    4. io broker startet nicht nach backitup
      Wildbill @Homoran last edited by Wildbill
      @Homoran
      Kann tatsächlich sein. War da nicht was, dass in Docker-Containern bestimme (alle?) iob-Befehle nicht funktionieren?
      Eventuell klappt es mit
      iobroker logs —watch
      Gruss, Jürgen
      EDIT: @Thomas-Braun war etwas schneller.
      M Homoran 2 Replies Last reply Reply Quote 0
        mario.blass @Wildbill last edited by Homoran
        @wildbill Doch, hat geklappt, da sind im Befehl 2 Bindestriche, jetzt kommt:
        connection to databases possible, restart
        2023-09-29 17:27:59.105  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:28:04.560  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:28:04.567  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:28:04.569  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:28:04.569  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:28:06.620  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:28:34.595  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:28:34.603  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:28:40.543  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:28:40.553  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:28:40.554  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:28:40.555  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:28:42.321  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:29:10.583  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:29:10.589  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:29:15.957  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:29:15.969  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:29:15.970  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:29:15.971  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:29:18.424  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:29:46.001  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:29:46.011  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:29:52.667  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:29:52.676  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:29:52.678  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:29:52.679  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:29:54.314  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:30:22.711  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:30:22.726  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:30:30.771  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:30:30.782  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:30:30.784  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:30:30.785  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:30:33.730  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:31:00.814  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:31:00.821  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:31:08.876  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:31:08.887  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:31:08.888  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:31:08.890  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:31:10.920  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:31:38.929  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:31:38.936  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:31:44.415  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:31:44.425  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:31:44.427  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:31:44.428  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:31:47.318  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:32:14.467  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:32:14.472  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:32:22.057  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:32:22.065  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:32:22.066  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:32:22.067  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:32:23.901  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:32:52.094  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:32:52.100  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:32:57.993  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:32:58.003  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:32:58.004  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:32:58.005  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:33:00.075  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:33:28.036  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:33:28.043  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:33:34.809  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:33:34.819  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:33:34.821  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:33:34.822  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:33:36.636  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:34:04.862  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:34:04.881  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:34:12.197  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:34:12.207  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:34:12.208  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:34:12.209  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:34:13.966  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:34:42.238  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:34:42.244  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:34:48.955  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:34:48.963  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:34:48.964  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:34:48.965  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:34:50.769  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:35:19.003  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:35:19.022  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:35:25.084  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:35:25.095  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:35:25.096  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:35:25.097  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:35:27.235  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:35:55.126  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:35:55.135  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:36:00.806  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:36:00.814  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:36:00.815  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:36:00.816  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:36:02.695  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:36:30.841  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:36:30.847  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:36:36.432  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:36:36.440  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:36:36.441  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:36:36.442  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:36:38.782  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:37:06.468  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:37:06.475  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:37:12.604  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:37:12.612  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:37:12.613  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:37:12.614  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:37:14.567  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:37:42.639  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:37:42.646  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:37:49.781  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:37:49.799  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:37:49.801  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:37:49.801  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:37:52.360  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:38:19.845  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:38:19.852  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:38:26.017  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:38:26.025  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:38:26.026  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:38:26.027  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:38:28.359  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:38:56.056  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:38:56.065  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:39:02.141  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:39:02.152  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:39:02.153  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:39:02.154  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:39:03.929  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:39:32.184  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:39:32.192  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:39:38.304  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:39:38.312  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:39:38.313  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:39:38.314  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:39:40.173  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:40:08.339  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:40:08.345  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:40:14.967  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:40:14.976  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:40:14.977  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:40:14.978  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:40:16.901  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:40:45.008  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:40:45.016  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:40:52.431  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:40:52.438  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:40:52.440  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:40:52.441  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:40:54.202  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:41:22.467  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:41:22.475  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:41:27.935  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:41:27.944  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:41:27.945  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:41:27.946  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:41:29.878  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:41:57.975  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:41:57.982  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:42:04.071  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:42:04.082  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:42:04.083  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:42:04.084  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:42:06.030  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:42:34.117  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:42:34.126  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:42:40.615  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:42:40.623  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:42:40.624  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:42:40.625  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:42:42.511  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:43:10.653  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:43:10.660  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:43:16.389  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:43:16.398  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:43:16.399  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:43:16.400  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:43:19.434  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:43:46.431  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:43:46.440  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:43:52.649  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:43:52.657  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:43:52.659  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:43:52.660  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:43:55.135  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:44:22.693  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:44:22.699  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:44:28.308  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:44:28.315  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:44:28.317  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:44:28.317  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:44:30.203  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:44:58.344  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:44:58.350  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:45:05.343  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:45:05.352  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:45:05.354  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:45:05.355  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:45:07.960  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:45:35.391  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:45:35.397  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:45:47.848  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:45:47.862  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:45:47.864  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:45:47.869  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:45:50.084  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:46:17.938  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:46:17.947  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:46:24.444  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:46:24.454  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:46:24.455  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:46:24.456  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:46:26.412  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:46:54.488  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:46:54.495  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:47:00.124  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:47:00.136  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:47:00.138  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:47:00.139  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:47:01.898  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:47:30.171  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:47:30.179  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:47:35.713  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:47:35.726  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:47:35.728  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:47:35.730  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:47:37.581  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:48:05.767  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:48:05.773  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:48:11.480  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:48:11.487  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:48:11.489  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:48:11.489  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:48:13.128  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:48:41.517  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:48:41.524  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:48:48.070  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:48:48.078  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:48:48.079  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:48:48.080  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:48:50.221  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:49:18.105  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:49:18.112  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:49:24.355  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:49:24.366  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:49:24.368  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:49:24.369  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:49:26.676  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:49:54.407  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:49:54.415  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:50:01.143  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:50:01.154  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:50:01.156  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:50:01.157  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:50:03.661  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:50:31.193  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:50:31.199  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:50:40.853  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:50:40.862  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:50:40.863  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:50:40.867  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:50:42.908  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:51:10.910  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:51:10.917  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:51:17.127  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:51:17.137  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:51:17.138  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:51:17.139  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:51:19.229  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:51:47.177  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:51:47.188  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:51:53.446  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:51:53.459  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:51:53.460  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:51:53.461  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:51:55.383  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:52:23.490  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:52:23.497  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:52:34.465  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:52:34.477  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:52:34.479  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:52:34.481  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:52:37.677  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:53:04.584  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:53:04.590  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:53:11.049  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:53:11.057  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:53:11.058  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:53:11.059  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:53:12.915  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:53:41.086  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:53:41.094  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:53:47.575  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:53:47.583  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:53:47.584  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:53:47.585  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:53:49.535  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:54:17.610  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:54:17.616  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:54:23.105  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:54:23.125  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:54:23.130  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:54:23.131  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:54:25.056  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:54:53.167  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:54:53.173  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:54:58.815  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:54:58.823  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:54:58.824  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:54:58.825  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:55:01.315  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:55:28.852  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:55:28.858  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:55:34.677  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:55:34.685  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:55:34.686  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:55:34.687  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:55:36.550  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:56:04.714  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:56:04.721  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:56:11.277  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:56:11.285  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:56:11.286  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:56:11.287  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:56:13.526  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:56:41.315  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:56:41.322  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:56:47.104  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:56:47.138  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:56:47.142  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:56:47.145  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:56:50.328  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:57:17.220  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:57:17.255  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:57:24.023  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:57:24.031  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:57:24.033  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:57:24.034  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:57:25.828  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:57:54.062  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:57:54.069  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:57:59.996  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:58:00.026  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:58:00.027  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:58:00.028  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:58:02.200  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:58:30.076  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:58:30.083  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:58:37.110  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:58:37.119  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:58:37.121  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:58:37.122  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:58:39.307  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:59:07.188  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:59:07.195  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:59:13.251  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:59:13.261  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:59:13.263  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:59:13.264  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:59:15.208  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 17:59:43.302  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 17:59:43.318  - info: host.2edb3017894a iobroker _restart
        2023-09-29 17:59:49.746  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 17:59:49.758  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 17:59:49.761  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 17:59:49.762  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 17:59:52.097  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 18:00:19.797  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 18:00:19.805  - info: host.2edb3017894a iobroker _restart
        2023-09-29 18:00:33.460  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 18:00:33.480  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 18:00:33.485  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 18:00:33.486  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 18:00:36.433  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        2023-09-29 18:01:03.679  - error: host.2edb3017894a No connection to databases possible, restart
        2023-09-29 18:01:03.687  - info: host.2edb3017894a iobroker _restart
        2023-09-29 18:01:10.830  - info: host.2edb3017894a iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-29 18:01:10.841  - info: host.2edb3017894a Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-29 18:01:10.843  - info: host.2edb3017894a hostname: 2edb3017894a, node: v18.17.0
        2023-09-29 18:01:10.844  - info: host.2edb3017894a ip addresses: 192.168.178.125
        2023-09-29 18:01:13.101  - info: host.2edb3017894a-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        Homoran Samson71 Thomas Braun 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Wildbill last edited by
          @wildbill sagte in io broker startet nicht nach backitup:
          ich weiss nur von iob stop >> pkill....
          Allerdings bin ich sowas von weit entfernt etwas über Docker zu wissen,.....
            Homoran Global Moderator Administrators @mario.blass last edited by
            @mario-blass sagte in io broker startet nicht nach backitup:
            das hab ich vermutet
            und code-tags sind nicht nur zur Deko da
              @homoran sagte in io broker startet nicht nach backitup:
              So geht es mir auch.
              @mario-blass Wenn Du das in code-tags (oben </>) packst, wäre das lesbarer.
              Gruss, Jürgen
              • Samson71
                Samson71 Global Moderator @mario.blass last edited by
                @mario-blass
                Du bist doch auch nicht erst seit gestern dabei. Pack das Zeug mal in Code Tags.
                  @mario-blass @homoran Die zwei Bindestriche macht mein Ipad da irgendwie zu einem langen. Sorry. Es müssen zwei Minus hin!
                    Thomas Braun Most Active @mario.blass last edited by
                    Da wohnt schon wer.
                      @wildbill ```
                      M W 2 Replies Last reply Reply Quote 0
                        mario.blass @mario.blass last edited by
                        @mario-blass Aber wo kommt diese Adresse her (127.0.0.1:9001)
                          Wildbill @mario.blass last edited by Wildbill
                          @mario-blass Entweder läuft auf Deinem Docker-Host schon ein anderer Container, der 9001 belegt, der Port ist durch einen Dienst des Host selbst belegt, oder im iobroker-Container hängt was. Hast Du den mal neu gestartet?
                          Gruss, Jürgen
                          127.0.0.1 ist der localhost, also genau dieses Gerät. Wobei ich nicht weiss, ob da bei Docker der Host auch als localhost sichtbar ist.
                            127.0.0.1
                            Ist der 'local host', also die Maschine selber. 9001 ist der Port der Datenbank. Da läuft also schon was.
                              mario.blass @Thomas Braun last edited by mario.blass
                              Ich habe noch den "Alten" Broker in einem Container laufen mit der alten node Version. Liegt es daran ?
                                Wildbill @Thomas Braun last edited by
                                @thomas-braun Wieso schreibst Du immer das, was ich auch schreibe, nur eine Sekunde vor mir? 😊
                                  Ich habe noch den "Alten" Broker in einem Container laufen mit der alten node VErson. Liegt es daran ?
                                  Der belegt dann ziemlich sicher den Port, da hast Du die Antwort.
                                    @wildbill Reicht es den Container der alten Version zu stoppen oder muss ich diesen löschen ?
                                    Wollte eigentlich vorerst nicht löschen bevor der neue läuft.
                                      Thomas Braun Most Active @Wildbill last edited by
                                      Bin Lucky Luke, der Kerl der schneller postet als sein Schatten.
                                        Stoppen sollte reichen.
                                        @Thomas-Braun Qualität vor Quantität 😀
                                          Da hast du natürlich vollkommen Recht. Ich ollen Spammer...
                                            Hilft nicht, Mist.....
                                            2600
