    4. Sonnof Adapter hat ständig Warnungen
    • teletapi
      teletapi @teletapi last edited by teletapi
      @teletapi ```
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
              Machine ID: a9f1eae0dc5a48ddbf0e2a62c2227673
                 Boot ID: 5cce62b81695480fbfbda66850260622
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       19:54:38 up 10:22,  1 user,  load average: 0.22, 0.56, 0.83
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=39.9'C
      volt=0.9460V
      *** Time and Time Zones ***
                     Local time: Sat 2023-09-30 19:54:39 CEST
                 Universal time: Sat 2023-09-30 17:54:39 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.8G        2.9G        3.3G        1.0M        1.6G        4.8G
      Swap:            99M          0B         99M
      Total:          7.9G        2.9G        3.4G
               7811 M total memory
               2875 M used memory
               3711 M active memory
                607 M inactive memory
               3307 M free memory
                130 M buffer memory
               1498 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       59G  9.7G   47G  18% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
      [Sat Sep 30 09:32:14 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sat Sep 30 09:32:16 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Sep 30 09:32:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Sep 30 09:32:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.8G    /var/
      1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
      1.1G    /var/log
      511M    /var/lib
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      1.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      361M    /opt/iobroker/iobroker-data/
      181M    /opt/iobroker/iobroker-data/files
      71M     /opt/iobroker/iobroker-data/backup-objects
      62M     /opt/iobroker/iobroker-data/node-red/node_modules
      37M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js.map
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.4
      javascript:     7.1.4
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
      + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
      + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
      + system.adapter.panasonic-viera.0        : panasonic-viera       : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
        system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
        system.adapter.smartmeter.1             : smartmeter            : iobroker                                 - disabled
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.10.4   , installed 6.10.4
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.2    , installed 2.8.2
      Adapter    "discovery"    : 4.1.0    , installed 4.1.0
      Adapter    "fritzdect"    : 2.4.1    , installed 2.4.1
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "opendtu"      : 0.1.8    , installed 0.1.8
      Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "socketio"     : 6.5.6    , installed 6.5.6
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "web"          : 6.1.3    , installed 6.1.3
      Adapter    "ws"           : 2.5.6    , installed 2.5.6
      Objects and States
      Objects:        9645
      States:         8963
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       24790      2163/io.simple-api.
      tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       17735      1337/io.hm-rpc.1
      tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       18890      1360/io.hm-rpc.2
      tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       15591      1310/io.hm-rpc.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14092      540/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3986       654/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15240      654/iobroker.js-con
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       1529196    88470/io.sonoff.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17026      1239/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        13041      568/mosquitto
      tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       19037      1415/io.hm-rpc.3
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20458      1820/io.jarvis.0
      tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24068      2020/io.nuki.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14073      572/sshd: /usr/sbin
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24135      2315/io.socketio.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        14121      549/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15443      1055/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19700      1643/io.web.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      117        15416      653/grafana
      tcp6       0      0 :::1883                 :::*                    LISTEN      116        13042      568/mosquitto
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14091      540/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14075      572/sshd: /usr/sbin
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13123      457/dhcpcd
      udp        0      0 0.0.0.0:45674           0.0.0.0:*                           108        14965      401/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15175      630/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14963      401/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14145      457/dhcpcd
      udp6       0      0 :::54331                :::*                                108        14966      401/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        14964      401/avahi-daemon: r
      2023-09-30 19:30:00.172  - info: host.iobroker instance system.adapter.ical.0 started with pid 96578
      2023-09-30 19:30:09.741  - info: ical.0 (96578) Terminated (NO_ERROR): Without reason
      2023-09-30 19:30:10.286  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-09-30 19:31:42.572  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
      2023-09-30 19:31:42.573  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
      2023-09-30 19:32:03.027  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
      2023-09-30 19:32:03.028  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
      2023-09-30 19:33:14.175  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
      2023-09-30 19:33:14.176  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
      2023-09-30 19:33:34.878  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
      2023-09-30 19:33:34.879  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
      2023-09-30 19:54:21.440  - info: nuki.0 (2020) status change received for NukiID 790083444: locking
      2023-09-30 19:54:21.441  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
      2023-09-30 19:54:41.344  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
      2023-09-30 19:54:41.345  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
      2023-09-30 19:55:01.853  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
      2023-09-30 19:55:01.854  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
      2023-09-30 19:55:22.003  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
      2023-09-30 19:55:22.004  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
      2023-09-30 19:55:51.541  - info: hue-extended.0 (1725) Attempt 1x - Successfully set Deckenlicht Flur unten Haustuer.
      iob diag has finished.
      Glasfaser haselchen 3 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @teletapi last edited by
        @teletapi sagte in Sonnof Adapter hat ständig Warnungen:
        aber es gab auch bereits vor dem Update immer wieder mal fehler bzw Warnungen
        Ja ... ich sehe ( alte Beiträge ) das du mit deinem ioBroker im Beta unterwegs bis .. ist ja nicht schlimm aber ...
        Was wäre mit der Stable Version ist es auch dort !?
        • Glasfaser
          @teletapi
          Nimm die Kalender Daten URL aus dem LOG !!
          • Glasfaser
            • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
            • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1886, bind: 0.0.0.0
            mosquitto
            Eventuell funkt da was zwischen !?
            • Glasfaser
              Glasfaser last edited by
              throttled=0x0
              Hast du diese Meldung im Log auch gesehn !?
              • haselchen
                haselchen Most Active @teletapi last edited by haselchen
                @teletapi
                Meine Erfahrungen mit den Meldungen sind netzwerktechnischer Natur.
                Wie ist Dein Netzwerk aufgebaut ?
                Und dann hat Dein Raspi zu wenig Power.
                Richtiges (originales) Netzteil?
                Raspberry only:
                throttled=0x0
                temp=39.9'C
                volt=0.9460V
                Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @haselchen last edited by
                  @haselchen sagte in Sonnof Adapter hat ständig Warnungen:
                  Nein, die Werte sind super. Gibt ja auch kein Gemecker, throttled=0x0 ist die Null-Meldung, also alles i.O.
                  Die neuste Version von iob diag ist da aber besser lesbar,die gibt Klartext aus.
                  haselchen teletapi 2 Replies Last reply Reply Quote 0
                  • haselchen
                    haselchen Most Active @Thomas Braun last edited by
                    Okay , hatte mich da an einen anderen Thread orientiert, wo ich dachte gelesen zu haben , dass diese Aussage Probleme mit der Stromversorgung suggeriert .
                      @haselchen
                      Wenn da was anders als 0x0 steht ja. Z.B. 0x5005 oder sowas.
                        crunchip Forum Testing Most Active @haselchen last edited by
                        so auch meine , z.b.
                        • in Verbindung mit TasmoAdmin( werden wohl zu viele Anfragen auf einmal gesendet, beim starten)
                        • Wlan überlastet, z.b. durch W-lan Cams
                        teletapi 1 Reply Last reply Reply Quote 1
                        • teletapi
                          teletapi @crunchip last edited by
                          @crunchip
                          Ich habe 1ne Wlan Kamera im Netzwerk, der Rest ist per Lan angebunden allerdings hab ich einige Tasmota Steckdosen die ja alle per Wlan eingebunden sind im Netzwerk. Vielleicht liegt es ja tatsächlich daran,
                          • teletapi
                            teletapi @Thomas Braun last edited by
                            @thomas-braun Hallo Thomas, was heißt die neue Iob Diag Version wie kann ich die denn aufrufen...?
                              crunchip Forum Testing Most Active @teletapi last edited by
                              @teletapi kann sein, das dieser genutzte Kanal überlastet ist(anderweitige Störquellen), mögliche Besserung wäre auf einen anderen Kanal zu wechseln
                              teletapi 1 Reply Last reply Reply Quote 0
                              • teletapi
                                @crunchip Jetzt müsstest du mir evtl. dabei helfen wie ich das wechseln könnte in der Fritzbox 7590 . ich hab da schon von gelesen aber bin nicht wirklich sicher wie ich den kanal tauschen bzw. wechseln könnte
                                  @teletapi https://www.heise.de/tipps-tricks/FritzBox-Kanal-aendern-so-geht-s-6072593.html?hg=1&hgi=1&hgf=false
                                    Thomas Braun Most Active @teletapi last edited by Thomas Braun
                                    Hier stand Quark.
                                      Maxtor62 @Thomas Braun last edited by
                                      Hi, diese Warnungen habe ich auch ständig. Auch seit ich den Shelly Adapter upgedatet habe. Werte und Datenpunkte sind aktuell aber haufenweise Warnungen im Log. Das kommt bei mir vermutlich von dem Flatter-Mesh-WLAN-Netzwerk der Fritte. Habe zwei Fritten und zwei Repeater durch drei Betondecken im Einsatz.
                                      • haselchen
                                        haselchen Most Active @Maxtor62 last edited by haselchen
                                        @maxtor62
                                        Die Repeater und die Tasmota Geräte sind ja an ihrem Standort fest installiert denke ich mal?
                                        Dann kannst du in die GUI der Tasmota Geräte gehen und dort das WLAN stärkste Signal zum Verbinden auswählen.
                                        Und so sollte eigentlich jedes Gerät dann stabil verbunden sein.
                                        Es sei denn natürlich das die Geräte weit ausserhalb der Repeater Range sind.
                                        M crunchip 2 Replies Last reply Reply Quote 0
                                          Maxtor62 @haselchen last edited by
                                          @haselchen
                                          Das ist eine Option die ich mal testen werde. Danke Dir für den Tipp. Komischerweise, es sind zwei Tasmota Steckdosen ca. 2Meter neben einem FritzRepeater eingesteckt, der über LAN das WLAN verteilt. Auch von denen bekomme ich die Warnmeldungen.
                                            @haselchen gibt aber auch eine SetOption damit sich das tasmota Gerät mit dem stärksten Signal verbindet
                                            haselchen 1 Reply Last reply Reply Quote 1
                                            1555
