    4. Node-Red
    5. Node Red Tasmota und Switsch
      JosefThal @JosefThal last edited by
      @josefthal [
      "id": "f884ce11d9d7f084",
      "type": "tab",
      "label": "Flow 7",
      "disabled": false,
      "info": "",
      "env": []
      "id": "50abe2e8af7541c0",
      "type": "debug",
      "z": "f884ce11d9d7f084",
      "name": "debug 45",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "complete": "false",
      "statusVal": "",
      "statusType": "auto",
      "x": 940,
      "y": 400,
      "wires": []
      "id": "2ae715d42c837120",
      "type": "debug",
      "name": "debug 46",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 660,
      "y": 300,
      "wires": []
      "id": "1d78f8b2a54f18bd",
      "type": "debug",
      "name": "debug 47",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 760,
      "y": 200,
      "wires": []
      "id": "4b419759b1939781",
      "type": "mqtt in",
      "name": "",
      "topic": "tele/Tasmota_test2/SENSOR",
      "qos": "0",
      "datatype": "json",
      "broker": "b84a725bf6dd8e6b",
      "nl": false,
      "rap": true,
      "rh": 0,
      "inputs": 0,
      "x": 160,
      "y": 200,
      "wires": [
      "1d78f8b2a54f18bd",
      "5767de948061f591",
      "4fe0cb071a28c291"
      "id": "3f94cadf66b7c243",
      "type": "debug",
      "name": "debug 48",
      "active": false,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 820,
      "y": 740,
      "wires": []
      "id": "85752b032892a0bf",
      "type": "mqtt in",
      "name": "",
      "topic": "tele/Tasmota_test2/SENSOR ",
      "qos": "0",
      "datatype": "utf8",
      "nl": false,
      "rap": true,
      "rh": 0,
      "inputs": 0,
      "x": 200,
      "y": 780,
      "wires": [
      "3f94cadf66b7c243",
      "a4c8f372f7e5208d"
      "id": "a4c8f372f7e5208d",
      "type": "change",
      "name": "Strom Filter",
      "rules": [
      "t": "set",
      "p": "payload.Switch1",
      "pt": "msg",
      "to": "on",
      "tot": "str"
      "action": "",
      "property": "",
      "from": "",
      "to": "",
      "reg": false,
      "x": 690,
      "y": 800,
      "wires": [
      "62298753547437f4"
      "id": "62298753547437f4",
      "type": "debug",
      "name": "debug 49",
      "active": false,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 940,
      "y": 820,
      "wires": []
      "id": "5d69362e4fbdf5e3",
      "type": "mqtt out",
      "name": "",
      "topic": "cmnd/Tasmota_test2/POWER1",
      "qos": "",
      "retain": "",
      "respTopic": "",
      "contentType": "",
      "userProps": "",
      "correl": "",
      "expiry": "",
      "x": 630,
      "y": 560,
      "wires": []
      "id": "3407d481c1a27b47",
      "type": "Tasmota Sensor",
      "broker": "7a7b311bf649aa87",
      "device": "Tasmota_test2",
      "name": "",
      "outputs": 1,
      "uidisabler": false,
      "fullTopic": "",
      "cmndPrefix": "",
      "statPrefix": "",
      "telePrefix": "",
      "qos": 1,
      "retain": false,
      "rules": [],
      "outputTopic": "",
      "x": 220,
      "y": 80,
      "wires": [
      "dc357bf80dd84722"
      "id": "4a52a2c387ec9267",
      "type": "debug",
      "name": "debug 50",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 940,
      "y": 460,
      "wires": []
      "id": "dc357bf80dd84722",
      "type": "debug",
      "name": "debug 51",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 420,
      "y": 20,
      "wires": []
      "id": "8edf93019b1dda14",
      "type": "debug",
      "name": "debug 52",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 760,
      "y": 240,
      "wires": []
      "id": "2ae5cbaad2be8669",
      "type": "inject",
      "name": "",
      "props": [
      "p": "payload"
      "p": "topic",
      "vt": "str"
      "repeat": "",
      "crontab": "",
      "once": false,
      "onceDelay": 0.1,
      "topic": "",
      "payload": "off",
      "payloadType": "str",
      "x": 190,
      "y": 580,
      "wires": [
      "5d69362e4fbdf5e3"
      "id": "fe76fb3e70ee4cd1",
      "type": "inject",
      "name": "",
      "props": [
      "p": "payload"
      "p": "topic",
      "vt": "str"
      "repeat": "",
      "crontab": "",
      "once": false,
      "onceDelay": 0.1,
      "topic": "",
      "payload": "on",
      "x": 190,
      "y": 620,
      "wires": [
      "5d69362e4fbdf5e3"
      "id": "5767de948061f591",
      "type": "switch",
      "name": "",
      "property": "payload.Switch1",
      "propertyType": "msg",
      "rules": [
      "t": "eq",
      "v": "on",
      "vt": "str"
      "checkall": "true",
      "repair": false,
      "outputs": 1,
      "x": 450,
      "y": 300,
      "wires": [
      "2ae715d42c837120"
      "id": "970c70446706d958",
      "type": "debug",
      "name": "debug 55",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 660,
      "y": 360,
      "wires": []
      "id": "4fe0cb071a28c291",
      "type": "switch",
      "name": "",
      "rules": [
      "t": "eq",
      "v": "off",
      "vt": "str"
      "checkall": "true",
      "repair": false,
      "outputs": 1,
      "x": 450,
      "y": 360,
      "wires": [
      "970c70446706d958"
      "id": "b84a725bf6dd8e6b",
      "type": "mqtt-broker",
      "name": "CerboGX",
      "broker": "192.168.178.35",
      "port": "1883",
      "clientid": "",
      "autoConnect": true,
      "usetls": false,
      "protocolVersion": "4",
      "keepalive": "60",
      "cleansession": true,
      "birthTopic": "",
      "birthQos": "0",
      "birthPayload": "",
      "birthMsg": {},
      "closeTopic": "",
      "closeQos": "0",
      "closePayload": "",
      "closeMsg": {},
      "willTopic": "",
      "willQos": "0",
      "willPayload": "",
      "willMsg": {},
      "userProps": "",
      "sessionExpiry": ""
      "id": "7a7b311bf649aa87",
      "type": "tasmota-mqtt-broker",
      "name": "",
      "broker": "localhost",
      "port": "1883",
      "clientid": "",
      "usetls": false,
      "keepalive": "60",
      • mickym
        mickym Most Active @JosefThal last edited by mickym
        @josefthal Damit kann man nichts anfangen. Bitte immer in CodeTags einstellen und ggf. mit Spoiler:
        code_text
        Den Code hier direkt einzustellen - ist nicht importierbar - da das vom Browser interpretiert wird
          JosefThal @mickym last edited by
          @mickym ```
          "type": "tab",
          "label": "Flow 7",
          "disabled": false,
          "info": "",
          "env": []
          "type": "debug",
          "name": "debug 45",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 940,
          "y": 400,
          "wires": []
          "type": "debug",
          "name": "debug 46",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 660,
          "y": 300,
          "wires": []
          "type": "debug",
          "name": "debug 47",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 760,
          "y": 200,
          "wires": []
          "type": "mqtt in",
          "name": "",
          "qos": "0",
          "datatype": "json",
          "nl": false,
          "rap": true,
          "rh": 0,
          "inputs": 0,
          "x": 160,
          "y": 200,
          "wires": [
          "1d78f8b2a54f18bd",
          "5767de948061f591",
          "4fe0cb071a28c291"
          "type": "debug",
          "name": "debug 48",
          "active": false,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 820,
          "y": 740,
          "wires": []
          "type": "mqtt in",
          "name": "",
          "qos": "0",
          "datatype": "utf8",
          "nl": false,
          "rap": true,
          "rh": 0,
          "inputs": 0,
          "x": 200,
          "y": 780,
          "wires": [
          "3f94cadf66b7c243",
          "a4c8f372f7e5208d"
          "type": "change",
          "rules": [
          "t": "set",
          "pt": "msg",
          "to": "on",
          "tot": "str"
          "action": "",
          "property": "",
          "from": "",
          "to": "",
          "reg": false,
          "x": 690,
          "y": 800,
          "wires": [
          "62298753547437f4"
          "type": "debug",
          "name": "debug 49",
          "active": false,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 940,
          "y": 820,
          "wires": []
          "type": "mqtt out",
          "name": "",
          "qos": "",
          "retain": "",
          "respTopic": "",
          "contentType": "",
          "userProps": "",
          "correl": "",
          "expiry": "",
          "x": 630,
          "y": 560,
          "wires": []
          "name": "",
          "outputs": 1,
          "fullTopic": "",
          "cmndPrefix": "",
          "statPrefix": "",
          "telePrefix": "",
          "qos": 1,
          "retain": false,
          "rules": [],
          "outputTopic": "",
          "x": 220,
          "y": 80,
          "wires": [
          "dc357bf80dd84722"
          "type": "debug",
          "name": "debug 50",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 940,
          "y": 460,
          "wires": []
          "type": "debug",
          "name": "debug 51",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 420,
          "y": 20,
          "wires": []
          "type": "debug",
          "name": "debug 52",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 760,
          "y": 240,
          "wires": []
          "type": "inject",
          "name": "",
          "props": [
          "p": "payload"
          "p": "topic",
          "vt": "str"
          "repeat": "",
          "crontab": "",
          "once": false,
          "onceDelay": 0.1,
          "topic": "",
          "payload": "off",
          "x": 190,
          "y": 580,
          "wires": [
          "5d69362e4fbdf5e3"
          "type": "inject",
          "name": "",
          "props": [
          "p": "payload"
          "p": "topic",
          "vt": "str"
          "repeat": "",
          "crontab": "",
          "once": false,
          "onceDelay": 0.1,
          "topic": "",
          "payload": "on",
          "x": 190,
          "y": 620,
          "wires": [
          "5d69362e4fbdf5e3"
          "type": "switch",
          "name": "",
          "rules": [
          "t": "eq",
          "v": "on",
          "vt": "str"
          "checkall": "true",
          "repair": false,
          "outputs": 1,
          "x": 450,
          "y": 300,
          "wires": [
          "2ae715d42c837120"
          "type": "debug",
          "name": "debug 55",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 660,
          "y": 360,
          "wires": []
          "type": "switch",
          "name": "",
          "rules": [
          "t": "eq",
          "v": "off",
          "vt": "str"
          "checkall": "true",
          "repair": false,
          "outputs": 1,
          "x": 450,
          "y": 360,
          "wires": [
          "970c70446706d958"
          "name": "CerboGX",
          "port": "1883",
          "clientid": "",
          "usetls": false,
          "keepalive": "60",
          "birthTopic": "",
          "birthQos": "0",
          "birthPayload": "",
          "birthMsg": {},
          "closeTopic": "",
          "closeQos": "0",
          "closePayload": "",
          "closeMsg": {},
          "willTopic": "",
          "willQos": "0",
          "willPayload": "",
          "willMsg": {},
          "userProps": "",
          "sessionExpiry": ""
          "name": "",
          "port": "1883",
          "clientid": "",
          "usetls": false,
          "keepalive": "60",
          • mickym
            @josefthal Nein in codetags - die ''' müssen in einer extra Zeile stehen
            code_text
              @mickym flows(3).json
                @josefthal
                hoffe es geht so
                bin einfach zu dof ( ICH )
                • mickym
                  @josefthal Ja geht schon - ich hab Dir aber doch hier einen Vorschlag zum Import eingestellt: https://forum.iobroker.net/post/1053445
                  • mickym
                    mickym Most Active last edited by mickym
                    @josefthal sagte in Node Red Tasmota und Switsch:
                    So zu Deinen Fehler die ich sehe
                    Die Eigenschaft ist richtig, aber Du musst auf Groß-und Kleinschreibung achten. Es kommt - auf der KONSOLE ein "ON" und kein "on".
                    Dann brauchst Du dafür keine 2 switch Nodes - sondern ein mit 2 Ausgängen.
                    Bei der Eingabe ist tasmota nicht case-sensitiv - das heißt wird automatisch verstanden.
                    Aber wie gesagt ich hab Dir einen Vorschlag unten geschickt.
                      @mickym Danke
                      hat ein fehler beim Übertragen gegeben groß und kleinschreibung
                      sensor muß Groß sein SENSOR
                      und dann ging es
                      und ich Spiele und Lesen ca 2 wochen rum
                      und du machst es in 30 S
                      • mickym
                        Mit etwas Übung schaffst Du das auch. 😉
                          @mickym Danke
                            benötige noch mal euer hilfe
                            es geht soweit ,die batterie über 91 % voll schaltet er eine wenn er unter 71 % ist schaltet er aus.
                            wenn ich den taster Starten ( Manuel ) geht es aber wenn die Batterie runter geht ( z.b. 50 % auf 49 % ) schaltet der Timer aus obwohl die zeit nicht abgelaufen ist
                            hab schon versucht eine undglied einzusetzt geht nicht
                                   "id": "e4aa7e9b9fb405d9",
                                   "type": "tab",
                                   "label": "Tasmota Test1",
                                   "disabled": false,
                                   "info": "",
                                   "env": []
                                   "id": "74f2d76bc3ce958f",
                                   "type": "junction",
                                   "z": "e4aa7e9b9fb405d9",
                                   "x": 1060,
                                   "y": 480,
                                   "wires": [
                                   "id": "e5c4d789e94d350e",
                                   "type": "debug",
                                   "name": "debug 81",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1040,
                                   "y": 160,
                                   "wires": []
                                   "id": "7cf3622b17046eee",
                                   "type": "change",
                                   "name": "Spannung",
                                   "rules": [
                                           "t": "move",
                                           "p": "payload.ENERGY.Voltage",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 580,
                                   "y": 160,
                                   "wires": [
                                           "e5c4d789e94d350e",
                                           "a10b8a367682404e"
                                   "id": "a10b8a367682404e",
                                   "type": "ui_gauge",
                                   "name": "",
                                   "group": "04d5298db5344c1e",
                                   "order": 1,
                                   "width": 0,
                                   "height": 0,
                                   "gtype": "gage",
                                   "title": "volt Test 1",
                                   "label": "units",
                                   "format": "{{value}}",
                                   "min": 0,
                                   "max": "240",
                                   "colors": [
                                       "#ff0000",
                                       "#ffff00",
                                       "#008000"
                                   "seg1": "200",
                                   "seg2": "220",
                                   "x": 760,
                                   "y": 160,
                                   "wires": []
                                   "id": "77456c5a3405fff3",
                                   "type": "debug",
                                   "name": "debug 82",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 440,
                                   "y": 100,
                                   "wires": []
                                   "id": "89e9cf65394790da",
                                   "type": "change",
                                   "rules": [
                                           "t": "move",
                                           "p": "payload.ENERGY.Current[1]",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 570,
                                   "y": 200,
                                   "wires": [
                                           "e60c46e0c106e4dc"
                                   "id": "318a5c613a88c769",
                                   "type": "debug",
                                   "name": "debug 83",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1040,
                                   "y": 200,
                                   "wires": []
                                   "id": "401d1fdd51ecce14",
                                   "type": "victron-input-battery",
                                   "service": "com.victronenergy.battery.socketcan_can1",
                                   "path": "/Soc",
                                   "serviceObj": {
                                       "name": "Pylontech battery"
                                   "pathObj": {
                                       "path": "/Soc",
                                       "type": "float",
                                       "name": "State of charge (%)"
                                   "initial": "",
                                   "name": "",
                                   "onlyChanges": false,
                                   "x": 190,
                                   "y": 340,
                                   "wires": [
                                           "6ddde74da4bb9545"
                                   "id": "5369f8cb591ac34d",
                                   "type": "switch",
                                   "name": "",
                                   "property": "payload",
                                   "rules": [
                                           "t": "gt",
                                           "v": "91",
                                           "vt": "num"
                                           "t": "lt",
                                           "v": "70",
                                           "vt": "num"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 210,
                                   "y": 500,
                                   "wires": [
                                           "e5fea5b934a2efc7",
                                           "b9ed6599cf70de74"
                                           "5012c46291e78a77",
                                           "cbe9c595bb01b81e"
                                   "id": "f237aa09ab50cbd7",
                                   "type": "debug",
                                   "name": "debug 84",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "complete": "payload",
                                   "targetType": "msg",
                                   "statusVal": "",
                                   "x": 720,
                                   "y": 1020,
                                   "wires": []
                                   "id": "5d01b124055bea37",
                                   "type": "debug",
                                   "name": "State Of Charge",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1100,
                                   "y": 360,
                                   "wires": []
                                   "id": "6ddde74da4bb9545",
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "StateOfCharge",
                                           "pt": "global",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 560,
                                   "y": 340,
                                   "wires": [
                                           "5d01b124055bea37",
                                           "52e26a73c3b27f6e",
                                           "50eb11e95ce1c4f3"
                                   "id": "bd97fddd9dcd4646",
                                   "type": "ui_slider",
                                   "name": "",
                                   "label": "0 bis 100  test 1eingang",
                                   "tooltip": "",
                                   "order": 3,
                                   "width": 0,
                                   "height": 0,
                                   "passthru": true,
                                   "outs": "all",
                                   "topic": "topic",
                                   "topicType": "msg",
                                   "min": 0,
                                   "max": "100",
                                   "step": 1,
                                   "x": 120,
                                   "y": 760,
                                   "wires": [
                                           "1b2e513f58f2960b",
                                           "5369f8cb591ac34d"
                                   "id": "1b2e513f58f2960b",
                                   "type": "ui_gauge",
                                   "name": "",
                                   "order": 4,
                                   "width": 0,
                                   "height": 0,
                                   "gtype": "gage",
                                   "title": "0 bis 100   test 1 Ausgang",
                                   "label": "Batterie",
                                   "min": 0,
                                   "max": "100",
                                   "colors": [
                                       "#ff0000",
                                       "#e6e600",
                                       "#00ff00"
                                   "seg1": "",
                                   "seg2": "",
                                   "x": 490,
                                   "y": 760,
                                   "wires": []
                                   "id": "0d5525e74b9b0109",
                                   "type": "debug",
                                   "name": "debug 86",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 680,
                                   "y": 580,
                                   "wires": []
                                   "id": "73f440c9fc6e840c",
                                   "type": "debug",
                                   "name": "debug 87",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1060,
                                   "y": 280,
                                   "wires": []
                                   "id": "6ebf1c2b99b260a0",
                                   "type": "debug",
                                   "name": "debug 88",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 920,
                                   "y": 880,
                                   "wires": []
                                   "id": "99db0d2dae9eefe5",
                                   "type": "change",
                                   "name": "Strom power",
                                   "rules": [
                                           "t": "move",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "on",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 570,
                                   "y": 280,
                                   "wires": [
                                           "ec8f88403a3d804a"
                                   "id": "d6f7d9277bab1b46",
                                   "type": "ui_chart",
                                   "name": "",
                                   "group": "a9d0f0d6dc0f0a7e",
                                   "order": 1,
                                   "width": 0,
                                   "height": 0,
                                   "label": "1Strom Test1",
                                   "chartType": "bar",
                                   "legend": "true",
                                   "xformat": "HH:mm:ss",
                                   "interpolate": "linear",
                                   "nodata": "",
                                   "dot": false,
                                   "ymin": "",
                                   "ymax": "",
                                   "removeOlder": 1,
                                   "removeOlderPoints": "",
                                   "removeOlderUnit": "3600",
                                   "cutout": 0,
                                   "useOneColor": false,
                                   "useUTC": false,
                                   "colors": [
                                       "#1f77b4",
                                       "#aec7e8",
                                       "#ff7f0e",
                                       "#2ca02c",
                                       "#98df8a",
                                       "#d62728",
                                       "#ff9896",
                                       "#9467bd",
                                       "#c5b0d5"
                                   "outputs": 1,
                                   "useDifferentColor": false,
                                   "x": 770,
                                   "y": 240,
                                   "wires": [
                                           "eba281a8c7d862c3"
                                   "id": "eba281a8c7d862c3",
                                   "type": "debug",
                                   "name": "debug 89",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1060,
                                   "y": 240,
                                   "wires": []
                                   "id": "f5252ff2d2f5e5c1",
                                   "type": "change",
                                   "rules": [
                                           "t": "move",
                                           "p": "payload.ENERGY.Current[0]",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 570,
                                   "y": 240,
                                   "wires": [
                                           "d6f7d9277bab1b46"
                                   "id": "e60c46e0c106e4dc",
                                   "type": "ui_chart",
                                   "name": "",
                                   "order": 5,
                                   "width": 0,
                                   "height": 0,
                                   "label": "Strom Test1",
                                   "chartType": "bar",
                                   "legend": "false",
                                   "nodata": "",
                                   "dot": false,
                                   "ymin": "",
                                   "ymax": "",
                                   "removeOlder": 1,
                                   "cutout": 0,
                                   "useUTC": false,
                                   "colors": [
                                       "#1f77b4",
                                       "#aec7e8",
                                       "#ff7f0e",
                                       "#2ca02c",
                                       "#98df8a",
                                       "#d62728",
                                       "#ff9896",
                                       "#9467bd",
                                       "#c5b0d5"
                                   "outputs": 1,
                                   "x": 770,
                                   "y": 200,
                                   "wires": [
                                           "318a5c613a88c769"
                                   "id": "e5fea5b934a2efc7",
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "ON",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 630,
                                   "y": 480,
                                   "wires": [
                                           "a3ff7d845272b908",
                                           "d00e1f649acb16f3"
                                   "id": "7dd91967b9ae0e11",
                                   "device": "Tasmota_test1",
                                   "name": "",
                                   "outputs": 1,
                                   "fullTopic": "",
                                   "cmndPrefix": "",
                                   "statPrefix": "",
                                   "telePrefix": "",
                                   "qos": 1,
                                   "retain": false,
                                   "rules": [],
                                   "outputTopic": "",
                                   "x": 240,
                                   "y": 140,
                                   "wires": [
                                           "99db0d2dae9eefe5",
                                           "f5252ff2d2f5e5c1",
                                           "89e9cf65394790da",
                                           "7cf3622b17046eee",
                                           "77456c5a3405fff3"
                                   "id": "ec8f88403a3d804a",
                                   "type": "ui_chart",
                                   "name": "",
                                   "order": 6,
                                   "width": 0,
                                   "height": 0,
                                   "label": "Pauer Test1",
                                   "chartType": "bar",
                                   "legend": "true",
                                   "nodata": "",
                                   "dot": false,
                                   "ymin": "",
                                   "ymax": "",
                                   "removeOlder": 1,
                                   "cutout": 0,
                                   "useUTC": false,
                                   "colors": [
                                       "#1f77b4",
                                       "#aec7e8",
                                       "#ff7f0e",
                                       "#2ca02c",
                                       "#98df8a",
                                       "#d62728",
                                       "#ff9896",
                                       "#9467bd",
                                       "#c5b0d5"
                                   "outputs": 1,
                                   "x": 770,
                                   "y": 280,
                                   "wires": [
                                           "73f440c9fc6e840c"
                                   "id": "d00e1f649acb16f3",
                                   "type": "mqtt out",
                                   "name": "",
                                   "topic": "cmnd/Tasmota_test1/POWER1",
                                   "qos": "",
                                   "retain": "",
                                   "respTopic": "",
                                   "contentType": "",
                                   "userProps": "",
                                   "correl": "",
                                   "expiry": "",
                                   "x": 1530,
                                   "y": 500,
                                   "wires": []
                                   "id": "d9062f21b1c4fdaf",
                                   "type": "switch",
                                   "name": "",
                                   "rules": [
                                           "t": "eq",
                                           "v": "ON",
                                           "vt": "str"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 1,
                                   "x": 470,
                                   "y": 1020,
                                   "wires": [
                                           "b22e13f626cd98a3",
                                           "f237aa09ab50cbd7"
                                   "id": "56a67d7f80182ecc",
                                   "type": "mqtt in",
                                   "name": "",
                                   "topic": "tele/Tasmota_test1/SENSOR",
                                   "qos": "0",
                                   "datatype": "json",
                                   "nl": false,
                                   "rap": true,
                                   "rh": 0,
                                   "inputs": 0,
                                   "x": 190,
                                   "y": 980,
                                   "wires": [
                                           "d9062f21b1c4fdaf",
                                           "a79580173aa2a19f"
                                   "id": "b22e13f626cd98a3",
                                   "type": "trigger",
                                   "name": "",
                                   "op1": "ON",
                                   "op2": "OFF",
                                   "op1type": "str",
                                   "op2type": "str",
                                   "duration": "12",
                                   "extend": false,
                                   "overrideDelay": true,
                                   "units": "s",
                                   "reset": "",
                                   "bytopic": "all",
                                   "topic": "topic",
                                   "outputs": 1,
                                   "x": 630,
                                   "y": 880,
                                   "wires": [
                                           "6ebf1c2b99b260a0",
                                           "d00e1f649acb16f3"
                                   "id": "a3ff7d845272b908",
                                   "type": "debug",
                                   "name": "debug 98",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 620,
                                   "y": 420,
                                   "wires": []
                                   "id": "a79580173aa2a19f",
                                   "type": "debug",
                                   "name": "debug 100",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 430,
                                   "y": 900,
                                   "wires": []
                                   "id": "52e26a73c3b27f6e",
                                   "type": "ui_text",
                                   "group": "71e172fc8641b4f7",
                                   "order": 6,
                                   "width": 6,
                                   "height": 1,
                                   "name": "",
                                   "label": "Batterie test 1",
                                   "format": "{{msg.payload}}",
                                   "layout": "row-spread",
                                   "x": 830,
                                   "y": 380,
                                   "wires": []
                                   "id": "50eb11e95ce1c4f3",
                                   "type": "ui_gauge",
                                   "name": "",
                                   "order": 2,
                                   "width": 0,
                                   "height": 0,
                                   "gtype": "gage",
                                   "title": "Batterie Test 1",
                                   "label": "units",
                                   "min": 0,
                                   "max": "100",
                                   "colors": [
                                       "#ff0000",
                                       "#ffff00",
                                       "#008000"
                                   "seg1": "30",
                                   "seg2": "75",
                                   "x": 840,
                                   "y": 420,
                                   "wires": []
                                   "id": "5012c46291e78a77",
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "OFF",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 630,
                                   "y": 520,
                                   "wires": [
                                           "0d5525e74b9b0109",
                                           "d00e1f649acb16f3"
                                   "id": "b9ed6599cf70de74",
                                   "type": "debug",
                                   "name": "debug 101",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 390,
                                   "y": 440,
                                   "wires": []
                                   "id": "cbe9c595bb01b81e",
                                   "type": "debug",
                                   "name": "debug 102",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 370,
                                   "y": 600,
                                   "wires": []
                                   "id": "934a40174dc661ef",
                                   "type": "function",
                                   "name": "function 1",
                                   "func": "\nreturn msg;",
                                   "outputs": 1,
                                   "noerr": 0,
                                   "initialize": "",
                                   "finalize": "",
                                   "libs": [],
                                   "x": 1340,
                                   "y": 240,
                                   "wires": [
                                   "id": "04d5298db5344c1e",
                                   "type": "ui_group",
                                   "name": "Group 4",
                                   "tab": "12a65f5c2118623e",
                                   "order": 3,
                                   "disp": true,
                                   "width": 6
                                   "id": "a9d0f0d6dc0f0a7e",
                                   "type": "ui_group",
                                   "name": "Default",
                                   "order": 4,
                                   "disp": true,
                                   "width": 6,
                                   "collapse": false
                                   "name": "",
                                   "port": "1883",
                                   "clientid": "",
                                   "usetls": false,
                                   "keepalive": "60",
                                   "name": "CerboGX",
                                   "port": "1883",
                                   "clientid": "",
                                   "usetls": false,
                                   "keepalive": "60",
                                   "birthTopic": "",
                                   "birthQos": "0",
                                   "birthPayload": "",
                                   "birthMsg": {},
                                   "closeTopic": "",
                                   "closeQos": "0",
                                   "closePayload": "",
                                   "closeMsg": {},
                                   "willTopic": "",
                                   "willQos": "0",
                                   "willPayload": "",
                                   "willMsg": {},
                                   "userProps": "",
                                   "sessionExpiry": ""
                                   "id": "71e172fc8641b4f7",
                                   "type": "ui_group",
                                   "name": "Stapler ",
                                   "order": 1,
                                   "disp": true,
                                   "width": "6",
                                   "collapse": false
                                   "id": "12a65f5c2118623e",
                                   "type": "ui_tab",
                                   "name": "Home",
                                   "icon": "dashboard",
                                   "order": 2,
                                   "disabled": false,
                                   "hidden": false
                            • mickym
                              @josefthal Verstehe zwar nicht wie das gehen Soll, ausser der Tasmota Sensor gibt längere Zeit kein ON Signal.
                              Du hast doch nur EINE externe Quelle in Deinem Flow - der selbstständig schalten kann? (ROT markiert).
                              Bist Du Dir denn sicher, dass das Ganze was mit dem NodeRedFlow zu tun hat?
                                @mickym wichtig s.url
                                  • mickym
                                    @josefthal Wie ich sagte - der Flow kann nur von dem unterne Kasten automatisch schalten, das siehst Du doch an der debug Node 55
                                    • mickym
                                      Grundsätzlich ist es jedoch so, um Dir allgemein zu helfen. Du brauchste keine UND Node oder so einen Schmarn. Wenn Du willst das ein Flow an einer Stelle unterbrochen wird, machst Du eine SwitchNode rein und prüfst dort auf den Zustand einer Flowvariablen.
                                      Diese Flowvariable kannst Du an anderer Stelle setzen - egal durch was.
                                        @mickym [
                                        "id": "c38eca0b6d0feb3e",
                                        "type": "tab",
                                        "label": "Flow 2",
                                        "disabled": false,
                                        "info": "",
                                        "env": []
                                        "id": "1e1408fe355f5f7c",
                                        "type": "mqtt in",
                                        "z": "c38eca0b6d0feb3e",
                                        "name": "",
                                        "qos": "0",
                                        "datatype": "json",
                                        "nl": false,
                                        "rap": true,
                                        "rh": 0,
                                        "inputs": 0,
                                        "x": 240,
                                        "y": 260,
                                        "wires": [
                                        "99a27f412cc4724b"
                                        "id": "99a27f412cc4724b",
                                        "type": "change",
                                        "rules": [
                                        "t": "move",
                                        "pt": "msg",
                                        "to": "payload",
                                        "tot": "msg"
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "on",
                                        "tot": "str"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 530,
                                        "y": 260,
                                        "wires": [
                                        "e4734f30a2286602"
                                        "id": "e4734f30a2286602",
                                        "type": "debug",
                                        "name": "debug 113",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "statusVal": "",
                                        "x": 760,
                                        "y": 260,
                                        "wires": []
                                        "name": "CerboGX",
                                        "port": "1883",
                                        "clientid": "",
                                        "usetls": false,
                                        "keepalive": "60",
                                        "birthTopic": "",
                                        "birthQos": "0",
                                        "birthPayload": "",
                                        "birthMsg": {},
                                        "closeTopic": "",
                                        "closeQos": "0",
                                        "closePayload": "",
                                        "closeMsg": {},
                                        "willTopic": "",
                                        "willQos": "0",
                                        "willPayload": "",
                                        "willMsg": {},
                                        "userProps": "",
                                        "sessionExpiry": ""
                                            da habe ich noch einen Fehler aber komme nicht drauf wie ich es hin bekommen
                                            das signal mus erst einmal für 2 sekunden anlegen das es durchgeschaltet wird wenn es unter 2 Sekunden anlegt soll nicht pasieren
                                            2127
