    3. Off Topic
    4. Proxmox
    5. ioBroker in Proxmox nach Doku installiert, aber Fragen!
      crunchip Forum Testing Most Active @Homoran last edited by crunchip
      @homoran sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
      nööö
      oder so 😊
      jetzt chmodden
      sudo chmod 766 -c -R /media/usbstick
      dann
      sudo mount /dev/sdc1 /media/usbstick
      nun backitup testen
        d????????? ? ? ? ? ? . d????????? ? ? ? ? ? .. d????????? ? ? ? ? ? lost+found
        was hast du da noch auf dem Stick?
        drwxr-xr-x 4 root root 4096 29. Sep 13:39 ..
        dachte du hast den neu formatiert
          Homoran Global Moderator Administrators @crunchip last edited by
          @crunchip sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
          nicht dass ich wüsstexwas ich hier tue 😁
          das kam ohne sudo
          mit sudo war es anscheinend richtig
          pi@VM03:~$ sudo mkdir /media/usbstick/backups
          pi@VM03:~$ sudo ls -la /media/usbstick
          insgesamt 28
          drwxrw-rw- 4 root root  4096 30. Sep 20:19 .
          drwxr-xr-x 2 root root  4096 30. Sep 20:19 backups
          drwxrw-rw- 2 root root 16384 30. Sep 17:20 lost+found
          pi@VM03:~$ sudo ls -la /media/usbstick/backups
          insgesamt 8
          drwxr-xr-x 2 root root 4096 30. Sep 20:19 .
          drwxrw-rw- 4 root root 4096 30. Sep 20:19 ..
          pi@VM03:~$
          allerdings findet backitup es nicht
          Started iobroker ...
          [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
          [DEBUG] [iobroker] - host.VM03 105 states saved
          [DEBUG] [iobroker] - host.VM03 144 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-20_22_05_backupiobroker.tar.gz
          This backup can only be restored with js-controller version up from 4.1
          [DEBUG] [iobroker] - done
          [DEBUG] [cifs] - used copy path: /media/usbstick/backups
          [ERROR] [cifs] - Path "/media/usbstick/backups" not found
          [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
            dann eben nochmal!
            kann ich das jetzt aus der VM machen?
            oder nochmal von vorne?
              dann eben nochmal!
              warte mal
              du hast ja jetzt noch /backups mit dran hängen
              mach mal
              sudo umount /dev/sdc1 /media/usbstick
              dann
              sudo mount /dev/sdc1 /media/usbstick/backups
              und jetzt backup testen
              den mount erstellst du aber schon aus deiner VM?
              edit
              passen ja immer noch nicht die Rechte
              Homoran 3 Replies Last reply Reply Quote 0
                ja!
                danke!
                stay tuned
                  Homoran Global Moderator Administrators @crunchip last edited by Homoran
                  @crunchip hmm
                  i@VM03:~$ sudo mount /dev/sdc1 /media/usbstick/backups
                  mount: /media/usbstick/backups: mount point does not exist.
                         dmesg(1) may have more information after failed mount system call.
                  pi@VM03:~$
                  insgesamt 8
                  drwxr-xr-x 2 root root 4096 29. Sep 13:39 .
                  pi@VM03:~$
                  wo ist denn der Unterordber hin?
                    du fragst mich sachen😁
                      hat sich verstellt!
                      nochmal gemacht
                       i@VM03:~$ sudo chmod 766 -c -R /media/usbstick
                      der Modus von '/media/usbstick' wurde von 0755 (rwxr-xr-x) in 0766 (rwxrw-rw-) geändert
                      pi@VM03:~$
                      das war schon mal so
                        @homoran ok, aber wo is der Ordner
                          das existiert auch noch.
                          anschließend
                          qm set 100 -scsi1 /dev/disk/by-id/Deine-Bezeichnung-DesSticks
                          update VM 100: -scsi1 /dev/disk/by-id/Deine-BezeichnungDes-Sticks
                          spuckt uns das in die Suppe.
                          Die Rechte sehen gerade so aus
                          insgesamt 8
                          drwxrw-rw- 2 root root 4096 29. Sep 13:39 .
                          pi@VM03:~$
                            den leg ich jetzt nochmal an
                            und schwupps hat er wieder die falschen Rechte
                            insgesamt 12
                            drwxrw-rw- 3 root root 4096 30. Sep 21:02 .
                            drwxr-xr-x 2 root root 4096 30. Sep 21:02 backups
                            pi@VM03:~$
                            geändert! dann klappt's auch mit dem mount
                            pi@VM03:~$ sudo chmod 766 -c -R /media/usbstick/backups
                            der Modus von '/media/usbstick/backups' wurde von 0755 (rwxr-xr-x) in 0766 (rwxrw-rw-) geändert
                            insgesamt 12
                            drwxrw-rw- 2 root root 4096 30. Sep 21:02 backups
                            pi@VM03:~$ sudo mount /dev/sdc1 /media/usbstick/backups
                            pi@VM03:~$
                              dachte das hast du rausgenommen
                              scsi1
                                ja, weil nachträglich
                                dann sollte backitup nun durchlaufen
                                  hab ich jetzt. überlebt das einen Neustart?
                                    nope
                                    [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-21_09_11_backupiobroker.tar.gz
                                    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                                    [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
                                    unter den mounts ist es drin /dev/sdc1 on /media/usbstick/backups type ext4 (rw,relatime)
                                      eigentlich nicht, soweit ich weiß
                                      gibts doch nicht🤔
                                        gibts doch nicht
                                        hab schon alles durch was mir einfällt.
                                        /media/... oder ohne slash media/...
                                        cifs-utils sind installiert
                                        pi@VM03:~$ apt policy cifs-utils
                                        cifs-utils:
                                          Installiert:           2:7.0-2
                                          Installationskandidat: 2:7.0-2
                                          Versionstabelle:
                                         *** 2:7.0-2 500
                                                500 http://debian.netcologne.de/debian bookworm/main amd64 Packages
                                                100 /var/lib/dpkg/status
                                        pi@VM03:~$
                                          @homoran komisch
                                          einzige was bei mir anders ist, ich hab nicht zusätzlich noch einen Unterordner angelegt
                                          ich hab
                                          mkdir /media/ext_usb
                                          mount /dev/sdb1 /media/ext_usb
                                          und meine Backups liegen in ext_usb
                                          Pfadangabe in der Instanz
                                          /media/ext_usb
                                          allerdings grad noch mal nach den Rechten gesehen, ich hab 777 vergeben
                                          hatte das ja heute mittag getestet und soeben nochmal gegengeprüft
                                          mario@IoBroker:~$ sudo ls -la /media/ext_usb
                                          insgesamt 219888
                                          drwxrwxrwx 3 root     root          4096 30. Sep 21:25 .
                                          drwxr-xr-x 4 root     root          4096 30. Sep 14:14 ..
                                          -rwxrwxrwx 1 root     root       2502737 30. Sep 14:23 historyDB_2023_09_30-14_23_06_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker   2518880 30. Sep 21:25 historyDB_2023_09_30-21_24_57_backupiobroker.tar.gz
                                          -rwxrwxrwx 1 root     root     108928731 30. Sep 14:23 iobroker_2023_09_30-14_22_27_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 108932088 30. Sep 21:25 iobroker_2023_09_30-21_24_21_backupiobroker.tar.gz
                                          -rwxrwxrwx 1 root     root        121703 30. Sep 14:23 jarvis.0_2023_09_30-14_23_13_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker    121703 30. Sep 21:25 jarvis.0_2023_09_30-21_25_01_backupiobroker.tar.gz
                                          -rwxrwxrwx 1 root     root        988421 30. Sep 14:23 javascripts_2023_09_30-14_23_13_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker    988418 30. Sep 21:25 javascripts_2023_09_30-21_25_02_backupiobroker.tar.gz
                                          drwxrwxrwx 2 root     root         16384 30. Sep 14:05 lost+found
                                          -rwxrwxrwx 1 root     root          9152 30. Sep 14:23 zigbee.0_2023_09_30-14_23_12_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker      9152 30. Sep 21:25 zigbee.0_2023_09_30-21_25_01_backupiobroker.tar.gz
                                          heut mittag als root(warum auch immer) und jetzt als User iobroker
                                            @crunchip mir ist gerade etwas aufgefallen
                                            das laufwerk existiert noch, hat allerdings jetzt 100GB
                                            wo immer das jetzt her kommt
                                            es ist der in der pve gemountete erste Versuch gewesen.
                                            der mount ist in der pve fstab auskommentiert und ich hab mehrfach rebootet
                                            mit 777 hab ich auch schon spielen wollen, jetzt wollte ich es umsetzen
                                            pi@VM03:~$ sudo chmod 777 -c -R /media/usbstick/backups
                                            [sudo] Passwort für pi:
                                            der Modus von '/media/usbstick/backups' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
                                            der Modus von '/media/usbstick/backups/backups' wurde von 0755 (rwxr-xr-x) in 0777 (rwxrwxrwx) geändert
                                            der Modus von '/media/usbstick/backups/lost+found' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
                                            insgesamt 12
                                            drwxrwxrwx 4 root root 4096 30. Sep 20:19 backups
                                            pi@VM03:~$
                                            Obwohl er sagt, dass er es ändert ist es nicht so
                                            crunchip ? 5 Replies Last reply Reply Quote 0
                                            1.0k
                                            81.1k
                                            22172
