    3. Off Topic
    4. Proxmox
    5. ioBroker in Proxmox nach Doku installiert, aber Fragen!
      Homoran Global Moderator Administrators @crunchip last edited by
      @crunchip sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
      @homoran sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
      d????????? ? ? ? ? ? . d????????? ? ? ? ? ? .. d????????? ? ? ? ? ? lost+found
      was hast du da noch auf dem Stick?
      nicht dass ich wüsstexwas ich hier tue 😁
      das kam ohne sudo
      mit sudo war es anscheinend richtig
      pi@VM03:~$ sudo mkdir /media/usbstick/backups
      pi@VM03:~$ sudo ls -la /media/usbstick
      insgesamt 28
      drwxrw-rw- 4 root root  4096 30. Sep 20:19 .
      drwxr-xr-x 4 root root  4096 29. Sep 13:39 ..
      drwxr-xr-x 2 root root  4096 30. Sep 20:19 backups
      drwxrw-rw- 2 root root 16384 30. Sep 17:20 lost+found
      pi@VM03:~$ sudo ls -la /media/usbstick/backups
      insgesamt 8
      drwxr-xr-x 2 root root 4096 30. Sep 20:19 .
      drwxrw-rw- 4 root root 4096 30. Sep 20:19 ..
      pi@VM03:~$
      allerdings findet backitup es nicht
      Started iobroker ...
      [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.VM03 105 states saved
      [DEBUG] [iobroker] - host.VM03 144 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-20_22_05_backupiobroker.tar.gz
      This backup can only be restored with js-controller version up from 4.1
      [DEBUG] [iobroker] - done
      [DEBUG] [cifs] - used copy path: /media/usbstick/backups
      [ERROR] [cifs] - Path "/media/usbstick/backups" not found
      [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
        dachte du hast den neu formatiert
        dann eben nochmal!
        kann ich das jetzt aus der VM machen?
        oder nochmal von vorne?
          crunchip Forum Testing Most Active @Homoran last edited by crunchip
          dann eben nochmal!
          warte mal
          du hast ja jetzt noch /backups mit dran hängen
          mach mal
          sudo umount /dev/sdc1 /media/usbstick
          dann
          sudo mount /dev/sdc1 /media/usbstick/backups
          und jetzt backup testen
          den mount erstellst du aber schon aus deiner VM?
          edit
          passen ja immer noch nicht die Rechte
          Homoran 3 Replies Last reply Reply Quote 0
            ja!
            danke!
            stay tuned
              Homoran Global Moderator Administrators @crunchip last edited by Homoran
              @crunchip hmm
              i@VM03:~$ sudo mount /dev/sdc1 /media/usbstick/backups
              mount: /media/usbstick/backups: mount point does not exist.
                     dmesg(1) may have more information after failed mount system call.
              pi@VM03:~$
              insgesamt 8
              drwxr-xr-x 2 root root 4096 29. Sep 13:39 .
              pi@VM03:~$
              wo ist denn der Unterordber hin?
                du fragst mich sachen😁
                  hat sich verstellt!
                  nochmal gemacht
                   i@VM03:~$ sudo chmod 766 -c -R /media/usbstick
                  der Modus von '/media/usbstick' wurde von 0755 (rwxr-xr-x) in 0766 (rwxrw-rw-) geändert
                  pi@VM03:~$
                  das war schon mal so
                    @homoran ok, aber wo is der Ordner
                      das existiert auch noch.
                      anschließend
                      qm set 100 -scsi1 /dev/disk/by-id/Deine-Bezeichnung-DesSticks
                      update VM 100: -scsi1 /dev/disk/by-id/Deine-BezeichnungDes-Sticks
                      spuckt uns das in die Suppe.
                      Die Rechte sehen gerade so aus
                      insgesamt 8
                      drwxrw-rw- 2 root root 4096 29. Sep 13:39 .
                      pi@VM03:~$
                        den leg ich jetzt nochmal an
                        und schwupps hat er wieder die falschen Rechte
                        insgesamt 12
                        drwxrw-rw- 3 root root 4096 30. Sep 21:02 .
                        drwxr-xr-x 2 root root 4096 30. Sep 21:02 backups
                        pi@VM03:~$
                        geändert! dann klappt's auch mit dem mount
                        pi@VM03:~$ sudo chmod 766 -c -R /media/usbstick/backups
                        der Modus von '/media/usbstick/backups' wurde von 0755 (rwxr-xr-x) in 0766 (rwxrw-rw-) geändert
                        insgesamt 12
                        drwxrw-rw- 2 root root 4096 30. Sep 21:02 backups
                        pi@VM03:~$ sudo mount /dev/sdc1 /media/usbstick/backups
                        pi@VM03:~$
                          dachte das hast du rausgenommen
                          scsi1
                            ja, weil nachträglich
                            dann sollte backitup nun durchlaufen
                              hab ich jetzt. überlebt das einen Neustart?
                                nope
                                [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-21_09_11_backupiobroker.tar.gz
                                [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                                [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
                                unter den mounts ist es drin /dev/sdc1 on /media/usbstick/backups type ext4 (rw,relatime)
                                  eigentlich nicht, soweit ich weiß
                                  gibts doch nicht🤔
                                    gibts doch nicht
                                    hab schon alles durch was mir einfällt.
                                    /media/... oder ohne slash media/...
                                    cifs-utils sind installiert
                                    pi@VM03:~$ apt policy cifs-utils
                                    cifs-utils:
                                      Installiert:           2:7.0-2
                                      Installationskandidat: 2:7.0-2
                                      Versionstabelle:
                                     *** 2:7.0-2 500
                                            500 http://debian.netcologne.de/debian bookworm/main amd64 Packages
                                            100 /var/lib/dpkg/status
                                    pi@VM03:~$
                                      @homoran komisch
                                      einzige was bei mir anders ist, ich hab nicht zusätzlich noch einen Unterordner angelegt
                                      ich hab
                                      mkdir /media/ext_usb
                                      mount /dev/sdb1 /media/ext_usb
                                      und meine Backups liegen in ext_usb
                                      Pfadangabe in der Instanz
                                      /media/ext_usb
                                      allerdings grad noch mal nach den Rechten gesehen, ich hab 777 vergeben
                                      hatte das ja heute mittag getestet und soeben nochmal gegengeprüft
                                      mario@IoBroker:~$ sudo ls -la /media/ext_usb
                                      insgesamt 219888
                                      drwxrwxrwx 3 root     root          4096 30. Sep 21:25 .
                                      drwxr-xr-x 4 root     root          4096 30. Sep 14:14 ..
                                      -rwxrwxrwx 1 root     root       2502737 30. Sep 14:23 historyDB_2023_09_30-14_23_06_backupiobroker.tar.gz
                                      -rw-r--r-- 1 iobroker iobroker   2518880 30. Sep 21:25 historyDB_2023_09_30-21_24_57_backupiobroker.tar.gz
                                      -rwxrwxrwx 1 root     root     108928731 30. Sep 14:23 iobroker_2023_09_30-14_22_27_backupiobroker.tar.gz
                                      -rw-r--r-- 1 iobroker iobroker 108932088 30. Sep 21:25 iobroker_2023_09_30-21_24_21_backupiobroker.tar.gz
                                      -rwxrwxrwx 1 root     root        121703 30. Sep 14:23 jarvis.0_2023_09_30-14_23_13_backupiobroker.tar.gz
                                      -rw-r--r-- 1 iobroker iobroker    121703 30. Sep 21:25 jarvis.0_2023_09_30-21_25_01_backupiobroker.tar.gz
                                      -rwxrwxrwx 1 root     root        988421 30. Sep 14:23 javascripts_2023_09_30-14_23_13_backupiobroker.tar.gz
                                      -rw-r--r-- 1 iobroker iobroker    988418 30. Sep 21:25 javascripts_2023_09_30-21_25_02_backupiobroker.tar.gz
                                      drwxrwxrwx 2 root     root         16384 30. Sep 14:05 lost+found
                                      -rwxrwxrwx 1 root     root          9152 30. Sep 14:23 zigbee.0_2023_09_30-14_23_12_backupiobroker.tar.gz
                                      -rw-r--r-- 1 iobroker iobroker      9152 30. Sep 21:25 zigbee.0_2023_09_30-21_25_01_backupiobroker.tar.gz
                                      heut mittag als root(warum auch immer) und jetzt als User iobroker
                                        @crunchip mir ist gerade etwas aufgefallen
                                        das laufwerk existiert noch, hat allerdings jetzt 100GB
                                        wo immer das jetzt her kommt
                                        es ist der in der pve gemountete erste Versuch gewesen.
                                        der mount ist in der pve fstab auskommentiert und ich hab mehrfach rebootet
                                        mit 777 hab ich auch schon spielen wollen, jetzt wollte ich es umsetzen
                                        pi@VM03:~$ sudo chmod 777 -c -R /media/usbstick/backups
                                        [sudo] Passwort für pi:
                                        der Modus von '/media/usbstick/backups' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
                                        der Modus von '/media/usbstick/backups/backups' wurde von 0755 (rwxr-xr-x) in 0777 (rwxrwxrwx) geändert
                                        der Modus von '/media/usbstick/backups/lost+found' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
                                        insgesamt 12
                                        drwxrwxrwx 4 root root 4096 30. Sep 20:19 backups
                                        pi@VM03:~$
                                        Obwohl er sagt, dass er es ändert ist es nicht so
                                        crunchip ? 5 Replies Last reply Reply Quote 0
                                          du hast schon nen sehr seltsamen Stick, halb eingesteckt 32GB, drin 64 und jetzt hast ihn wohl zu weit rein geschoben???😂 😂
                                          aber als storage zugefügt, das musst du auch löschen
                                            ist es doch
                                            drwxrwxrwx
                                            81.1k
                                            22172
