    4. Adapter lassen sich nach io update nicht mehr öffnen?
      Thomas Braun Most Active @Tolkin last edited by
      @tolkin
      18.18.0 und npm kommt da in passender Version gleich mit.
      Siehe in meiner Signatur das 'node-fix-Skript'.
      • Tolkin
        Tolkin @crunchip last edited by Tolkin
        @crunchip sagte in Adapter lassen sich nach io update nicht mehr öffnen?:
        iob diag
        Skript v.2023-06-20
        *** BASE SYSTEM ***
           Static hostname: IOBroker
                 Icon name: computer-container
                   Chassis: container
                Machine ID: 00ce9495f0e241b5b8dd308da14042b1
                   Boot ID: 01ef84cc2372422eb709f4c5b1ac44ac
            Virtualization: lxc
          Operating System: Ubuntu 20.04.6 LTS
                    Kernel: Linux 5.15.107-2-pve
              Architecture: x86-64
        model name      : AMD Ryzen 5 PRO 4650G with Radeon Graphics
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         11:43:33 up 9 days, 16:59,  1 user,  load average: 0.46, 0.52, 0.70
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Fri 2023-09-29 11:43:33 CEST
                   Universal time: Fri 2023-09-29 09:43:33 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           8.2G         58M        8.1G        0.0K         79M        8.1G
        Swap:            0B          0B          0B
        Total:         8.2G         58M        8.1G
                 8192 M total memory
                   58 M used memory
                   59 M active memory
                   53 M inactive memory
                 8053 M free memory
                    0 M buffer memory
                   79 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        Filesystem                   Type      Size  Used Avail Use% Mounted on
        rpool/data/subvol-301-disk-1 zfs        32G  3.5G   29G  11% /
        none                         tmpfs     492K  4.0K  488K   1% /dev
        udev                         devtmpfs   16G     0   16G   0% /dev/ttyACM0
        tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
        tmpfs                        tmpfs     3.1G  116K  3.1G   1% /run
        tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                        tmpfs     3.1G     0  3.1G   0% /run/user/0
        Show mounted filesystems (real ones only):
        TARGET                    SOURCE                         FSTYPE     OPTIONS
        /                         rpool/data/subvol-301-disk-1   zfs        rw,relatime,xattr,posixacl
        |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/diskstats         lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/loadavg           lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/meminfo           lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/slabinfo          lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/stat              lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/swaps             lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/uptime            lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        940M    /var/
        538M    /var/log
        535M    /var/log/journal/00ce9495f0e241b5b8dd308da14042b1
        278M    /var/cache
        Archived and active journals take up 534.2M in the file system.
        /opt/iobroker/backups:
        10M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        295M    /opt/iobroker/iobroker-data/
        143M    /opt/iobroker/iobroker-data/files
        130M    /opt/iobroker/iobroker-data/backup-objects
        25M     /opt/iobroker/iobroker-data/files/material
        23M     /opt/iobroker/iobroker-data/files/material/static
        18M     /opt/iobroker/iobroker-data/objects.jsonl
        18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        6.7M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        6.1M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        5.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
                100 /var/lib/dpkg/status
             10.19.0~dfsg-3ubuntu1.1 500
                500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
             10.19.0~dfsg-3ubuntu1 500
                500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.8.0
        javascript:     7.1.4
        Adapters from github:   3
        Adapter State
          system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : IOBroker                                 -  enabled
          system.adapter.amtronwallbox.0          : amtronwallbox         : IOBroker                                 - disabled
          system.adapter.apcups.0                 : apcups                : IOBroker                                 -  enabled
          system.adapter.backitup.0               : backitup              : IOBroker                                 -  enabled
          system.adapter.cloud.0                  : cloud                 : IOBroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : IOBroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : IOBroker                                 -  enabled
          system.adapter.energiefluss.0           : energiefluss          : IOBroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : IOBroker                                 -  enabled
          system.adapter.history.0                : history               : IOBroker                                 -  enabled
          system.adapter.hm-rega.0                : hm-rega               : IOBroker                                 -  enabled
          system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
          system.adapter.hm-rpc.2                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
          system.adapter.hmip.0                   : hmip                  : IOBroker                                 - disabled
          system.adapter.influxdb.0               : influxdb              : IOBroker                                 - disabled, port: 8086
          system.adapter.info.0                   : info                  : IOBroker                                 -  enabled
          system.adapter.iot.0                    : iot                   : IOBroker                                 -  enabled
          system.adapter.javascript.0             : javascript            : IOBroker                                 -  enabled
          system.adapter.material.0               : material              : IOBroker                                 -  enabled
          system.adapter.mielecloudservice.0      : mielecloudservice     : IOBroker                                 - disabled
          system.adapter.modbus.0                 : modbus                : IOBroker                                 -  enabled
          system.adapter.node-red.0               : node-red              : IOBroker                                 - disabled, port: 1880, bind: 10.14.4.34 (SSL)
          system.adapter.nut.0                    : nut                   : IOBroker                                 - disabled
          system.adapter.onvif.0                  : onvif                 : IOBroker                                 - disabled
          system.adapter.ping.0                   : ping                  : IOBroker                                 -  enabled
          system.adapter.pushover.0               : pushover              : IOBroker                                 -  enabled
          system.adapter.pushover.1               : pushover              : IOBroker                                 -  enabled
          system.adapter.pushover.2               : pushover              : IOBroker                                 -  enabled
          system.adapter.pushover.3               : pushover              : IOBroker                                 -  enabled
          system.adapter.pushover.4               : pushover              : IOBroker                                 -  enabled
          system.adapter.pushover.5               : pushover              : IOBroker                                 -  enabled
          system.adapter.pushover.6               : pushover              : IOBroker                                 -  enabled
          system.adapter.pushover.7               : pushover              : IOBroker                                 -  enabled
          system.adapter.pushover.8               : pushover              : IOBroker                                 -  enabled
          system.adapter.shelly.0                 : shelly                : IOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.shuttercontrol.0         : shuttercontrol        : IOBroker                                 -  enabled
          system.adapter.sma-em.0                 : sma-em                : IOBroker                                 -  enabled
          system.adapter.smartmeter.0             : smartmeter            : IOBroker                                 - disabled
          system.adapter.sonoff.0                 : sonoff                : IOBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.sourceanalytix.0         : sourceanalytix        : IOBroker                                 - disabled
          system.adapter.synology.0               : synology              : IOBroker                                 -  enabled, port: 5001
          system.adapter.telegram.0               : telegram              : IOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : IOBroker                                 -  enabled
          system.adapter.tibber.0                 : tibber                : IOBroker                                 -  enabled
          system.adapter.unifi.0                  : unifi                 : IOBroker                                 - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : IOBroker                                 -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : IOBroker                                 - disabled
          system.adapter.web.0                    : web                   : IOBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.worx.0                   : worx                  : IOBroker                                 -  enabled
          system.adapter.yahka.0                  : yahka                 : IOBroker                                 -  enabled
          system.adapter.zigbee.0                 : zigbee                : IOBroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Github        : https://github.com/ioBroker/ioBroker.admin
        Active repo(s): Stable (default), Github
        Installed ioBroker-Instances
        [/s]
        crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
          crunchip Forum Testing Most Active @Tolkin last edited by crunchip
          @tolkin sagte in Adapter lassen sich nach io update nicht mehr öffnen?:
          was ist das?
            Kick das Github-Ding raus.
            Und installier nodejs 18.18.0 sauber.
            Die Ausgabe von iob diag ist auch nicht vollständig.
            Tolkin 1 Reply Last reply Reply Quote 0
            • Tolkin
              Tolkin @Thomas Braun last edited by
              Habe dein Skript laufen lassen und bin jetzt auf 18.18.0. Danke dafür..
              Die Adapter zeigen immer noch die gleiche Fehlermeldung. Wie kicke ich das Github-Ding raus? Keine Ahnung was das ist.
                Das ist schlecht. Die Kiste wird doch von dir verwaltet? Da solltest du schon wissen, was das ist und woher es kommt...
                iob repo del Github
                müsste das lauten.
                  @tolkin
                  Und
                  iob diag
                  sieht vollständig nun wie aus? Und hampel da nicht als root herum.
                  • Tolkin
                    @thomas-braun sagte in Adapter lassen sich nach io update nicht mehr öffnen?:
                    iob diag
                    Sorry, hast ja Recht 😉 Jetzt läuft wieder alles..
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                               Chassis: container
                               Boot ID: 49d8e102a1964114a590c493d98ff2ed
                        Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     12:17:15 up 5 min,  1 user,  load average: 2.16, 2.53, 2.01
                    CPU threads: 4
                                   Local time: Fri 2023-09-29 12:17:15 CEST
                               Universal time: Fri 2023-09-29 10:17:15 UTC
                                     RTC time: n/a
                              RTC in local TZ: no
                    user
                    /home/user
                    user adm sudo iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:           8.2G        3.3G        4.8G        0.0K         88M        4.9G
                    Swap:            0B          0B          0B
                    Total:         8.2G        3.3G        4.8G
                             8192 M total memory
                             3269 M used memory
                               60 M active memory
                             3138 M inactive memory
                             4833 M free memory
                                0 M buffer memory
                               88 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    rpool/data/subvol-301-disk-1 zfs        32G  3.6G   29G  12% /
                    tmpfs                        tmpfs     3.1G  124K  3.1G   1% /run
                    tmpfs                        tmpfs     3.1G     0  3.1G   0% /run/user/1001
                    /                         rpool/data/subvol-301-disk-1   zfs        rw,relatime,                                                     xattr,posixacl
                    |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/diskstats         lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/loadavg           lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/meminfo           lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/slabinfo          lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/stat              lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/swaps             lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/uptime            lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
                    /var:
                    969M    /var/
                    539M    /var/log
                    307M    /var/cache
                    Archived and active journals take up 415.8M in the file system.
                    302M    /opt/iobroker/iobroker-data/
                    23M     /opt/iobroker/iobroker-data/objects.jsonl
                    18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma                                                     p
                    6.9M    /opt/iobroker/iobroker-data/states.jsonl
                    6.7M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.m                                                     ap
                    6.1M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.m                                                     ap
                    /usr/bin/nodejs         v18.18.0
                    /usr/bin/node           v18.18.0
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Installed: 18.18.0-1nodesource1
                      Candidate: 18.18.0-1nodesource1
                      Version table:
                     *** 18.18.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                            500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packag                                                     es
                            500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packa                                                     ges
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : IOBroker        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                                                     n
                    + system.adapter.alexa2.0                 : alexa2                : IOBroker        -  enabled
                    + system.adapter.apcups.0                 : apcups                : IOBroker        -  enabled
                    + system.adapter.backitup.0               : backitup              : IOBroker        -  enabled
                    + system.adapter.cloud.0                  : cloud                 : IOBroker        -  enabled
                    + system.adapter.discovery.0              : discovery             : IOBroker        -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : IOBroker        -  enabled
                    + system.adapter.history.0                : history               : IOBroker        -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : IOBroker        -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker        -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : IOBroker        -  enabled, port: 0
                    + system.adapter.hm-rpc.2                 : hm-rpc                : IOBroker        -  enabled, port: 0
                    + system.adapter.info.0                   : info                  : IOBroker        -  enabled
                    + system.adapter.iot.0                    : iot                   : IOBroker        -  enabled
                    + system.adapter.javascript.0             : javascript            : IOBroker        -  enabled
                    + system.adapter.modbus.0                 : modbus                : IOBroker        -  enabled
                    + system.adapter.ping.0                   : ping                  : IOBroker        -  enabled
                    + system.adapter.pushover.0               : pushover              : IOBroker        -  enabled
                    + system.adapter.pushover.1               : pushover              : IOBroker        -  enabled
                    + system.adapter.pushover.2               : pushover              : IOBroker        -  enabled
                    + system.adapter.pushover.3               : pushover              : IOBroker        -  enabled
                    + system.adapter.pushover.4               : pushover              : IOBroker        -  enabled
                    + system.adapter.pushover.5               : pushover              : IOBroker        -  enabled
                    + system.adapter.pushover.6               : pushover              : IOBroker        -  enabled
                    + system.adapter.pushover.7               : pushover              : IOBroker        -  enabled
                    + system.adapter.pushover.8               : pushover              : IOBroker        -  enabled
                    + system.adapter.shelly.0                 : shelly                : IOBroker        -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shuttercontrol.0         : shuttercontrol        : IOBroker        -  enabled
                    + system.adapter.sma-em.0                 : sma-em                : IOBroker        -  enabled
                    + system.adapter.sonoff.0                 : sonoff                : IOBroker        -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.synology.0               : synology              : IOBroker        -  enabled, port: 5001
                    + system.adapter.telegram.0               : telegram              : IOBroker        -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.text2command.0           : text2command          : IOBroker        -  enabled
                    + system.adapter.tibber.0                 : tibber                : IOBroker        -  enabled
                    + system.adapter.web.0                    : web                   : IOBroker        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                                                     n
                    + system.adapter.worx.0                   : worx                  : IOBroker        -  enabled
                    + system.adapter.yahka.0                  : yahka                 : IOBroker        -  enabled
                    + system.adapter.zigbee.0                 : zigbee                : IOBroker        -  enabled, port: /dev/ttyACM0
                    + instance is alive
                    Used repositories: Stable (default), Github
                    Error: unknown repository is active - "Github". Known: Stable (default), Beta (l                                                     atest)
                    Adapter    "admin"        : 6.10.1   , installed 6.10.1
                    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                    Adapter    "apcups"       : 1.0.15   , installed 1.0.15
                    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                    Adapter    "history"      : 2.2.6    , installed 2.2.6
                    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                    Adapter    "info"         : 1.9.26   , installed 1.9.26
                    Adapter    "iot"          : 1.14.5   , installed 1.14.5
                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                    Controller "js-controller": 5.0.12   , installed 5.0.12
                    Adapter    "material"     : 1.3.1    , installed 1.3.1
                    Adapter    "miele"        : 0.1.5    , installed 0.1.5
                    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                    Adapter    "onvif"        : 1.0.5    , installed 1.0.5
                    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                    Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
                    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                    Adapter    "synology"     : 3.0.0    , installed 3.0.0
                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                    Adapter    "text2command" : 3.0.2    , installed 3.0.2
                    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                    Adapter    "vis"          : 1.4.16   , installed 1.4.16
                    Adapter    "web"          : 6.1.2    , installed 6.1.2
                    Adapter    "worx"         : 2.3.2    , installed 2.3.2
                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                    Objects and States
                    Objects:        133657
                    States:         102163
                    Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
                    Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                    Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    Proto Recv-Q Send-Q Local Address           Foreign Address         State                                                            User       Inode      PID/Program name
                    tcp        0      0 10.14.4.34:8701         0.0.0.0:*               LISTEN                                                           1000       41856576   652/io.hm-rpc.2
                    tcp        0      0 127.0.0.1:46487         0.0.0.0:*               LISTEN                                                           1000       41860740   1022/io.yahka.0
                    tcp        0      0 10.14.4.34:42001        0.0.0.0:*               LISTEN                                                           1000       41857598   618/io.hm-rpc.0
                    tcp        0      0 10.14.4.34:42010        0.0.0.0:*               LISTEN                                                           1000       41856553   633/io.hm-rpc.1
                    tcp        0      0 0.0.0.0:40299           0.0.0.0:*               LISTEN                                                           1000       41866666   1022/io.yahka.0
                    tcp        0      0 127.0.0.1:41881         0.0.0.0:*               LISTEN                                                           1000       41860725   1022/io.yahka.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN                                                           1000       41857101   155/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN                                                           1000       41857096   155/iobroker.js-con
                    tcp        0      0 0.0.0.0:32825           0.0.0.0:*               LISTEN                                                           1000       41866662   1022/io.yahka.0
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN                                                           0          41847171   1/init
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN                                                           1000       41857755   693/io.shelly.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN                                                           1000       41857819   713/io.sonoff.0
                    tcp        0      0 127.0.0.1:44823         0.0.0.0:*               LISTEN                                                           1000       41867622   1022/io.yahka.0
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN                                                           106        41850710   138/systemd-resolve
                    tcp        0      0 0.0.0.0:41521           0.0.0.0:*               LISTEN                                                           1000       41866658   1022/io.yahka.0
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN                                                           0          41846624   331/master
                    tcp        0      0 127.0.0.1:34733         0.0.0.0:*               LISTEN                                                           1000       41860720   1022/io.yahka.0
                    tcp        0      0 127.0.0.1:33823         0.0.0.0:*               LISTEN                                                           1000       41867842   1022/io.yahka.0
                    tcp6       0      0 ::1:25                  :::*                    LISTEN                                                           0          41846625   331/master
                    tcp6       0      0 :::8081                 :::*                    LISTEN                                                           1000       41871456   1825/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN                                                           1000       41867602   964/io.web.0
                    tcp6       0      0 :::22                   :::*                    LISTEN                                                           0          41850469   1/init
                    tcp6       0      0 :::111                  :::*                    LISTEN                                                           0          41847175   1/init
                    udp     1280      0 0.0.0.0:5353            0.0.0.0:*        1000       41866663   1022/io.yahka.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*        1000       41866659   1022/io.yahka.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*        1000       41866655   1022/io.yahka.0
                    udp        0      0 0.0.0.0:9522            0.0.0.0:*        1000       41866523   879/io.sma-em.0
                    udp        0      0 127.0.0.53:53           0.0.0.0:*        106        41850709   138/systemd-resolve
                    udp        0      0 0.0.0.0:111             0.0.0.0:*        0          41847172   1/init
                    udp6       0      0 :::111                  :::*        0          41847178   1/init
                    2023-09-29 12:16:07.744  - info: host.IOBroker iobroker Update "system.adapter.s                                                     huttercontrol.0"
                    2023-09-29 12:16:08.228  - info: host.IOBroker iobroker upload [5] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.pn                                                     g img/info-big.png image/png
                    2023-09-29 12:16:08.233  - info: host.IOBroker iobroker upload [4] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html in                                                     dex_m.html text/html
                    2023-09-29 12:16:08.235  - info: host.IOBroker iobroker upload [3] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js inde                                                     x_m.js application/javascript
                    2023-09-29 12:16:08.239  - info: host.IOBroker iobroker upload [2] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.                                                     png shuttercontrol.png image/png
                    2023-09-29 12:16:08.241  - info: host.IOBroker iobroker upload [1] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style                                                     .css text/css
                    2023-09-29 12:16:08.244  - info: host.IOBroker iobroker upload [0] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.                                                     js application/javascript
                    2023-09-29 12:16:08.246  - info: host.IOBroker iobroker host.IOBroker Adapter "s                                                     ystem.adapter.shuttercontrol.0" is started
                    2023-09-29 12:16:08.258  - info: host.IOBroker "system.adapter.shuttercontrol.0"                                                      enabled
                    2023-09-29 12:16:08.763  - info: host.IOBroker instance system.adapter.shutterco                                                     ntrol.0 started with pid 2712
                    2023-09-29 12:16:09.779  - info: host.IOBroker iobroker exit 0
                    2023-09-29 12:16:11.059  - info: shuttercontrol.0 (2712) starting. Version 1.6.2                                                      in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.18.0, js-contr                                                     oller: 5.0.12
                    2023-09-29 12:16:12.555  - warn: admin.0 (1825) No repository source configured
                    2023-09-29 12:16:21.539  - info: alexa2.0 (2096) No smart home devices to query
                    2023-09-29 12:16:21.929  - info: alexa2.0 (2096) Subscribing to states...
                    2023-09-29 12:16:21.931  - info: alexa2.0 (2096) Deleting the following states:                                                      ["Smart-Home-Devices.e789e8e3-a558-4134-afe6-cce1a7a8fc9d","Smart-Home-Devices.e                                                     789e8e3-a558-4134-afe6-cce1a7a8fc9d.#delete","Smart-Home-Devices.e789e8e3-a558-4                                                     134-afe6-cce1a7a8fc9d.#enabled"]
                    2023-09-29 12:16:23.774  - info: alexa2.0 (2096) Alexa-Push-Connection (macDms =                                                      true) established. Disable Polling
                    2023-09-29 12:16:33.281  - warn: host.IOBroker Requested repository "Github" doe                                                     s not exist in config.
                    2023-09-29 12:16:41.679  - info: alexa2.0 (2096) Initialization Done ...
                    2023-09-29 12:16:46.383  - error: modbus.0 (667) Socket Error
                    2023-09-29 12:16:46.383  - error: modbus.0 (667) Client in error state.
                    2023-09-29 12:16:46.383  - warn: modbus.0 (667) On error: {"errno":-111,"code":"                                                     ECONNREFUSED","syscall":"connect","address":"10.14.4.40","port":502}
                    2023-09-29 12:17:47.385  - error: modbus.0 (667) Socket Error
                    2023-09-29 12:17:47.386  - error: modbus.0 (667) Client in error state.
                    2023-09-29 12:17:47.386  - warn: modbus.0 (667) On error: {"errno":-111,"code":"                                                     ECONNREFUSED","syscall":"connect","address":"10.14.4.40","port":502}
                      Homoran Global Moderator Administrators @Tolkin last edited by
                      hmm, alles?
                        Thomas Braun Most Active @Tolkin last edited by Thomas Braun
                        Swap: 0B
                        Würde ich einschalten. Der wird auch dann und wann bei 8GB RAM verwendet.
                        Da schwirrt noch der Github-Eintrag herum.
                        iob repo unset Github
                        • Tolkin
                          Tolkin @Homoran last edited by
                          @homoran sagte in Adapter lassen sich nach io update nicht mehr öffnen?:
                          hmm, alles?
                          Ja, der Modbus Adapter funktioniert jetzt auch wieder. 😉
                          Ob das Problem jetzt wirklich der Github Adapter war?
                            du hast
                            ausgeschaltet wurde nur dein fehlerhafter Repoeintrag
                            558
