    4. iob node fix - Skript
      reutli @Thomas Braun last edited by
      @thomas-braun sagte in iob node fix - Skript:
      Ist das z. B. ein Multihost-Slave?
      Ja exakt, ist ein Slave
        Thomas Braun Most Active @firebowl last edited by
        @firebowl
        Dann lass mal sehen was da ausgespuckt wird. Vollständig.
          firebowl @Thomas Braun last edited by firebowl
          @thomas-braun Sorry, musste meinen kleinen schnell in die Krippe bringen.
          Hier der Output:
          ioBroker nodejs fixer 2023-09-24
          Recommended nodejs-version is: 18.18.0
          Checking your installation now. Please be patient!
          Your current setup is:
          /usr/bin/nodejs         v18.17.1
          /usr/bin/node           v18.17.1
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          /usr/bin/corepack       0.18.0
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.18.0-1nodesource1
            Version table:
               18.18.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           *** 18.17.1-deb-1nodesource1 100
                  100 /var/lib/dpkg/status
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.9~dfsg-1ubuntu3 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
          Press <y> to continue or any other key to quit
          Trying to fix your installation now. Please be patient.
          [sudo] password for mike:
          kvm
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
          Get:6 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
          Fetched 17.4 kB in 0s (36.4 kB/s)
          Installing the recommended nodejs version now!
          *** You need to manually restart your container/virtual machine now! ***
          We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
          Öhm Http error 500? Seh ich das richtig?
            @firebowl sagte in iob node fix - Skript:
            Wo siehst du das?
            sudo apt full-upgrade
            sagt?
              sagt?
              Mit apt hat es sich jetzt aktualisieren lassen, vorher wurden keine Updates gefunden.
                @firebowl
                Und wenn die vollständige Ausgabe gepostet wäre könnte man vielleicht auch mehr als 'Tja, ist dann halt so, warum auch immer' dazu sagen.
                  @thomas-braun vom apt? Sorry, hab nicht gedacht das Du davon den Output wolltest.
                    @firebowl
                    sagt?
                    Musst du natürlich weitersagen, ich kann dir nicht über die Schulter schauen.
                      Homoran Global Moderator Administrators @firebowl last edited by
                      immer alles zeigen!
                        Ich habe eben eine nagelneue Installation aufgesetzt.
                        Direkt danach den node-fixer drüber gejagt damit die neuen Repos angelegt werden
                        der will ums Verrecken nicht von 18.17.1.auf 18.18 upgraden
                        das bleibt so
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                                500 http://debian.netcologne.de/debian bookworm/main amd64 Packages
                        der node-fixer selbst
                        pi@VM03:~$ ./iob_node_update
                        ioBroker node-update v2023-09-28 is starting. Please be patient!
                        ioBroker nodejs fixer 2023-09-28
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        anschließend
                        kvm
                        Hit:1 http://debian.netcologne.de/debian bookworm InRelease
                        Hit:2 http://debian.netcologne.de/debian bookworm-updates InRelease
                        Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                        Package: nodejs
                        Pin-Priority: 1001
                        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                        Hit:2 http://debian.netcologne.de/debian bookworm InRelease
                        Hit:3 http://debian.netcologne.de/debian bookworm-updates InRelease
                        Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
                        Fetched 17.4 kB in 0s (45.0 kB/s)
                        und dann ist es wieder 18.17.1
                        crunchip 1 Reply Last reply Reply Quote 1
                          crunchip Forum Testing Most Active @Homoran last edited by
                          @homoran du musst abschließend ein normales
                          Update upgrade ausführen
                          Homoran Thomas Braun 2 Replies Last reply Reply Quote 1
                            Homoran Global Moderator Administrators @crunchip last edited by
                            @crunchip sagte in iob node fix - Skript:
                            Das wird doch Thomas sicher eingebaut haben!
                            Oder etwa nicht @thomas-braun????
                              Thomas Braun Most Active @crunchip last edited by
                              @crunchip @Homoran
                              Ha den Code an der Stelle ergänzt. Sollte jetzt auch mit Containern funktionieren.
                              Homoran 1 Reply Last reply Reply Quote 3
                                @homoran sagte in iob node fix - Skript:
                                Nein, hatte ich bewusst eigentlich für Container/VMs und anners virtuelles Zeuch nicht drin.
                                  @thomas-braun TUT ES!!!
                                  auch wenn es kein Container ist! 😡 ! eins ELF
                                    auch wenn es kein Container ist! ! eins ELF
                                    kvm aber.
                                      kvm aber.
                                      Ja
                                        Und das v steht für virtuell. 😉
                                          und das m für eine ganze Maschine und keine Blechbüchse
                                            bastler @Thomas Braun last edited by
                                            Moin, habe es endlich dank deiner tollen Anleitung geschafft das Update auf Bullseye durchzuführen.
                                            Es lief alles prima durch, allerdings will node.js sich nicht auf 18.18.0 aktualisieren, trotz mehrerer update Versuche.
                                            Kann ich das auch mit deinem node fix - Skript klären?
                                            Danke und Gruß
                                            Ingo
                                            		     v.2023-06-20
                                               Static hostname: ioBroker
                                                     Icon name: computer-vm
                                                       Chassis: vm
                                                    Machine ID: 00d6058392fa44d3b60e2dcfbf39a290
                                                       Boot ID: ab4aea8acd5c4141a66953e96c6126d8
                                                Virtualization: kvm
                                              Operating System: Debian GNU/Linux 11 (bullseye)
                                                        Kernel: Linux 5.10.0-25-amd64
                                                  Architecture: x86-64
                                            Installation: 		kvm
                                            Kernel: 		x86_64
                                            Userland: 		amd64
                                            Timezone: 		Europe/Berlin (CEST, +0200)
                                            User-ID: 		1000
                                            X-Server: 		false
                                            Boot Target: 		graphical.target
                                            Pending OS-Updates: 	0
                                            Pending iob updates: 	0
                                            Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.1
                                            			/usr/bin/npm 		9.6.7
                                            			/usr/bin/npx 		9.6.7
                                            Recommended versions are nodejs 18.x.y and npm 9.x.y
                                            MEMORY:
                                            Mem:             12G        2.6G        9.1G        0.0K        696M        9.5G
                                            Swap:           974M          0B        974M
                                            Total:           13G        2.6G         10G
                                            Active iob-Instances: 	36
                                            Active repo(s): Stable (default)
                                            ioBroker Core: 		js-controller 		5.0.12
                                            			admin 			6.10.1
                                            ioBroker Status: 	iobroker is running on this host.
                                            Objects type: jsonl
                                            States  type: jsonl
                                            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            Objects: 		18629
                                            States: 		15883
                                            Size of iob-Database:
                                            22M	/opt/iobroker/iobroker-data/objects.jsonl
                                            9.4M	/opt/iobroker/iobroker-data/objects.json.migrated
                                            9.4M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                                            51M	/opt/iobroker/iobroker-data/states.jsonl
                                            4.6M	/opt/iobroker/iobroker-data/states.json.migrated
                                            4.6M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                                            198
                                            38012
