    4. Roborock - Adapter stürzt ständig ab
    • Glasfaser
      Glasfaser @Michael Sauer last edited by
      @michael-sauer
      kannst du den Thread Titel anpassen auf :
      roborock Adapter stürzt ständig ab
      • Michael Sauer
        Michael Sauer @Glasfaser last edited by
        @glasfaser
        Steht auf Debug. System ist aktualisiert:
        roborock.0
        2023-09-29 08:17:46.345	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        roborock.0
        2023-09-29 08:17:46.334	error	adapter disabled
        roborock.0
        2023-09-29 08:17:46.317	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        roborock.0
        2023-09-29 08:17:10.665	info	terminating
        roborock.0
        2023-09-29 08:17:10.373	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
        roborock.0
        2023-09-29 08:17:10.370	warn	setTimeout called, but adapter is shutting down
        roborock.0
        2023-09-29 08:17:10.369	warn	setTimeout called, but adapter is shutting down
        roborock.0
        2023-09-29 08:17:10.271	warn	setTimeout called, but adapter is shutting down
        roborock.0
        roborock.0
        2023-09-29 08:17:10.185	warn	setTimeout called, but adapter is shutting down
        roborock.0
        2023-09-29 08:17:10.181	warn	Failed to create map. retry
        roborock.0
        2023-09-29 08:17:10.161	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        roborock.0
        2023-09-29 08:17:10.160	info	terminating
        roborock.0
        2023-09-29 08:17:10.146	error	Cannot read properties of undefined (reading 'captureException')
        roborock.0
        2023-09-29 08:17:10.146	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
        roborock.0
        2023-09-29 08:17:10.145	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
        roborock.0
        2023-09-29 08:17:10.144	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        roborock.0
        2023-09-29 08:17:07.454	warn	Failed to execute load_multi_map on robot 5Eo7zrAcFZhjGJqyG5saSx Error: There was an error processing the request with id 3224 error: {"code":-10003,"message":"action locked"}
        roborock.0
        2023-09-29 08:16:54.267	info	MQTT initialized
        roborock.0
        2023-09-29 08:16:52.229	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
        roborock.0
        2023-09-29 08:16:52.080	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        S Glasfaser 2 Replies Last reply Reply Quote 0
          SpacerX @Michael Sauer last edited by SpacerX
          @michael-sauer Hast du einen Raspi laufen? Wenn ja dort funzt das mit der Map nicht richtig. Deshalb vielleicht die deine Probs. Schau mal in den Beitrag zum Adapter.
          https://forum.iobroker.net/topic/67186/neuer-adapter-f%C3%BCr-roborock-staubsauger
          • Glasfaser
            @michael-sauer sagte in Roborock - Adapter stürzt ständig ab:
            Steht auf Debug.
            Nö ist nicht , ist die gleiche Info wie zuvor !
            Die Adapter Instanz auf DEBUG stellen .
            Beispiel :
            Was war hiermit !?
            @glasfaser sagte in Roborock - Adapter stürzt ständig ab:
            Die Version ist BETA , läuft es auch nicht mit dem Stable !?
            Und Zeige mal die Full Ausgabe von
            iob diag
            Michael Sauer 1 Reply Last reply Reply Quote 0
              ticaki Developer last edited by
              Kannst du das versenden von anonymisierten Daten mal aktivieren? Sentry
              • Michael Sauer
                @glasfaser Hast recht.
                Hier der vollständige Log:
                roborock.0
                2023-09-29 20:44:27.997	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
                roborock.0
                2023-09-29 20:44:27.787	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                roborock.0
                2023-09-29 20:44:27.769	debug	Plugin sentry Initialize Plugin (enabled=true)
                roborock.0
                2023-09-29 20:43:40.797	warn	Failed to execute get_clean_summary on robot 5Eo7zrAcFZhjGJqyG5saSx TypeError: Cannot read properties of undefined (reading 'captureException')
                roborock.0
                2023-09-29 20:43:40.797	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
                roborock.0
                2023-09-29 20:43:40.791	warn	Failed to execute get_clean_record_map on robot 5Eo7zrAcFZhjGJqyG5saSx retry
                roborock.0
                2023-09-29 20:43:40.790	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
                roborock.0
                2023-09-29 20:43:40.775	debug	Length of message queue: 0
                roborock.0
                2023-09-29 20:43:40.774	debug	dps debug: {"id":3403,"result":["retry"]}
                roborock.0
                2023-09-29 20:43:40.614	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
                roborock.0
                2023-09-29 20:43:40.611	warn	setTimeout called, but adapter is shutting down
                roborock.0
                2023-09-29 20:43:40.610	warn	setTimeout called, but adapter is shutting down
                roborock.0
                2023-09-29 20:43:40.591	debug	Length of message queue: 0
                roborock.0
                2023-09-29 20:43:40.591	debug	dps debug: {"id":8382,"result":[{"begin":1695980402,"end":1695981303,"duration":901,"area":11682500,"error":0,"complete":0,"start_type":3,"clean_type":3,"finish_reason":62,"dust_collection_status":1,"avoid_count":2,"map_flag":0}]}
                roborock.0
                2023-09-29 20:43:40.379	warn	Failed to create map. retry
                roborock.0
                2023-09-29 20:43:40.377	warn	setTimeout called, but adapter is shutting down
                roborock.0
                2023-09-29 20:43:40.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                roborock.0
                2023-09-29 20:43:40.343	debug	Plugin sentry destroyed
                roborock.0
                2023-09-29 20:43:40.341	info	terminating
                roborock.0
                2023-09-29 20:43:40.321	error	Cannot read properties of undefined (reading 'captureException')
                roborock.0
                2023-09-29 20:43:40.320	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                roborock.0
                2023-09-29 20:43:40.319	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                roborock.0
                2023-09-29 20:43:40.319	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                roborock.0
                2023-09-29 20:43:40.316	debug	Length of message queue: 2
                roborock.0
                2023-09-29 20:43:40.316	debug	Not clearing messageQueue. null - 24752
                roborock.0
                2023-09-29 20:43:40.315	debug	dps debug: {"id":5996,"result":["retry"]}
                roborock.0
                2023-09-29 20:43:40.312	debug	Length of message queue: 2
                roborock.0
                2023-09-29 20:43:40.312	debug	dps debug: {"id":1492,"result":{"clean_time":202871,"clean_area":2843662500,"clean_count":144,"dust_collection_count":128,"records":[1695980402,1695978009,1695807600,1695805205,1695718805,1695634800,1695632403,1695546005,1695459607,1695375600,1695373208,1695286806,1695202799,1695200405,1695114008,1695030000,1695027609,1694941211,1694854807,1694770801]}}
                roborock.0
                2023-09-29 20:43:39.961	debug	downloadURL: https://github.com/AlexxIT/go2rtc/releases/download/v1.3.0/go2rtc_linux_arm
                roborock.0
                2023-09-29 20:43:39.961	debug	System type: go2rtc_linux_arm
                roborock.0
                2023-09-29 20:43:39.961	debug	platform: linux
                roborock.0
                2023-09-29 20:43:39.960	debug	arch: arm
                roborock.0
                2023-09-29 20:43:39.958	debug	Update map
                roborock.0
                2023-09-29 20:43:39.955	debug	Length of message queue: 1
                roborock.0
                2023-09-29 20:43:39.954	debug	dps debug: {"id":1643,"result":{"water_box_mode":201}}
                roborock.0
                2023-09-29 20:43:39.684	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_water_box_custom_mode
                roborock.0
                2023-09-29 20:43:39.681	debug	Length of message queue: 1
                roborock.0
                2023-09-29 20:43:39.679	debug	dps debug: {"id":3641,"result":[{"carpet_clean_mode":3}]}
                roborock.0
                2023-09-29 20:43:39.388	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_clean_mode
                roborock.0
                2023-09-29 20:43:39.386	debug	Length of message queue: 1
                roborock.0
                2023-09-29 20:43:39.384	debug	dps debug: {"id":5183,"result":[{"enable":1,"current_integral":1000,"current_high":500,"current_low":1000,"stall_time":10}]}
                roborock.0
                2023-09-29 20:43:39.303	debug	get_timer: []
                roborock.0
                2023-09-29 20:43:39.302	debug	Length of message queue: 2
                roborock.0
                2023-09-29 20:43:39.301	debug	dps debug: {"id":1710,"result":[]}
                roborock.0
                2023-09-29 20:43:39.299	debug	get_server_timer: [["1688127243968","on",0],["1688127295244","on",0]]
                roborock.0
                2023-09-29 20:43:39.298	debug	Length of message queue: 3
                roborock.0
                2023-09-29 20:43:39.297	debug	dps debug: {"id":9140,"result":[["1688127243968","on",0],["1688127295244","on",0]]}
                roborock.0
                2023-09-29 20:43:38.906	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_mode
                roborock.0
                2023-09-29 20:43:38.905	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_timer
                roborock.0
                2023-09-29 20:43:38.904	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_server_timer
                roborock.0
                2023-09-29 20:43:38.903	debug	Length of message queue: 1
                roborock.0
                2023-09-29 20:43:38.902	debug	dps debug: {"id":1525,"result":{"ssid":"S-Home","ip":"192.168.78.122","mac":"b0:4a:39:6b:e2:59","bssid":"b0:f2:08:d9:88:ed","rssi":-68}}
                roborock.0
                2023-09-29 20:43:38.555	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_network_info
                roborock.0
                2023-09-29 20:43:38.554	debug	Consumables of robot: [{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]
                roborock.0
                2023-09-29 20:43:38.551	debug	Length of message queue: 1
                roborock.0
                2023-09-29 20:43:38.550	debug	dps debug: {"id":1936,"result":[{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]}
                roborock.0
                2023-09-29 20:43:38.287	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_consumable
                roborock.0
                2023-09-29 20:43:38.286	debug	Mapped room matched: 11316198 with name: Küche
                roborock.0
                2023-09-29 20:43:38.285	debug	Mapped room matched: 11316194 with name: Flur
                roborock.0
                2023-09-29 20:43:38.284	debug	Mapped room matched: 12646380 with name: Esszimmer
                roborock.0
                2023-09-29 20:43:38.283	debug	Mapped room matched: 11309675 with name: Wohnzimmer
                roborock.0
                2023-09-29 20:43:38.282	debug	All mapped rooms: [[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]
                roborock.0
                2023-09-29 20:43:38.281	debug	Length of message queue: 1
                roborock.0
                2023-09-29 20:43:38.281	debug	dps debug: {"id":8606,"result":[[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]}
                roborock.0
                2023-09-29 20:43:38.238	debug	foreign.message attribute: 128 with value: 4
                roborock.0
                2023-09-29 20:43:38.237	debug	dps debug: {"128":4}
                roborock.0
                2023-09-29 20:43:38.143	debug	Length of message queue: 1
                roborock.0
                2023-09-29 20:43:38.142	debug	dps debug: {"id":8398,"result":[{"msg_ver":2,"msg_seq":126,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
                roborock.0
                2023-09-29 20:43:37.907	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_room_mapping
                roborock.0
                2023-09-29 20:43:37.891	debug	get_status: {"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}
                roborock.0
                2023-09-29 20:43:37.889	debug	Length of message queue: 0
                roborock.0
                2023-09-29 20:43:37.888	debug	dps debug: {"id":5982,"result":[{"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
                roborock.0
                2023-09-29 20:43:37.645	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_status
                roborock.0
                2023-09-29 20:43:37.644	debug	Latest data requested
                roborock.0
                2023-09-29 20:43:37.642	debug	Length of message queue: 0
                roborock.0
                2023-09-29 20:43:37.640	debug	dps debug: {"id":1305,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1695979052,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1695806345}]},{"mapFlag":1,"add_time":1692254347,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1688451884}]}]}]}
                roborock.0
                2023-09-29 20:43:37.486	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_multi_maps_list
                roborock.0
                2023-09-29 20:43:37.382	debug	Length of message queue: 0
                roborock.0
                2023-09-29 20:43:37.379	debug	dps debug: {"id":3178,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                roborock.0
                2023-09-29 20:43:37.164	debug	Firmware features request
                roborock.0
                2023-09-29 20:43:37.164	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_fw_features
                roborock.0
                2023-09-29 20:43:37.160	debug	5Eo7zrAcFZhjGJqyG5saSx online. Starting mainUpdateInterval.
                roborock.0
                2023-09-29 20:43:23.804	debug	Robot key: roborock.vacuum.a51
                roborock.0
                2023-09-29 20:43:23.803	debug	RoomIDs debug: {"11309675":"Wohnzimmer","11314643":"Wohnzimmer1","11316194":"Flur","11316198":"Küche","11316201":"Küche1","11319794":"Badezimmer","11319802":"Spielzimmer","11319804":"Kinderzimmer","11319806":"Schlafzimmer","12646380":"Esszimmer","13421850":"Standard","13421863":"Phillip Schlafzimmer","13421865":"Badezimmer1"}
                roborock.0
                2023-09-29 20:43:23.801	info	MQTT initialized
                roborock.0
                2023-09-29 20:43:20.623	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
                roborock.0
                2023-09-29 20:43:20.491	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                roborock.0
                2023-09-29 20:43:20.474	debug	Plugin sentry Initialize Plugin (enabled=true)
                roborock.0
                2023-09-29 20:43:20.348	debug	States connected to redis: 127.0.0.1:6379
                roborock.0
                2023-09-29 20:43:20.336	debug	States create User PubSub Client
                roborock.0
                2023-09-29 20:43:20.335	debug	States create System PubSub Client
                roborock.0
                2023-09-29 20:43:20.327	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                roborock.0
                2023-09-29 20:43:20.307	debug	Objects connected to redis: 127.0.0.1:6379
                roborock.0
                2023-09-29 20:43:20.300	debug	Objects client initialize lua scripts
                roborock.0
                2023-09-29 20:43:19.846	debug	Objects create User PubSub Client
                roborock.0
                2023-09-29 20:43:19.844	debug	Objects create System PubSub Client
                roborock.0
                2023-09-29 20:43:19.842	debug	Objects client ready ... initialize now
                roborock.0
                2023-09-29 20:43:19.803	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                   Static hostname: iobroker
                         Icon name: computer
                        Machine ID: 5f09e0dc24364fc8951dcf01ea03774d
                           Boot ID: 687f969e56cf41c2bcbbdd9cffef19bb
                  Operating System: Raspbian GNU/Linux 10 (buster)
                            Kernel: Linux 5.10.103-v7l+
                      Architecture: arm
                Model           : Raspberry Pi 4 Model B Rev 1.2
                Docker          : false
                Virtualization  : none
                Kernel          : armv7l
                Userland        : armhf
                Systemuptime and Load:
                 20:55:52 up 23:02,  1 user,  load average: 4.01, 3.35, 2.81
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                Other values than 0x0 hint to temperature/voltage problems
                temp=57.4'C
                volt=0.8500V
                *** Time and Time Zones ***
                               Local time: Fri 2023-09-29 20:55:53 CEST
                           Universal time: Fri 2023-09-29 18:55:53 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           3.8G        2.7G        111M         13M        1.0G        971M
                Swap:           99M         99M        0.0K
                Total:         3.9G        2.8G        111M
                         3838 M total memory
                         2706 M used memory
                          670 M active memory
                         2888 M inactive memory
                          111 M free memory
                          167 M buffer memory
                          853 M swap cache
                           99 M total swap
                           99 M used swap
                            0 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4       59G   19G   38G  34% /
                devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                tmpfs          tmpfs     1.9G  2.2M  1.9G   1% /dev/shm
                tmpfs          tmpfs     1.9G   18M  1.9G   1% /run
                tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                /dev/loop1     squashfs   41M   41M     0 100% /snap/certbot/3025
                /dev/loop0     squashfs   54M   54M     0 100% /snap/core20/2018
                /dev/loop2     squashfs   91M   91M     0 100% /snap/core/15929
                /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16098
                /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                Show mounted filesystems (real ones only):
                TARGET               SOURCE         FSTYPE   OPTIONS
                /                    /dev/mmcblk0p2 ext4     rw,noatime
                |-/sys/fs/bpf        none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
                |-/snap/certbot/3025 /dev/loop1     squashfs ro,nodev,relatime
                |-/snap/core20/2018  /dev/loop0     squashfs ro,nodev,relatime
                |-/snap/core/15929   /dev/loop2     squashfs ro,nodev,relatime
                |-/snap/core/16098   /dev/loop3     squashfs ro,nodev,relatime
                `-/boot              /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                3.6G    /var/
                3.1G    /var/lib
                1.9G    /var/lib/mysql
                1.7G    /var/lib/mysql/iobroker
                525M    /var/lib/piVCCU3
                Archived and active journals take up 16.0M in the file system.
                /opt/iobroker/backups:
                197M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                695M    /opt/iobroker/iobroker-data/
                466M    /opt/iobroker/iobroker-data/files
                136M    /opt/iobroker/iobroker-data/backup-objects
                87M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                28M     /opt/iobroker/iobroker-data/objects.jsonl
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
                20M     /opt/iobroker/iobroker-data/objects.json.migrated
                20M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.18.0
                /usr/bin/node           v18.18.0
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Installed: 18.18.0-1nodesource1
                  Candidate: 18.18.0-1nodesource1
                  Version table:
                 *** 18.18.0-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                        100 /var/lib/dpkg/status
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                     10.24.0~dfsg-1~deb10u3 500
                No problems detected
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                At least one iobroker host is running.
                Objects type: redis
                States  type: redis
                No configuration change needed.
                Multihost discovery server: disabled
                Discovery authentication:   enabled
                Persistent activation:      disabled
                Objects:                    redis on 127.0.0.1
                States:                     redis on 127.0.0.1
                Core adapters versions
                admin:          6.10.2
                javascript:     7.1.4
                Adapters from github:   2
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
                + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                  system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
                  system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                  system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
                  system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                  system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 42001
                + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
                + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
                + system.adapter.radar2.1                 : radar2                : iobroker                                 -  enabled
                  system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
                  system.adapter.roadtraffic.0            : roadtraffic           : iobroker                                 - disabled
                  system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                  system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
                  system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                  system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                  system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
                + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                  system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                  system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                  system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): beta
                Installed ioBroker-Instances
                Used repository: beta
                Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
                Adapter    "alarm"        : 3.3.13   , installed 3.3.13
                Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
                Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
                Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                Adapter    "email"        : 1.2.0    , installed 1.2.0
                Adapter    "eusec"        : 1.1.2    , installed 1.1.0  [Updatable]
                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                Controller "js-controller": 5.0.12   , installed 5.0.12
                Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
                Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "pvforecast"   : 2.8.1    , installed 2.8.1
                Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                Adapter    "ring"         : 5.0.0-alpha.0, installed 3.4.0 [Updatable]
                Adapter    "roadtraffic"  : 0.2.0    , installed 0.2.0
                Adapter    "roborock"     : 0.4.4    , installed 0.4.4
                Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
                Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
                Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
                Adapter    "sonos"        : 2.3.3    , installed 2.3.1  [Updatable]
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
                Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
                Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                Objects and States
                Objects:        32411
                States:         52049
                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:2 http://phoscon.de/apt/deconz buster InRelease
                Ign:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:4 http://archive.raspberrypi.org/debian buster InRelease
                Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                Err:6 https://deb.nodesource.com/node_18.x nodistro Release
                  Could not handshake: Error in the pull function. [IP: 2606:4700:10::6816:41a 443]
                Get:7 https://apt.grafana.com stable InRelease [5984 B]
                Reading package lists...
                E: The repository 'https://deb.nodesource.com/node_18.x nodistro Release' no longer has a Release file.
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1318755    12061/io.jarvis.0
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          22913      809/lighttpd
                tcp        0      0 192.168.78.83:42001     0.0.0.0:*               LISTEN      1001       87501      6525/io.hm-rpc.0
                tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        21806      724/pihole-FTL
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18356      738/sshd
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          332335     14432/cupsd
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       88205      6262/node-red
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       86309      6281/io.shelly.0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       87235      6402/io.mqtt.0
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          22964      818/smbd
                tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21812      724/pihole-FTL
                tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        16875      808/mysqld
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          22965      818/smbd
                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16819      772/redis-server 12
                tcp6       0      0 :::80                   :::*                    LISTEN      0          22914      809/lighttpd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3021956    27005/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2963823    25413/io.web.0
                tcp6       0      0 :::53                   :::*                    LISTEN      999        21808      724/pihole-FTL
                tcp6       0      0 :::22                   :::*                    LISTEN      0          18358      738/sshd
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          332334     14432/cupsd
                tcp6       0      0 :::3000                 :::*                    LISTEN      113        136316     8949/grafana
                tcp6       0      0 :::445                  :::*                    LISTEN      0          22962      818/smbd
                tcp6       0      0 ::1:4711                :::*                    LISTEN      999        21813      724/pihole-FTL
                tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16820      772/redis-server 12
                tcp6       0      0 :::139                  :::*                    LISTEN      0          22963      818/smbd
                tcp6       0      0 :::3500                 :::*                    LISTEN      1001       90354      6593/io.sonos.0
                udp        0      0 0.0.0.0:41879           0.0.0.0:*                           1001       601710     9411/io.backitup.0
                udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        21805      724/pihole-FTL
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       89218      6437/io.radar2.0
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       88118      6318/io.radar2.1
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16209      471/dhclient
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          332343     14433/cups-browsed
                udp        0      0 192.168.78.255:137      0.0.0.0:*                           0          21669      701/nmbd
                udp        0      0 192.168.78.83:137       0.0.0.0:*                           0          21668      701/nmbd
                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          21656      701/nmbd
                udp        0      0 192.168.78.255:138      0.0.0.0:*                           0          21671      701/nmbd
                udp        0      0 192.168.78.83:138       0.0.0.0:*                           0          21670      701/nmbd
                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          21657      701/nmbd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17448      402/avahi-daemon: r
                udp        0      0 0.0.0.0:44942           0.0.0.0:*                           108        17450      402/avahi-daemon: r
                udp6       0      0 :::53                   :::*                                999        21807      724/pihole-FTL
                udp6       0      0 :::5353                 :::*                                108        17449      402/avahi-daemon: r
                udp6       0      0 :::52557                :::*                                108        17451      402/avahi-daemon: r
                2023-09-29 20:45:44.387  - warn: host.iobroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
                2023-09-29 20:46:00.229  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                    at /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:79:156
                    at processTicksAndRejections (node:internal/process/task_queues:95:5)
                2023-09-29 20:46:00.249  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                2023-09-29 20:48:08.985  - error: node-red.0 (6192) 29 Sep 20:48:08 - [error] [modbus-getter:n37000-37123] Error: Timed out
                2023-09-29 20:48:09.020  - error: node-red.0 (6192) 29 Sep 20:48:09 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                2023-09-29 20:50:45.740  - info: javascript.0 (6113) script.js.common.Weather: Material Design Widgets: Wetter Skript triggered by 'linkeddevices.0.Sensor.Wetter.temperature'
                2023-09-29 20:55:00.944  - info: sql.0 (6216) Do not store value "NULL" for hm-rpc.0.LTK0086602.4.VALVE_STATE because no number
                2023-09-29 20:56:42.693  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Timed out
                2023-09-29 20:56:42.720  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                Danke fürs ansehen.
                • Michael Sauer
                  Michael Sauer @ticaki last edited by
                  @ticaki Ist jetzt aktiviert.
                  • Glasfaser
                    Bullseye ist aktuell
                    free 111M
                    Dein Speicher geht aus ...
                    Redis OK , dann läuft aber
                    redis-server 12
                    Beta Tester ... OK ... aber nicht Aktuell ... up to Date!!!
                    Dann
                    • Michael Sauer
                      @glasfaser Was möchtest du mir damit sagen?
                      Glasfaser S 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        @michael-sauer
                        Ziemlich ausgelastet dein Raspberry und auch nicht ioBroker als "Beta Tester" gepflegt !
                        Ich würde auf jeden Fall mal PiHole prüfen , denn ich habe oben geschrieben :
                        setInterval called, but adapter is shutting down
                        Keine Verbindung !?
                          @michael-sauer ich bleibe dabei. Stelle die Maperstellung ab, dann sollte er laufen.
                            ticaki Developer last edited by ticaki
                            Der hängt in der Fehlerbehandlung(Map) beim Aufruf von Sentry. Das abschalten der Maperzeugung, so das diese Fehlerbehandlung nicht mehr aufgerufen wird, ist sicher ein Weg. @copystring
                            Hab nur den Sauger aber nicht den Adapter im Einsatz, sollte wohl ein github issue aufgemacht werden.
                            https://github.com/copystring/ioBroker.roborock
                            Michael Sauer A 2 Replies Last reply Reply Quote 0
                            • copystring
                              copystring @Michael Sauer last edited by
                              @michael-sauer Die Kartenerstellung kann auf einem RPi nicht funktionieren. Da gibt es ein Problem mit der Canvas-Bibliothek.
                              https://github.com/copystring/ioBroker.roborock#map-creation-does-not-work-on-raspberry-pi
                              • Michael Sauer
                                @ticaki sagte in Roborock - Adapter stürzt ständig ab:
                                Das war die Lösung. Danke.
                                  Almeda @ticaki last edited by
                                  @ticaki said in Roborock - Adapter stürzt ständig ab:
                                  ich möchte mich an dieses Thema kurz mit anhängen. Nutze den Roborock Adapter seit ca. 4 Wochen und habe seit Anbeginn, trotz ausgeschalteter Map Erstellung, das Problem, dass der Adapter laut dem Host ständig abstürzt und er ihn daher regelhaft nach 1-2 Tagen aus dem Rennen nimmt und den Neustart verhindert.
                                  Tatsächlich hat die Einrichtung nach der Installation problemlos geklappt und auch die Anbindung an Node-Red zum Ausspielen der Stati über Telegramm hat sofort funktioniert.
                                  Eine De- und Neuinstallation des Apdaters hat nichts gebracht. Ich habe dann auf das aktuelle Update gewartet, weil ich es für ein vllt. bekanntes Problem hielt. Das Update von vor einigen Tagen hat jedoch keine Besserung gebracht.
                                  IoB läuft auf einem Synology 918+ mit ausreichend RAM. Kein anderer Adapter macht Probleme.
                                  Kann einer weiterhelfen?
                                  Vielen Dank
                                  Almeda
                                  Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @Almeda last edited by
                                    @almeda sagte in Roborock - Adapter stürzt ständig ab:
                                    Ohne Log? Schwierig.
                                    • haselchen
                                      haselchen Most Active @Almeda last edited by
                                      @almeda
                                      Warum nicht den Mihome-Vacuum?
                                      Der funktioniert völlig unkompliziert und macht meines Erachtens das Gleiche wie Dein Adapter.
                                      Bei meinem weiß ich allerdings, dass er funktioniert 😉
                                        Almeda @Thomas Braun last edited by
                                        @thomas-braun said in Roborock - Adapter stürzt ständig ab:
                                        Sorry, vergessen anzuhängen. Es erscheint die Warnung:
                                        Failed to execute get_fw_features on robot 4d98R7TEpn6C0ZcYPNY52Q Error: Local request with id 5 with method get_fw_features timed out after 10 seconds
                                        @haselchen said in Roborock - Adapter stürzt ständig ab:
                                        @almeda
                                        Den hatte ich bisher nicht auf dem Schirm. Ich danke dir für den Hinweis. Probiere ihn gerne mal aus!
                                        haselchen 1 Reply Last reply Reply Quote 1
                                        • haselchen
                                          @almeda
                                          Gib dann mal bitte Feedback….
                                            Almeda @haselchen last edited by
                                            @almeda
                                            Eben versucht und in der Dokumentation festgestellt, dass der S7 nicht funktioniert. Damit ist die Option leider auch raus 😞
                                            30
                                            1587
