixen will, brauche ich Relais und aktuelle Firmware. Mein Risiko - aber vielleicht wird es ja gar nicht sooooo schlimm.
                                    skybundi last edited by
                                    Hallo
                                    Ich bekomme seit geraumer Zeit regelmäßig die Fehlermeldung "ControlCode faulty!: Data may be corrupt, therefore discarded". Wie bekomme ich das weg?
                                    Gruß Skybundi
                                    • Rene55
                                      Rene55 @skybundi last edited by
                                      @skybundi Hast du auch die neue Firmware drauf? Eine Möglichkeit - die nicht bei allen funktioniert hat - einfach nochmal direkt von Github drüberinstallieren.
                                        skybundi @Rene55 last edited by skybundi
                                        @rene55 ich habe die v0.0.11 drauf. Ich hatte den Adapter auch schon neu installiert.
                                        • Rene55
                                          @skybundi Das mag ja richtig sein. Es gibt ja auch noch keine neuere Version. Nur bei einer neuen Installation direkt von Github wird dieser Fehler nicht mehr angezeigt. Es bleibt bei der 0.0.11!
                                            MPF @Rene55 last edited by MPF
                                            @rene55 sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                                            Das stimmt, dafür benötigst Du natürlich die neue FW im WR.
                                            Nur noch mal der Vollständigkeit halber, den Fehler "ControlCode faulty!: Data may be corrupt, therefore discarded" habe ich aber auch mit der FW 1.57 im WR hin und wieder.
                                            Es soll wohl inzwischen eine FW-Version, glaube 2.36D geben, die auch wieder ohne Relais den WR einspeisen lässt.
                                            1158
                                            364851
