    4. [gelöst]Fehler bei update Information Tab 1.9.26 nach 2.0.0
      Siggi0904 last edited by Siggi0904
      mir ist gerade beim Update vom Information Tab der komplette IOBroker abgestürzt.
      Im Log finde ich dazu folgenden Fehler:
      2023-09-30 14:21:31.551 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-09-30 14:23:02.043 - info: host.iobroker iobroker upgrade info
      2023-09-30 14:23:05.039 - info: host.iobroker iobroker Update info from @1.9.26 to @2.0.0
      2023-09-30 14:23:06.055 - info: host.iobroker iobroker NPM version: 9.8.1
      2023-09-30 14:23:06.068 - info: host.iobroker iobroker Installing iobroker.info@2.0.0... (System call)
      2023-09-30 14:25:00.037 - info: host.iobroker instance system.adapter.dwd.0 started with pid 884657
      2023-09-30 14:25:05.386 - info: dwd.0 (884657) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
      2023-09-30 14:25:06.650 - info: dwd.0 (884657) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-30 14:25:07.248 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-30 14:25:42.777 - error: host.iobroker uncaught exception: Could not determine controller directory
      2023-09-30 14:25:42.784 - error: host.iobroker Error: Could not determine controller directory
      at getControllerDir (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:1924:11)
      at Object.getInstalledInfo (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:881:22)
      at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/build/main.js:2296:65)
      at processImmediate (node:internal/timers:478:21)
      Kann das jemand bestätigen?
      Nach dem Neustart in ich wieder bei der 1.9.26 und das Update wird wieder angezeigt.
      Thomas Braun mcm1957 Glasfaser 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Siggi0904 last edited by
        @siggi0904 sagte in Fehler bei update Information Tab 1.9.26 nach 2.0.0:
        Zumindest eine Erstinstallation des Adapters läuft bei mir 1A durch:
        2023-09-30 15:00:19.359  - info: info.0 (95915) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v20.8.0, js-controller: 5.0.12
        2023-09-30 15:00:19.656  - info: info.0 (95915) Reading/updating systemdata.
        2023-09-30 15:00:21.127  - info: info.0 (95915) cpu Temp res = {"main":50.634,"cores":[],"max":50.634,"socket":[],"chipset":null}
          Siggi0904 @Thomas Braun last edited by
          @thomas-braun okay. Du stehst aber aber auch in einer viel höheren Node-Version.
          Ich bin auf stable Version 18.18.0
          Vielleicht kann einer das Upgrade durchführen.
          Oder @Bluefox kann vielleicht dazu was sagen.
          Danke.
            Homoran Global Moderator Administrators @Siggi0904 last edited by
            das wäre eher negativ, da noch nicht für ioBroker freigegeben.
            was steht denn im log?
              Siggi0904 @Homoran last edited by
              @homoran siehe oben
                Das sollte aber keine Rolle spielen. Aber ist deine nodejs@18 sauber installiert?
                  @thomas-braun ja, erst mit dem Fixer auf die neue Version letzte Woche gehoben.
                  • mcm1957
                    mcm1957 @Siggi0904 last edited by
                    Also die 2.0.0 ist seit ca 14 Tagen im Latest und haben lt. Statistic ca 2000 User installiert.
                    Einen prinzipiellen schweren Fehler kann man zwar nie ausschließen, dass die Release aber an sich läuft wollte ma sagen dürfen.
                    • mcm1957
                      mcm1957 @Siggi0904 last edited by mcm1957
                      @siggi0904 said in Fehler bei update Information Tab 1.9.26 nach 2.0.0:
                      Also wenn ich mir die Fehlermeldung hier ansehe, dann steht da was davon dass der DWD Adapter terminiert ist.
                      EDIT: Oder doch nicht - das ist ein wenig durchmischte die Info
                      • Glasfaser
                        Glasfaser @Siggi0904 last edited by
                        Im Log finde ich
                        Da fehlt der Rest vom Log !
                        in der Konsole
                        iob upgrade iobroker.info@2.0.0 --debug
                          Okay, ich habe jetzt das Update über den Adapter-Tab gemacht.
                          Vielleicht war es keine gute Idee das Update aus dem Info-Tab heraus zu machen, wenn dieser aktualisiert werden soll.
                          So lief das Update auch durch.
                          1.0k
                          601
