    4. Test Adapter MyVBus v0.6.x Latest
      ChrisChros @pdbjjens last edited by
      @pdbjjens hab ich gestern nicht gemacht, kann ich heute Abend gerne nachholen und hochladen.
        @pdbjjens hier der log von eben:
        2023-09-27 16:49:53.868 - debug: discovery.0 (2835) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-09-27 16:49:53.923 - debug: discovery.0 (2835) Objects client ready ... initialize now
        2023-09-27 16:49:53.926 - debug: discovery.0 (2835) Objects create System PubSub Client
        2023-09-27 16:49:53.928 - debug: discovery.0 (2835) Objects create User PubSub Client
        2023-09-27 16:49:53.970 - debug: discovery.0 (2835) Objects client initialize lua scripts
        2023-09-27 16:49:53.982 - debug: discovery.0 (2835) Objects connected to redis: 127.0.0.1:9001
        2023-09-27 16:49:54.017 - debug: discovery.0 (2835) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-09-27 16:49:54.031 - debug: discovery.0 (2835) States create System PubSub Client
        2023-09-27 16:49:54.032 - debug: discovery.0 (2835) States create User PubSub Client
        2023-09-27 16:49:54.101 - debug: discovery.0 (2835) States connected to redis: 127.0.0.1:9000
        2023-09-27 16:49:54.201 - debug: discovery.0 (2835) Plugin sentry Initialize Plugin (enabled=true)
        2023-09-27 16:49:54.707 - info: discovery.0 (2835) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.17.1, js-controller: 5.0.12
        2023-09-27 16:50:21.436 - debug: discovery.0 (2835) Received "listMethods" event
        2023-09-27 16:50:27.180 - debug: discovery.0 (2835) Received "browse" event
        2023-09-27 16:50:28.694 - debug: discovery.0 (2835) main.addDevice: ip=10.10.20.6 source=RESOL VBus
        2023-09-27 16:50:28.695 - info: discovery.0 (2835) Done discovering RESOL VBus devices. 1 packages received
        2023-09-27 16:50:28.697 - info: discovery.0 (2835) Found 2 addresses
        2023-09-27 16:50:29.665 - debug: discovery.0 (2835) Test vbus 10.10.20.6 myvbus
        2023-09-27 16:50:29.680 - debug: discovery.0 (2835) Test vbus 10.10.20.6 resol
        2023-09-27 16:50:29.706 - debug: discovery.0 (2835) Test once 0.0.0.0 sma-em
        2023-09-27 16:50:31.715 - debug: discovery.0 (2835) Added suggested adapter: cloud.0
        2023-09-27 16:50:31.728 - debug: discovery.0 (2835) Added suggested adapter: echarts.0
        2023-09-27 16:50:31.732 - debug: discovery.0 (2835) Added suggested adapter: iot.0
        2023-09-27 16:50:31.734 - debug: discovery.0 (2835) Added suggested adapter: iqontrol.0
        2023-09-27 16:50:31.737 - debug: discovery.0 (2835) Added suggested adapter: jarvis.0
        2023-09-27 16:50:31.744 - info: discovery.0 (2835) Discovery finished. Found new or modified 5 instances
        2023-09-27 16:50:31.816 - info: discovery.0 (2835) Discovery finished
        2023-09-27 16:50:31.818 - debug: discovery.0 (2835) Browse finished
        Laut Log scheint er auch etwas zu finden, aber der Adapter wird mir nicht angezeigt.
          pdbjjens @ChrisChros last edited by
          @chrischros said in Test Adapter MyVBus v0.2.x Latest:
          Danke für das log; Deine Beobachtung ist richtig. Offenbar verläuft der Test nicht erfolgreich. Um darüber mehr zu erfahren, müsste ich das debug im Detectormodul aktivieren. Das geht aber leider nur durch eine Änderung in den Detektormodulen myvbus.js und resol.js (const debug = true;). Wärst Du bereit, eine entsprechend modifizierte Version des discovery adapters von gitHub zu installieren? Dann würde ich sie demnächst bereitstellen.
          Noch eine Frage: welches Resol-Gerät hast Du für den LAN-Anschluss?
            @pdbjjens ich nutze hier einen vbus/Lan-Adapter um die Werte von meiner Steuerung zu bekommen.
            Bezüglich des Testens kann ich das frühestens am Samstag Abend machen. Wenn das für die i.O. kann ich das gerne die modifizierte Version installieren.
              @chrischros
              Danke für die Info und Deine Bereitschaft zum Testen. Ich melde mich hier, sobald die Testversion bereitsteht.
                pdbjjens @pdbjjens last edited by
                @ChrisChros
                Die Debug Version steht zum Test bereit unter https://github.com/pdbjjens/ioBroker.discovery.git
                  @pdbjjens sagte in Test Adapter MyVBus v0.2.x Latest:
                  Hab nun die Testversion installiert und damit bekomme ich den Resol-Adapter angezeigt.
                  Zusätzlich noch der debug Log:
                  2023-09-29 19:52:36.337 - debug: discovery.0 (26694) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2023-09-29 19:52:36.393 - debug: discovery.0 (26694) Objects client ready ... initialize now
                  2023-09-29 19:52:36.396 - debug: discovery.0 (26694) Objects create System PubSub Client
                  2023-09-29 19:52:36.397 - debug: discovery.0 (26694) Objects create User PubSub Client
                  2023-09-29 19:52:36.436 - debug: discovery.0 (26694) Objects client initialize lua scripts
                  2023-09-29 19:52:36.445 - debug: discovery.0 (26694) Objects connected to redis: 127.0.0.1:9001
                  2023-09-29 19:52:36.477 - debug: discovery.0 (26694) Redis States: Use Redis connection: 127.0.0.1:9000
                  2023-09-29 19:52:36.491 - debug: discovery.0 (26694) States create System PubSub Client
                  2023-09-29 19:52:36.492 - debug: discovery.0 (26694) States create User PubSub Client
                  2023-09-29 19:52:36.559 - debug: discovery.0 (26694) States connected to redis: 127.0.0.1:9000
                  2023-09-29 19:52:36.653 - debug: discovery.0 (26694) Plugin sentry Initialize Plugin (enabled=true)
                  2023-09-29 19:53:41.403 - debug: discovery.0 (26694) Received "listMethods" event
                  2023-09-29 19:53:45.712 - debug: discovery.0 (26694) Received "browse" event
                  2023-09-29 19:53:47.227 - debug: discovery.0 (26694) main.addDevice: ip=XX.XX.XX.X source=RESOL VBus
                  2023-09-29 19:53:47.229 - info: discovery.0 (26694) Done discovering RESOL VBus devices. 1 packages received
                  2023-09-29 19:53:47.231 - info: discovery.0 (26694) Found 2 addresses
                  2023-09-29 19:53:48.166 - debug: discovery.0 (26694) Test vbus XX.XX.XX.X myvbus
                  2023-09-29 19:53:48.168 - debug: discovery.0 (26694) Start detecting VBus device information on XX.XX.XX.X...
                  2023-09-29 19:53:48.169 - debug: discovery.0 (26694) Checking for device information at XX.XX.XX.X:80
                  2023-09-29 19:53:48.182 - debug: discovery.0 (26694) Test vbus XX.XX.XX.X resol
                  2023-09-29 19:53:48.184 - debug: discovery.0 (26694) Start detecting VBus device information on XX.XX.XX.X...
                  2023-09-29 19:53:48.184 - debug: discovery.0 (26694) Checking for device information at XX.XX.XX.X:80
                  2023-09-29 19:53:48.203 - debug: discovery.0 (26694) Device Information of XX.XX.XX.X:80 vendor = "RESOL"
                  product = "VBus/LAN Adapter"
                  serial = "XXX"
                  version = "2.0"
                  build = "rc1-WL-MAR"
                  name = "RESOL-LAN-XXX"
                  features = "vbus"
                  pcbserial = "XXX"
                  2023-09-29 19:53:48.205 - debug: discovery.0 (26694) Parsed Device Information of XX.XX.XX.X {"vendor":"RESOL","product":"VBus/LAN Adapter","serial":"XXX","version":"2.0","build":"rc1-WL-MAR","name":"RESOL-LAN-XXX","features":"vbus","pcbserial":"XXX"}
                  2023-09-29 19:53:48.208 - debug: discovery.0 (26694) Device Information of XX.XX.XX.X:80 vendor = "RESOL"
                  serial = "XXX"
                  version = "2.0"
                  features = "vbus"
                  pcbserial = "XXX"
                  2023-09-29 19:53:48.210 - debug: discovery.0 (26694) Parsed Device Information of XX.XX.XX.X {"vendor":"RESOL","product":"VBus/LAN Adapter","serial":"XXX","version":"2.0","build":"rc1-WL-MAR","name":"RESOL-LAN-XXX","features":"vbus","pcbserial":"XXX"}
                  2023-09-29 19:53:48.210 - debug: discovery.0 (26694) New Device RESOL RESOL-LAN-XXX Type lan found!
                  2023-09-29 19:53:48.211 - debug: discovery.0 (26694) Pushed new VBus device instance on XX.XX.XX.X:80
                  2023-09-29 19:53:48.212 - debug: discovery.0 (26694) Test XX.XX.XX.X resol DETECTED!
                  2023-09-29 19:53:48.219 - debug: discovery.0 (26694) Test once 0.0.0.0 sma-em
                  2023-09-29 19:53:50.227 - debug: discovery.0 (26694) Added suggested adapter: cloud.0
                  2023-09-29 19:53:50.231 - debug: discovery.0 (26694) Added suggested adapter: echarts.0
                  2023-09-29 19:53:50.234 - debug: discovery.0 (26694) Added suggested adapter: iot.0
                  2023-09-29 19:53:50.237 - debug: discovery.0 (26694) Added suggested adapter: iqontrol.0
                  2023-09-29 19:53:50.241 - debug: discovery.0 (26694) Added suggested adapter: jarvis.0
                  2023-09-29 19:53:50.254 - info: discovery.0 (26694) Discovery finished. Found new or modified 6 instances
                  2023-09-29 19:53:50.318 - info: discovery.0 (26694) Discovery finished
                  2023-09-29 19:53:50.320 - debug: discovery.0 (26694) Browse finished
                    @chrischros
                    Super, danke für den Test und das Log. Das hilft mir sehr.
                    Das Problem lag daran, dass der VBUS/Lan Hardware Adapter auf dem http Port (:80) antwortet und nicht auf (:3000). In der Debug-Version habe ich die Abfrage auf Port (:80) ergänzt. Daher wird der ioBroker.resol adapter jetzt gefunden.
                    Hast Du auch probiert, den iobroker.resol adapter über die discovery zu installieren? Gab es dabei irgendwelche Auffälligkeiten (ausser der evtl. notwendigen Passwort-Eingabe)?
                    Weiterhin ist für mich interessant, dass der VBUS/Lan Adapter sich mit product = "VBus/LAN Adapter" identifiziert. Diese Info bräuchte ich auch von anderen VBus-Geräten (DL2,DL3,KM2 usw.) um in der Konfiguration des ioBroker.adapters den Gerätetyp korrekt vorzubelegen.
                    Falls jemand hier mitliest, der ein solches Gerät hat und bereit ist, die Test-Version zu installieren und ein Log zu teilen, wäre das sehr hilfreich für die Verbesserung des discovery-moduls.
                      @chrischros
                      Installieren des Resol-Adapters über discovery scheint zu klappen:
                      resol.0 2023-09-30 15:20:34.787	info	Connection state changed to DISCONNECTED
                      resol.0 2023-09-30 15:20:34.779	info	Connection state changed to CONNECTING
                      resol.0 2023-09-30 15:20:34.777	info	Connection state changed to DISCONNECTED
                      resol.0 2023-09-30 15:20:34.769	info	Connection state changed to CONNECTING
                      resol.0 2023-09-30 15:20:34.768	info	Connection state changed to DISCONNECTED
                      resol.0 2023-09-30 15:20:34.741	info	Connection state changed to CONNECTING
                      resol.0 2023-09-30 15:20:34.740	info	Waiting for Connection...
                      resol.0 2023-09-30 15:20:34.738	info	TCP Connection via LAN to [10.10.20.6:7053] selected
                      resol.0 2023-09-30 15:20:34.703	info	Config seems to be valid for LAN.
                      resol.0 2023-09-30 15:20:34.650	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.resol, node: v18.17.1, js-controller: 5.0.12
                      resol.0 2023-09-30 15:19:58.574	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      resol.0 2023-09-30 15:19:58.568	error	resol.0 already running
                      resol.0 2023-09-30 15:19:47.185	info	Connection state changed to CONNECTING
                      resol.0 2023-09-30 15:19:47.184	info	Waiting for Connection...
                      resol.0 2023-09-30 15:19:47.181	info	TCP Connection via LAN to [10.10.20.6:7053] selected
                      resol.0 2023-09-30 15:19:47.133	info	Config seems to be valid for LAN.
                      resol.0 2023-09-30 15:19:47.072	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.resol, node: v18.17.1, js-controller: 5.0.12
                        @chrischros
                        Mir fällt im Log auf, dass der connection state sich dauernd ändert. Wird der Adapterstatus (Quadrat im Instanzen Tab) grün? Werden die Objekte angelegt und aktualisiert?
                        Ich hatte so ein Verhalten schon mal. Nach nochmaliger Eingabe des vbus-passwords und neustart des resol adapters liefen dann beide ioBroker vbus adapter parallel.
                        Möglich ist natürlich auch, dass der VBus/LAN Adapter nur eine Connection zur Zeit akzeptiert. Das könnte man testen indem der myvbus adapter pausiert wird.
                          @pdbjjens ich denke das liegt daran, dass der myvbus noch verbunden war. der vbus/lan Konverter kann wohl nur eine Verbindung aufbauen.
                          Hatte jetzt auch nicht weiter den resol Adapter getestet, da ich mir dem myvbus bisher alles abgedeckt bekomme.
                          P 2 Replies Last reply Reply Quote 0
                            @chrischros
                            O.K. Danke jedenfalls für die Mühe. Und ich freue mich natürlich, dass Dir der myvbus adapter gefällt. Mir reicht er ebenfalls völlig aus, da ich nicht die Absicht habe, Parameter des RESOL-Reglers über ioBroker zu ändern.
                              @chrischros
                              Mittlerweile kann man die aktualisierte Gerätesuche (ioBroker.discovery) in der v4.2.0 aus dem ioBroker latest repo installieren. Es ist nicht mehr nötig, die Debug Version aus meinem privaten repo https://github.com/pdbjjens/ioBroker.discovery.git zu installieren. Ich bitte daher, die Debug Version zu deinstallieren und durch v4.2.0 aus dem ioBroker latest repo zu ersetzen.
                                Ich habe soeben ioBroker.mybus v0.3.0 latest zum Testen freigegeben.
                                Neu: Support für Discovery ab ioBroker.discovery v4.2.0, welches auch ioBroker.resol Discovery unterstützt
                                Neu: Das Configuration GUI wurde auf JSONconfig umgestellt.
                                Mono990 1 Reply Last reply Reply Quote 2
                                • Mono990
                                  Mono990 @pdbjjens last edited by
                                  Hallo
                                  Ich habe mir jetzt auch den KM2 besorgt um meine Daten von der Solarthermie anlage in meiner Vis anzeigen zu lassen.
                                  Dabei habe ich aber leider große Probleme.
                                  Der Adapeter zeigt alles grün an aber es kommen keine Daten rein.
                                  und in der Vis über iframe kann er die seite von Vbus.net nicht anzeigen da die seite Password geschützt ist.
                                  über Http://Login:password@Link klapt es auch nicht
                                  Kann mir jemand helfen das ich das in meiner Vis bekomme?
                                    pdbjjens @Mono990 last edited by
                                    @mono990 said in Test Adapter MyVBus v0.3.x Latest:
                                    Bitte poste hier mal ein Screenshot der Config-Seite der Instanz (Grundeinstellungen) sowie ein Protokoll des Adapter-Starts.
                                    Mono990 1 Reply Last reply Reply Quote 0
                                    • Mono990
                                      Mono990 @pdbjjens last edited by Mono990
                                      @pdbjjens
                                      hier die daten
                                      Mono990 P 2 Replies Last reply Reply Quote 0
                                      • Mono990
                                        Mono990 @Mono990 last edited by
                                        @mono990
                                        wenn ich in den einstellungen auf KM2 /DL2 einstelle kommt das
                                          hier die daten
                                          Das funktioniert nicht, da das Gerät "Seriell-zu-LAN-Gateway" eingestellt ist. Richtig sollte KM2/DL2 sein.
                                            Bitte mal ein screenshot der Config Seite. Außerdem: kommst Du mit dem Browser auf Deine vbus.net-Seite?
                                            resol vbus
                                            27
                                            381
                                            86164
