    4. Nach Update läuft nichts mehr!
      SpeedyBlade @Thomas Braun last edited by SpeedyBlade
      perfekt....jetzt geht gar nichts mehr 😣
      Ps.: nein, sitze nicht in UK
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       08:27:55 up 6 min,  1 user,  load average: 0.21, 0.25, 0.11
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=47.2'C
      volt=0.8700V
      *** Time and Time Zones ***
                     Local time: Fri 2023-09-29 08:27:55 BST
                 Universal time: Fri 2023-09-29 07:27:55 UTC
                       RTC time: n/a
                      Time zone: Europe/London (BST, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.8G         55M        7.4G         16M        373M        7.5G
      Swap:           99M          0B         99M
      Total:         7.9G         55M        7.5G
               7846 M total memory
                 55 M used memory
                187 M active memory
                180 M inactive memory
               7416 M free memory
                 35 M buffer memory
                338 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      916G  3.1G  866G   1% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     3.9G   17M  3.9G   1% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     785M     0  785M   0% /run/user/1000
      [Fri Sep 29 08:21:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D6:FD:D6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=206cf84d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Fri Sep 29 08:21:43 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Sep 29 08:21:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Sep 29 08:21:47 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
      Show mounted filesystems (real ones only):
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda2 ext4   rw,noatime,stripe=8191
      |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      368M    /var/
      169M    /var/cache
      163M    /var/cache/apt
      104M    /var/cache/apt/archives
      93M     /var/lib
      Archived and active journals take up 16.0M in the file system.
      /opt/iobroker/backups:
      17M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      122M    /opt/iobroker/iobroker-data/
      59M     /opt/iobroker/iobroker-data/backup-objects
      25M     /opt/iobroker/iobroker-data/files
      23M     /opt/iobroker/iobroker-data/node-red/node_modules
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.2M    /opt/iobroker/iobroker-data/files/knx.admin/static/js/main.fcc1088d.js.map
      5.1M    /opt/iobroker/iobroker-data/objects.json.migrated
      5.1M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      4.5M    /opt/iobroker/iobroker-data/objects.jsonl
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 100
              100 /var/lib/dpkg/status
           18.17.1-deb-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1080
        throw err;
      Error: Cannot find module 'tar'
      Require stack:
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Module.require (node:internal/modules/cjs/loader:1143:19)
          at require (node:internal/modules/cjs/helpers:119:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
          at Module._compile (node:internal/modules/cjs/loader:1256:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          at Module.load (node:internal/modules/cjs/loader:1119:32)
          at Module._load (node:internal/modules/cjs/loader:960:12)
          at Module.require (node:internal/modules/cjs/loader:1143:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      Node.js v18.18.0
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.18.0
      Core adapters versions
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.18.0
      js-controller:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.18.0
      admin:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.18.0
      javascript:
      Adapters from github:   0
      Adapter State
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.18.0
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.18.0
      ioBroker-Repositories
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.18.0
      Installed ioBroker-Instances
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.18.0
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16156      624/sshd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16158      624/sshd
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17451      615/dhcpcd
      udp        0      0 0.0.0.0:45185           0.0.0.0:*                           108        15399      387/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15397      387/avahi-daemon: r
      udp6       0      0 :::43947                :::*                                108        15400      387/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15573      615/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        15398      387/avahi-daemon: r
      2023-09-29 08:20:45.300  - error: host.RaspberryPi4 Caught by controller[6]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.300  - error: host.RaspberryPi4 Caught by controller[7]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[8]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[9]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[10]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[11]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.305  - error: host.RaspberryPi4 Caught by controller[12]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[13]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[14]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[15]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[16]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[17]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[18]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[19]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[20]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[21]: sh: 0: getcwd() failed: No such file or directory
      2023-09-29 08:20:45.308  - info: host.RaspberryPi4 instance system.adapter.rpi2.0 terminated with code 0 (NO_ERROR)
      2023-09-29 08:20:45.309  - info: host.RaspberryPi4 instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      2023-09-29 08:20:45.408  - info: host.RaspberryPi4 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2023-09-29 08:20:45.409  - info: host.RaspberryPi4 instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
      2023-09-29 08:20:45.470  - info: host.RaspberryPi4 instance system.adapter.knx.0 terminated with code 0 (NO_ERROR)
      2023-09-29 08:20:45.687  - info: host.RaspberryPi4 instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
      2023-09-29 08:20:45.687  - info: host.RaspberryPi4 instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
      2023-09-29 08:20:45.688  - info: host.RaspberryPi4 All instances are stopped.
      2023-09-29 08:20:45.862  - info: host.RaspberryPi4 terminated
        Thomas Braun Most Active @SpeedyBlade last edited by
        @speedyblade sagte in Nach Update läuft nichts mehr!:
        Dann stell die Uhrzeit. Geht z. B. in
        sudo raspi-config
          @speedyblade
          Und warum hast du es nicht mit meinem Skript gemacht?
          Das hätte dir nämlich das richtige Repository eingespielt.
            was für einem Skript?
            Wenn ich die Dinge nach Anleitung aufspiele und dann doch nicht funktionieren, muss ich einfach die Anleitungen hinterfragen.
            Bei 5 Geräten funktioniert alles einwandfrei und dann auf einmal nicht mehr, das versteht kein Mensch
              Thomas Braun Most Active @SpeedyBlade last edited by Thomas Braun
              Welche?
              Wenn da offenbar falsche Versionen über einen falschen Weg ins das System geprügelt werden muss man da gar nichts verstehen. Da ist einfach Murks gemacht worden.
              Das von @Homoran verlinkte und auch in meiner Signatur zu findende 'node-fix-Skript'.
                ich bin eigentlich genau nach der Anleitung vor gegangen:
                https://github.com/nodesource/distributions#nodejs
                  @speedyblade
                  Für die v20 passte das ja auch. Die v16 hast du da mal schräg reingedonnert.
                    ioBroker nodejs fixer 2023-09-29
                    No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                    Your current setup is:
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    /usr/bin/corepack       0.19.0
                    We found these nodejs versions available for installation:
                    nodejs:
                      Version table:
                    Nothing to do - Your installation is using the correct paths.
                    You are running nodejs v18.18.0. Do you want to install recommended version from nodejs v.18 tree?
                    Press <y> to continue or any other key to quit
                    Trying to fix your installation now. Please be patient.
                    rm: cannot remove '/etc/apt/keyrings/nodesource.gpg'$'\n''/usr/share/keyrings/nodesource.gpg': No such file or directory
                    Waiting for ioBroker to shut down - Give me a minute...
                    *** These repos are active on your system:
                    Reading package lists... Done
                    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                    Package: nodejs
                    Pin: origin deb.nodesource.com
                    Pin-Priority: 1001
                    *** These repos are active after the adjustments:
                    Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                    Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
                    Fetched 17.4 kB in 1s (15.7 kB/s)
                    Installing the recommended nodejs version now!
                    Exact recommended version unknown, installing a fallback!
                    Building dependency tree
                    The following packages will be DOWNGRADED:
                      nodejs
                    0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
                    Need to get 25.4 MB of archives.
                    After this operation, 2314 kB disk space will be freed.
                    Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.0.0-1nodesource1 [25.4 MB]
                    Fetched 25.4 MB in 4s (6639 kB/s)
                    dpkg: warning: downgrading nodejs from 18.18.0-1nodesource1 to 18.0.0-1nodesource1
                    (Reading database ... 53807 files and directories currently installed.)
                    Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
                    Detected old npm client, removing...
                    Unpacking nodejs (18.0.0-1nodesource1) over (18.18.0-1nodesource1) ...
                    Setting up nodejs (18.0.0-1nodesource1) ...
                    Processing triggers for man-db (2.8.5-2) ...
                    Updating fallback to latest nodejs v18 release
                    (Reading database ... 53908 files and directories currently installed.)
                    Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
                    Unpacking nodejs (18.18.0-1nodesource1) over (18.0.0-1nodesource1) ...
                    Setting up nodejs (18.18.0-1nodesource1) ...
                    v18.18.0 has been installed! You are using the latest version now!
                    Installing the recommended nodejs version and other updates now!
                    We tried our best to fix your nodejs. Please run iob diag again to verify.
                    *** RESTARTING ioBroker NOW! ***
                     Please refresh or restart your browser in a few moments.
                    pi@RaspberryPi4:~ $ sudo iobroker start
                    pi@RaspberryPi4:~ $ iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                    -bash: iob_diag:: Kommando nicht gefunden.
                      @speedyblade
                      Das Skript funktioniert und zaubert dir eine senkrechte Installation von nodejs 18 und Konsorten hin.
                      iob diag
                      sagt nun?
                        @thomas-braun sagte in Nach Update läuft nichts mehr!:
                        eigentlich soll die runter und v20 drauf
                        Codierknecht Thomas Braun 3 Replies Last reply Reply Quote 0
                        • Codierknecht
                          Codierknecht Developer Most Active @SpeedyBlade last edited by
                          Wozu?
                          Die ist zu neu und wird für ioBroker nicht empfohlen.
                            @speedyblade
                            Und NIE NIE NIE NIEMALS iobroker mittels sudo anpacken. NIE!
                            iob stop
                            iob fix
                              Die 16 ist runter und die vorgesehene v18 ist drauf. Das passt.
                                SpeedyBlade @Codierknecht last edited by SpeedyBlade
                                @codierknecht
                                wo steht dies?
                                Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                                        Architecture: arm
                                  Docker          : false
                                  Kernel          : armv7l
                                  Userland        : armhf
                                   09:44:56 up 23 min,  1 user,  load average: 1.22, 0.89, 0.49
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=48.7'C
                                  volt=0.8700V
                                                 Local time: Fri 2023-09-29 09:44:56 CEST
                                             Universal time: Fri 2023-09-29 07:44:56 UTC
                                                   RTC time: n/a
                                                  Time zone: Europe/Vienna (CEST, +0200)
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:           7.8G         58M        7.1G         16M        673M        7.5G
                                  Swap:           99M          0B         99M
                                  Total:         7.9G         58M        7.2G
                                           7846 M total memory
                                             58 M used memory
                                            280 M active memory
                                            345 M inactive memory
                                           7113 M free memory
                                            115 M buffer memory
                                            557 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4      916G  3.2G  866G   1% /
                                  [Fri Sep 29 09:21:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D6:FD:D6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=206cf84d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                  [Fri Sep 29 09:21:43 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                  [Fri Sep 29 09:21:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                  [Fri Sep 29 09:21:47 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                                  /var:
                                  393M    /var/
                                  193M    /var/cache
                                  188M    /var/cache/apt
                                  128M    /var/cache/apt/archives
                                  93M     /var/lib
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Candidate: 18.18.0-1nodesource1
                                    Version table:
                                   *** 18.18.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                       18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                  ioBroker Status
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                  js-controller:
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                  admin:
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                  javascript:
                                  Adapter State
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                  Objects and States
                                  Objects:        0
                                  States:         0
                                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Pending Updates: 0
                                    @speedyblade
                                    Das sind die Releases von nodejs.
                                    Das heißt aber noch lange nicht, das die neueste Version auch für den ioBroker empfohlen wird.
                                    Davon abgesehen stehst du auf 'Buster'.
                                    • Codierknecht
                                      wo steht dies?
                                      Recommended versions are nodejs 18.x.y and npm 9.x.y
                                        => das heißt?
                                          @codierknecht
                                          wo oder wie holst du dir diese Info her?
                                            Er kennt den ioBroker.
                                            Die Empfehlung steht im Admin und auch im diag-Skript drin.
                                            help wanted iobroker update js controller update json npm
                                            18
                                            416
                                            56239
