      DPO99 @Thomas Braun last edited by
      @thomas-braun Welche Daten zum Setup genau helfen denn für die Analyse? Ansonten würde ich den Adapter einmal auf Debug stellen, wenn er heute das nächste mal los rennt, da sollte dann ja einiges drin stehen.
      Danke schonmal!
      • simatec
        simatec Developer Most Active @DPO99 last edited by
        @dpo99 Bitte poste den kompletten Debuglog vom Backupprozess
          DPO99 @simatec last edited by
          @simatec
          Heute trag der Fehler natürlich nicht auf...werde das weiter beobachten und mal auf Debug stehen lassen.
          2023-09-22 23:00:10.076 - debug: backitup.0 (258932) The local storage check was completed successfully. On the host "iobroker" are currently 24314 MB free space available!
          2023-09-22 23:00:10.141 - debug: backitup.0 (258932) Backup has started ...
          2023-09-22 23:00:20.144 - debug: backitup.0 (258932) [iobroker/mount] noserverino option: false
          2023-09-22 23:00:20.144 - debug: backitup.0 (258932) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
          2023-09-22 23:00:20.480 - debug: backitup.0 (258932) [iobroker/mount] mount successfully completed
          2023-09-22 23:00:20.482 - debug: backitup.0 (258932) [iobroker/mount] done
          2023-09-22 23:00:23.453 - debug: backitup.0 (258932) [iobroker/iobroker] host.iobroker 2904 states saved
          2023-09-22 23:00:25.946 - debug: backitup.0 (258932) [iobroker/iobroker] host.iobroker 3395 objects saved
          2023-09-22 23:00:29.829 - debug: backitup.0 (258932) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_09_22-23_00_20_backupiobroker.tar.gz
          2023-09-22 23:00:31.162 - debug: backitup.0 (258932) [iobroker/iobroker] done
          2023-09-22 23:00:32.067 - debug: backitup.0 (258932) [iobroker/historyDB] compress from historyDB started ...
          2023-09-22 23:00:36.909 - debug: backitup.0 (258932) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_09_22-23_00_32_backupiobroker.tar.gz
          2023-09-22 23:00:36.912 - debug: backitup.0 (258932) [iobroker/historyDB] done
          2023-09-22 23:00:37.833 - debug: backitup.0 (258932) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
          2023-09-22 23:00:37.979 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
          2023-09-22 23:00:37.980 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
          2023-09-22 23:00:37.981 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
          2023-09-22 23:00:37.981 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
          2023-09-22 23:00:37.981 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: Schaltung_openDTU
          2023-09-22 23:00:37.981 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: Notabschaltung___Alarm
          2023-09-22 23:00:37.982 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
          2023-09-22 23:00:37.982 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
          2023-09-22 23:00:37.983 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: Akku_Balancing
          2023-09-22 23:00:37.984 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: Luftentfeuchter
          2023-09-22 23:00:37.984 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: Raspberry_PI
          2023-09-22 23:00:37.985 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: OpenDTU
          2023-09-22 23:00:37.986 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: HM_WR_Keller
          2023-09-22 23:00:37.987 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: HW_WR_Garage
          2023-09-22 23:00:37.987 - debug: backitup.0 (258932) [iobroker/javascripts] found Script: Akkuladung_100
          2023-09-22 23:00:38.091 - debug: backitup.0 (258932) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
          2023-09-22 23:00:38.112 - debug: backitup.0 (258932) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
          2023-09-22 23:00:38.113 - debug: backitup.0 (258932) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_09_22-23_00_37_backupiobroker.tar.gz
          2023-09-22 23:00:38.113 - debug: backitup.0 (258932) [iobroker/javascripts] done
          2023-09-22 23:00:38.867 - debug: backitup.0 (258932) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
          2023-09-22 23:00:38.867 - debug: backitup.0 (258932) [iobroker/cifs] done
          2023-09-22 23:00:39.486 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_18-23_00_25_backupiobroker.tar.gz
          2023-09-22 23:00:39.489 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_17-23_00_20_backupiobroker.tar.gz
          2023-09-22 23:00:39.491 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_16-23_00_20_backupiobroker.tar.gz
          2023-09-22 23:00:39.503 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_18-23_00_36_backupiobroker.tar.gz
          2023-09-22 23:00:39.506 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_17-23_00_32_backupiobroker.tar.gz
          2023-09-22 23:00:39.521 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_16-23_00_31_backupiobroker.tar.gz
          2023-09-22 23:00:39.536 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_18-23_00_40_backupiobroker.tar.gz
          2023-09-22 23:00:39.539 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_17-23_00_35_backupiobroker.tar.gz
          2023-09-22 23:00:39.542 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_16-23_00_35_backupiobroker.tar.gz
          2023-09-22 23:00:39.545 - debug: backitup.0 (258932) [iobroker/clean] done
          2023-09-22 23:00:40.793 - debug: backitup.0 (258932) [iobroker/historyHTML] new history html values created
          2023-09-22 23:00:40.866 - debug: backitup.0 (258932) [iobroker/historyHTML] done
          2023-09-22 23:00:41.094 - debug: backitup.0 (258932) [iobroker/historyJSON] new history json values created
          2023-09-22 23:00:41.095 - debug: backitup.0 (258932) [iobroker/historyJSON] done
          2023-09-22 23:00:41.276 - debug: backitup.0 (258932) [iobroker/umount] mount activ, umount is started ...
          2023-09-22 23:00:46.329 - debug: backitup.0 (258932) [iobroker/umount] umount successfully completed
          2023-09-22 23:00:46.330 - debug: backitup.0 (258932) [iobroker/umount] done
          2023-09-22 23:00:46.481 - debug: backitup.0 (258932) [iobroker] exec: done
          • simatec
            @dpo99 der Log sieht gut aus…
              DPO99 @simatec last edited by DPO99
              Update**
              @simatec Fehler trat nun wieder auf. Anbei das log.
              2023-09-29 23:00:10.051 - debug: backitup.0 (929) The local storage check was completed successfully. On the host "iobroker" are currently 24137 MB free space available!
              2023-09-29 23:00:10.059 - debug: backitup.0 (929) Backup has started ...
              2023-09-29 23:00:20.060 - debug: backitup.0 (929) [iobroker/mount] noserverino option: false
              2023-09-29 23:00:20.061 - debug: backitup.0 (929) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
              2023-09-29 23:00:20.349 - debug: backitup.0 (929) [iobroker/mount] mount successfully completed
              2023-09-29 23:00:20.351 - debug: backitup.0 (929) [iobroker/mount] done
              2023-09-29 23:00:23.687 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3001 states saved
              2023-09-29 23:00:25.923 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3512 objects saved
              2023-09-29 23:00:29.810 - debug: backitup.0 (929) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_09_29-23_00_20_backupiobroker.tar.gz
              2023-09-29 23:00:37.788 - debug: backitup.0 (929) [iobroker/iobroker] done
              2023-09-29 23:00:38.692 - debug: backitup.0 (929) [iobroker/historyDB] compress from historyDB started ...
              2023-09-29 23:00:41.848 - debug: backitup.0 (929) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_09_29-23_00_38_backupiobroker.tar.gz
              2023-09-29 23:00:41.849 - debug: backitup.0 (929) [iobroker/historyDB] done
              2023-09-29 23:00:42.805 - debug: backitup.0 (929) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
              2023-09-29 23:00:43.022 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
              2023-09-29 23:00:43.023 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
              2023-09-29 23:00:43.023 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
              2023-09-29 23:00:43.024 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
              2023-09-29 23:00:43.024 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Schaltung_openDTU
              2023-09-29 23:00:43.024 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Notabschaltung___Alarm
              2023-09-29 23:00:43.025 - debug: backitup.0 (929) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
              2023-09-29 23:00:43.025 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
              2023-09-29 23:00:43.025 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akku_Balancing
              2023-09-29 23:00:43.025 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Luftentfeuchter
              2023-09-29 23:00:43.026 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Raspberry_PI
              2023-09-29 23:00:43.026 - debug: backitup.0 (929) [iobroker/javascripts] found Script: OpenDTU
              2023-09-29 23:00:43.026 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HM_WR_Keller
              2023-09-29 23:00:43.026 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HW_WR_Garage
              2023-09-29 23:00:43.027 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akkuladung_100
              2023-09-29 23:00:43.027 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Jahresverbrauch
              2023-09-29 23:00:43.027 - debug: backitup.0 (929) [iobroker/javascripts] found Script: TEST
              2023-09-29 23:00:43.027 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Test_Hama
              2023-09-29 23:00:43.324 - debug: backitup.0 (929) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
              2023-09-29 23:00:43.430 - debug: backitup.0 (929) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
              2023-09-29 23:00:43.431 - debug: backitup.0 (929) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_09_29-23_00_42_backupiobroker.tar.gz
              2023-09-29 23:00:43.431 - debug: backitup.0 (929) [iobroker/javascripts] done
              2023-09-29 23:00:44.184 - debug: backitup.0 (929) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
              2023-09-29 23:00:44.185 - debug: backitup.0 (929) [iobroker/cifs] done
              2023-09-29 23:00:44.787 - error: backitup.0 (929) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
              2023-09-29 23:00:44.788 - debug: backitup.0 (929) [iobroker/clean] done
              2023-09-29 23:00:46.003 - debug: backitup.0 (929) [iobroker/historyHTML] new history html values created
              2023-09-29 23:00:46.069 - debug: backitup.0 (929) [iobroker/historyHTML] done
              2023-09-29 23:00:46.307 - debug: backitup.0 (929) [iobroker/historyJSON] new history json values created
              2023-09-29 23:00:46.308 - debug: backitup.0 (929) [iobroker/historyJSON] done
              2023-09-29 23:00:46.487 - debug: backitup.0 (929) [iobroker/umount] mount activ, umount is started ...
              2023-09-29 23:00:51.587 - debug: backitup.0 (929) [iobroker/umount] umount successfully completed
              2023-09-29 23:00:51.589 - debug: backitup.0 (929) [iobroker/umount] done
              2023-09-29 23:00:51.740 - debug: backitup.0 (929) [iobroker] exec: done
              Die Backups sind auch noch auf dem Pi gespeichert:
              iobroker@iobroker:/opt/iobroker/backups $ dir
              historyDB_2023_09_24-23_00_31_backupiobroker.tar.gz  iobroker_2023_09_27-23_00_20_backupiobroker.tar.gz
              historyDB_2023_09_25-23_00_31_backupiobroker.tar.gz  iobroker_2023_09_28-23_00_20_backupiobroker.tar.gz
              historyDB_2023_09_26-23_00_36_backupiobroker.tar.gz  iobroker_2023_09_29-23_00_20_backupiobroker.tar.gz
              historyDB_2023_09_27-23_00_32_backupiobroker.tar.gz  javascripts_2023_09_24-23_00_35_backupiobroker.tar.gz
              historyDB_2023_09_28-23_00_33_backupiobroker.tar.gz  javascripts_2023_09_25-23_00_35_backupiobroker.tar.gz
              historyDB_2023_09_29-23_00_38_backupiobroker.tar.gz  javascripts_2023_09_26-23_00_41_backupiobroker.tar.gz
              iobroker_2023_09_24-23_00_20_backupiobroker.tar.gz   javascripts_2023_09_27-23_00_36_backupiobroker.tar.gz
              iobroker_2023_09_25-23_00_20_backupiobroker.tar.gz   javascripts_2023_09_28-23_00_40_backupiobroker.tar.gz
              iobroker_2023_09_26-23_00_25_backupiobroker.tar.gz   javascripts_2023_09_29-23_00_42_backupiobroker.tar.gz
              Anbei einmal die Einstellungen:
              Zum System:
              Raspberry Pi 4 8GB
              Node.js: v18.18.0
              NPM: 9.8.1
              js-controller: 4.0.24
              backitup: v2.8.1
              Mir ist dann noch was aufgefallen.
              Er hat hier m.E. eine Version zu viel gelöscht. Ich hebe immer 5 auf, also hätte er doch am 23.09.2023 den 19.09.2023 noch gar nicht löschen dürfen oder?
              2023-09-23 23:00:37.923 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_19-23_00_20_backupiobroker.tar.gz
              2023-09-23 23:00:37.937 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_19-23_00_33_backupiobroker.tar.gz
              2023-09-23 23:00:37.951 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_19-23_00_40_backupiobroker.tar.gz
              2023-09-23 23:00:37.954 - debug: backitup.0 (258932) [iobroker/clean] done
              Am 26.09.2023 z.B. hat er tatsächlich 5 Versionen stehen lassen und die 6. gelöscht (also anders als am 23.09.2023):
              2023-09-26 23:00:42.869 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_21-23_54_53_backupiobroker.tar.gz
              2023-09-26 23:00:42.884 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_21-23_55_04_backupiobroker.tar.gz
              2023-09-26 23:00:42.898 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_21-23_55_08_backupiobroker.tar.gz
              2023-09-26 23:00:42.901 - debug: backitup.0 (258932) [iobroker/clean] done
              D simatec 2 Replies Last reply Reply Quote 0
                DPO99 @DPO99 last edited by
                Gestern hatte er es dann auch geschafft, dass vom 29.09.2023 "stehen gelassene" Backup zu löschen. Und auch hier hat er m.E. korrekt 5 Stück stehen lassen:
                2023-09-30 23:00:37.375 - debug: backitup.0 (929) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_25-23_00_20_backupiobroker.tar.gz
                2023-09-30 23:00:37.378 - debug: backitup.0 (929) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_24-23_00_20_backupiobroker.tar.gz
                2023-09-30 23:00:37.394 - debug: backitup.0 (929) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_25-23_00_31_backupiobroker.tar.gz
                2023-09-30 23:00:37.397 - debug: backitup.0 (929) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_24-23_00_31_backupiobroker.tar.gz
                2023-09-30 23:00:37.411 - debug: backitup.0 (929) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_25-23_00_35_backupiobroker.tar.gz
                2023-09-30 23:00:37.414 - debug: backitup.0 (929) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_24-23_00_35_backupiobroker.tar.gz
                2023-09-30 23:00:37.417 - debug: backitup.0 (929) [iobroker/clean] done
                • simatec
                  @dpo99 sagte in Test Adapter ioBroker.backitup v2.8.x:
                  Wenn du ein NAS nutzt, können die Backups nicht auf dem PI liegen
                    @simatec
                    Diese Aussage deckt sich aber nicht mit dem Verhalten. Die Backups liegen auf dem PI und auf dem NAS. So gesehen "doppelt" könnte man sagen.
                    DJMarc75 simatec Thomas Braun 3 Replies Last reply Reply Quote 0
                    • DJMarc75
                      DJMarc75 @DPO99 last edited by
                      @dpo99 Sind das manuell angestoßene Backups ?
                      • simatec
                        @dpo99 Und genau dies kann bei einem CIFS Mount nicht sein... Der lokale Pfad muss leer sein.
                          Thomas Braun Most Active @DPO99 last edited by
                          Üblicherweise werden NAS per NFS oder CIFS in dem Mountpunkt /opt/iobroker/backups gemountet. Da kann es keine Dopplung geben, weil die Dateien physisch auf dem NAS liegen und nur logisch in /opt/iobroker/backups.
                          Dieser Ordner ist dann auch leer, wenn das NAS gerade nicht gemountet ist .
                            DPO99 @Thomas Braun last edited by DPO99
                            @thomas-braun @simatec
                            Ah okay alles klar. Das wäre dann soweit logisch. Hab das NAS mal eben ausgemacht und in den lokalen Pfad geschaut. Sieht so aus, wie beschrieben:
                            2023_02_19-18_44_43_backupiobroker.tar.gz
                            Gibts zum ursprünglichen Problem und dem "stehen lassen" bzw. zu "früh" löschen von Backups auch eine Idee?
                            @DJMarc75 Wenn mein NAS aus ist, dann sehe ich nur das manuelle Backup. Von daher passt das zur Aussage von Thomas Braun und Simatec.
                              ...muss das Verzeichnis leer sein. Lösch das Backup da raus.
                                ist erl. Danke. Soll ich dann mal weiter beobachten?
                                  @dpo99
                                  Statt dir besser ls -lAh verwenden. Das zeigt mehr und übersichtlicher an.
                                    @thomas-braun Danke für den Tipp. Dabei kommt das raus:
                                    iobroker@iobroker:/opt/iobroker/backups $ ls -lAh
                                    total 0
                                      @simatec
                                      Fehler trat heute leider wieder auf. Sehr komisch...schreiben kann er die Backups aber löschen teilweise nicht...
                                      2023-10-01 23:00:10.034 - debug: backitup.0 (929) The local storage check was completed successfully. On the host "iobroker" are currently 24128 MB free space available!
                                      2023-10-01 23:00:10.036 - debug: backitup.0 (929) Backup has started ...
                                      2023-10-01 23:00:20.037 - debug: backitup.0 (929) [iobroker/mount] noserverino option: false
                                      2023-10-01 23:00:20.038 - debug: backitup.0 (929) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
                                      2023-10-01 23:00:20.234 - debug: backitup.0 (929) [iobroker/mount] mount successfully completed
                                      2023-10-01 23:00:20.236 - debug: backitup.0 (929) [iobroker/mount] done
                                      2023-10-01 23:00:23.555 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3030 states saved
                                      2023-10-01 23:00:26.328 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3545 objects saved
                                      2023-10-01 23:00:30.484 - debug: backitup.0 (929) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_01-23_00_20_backupiobroker.tar.gz
                                      2023-10-01 23:00:34.701 - debug: backitup.0 (929) [iobroker/iobroker] done
                                      2023-10-01 23:00:35.604 - debug: backitup.0 (929) [iobroker/historyDB] compress from historyDB started ...
                                      2023-10-01 23:00:38.610 - debug: backitup.0 (929) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_10_01-23_00_35_backupiobroker.tar.gz
                                      2023-10-01 23:00:38.611 - debug: backitup.0 (929) [iobroker/historyDB] done
                                      2023-10-01 23:00:39.523 - debug: backitup.0 (929) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                      2023-10-01 23:00:39.646 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
                                      2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
                                      2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
                                      2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
                                      2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Schaltung_openDTU
                                      2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Notabschaltung___Alarm
                                      2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
                                      2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
                                      2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akku_Balancing
                                      2023-10-01 23:00:39.649 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Luftentfeuchter
                                      2023-10-01 23:00:39.649 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Raspberry_PI
                                      2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: OpenDTU
                                      2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HM_WR_Keller
                                      2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akkuladung_100
                                      2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Jahresverbrauch
                                      2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: TEST
                                      2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Test_Hama
                                      2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HM_WR_Garage
                                      2023-10-01 23:00:39.771 - debug: backitup.0 (929) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                                      2023-10-01 23:00:39.801 - debug: backitup.0 (929) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                      2023-10-01 23:00:39.802 - debug: backitup.0 (929) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_01-23_00_39_backupiobroker.tar.gz
                                      2023-10-01 23:00:39.802 - debug: backitup.0 (929) [iobroker/javascripts] done
                                      2023-10-01 23:00:40.555 - debug: backitup.0 (929) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
                                      2023-10-01 23:00:40.555 - debug: backitup.0 (929) [iobroker/cifs] done
                                      2023-10-01 23:00:41.157 - error: backitup.0 (929) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                      2023-10-01 23:00:41.158 - debug: backitup.0 (929) [iobroker/clean] done
                                      2023-10-01 23:00:42.364 - debug: backitup.0 (929) [iobroker/historyHTML] new history html values created
                                      2023-10-01 23:00:42.421 - debug: backitup.0 (929) [iobroker/historyHTML] done
                                      2023-10-01 23:00:42.611 - debug: backitup.0 (929) [iobroker/historyJSON] new history json values created
                                      2023-10-01 23:00:42.612 - debug: backitup.0 (929) [iobroker/historyJSON] done
                                      2023-10-01 23:00:42.781 - debug: backitup.0 (929) [iobroker/umount] mount activ, umount is started ...
                                      2023-10-01 23:00:47.829 - debug: backitup.0 (929) [iobroker/umount] umount successfully completed
                                      2023-10-01 23:00:47.830 - debug: backitup.0 (929) [iobroker/umount] done
                                      2023-10-01 23:00:47.980 - debug: backitup.0 (929) [iobroker] exec: done
                                      • simatec
                                        @dpo99 Was hast du für ein NAS?
                                          @simatec
                                          Synology DS220+. Hat Backitup ggf ein Problem, wenn der Speicher aus dem Standby nicht 100% online ist? Ich schalte den um 23h ein (zeitgleich startet auch das Backup). Aber schreiben konnte er ja immer...hm
                                          Thomas Braun Siggi0904 2 Replies Last reply Reply Quote 0
                                            Dann mach das mal um ein paar Minuten versetzt...
                                            170
                                            2780
                                            2367506
