    3. Off Topic
    4. Proxmox
    5. ioBroker in Proxmox nach Doku installiert, aber Fragen!
      crunchip Forum Testing Most Active @Homoran last edited by crunchip
      @homoran sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
      und schwupps hat er wieder die falschen Rechte
      ja, weil nachträglich
      geändert! dann klappt's auch mit dem mount
      dann sollte backitup nun durchlaufen
        Homoran Global Moderator Administrators @crunchip last edited by
        @crunchip sagte in ioBroker in Proxmox nach Doku installiert, aber Fragen!:
        dachte das hast du rausgenommen
        hab ich jetzt. überlebt das einen Neustart?
          Homoran Global Moderator Administrators @crunchip last edited by Homoran
          nope
          Started iobroker ...
          [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
          [DEBUG] [iobroker] - host.VM03 105 states saved
          [DEBUG] [iobroker] - host.VM03 144 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_30-21_09_11_backupiobroker.tar.gz
          [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
          [DEBUG] [iobroker] - done
          [DEBUG] [cifs] - used copy path: /media/usbstick/backups
          [ERROR] [cifs] - Path "/media/usbstick/backups" not found
          [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/media/usbstick/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
          unter den mounts ist es drin /dev/sdc1 on /media/usbstick/backups type ext4 (rw,relatime)
            eigentlich nicht, soweit ich weiß
            gibts doch nicht🤔
              gibts doch nicht
              hab schon alles durch was mir einfällt.
              /media/... oder ohne slash media/...
              cifs-utils sind installiert
              pi@VM03:~$ apt policy cifs-utils
              cifs-utils:
                Installiert:           2:7.0-2
                Installationskandidat: 2:7.0-2
                Versionstabelle:
               *** 2:7.0-2 500
                      500 http://debian.netcologne.de/debian bookworm/main amd64 Packages
                      100 /var/lib/dpkg/status
              pi@VM03:~$
                @homoran komisch
                einzige was bei mir anders ist, ich hab nicht zusätzlich noch einen Unterordner angelegt
                ich hab
                mkdir /media/ext_usb
                mount /dev/sdb1 /media/ext_usb
                und meine Backups liegen in ext_usb
                Pfadangabe in der Instanz
                /media/ext_usb
                allerdings grad noch mal nach den Rechten gesehen, ich hab 777 vergeben
                hatte das ja heute mittag getestet und soeben nochmal gegengeprüft
                mario@IoBroker:~$ sudo ls -la /media/ext_usb
                insgesamt 219888
                drwxrwxrwx 3 root     root          4096 30. Sep 21:25 .
                drwxr-xr-x 4 root     root          4096 30. Sep 14:14 ..
                -rwxrwxrwx 1 root     root       2502737 30. Sep 14:23 historyDB_2023_09_30-14_23_06_backupiobroker.tar.gz
                -rw-r--r-- 1 iobroker iobroker   2518880 30. Sep 21:25 historyDB_2023_09_30-21_24_57_backupiobroker.tar.gz
                -rwxrwxrwx 1 root     root     108928731 30. Sep 14:23 iobroker_2023_09_30-14_22_27_backupiobroker.tar.gz
                -rw-r--r-- 1 iobroker iobroker 108932088 30. Sep 21:25 iobroker_2023_09_30-21_24_21_backupiobroker.tar.gz
                -rwxrwxrwx 1 root     root        121703 30. Sep 14:23 jarvis.0_2023_09_30-14_23_13_backupiobroker.tar.gz
                -rw-r--r-- 1 iobroker iobroker    121703 30. Sep 21:25 jarvis.0_2023_09_30-21_25_01_backupiobroker.tar.gz
                -rwxrwxrwx 1 root     root        988421 30. Sep 14:23 javascripts_2023_09_30-14_23_13_backupiobroker.tar.gz
                -rw-r--r-- 1 iobroker iobroker    988418 30. Sep 21:25 javascripts_2023_09_30-21_25_02_backupiobroker.tar.gz
                drwxrwxrwx 2 root     root         16384 30. Sep 14:05 lost+found
                -rwxrwxrwx 1 root     root          9152 30. Sep 14:23 zigbee.0_2023_09_30-14_23_12_backupiobroker.tar.gz
                -rw-r--r-- 1 iobroker iobroker      9152 30. Sep 21:25 zigbee.0_2023_09_30-21_25_01_backupiobroker.tar.gz
                heut mittag als root(warum auch immer) und jetzt als User iobroker
                  @crunchip mir ist gerade etwas aufgefallen
                  das laufwerk existiert noch, hat allerdings jetzt 100GB
                  wo immer das jetzt her kommt
                  es ist der in der pve gemountete erste Versuch gewesen.
                  der mount ist in der pve fstab auskommentiert und ich hab mehrfach rebootet
                  mit 777 hab ich auch schon spielen wollen, jetzt wollte ich es umsetzen
                  pi@VM03:~$ sudo chmod 777 -c -R /media/usbstick/backups
                  [sudo] Passwort für pi:
                  der Modus von '/media/usbstick/backups' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
                  der Modus von '/media/usbstick/backups/backups' wurde von 0755 (rwxr-xr-x) in 0777 (rwxrwxrwx) geändert
                  der Modus von '/media/usbstick/backups/lost+found' wurde von 0766 (rwxrw-rw-) in 0777 (rwxrwxrwx) geändert
                  pi@VM03:~$ sudo ls -la /media/usbstick
                  insgesamt 12
                  drwxrw-rw- 3 root root 4096 30. Sep 21:02 .
                  drwxr-xr-x 4 root root 4096 29. Sep 13:39 ..
                  drwxrwxrwx 4 root root 4096 30. Sep 20:19 backups
                  pi@VM03:~$
                  Obwohl er sagt, dass er es ändert ist es nicht so
                  crunchip ? 5 Replies Last reply Reply Quote 0
                    du hast schon nen sehr seltsamen Stick, halb eingesteckt 32GB, drin 64 und jetzt hast ihn wohl zu weit rein geschoben???😂 😂
                    aber als storage zugefügt, das musst du auch löschen
                      ist es doch
                      drwxrwxrwx
                          wott??
                          pi@VM03:~$ sudo ls -la /media/usbstick/backups
                          insgesamt 1264
                          drwxrwxrwx 4 root     root        4096 30. Sep 21:47 .
                          drwxrwxrwx 3 root     root        4096 30. Sep 21:02 ..
                          drwxrwxrwx 2 root     root        4096 30. Sep 20:19 backups
                          -rw-r--r-- 1 iobroker iobroker 1265480 30. Sep 21:47 iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz
                          drwxrwxrwx 2 root     root       16384 30. Sep 17:20 lost+found
                          pi@VM03:~$
                          2023-09-30 21:47:17.343	debug	[iobroker/cifs] Copy iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz...
                          backitup.0
                          	2023-09-30 21:47:17.343	debug	[iobroker/cifs] used copy path: /media/usbstick/backups
                          das biege ich auch noch hin
                            du hast noch einen unterordner angelegt aber chmod direkt auf /media/usbstick/backups gelegt
                            korrekt wäre doch
                            -R steht doch für rekursiv ... alle folgenden Unterordner
                              @crunchip danke, mach ich
                              aufgeräumt ist
                              pi@VM03:~$ rm /media/usbstick/backups/backups
                              rm: das Entfernen von '/media/usbstick/backups/backups' ist nicht möglich: Ist ein Verzeichnis
                              pi@VM03:~$ rm -r /media/usbstick/backups/backups
                              pi@VM03:~$
                              pi@VM03:~$
                              pi@VM03:~$
                              pi@VM03:~$
                              pi@VM03:~$
                              insgesamt 1260
                              drwxrwxrwx 3 root     root        4096 30. Sep 21:53 .
                              pi@VM03:~$
                              was muss jetzt in die fstab der VM?
                              dann reboote ich mal
                                drwxrwxrwx 4 root root 4096 30. Sep 21:47 . drwxrwxrwx 3 root root 4096 30. Sep 21:02 .. drwxrwxrwx 2 root root 4096 30. Sep 20:19 backups -rw-r--r-- 1 iobroker iobroker 1265480 30. Sep 21:47 iobroker_2023_09_30-21_47_13_backupiobroker.tar.gz drwxrwxrwx 2 root root 16384 30. Sep 17:20 lost+found
                                das passt doch jetzt, auch die Rechte, musst nur den einen Unterordner backup löschen
                                  hab ich schon
                                    die uuid deines Sticks auslesen
                                    und dann so wie auch in der Doku, in deinem Fall aber in der VM, nicht vom Host aus
                                    UUID=BEZEI-CHNUNG /media/usbstick/backups ext4 defaults 0 0
                                    du kannst vorher den Stick aushängen, dann den Eintrag tätigen, anschließend mit mount -a wieder einhängen und prüfen ob alles ok
                                    sollte alles passen, kannst du rebooten
                                      so?
                                      pi@VM03:~$ sudo blkid
                                      /dev/sr0: BLOCK_SIZE="2048" UUID="2023-07-22-10-52-30-00" LABEL="Debian 12.1.0 amd64 n" TYPE="iso9660" PTUUID="3db87b5e" PTTYPE="dos"
                                      /dev/sdc1: UUID="60a9d942-0ebd-473c-8d77-b15e15a21df7" BLOCK_SIZE="4096" TYPE="ext4"
                                      /dev/sda5: UUID="fc17aa9c-8f67-44c1-a81e-596eaf6b932e" TYPE="swap" PARTUUID="f97472f3-05"
                                      /dev/sda1: UUID="8c135bc3-7ee2-40fa-b164-d21aab2f5661" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f97472f3-01"
                                      pi@VM03:~$
                                      will meine kurze ID wiederhaben
                                        Obi oder Hornbach😂 kannst ja nochmal von vorn und mit vfat probieren😜
                                          @crunchip danke, ich trau mich dann....
                                            @homoran die Spannung steigt🤔
                                            81.1k
                                            22166
