    3. Off Topic
    4. Proxmox
    5. ioBroker in Proxmox nach Doku installiert, aber Fragen!
      crunchip Forum Testing Most Active @Homoran last edited by crunchip
      @homoran sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
      d????????? ? ? ? ? ? . d????????? ? ? ? ? ? .. d????????? ? ? ? ? ? lost+found
      was hast du da noch auf dem Stick?
      drwxr-xr-x 4 root root 4096 29. Sep 13:39 ..
      dachte du hast den neu formatiert
        Homoran Global Moderator Administrators @crunchip last edited by
        @crunchip sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
        nicht dass ich wüsstexwas ich hier tue 😁
        das kam ohne sudo
        mit sudo war es anscheinend richtig
        pi@VM03:~$ sudo mkdir /media/usbstick/backups
        pi@VM03:~$ sudo ls -la /media/usbstick
        insgesamt 28
        drwxrw-rw- 4 root root  4096 30. Sep 20:19 .
        drwxr-xr-x 2 root root  4096 30. Sep 20:19 backups
        drwxrw-rw- 2 root root 16384 30. Sep 17:20 lost+found
        pi@VM03:~$ sudo ls -la /media/usbstick/backups
        insgesamt 8
        drwxr-xr-x 2 root root 4096 30. Sep 20:19 .
        drwxrw-rw- 4 root root 4096 30. Sep 20:19 ..
        pi@VM03:~$
        allerdings findet backitup es nicht
        Started iobroker ...
        [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.VM03 105 states saved
        [DEBUG] [iobroker] - host.VM03 144 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-20_22_05_backupiobroker.tar.gz
        This backup can only be restored with js-controller version up from 4.1
        [DEBUG] [iobroker] - done
        [DEBUG] [cifs] - used copy path: /media/usbstick/backups
        [ERROR] [cifs] - Path "/media/usbstick/backups" not found
        [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
          dann eben nochmal!
          kann ich das jetzt aus der VM machen?
          oder nochmal von vorne?
            dann eben nochmal!
            warte mal
            du hast ja jetzt noch /backups mit dran hängen
            mach mal
            sudo umount /dev/sdc1 /media/usbstick
            dann
            sudo mount /dev/sdc1 /media/usbstick/backups
            und jetzt backup testen
            den mount erstellst du aber schon aus deiner VM?
            edit
            passen ja immer noch nicht die Rechte
            Homoran 3 Replies Last reply Reply Quote 0
              ja!
              danke!
              stay tuned
                Homoran Global Moderator Administrators @crunchip last edited by Homoran
                @crunchip hmm
                i@VM03:~$ sudo mount /dev/sdc1 /media/usbstick/backups
                mount: /media/usbstick/backups: mount point does not exist.
                       dmesg(1) may have more information after failed mount system call.
                pi@VM03:~$
                insgesamt 8
                drwxr-xr-x 2 root root 4096 29. Sep 13:39 .
                pi@VM03:~$
                wo ist denn der Unterordber hin?
                  du fragst mich sachen😁
                    hat sich verstellt!
                    nochmal gemacht
                     i@VM03:~$ sudo chmod 766 -c -R /media/usbstick
                    der Modus von '/media/usbstick' wurde von 0755 (rwxr-xr-x) in 0766 (rwxrw-rw-) geändert
                    pi@VM03:~$
                    das war schon mal so
                      @homoran ok, aber wo is der Ordner
                        das existiert auch noch.
                        anschließend
                        qm set 100 -scsi1 /dev/disk/by-id/Deine-Bezeichnung-DesSticks
                        update VM 100: -scsi1 /dev/disk/by-id/Deine-BezeichnungDes-Sticks
                        spuckt uns das in die Suppe.
                        Die Rechte sehen gerade so aus
                        insgesamt 8
                        drwxrw-rw- 2 root root 4096 29. Sep 13:39 .
                        pi@VM03:~$
                          den leg ich jetzt nochmal an
                          und schwupps hat er wieder die falschen Rechte
                          insgesamt 12
                          drwxrw-rw- 3 root root 4096 30. Sep 21:02 .
                          drwxr-xr-x 2 root root 4096 30. Sep 21:02 backups
                          pi@VM03:~$
                          geändert! dann klappt's auch mit dem mount
                          pi@VM03:~$ sudo chmod 766 -c -R /media/usbstick/backups
                          der Modus von '/media/usbstick/backups' wurde von 0755 (rwxr-xr-x) in 0766 (rwxrw-rw-) geändert
                          insgesamt 12
                          drwxrw-rw- 2 root root 4096 30. Sep 21:02 backups
                          pi@VM03:~$ sudo mount /dev/sdc1 /media/usbstick/backups
                          pi@VM03:~$
                            dachte das hast du rausgenommen
                            scsi1
                              ja, weil nachträglich
                              dann sollte backitup nun durchlaufen
                                hab ich jetzt. überlebt das einen Neustart?
                                  nope
                                  [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-21_09_11_backupiobroker.tar.gz
                                  [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                                  [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
                                  unter den mounts ist es drin /dev/sdc1 on /media/usbstick/backups type ext4 (rw,relatime)
                                    eigentlich nicht, soweit ich weiß
                                    gibts doch nicht🤔
                                      gibts doch nicht
                                      hab schon alles durch was mir einfällt.
                                      /media/... oder ohne slash media/...
                                      cifs-utils sind installiert
                                      pi@VM03:~$ apt policy cifs-utils
                                      cifs-utils:
                                        Installiert:           2:7.0-2
                                        Installationskandidat: 2:7.0-2
                                        Versionstabelle:
                                       *** 2:7.0-2 500
                                              500 http://debian.netcologne.de/debian bookworm/main amd64 Packages
                                              100 /var/lib/dpkg/status
                                      pi@VM03:~$
                                        @homoran komisch
                                        einzige was bei mir anders ist, ich hab nicht zusätzlich noch einen Unterordner angelegt
                                        ich hab
                                        mkdir /media/ext_usb
                                        mount /dev/sdb1 /media/ext_usb
                                        und meine Backups liegen in ext_usb
                                        Pfadangabe in der Instanz
                                        /media/ext_usb
                                        allerdings grad noch mal nach den Rechten gesehen, ich hab 777 vergeben
                                        hatte das ja heute mittag getestet und soeben nochmal gegengeprüft
                                        mario@IoBroker:~$ sudo ls -la /media/ext_usb
                                        insgesamt 219888
                                        drwxrwxrwx 3 root     root          4096 30. Sep 21:25 .
                                        drwxr-xr-x 4 root     root          4096 30. Sep 14:14 ..
                                        -rwxrwxrwx 1 root     root       2502737 30. Sep 14:23 historyDB_2023_09_30-14_23_06_backupiobroker.tar.gz
                                        -rw-r--r-- 1 iobroker iobroker   2518880 30. Sep 21:25 historyDB_2023_09_30-21_24_57_backupiobroker.tar.gz
                                        -rwxrwxrwx 1 root     root     108928731 30. Sep 14:23 iobroker_2023_09_30-14_22_27_backupiobroker.tar.gz
                                        -rw-r--r-- 1 iobroker iobroker 108932088 30. Sep 21:25 iobroker_2023_09_30-21_24_21_backupiobroker.tar.gz
                                        -rwxrwxrwx 1 root     root        121703 30. Sep 14:23 jarvis.0_2023_09_30-14_23_13_backupiobroker.tar.gz
                                        -rw-r--r-- 1 iobroker iobroker    121703 30. Sep 21:25 jarvis.0_2023_09_30-21_25_01_backupiobroker.tar.gz
                                        -rwxrwxrwx 1 root     root        988421 30. Sep 14:23 javascripts_2023_09_30-14_23_13_backupiobroker.tar.gz
                                        -rw-r--r-- 1 iobroker iobroker    988418 30. Sep 21:25 javascripts_2023_09_30-21_25_02_backupiobroker.tar.gz
                                        drwxrwxrwx 2 root     root         16384 30. Sep 14:05 lost+found
                                        -rwxrwxrwx 1 root     root          9152 30. Sep 14:23 zigbee.0_2023_09_30-14_23_12_backupiobroker.tar.gz
                                        -rw-r--r-- 1 iobroker iobroker      9152 30. Sep 21:25 zigbee.0_2023_09_30-21_25_01_backupiobroker.tar.gz
                                        heut mittag als root(warum auch immer) und jetzt als User iobroker
                                          @crunchip mir ist gerade etwas aufgefallen
                                          das laufwerk existiert noch, hat allerdings jetzt 100GB
                                          wo immer das jetzt her kommt
                                          es ist der in der pve gemountete erste Versuch gewesen.
                                          der mount ist in der pve fstab auskommentiert und ich hab mehrfach rebootet
                                          mit 777 hab ich auch schon spielen wollen, jetzt wollte ich es umsetzen
                                          pi@VM03:~$ sudo chmod 777 -c -R /media/usbstick/backups
                                          [sudo] Passwort für pi:
                                          der Modus von '/media/usbstick/backups' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
                                          der Modus von '/media/usbstick/backups/backups' wurde von 0755 (rwxr-xr-x) in 0777 (rwxrwxrwx) geändert
                                          der Modus von '/media/usbstick/backups/lost+found' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
                                          insgesamt 12
                                          drwxrwxrwx 4 root root 4096 30. Sep 20:19 backups
                                          pi@VM03:~$
                                          Obwohl er sagt, dass er es ändert ist es nicht so
                                          crunchip ? 5 Replies Last reply Reply Quote 0
                                            du hast schon nen sehr seltsamen Stick, halb eingesteckt 32GB, drin 64 und jetzt hast ihn wohl zu weit rein geschoben???😂 😂
                                            aber als storage zugefügt, das musst du auch löschen
                                            81.1k
                                            22166
