    4. Nach Update läuft nichts mehr!
      Thomas Braun Most Active @SpeedyBlade last edited by
      @speedyblade
      cd /opt/iobroker
      npm ls tar
      Das Modul 'tar' fehlte die Tage auch bei anderen Usern. Keine Ahnung wo/ob es da klemmt.
        SpeedyBlade @SpeedyBlade last edited by
        @speedyblade
        pi@RaspberryPi4:/opt/iobroker $ cd /opt/iobroker
        pi@RaspberryPi4:/opt/iobroker $ npm ls tar
        iobroker.inst@3.0.0 /opt/iobroker
        └─┬ iobroker.js-controller@5.0.12
          └── tar@6.2.0
          @speedyblade
          Passt eigentlich. Sieht bei mir ähnlich aus.
          echad@chet:/opt/iobroker $ npm ls tar
          ├─┬ iobroker.echarts@1.5.4
          │ └─┬ canvas@2.11.2
          │   └─┬ @mapbox/node-pre-gyp@1.0.11
          │     └── tar@6.1.15 deduped
          ├─┬ iobroker.js-controller@5.0.12
          │ └── tar@6.1.15
          └─┬ iobroker.zigbee@1.8.24
            SpeedyBlade @Thomas Braun last edited by SpeedyBlade
            iobroker läuft dennoch nicht
            pi@RaspberryPi4:~ $ node -v & nodejs -v & npm -v
            [1] 1261
            [2] 1262
            v18.17.1
            v18.17.1
            9.6.7
            [1]-  Fertig                  node -v
            [2]+  Fertig                  nodejs -v
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            node:internal/modules/cjs/loader:1080
              throw err;
            Error: Cannot find module 'tar'
            Require stack:
            - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
            - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
            - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                at Module._load (node:internal/modules/cjs/loader:922:27)
                at Module.require (node:internal/modules/cjs/loader:1143:19)
                at require (node:internal/modules/cjs/helpers:121:18)
                at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
                at Module._compile (node:internal/modules/cjs/loader:1256:14)
                at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                at Module.load (node:internal/modules/cjs/loader:1119:32)
                at Module._load (node:internal/modules/cjs/loader:960:12)
                at Module.require (node:internal/modules/cjs/loader:1143:19) {
              code: 'MODULE_NOT_FOUND',
              requireStack: [
                '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
                '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
                '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            Node.js v18.17.1
              @speedyblade sagte in Nach Update läuft nichts mehr!:
              [1] 1261
              [2] 1262
              v18.17.1
              v18.17.1
              9.6.7
              [1]- Fertig node -v
              Was sind das für komische 'Fertig' Einträge? Womit agierst du da?
                keine ahnung...wollte mir nur die Version anzeigen lassen 😉
                Oberjembker 1 Reply Last reply Reply Quote 0
                • Oberjembker
                  Oberjembker @SpeedyBlade last edited by
                  @speedyblade Es müsste heißen:
                  node -v && nodejs -v && npm -v
                  Das einfache '&' schickt den Prozess in den Hintergrund und der meldet dann 'Fertig'.
                  S 1 Reply Last reply Reply Quote 2
                    SpeedyBlade @Oberjembker last edited by
                    @oberjembker
                    pi@RaspberryPi4:~ $ node -v && nodejs -v && npm -v
                    v18.17.1
                    v18.17.1
                    9.6.7
                    schaut eigentlich gut aus, nur die WebOberfläche vom ioBroker bleibt dunkel 😞
                      Homoran Global Moderator Administrators @SpeedyBlade last edited by Homoran
                      @speedyblade iob status?
                      aber du bist ja immer noch auf 18.17.1
                        SpeedyBlade @Homoran last edited by SpeedyBlade
                        aber du bist ja immer noch auf 18.17.1 => was ist daran falsch, hieß ja oben, dass v18 released ist
                        pi@RaspberryPi4:~ $ iob status
                          throw err;
                        Require stack:
                          requireStack: [
                        Node.js v18.17.1
                          korrekt, aber es müsste 18.18.0 sein
                            v18.18.0
                            v18.18.0
                            9.8.1
                            ist up to date...ioBroker immer noch tot
                            beim löschen von NodeJS bekomme ich immer folgende Meldung
                            Entfernen von nodejs (18.17.1-deb-1nodesource1) ...
                            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules« nicht leer, wird daher nicht gelöscht
                            Entfernen von perl-modules-5.28 (5.28.1-6+deb10u1) ...
                            pi@RaspberryPi4:/lib $ cd /usr/lib/node_modules
                            pi@RaspberryPi4:/usr/lib/node_modules $ dir
                            corepack  n  npm
                            bin mittlerweile sprachlos 🤕 🙆‍♂️
                            Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                              @speedyblade
                              Das Skript zum Umstellen des nodesource-Repos kennst du ja schon.
                              Versuch mal
                              cd /opt/iobroker/node_modules/iobroker.js-controller
                              sudo -H -u iobroker npm install tar
                                Thomas Braun Most Active @SpeedyBlade last edited by Thomas Braun
                                Warum????
                                Lass die Finger davon, wenn die 18.18.0 (sauber!) drauf ist.
                                  pi@RaspberryPi4:/opt/iobroker/node_modules/iobroker.js-controller $ sudo -H -u iobroker npm install tar
                                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                  added 295 packages, changed 1 package, and audited 305 packages in 2m
                                  13 packages are looking for funding
                                    run `npm fund` for details
                                  5 vulnerabilities (1 low, 3 moderate, 1 high)
                                  To address issues that do not require attention, run:
                                    npm audit fix
                                  Some issues need review, and may require choosing
                                  a different dependency.
                                  Run `npm audit` for details.
                                  npm notice
                                  npm notice New major version of npm available! 9.8.1 -> 10.1.0
                                  npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.1.0
                                  npm notice Run npm install -g npm@10.1.0 to update!
                                  npm notice
                                  mikeal created this issue in request/request
                                  open Request’s Past, Present and Future #3142
                                    Und mit n sehe ich auch schon den Grund des Übels. Man installiert nodejs nicht per n sondern über den Paketmanager.
                                      @thomas-braun sagte in Nach Update läuft nichts mehr!:
                                      Warum????
                                      wie meinst du das mit "n"?
                                        @speedyblade
                                        n ist einer der nodejs-Versionsmanager. Neben nvm und ein paar anderen Programmen. Der pfuscht dir aber in die 'ordentliche Installation über den Paketmanager' rein. Wie man hier sieht.
                                          ok...ich wie bekommen wir das beseitigt?
                                            @speedyblade
                                            Lass ihn stehen.
                                            help wanted iobroker update js controller update json npm
                                            18
                                            416
                                            56210
