    4. Nach Update läuft nichts mehr!
      Thomas Braun Most Active @SpeedyBlade last edited by
      @speedyblade
      Poste die Langfassung.
        SpeedyBlade @Thomas Braun last edited by
           Static hostname: RaspberryPi3B1GB
                 Icon name: computer
                Machine ID: 0a3492672676440e91094afe51dc1729
                   Boot ID: 014394ca8eed41a288a0b89111927ea2
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         15:25:26 up  1:24,  1 user,  load average: 1.04, 3.03, 1.99
        CPU threads: 4
        Raspberry only:
        throttled=0x50000
        Other values than 0x0 hint to temperature/voltage problems
        temp=63.9'C
        volt=1.3062V
        *** Time and Time Zones ***
                       Local time: Sun 2023-10-01 15:25:27 CEST
                   Universal time: Sun 2023-10-01 13:25:27 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CEST, +0200)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        piuser
        /home/piuser
        piuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            909M        118M        586M        0.0K        204M        717M
        Swap:            99M         65M         34M
        Total:          1.0G        184M        620M
                  909 M total memory
                  118 M used memory
                  154 M active memory
                   71 M inactive memory
                  586 M free memory
                    8 M buffer memory
                  195 M swap cache
                   99 M total swap
                   65 M used swap
                   34 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4      294G  2.8G  279G   1% /
        devtmpfs       devtmpfs  325M     0  325M   0% /dev
        tmpfs          tmpfs     455M     0  455M   0% /dev/shm
        tmpfs          tmpfs     182M  968K  181M   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
        [Sun Oct  1 14:00:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=86e36461-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): write access will be enabled during recovery
        [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): recovery complete
        [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Oct  1 14:00:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sun Oct  1 14:00:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        570M    /var/
        234M    /var/cache
        228M    /var/cache/apt
        147M    /var/lib
        128M    /var/cache/apt/archives
        Archived and active journals take up 88.0M in the file system.
        /opt/iobroker/backups:
        1.4M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        45M     /opt/iobroker/iobroker-data/
        28M     /opt/iobroker/iobroker-data/files
        13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        5.9M    /opt/iobroker/iobroker-data/objects.jsonl
        4.4M    /opt/iobroker/iobroker-data/objects.json.migrated
        4.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        4.4M    /opt/iobroker/iobroker-data/files/web.admin/static/js/2.d0deddb4.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.0
        /usr/bin/node           v18.18.0
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Installed: 18.18.0-1nodesource1
          Candidate: 18.18.0-1nodesource1
          Version table:
         *** 18.18.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  5.0.12
        admin:          5.2.3
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
          system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : RaspberryPi3B1GB                         -  enabled
          system.adapter.discovery.0              : discovery             : RaspberryPi3B1GB                         - disabled
          system.adapter.mqtt.0                   : mqtt                  : RaspberryPi3B1GB                         - disabled, port: 1883, bind: 0.0.0.0
          system.adapter.node-red.0               : node-red              : RaspberryPi3B1GB                         - disabled, port: 1885, bind: 0.0.0.0
          system.adapter.rpi2.0                   : rpi2                  : RaspberryPi3B1GB                         - disabled
          system.adapter.socketio.0               : socketio              : RaspberryPi3B1GB                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : RaspberryPi3B1GB                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.10.1   , installed 5.2.3  [Updatable]
        Adapter    "backitup"     : 2.8.1    , installed 2.2.3  [Updatable]
        Adapter    "discovery"    : 3.1.0    , installed 2.7.3  [Updatable]
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "mqtt"         : 4.1.1    , installed 2.4.0  [Updatable]
        Adapter    "node-red"     : 4.0.3    , installed 2.4.1  [Updatable]
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
        Adapter    "socketio"     : 6.5.5    , installed 3.1.5  [Updatable]
        Adapter    "web"          : 6.1.2    , installed 3.4.16 [Updatable]
        Objects and States
        Objects:        360
        States:         230
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37390      8921/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37385      8921/iobroker.js-co
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14409      517/sshd: /usr/sbin
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14411      517/sshd: /usr/sbin
        udp        0      0 0.0.0.0:44571           0.0.0.0:*                           108        14352      388/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1767       574/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14350      388/avahi-daemon: r
        udp6       0      0 :::56729                :::*                                108        14353      388/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14351      388/avahi-daemon: r
        2023-10-01 15:22:47.009  - info: host.RaspberryPi3B1GB iobroker npm-rebuild: Rebuilding native modules done
        2023-10-01 15:22:48.051  - info: host.RaspberryPi3B1GB iobroker npm-rebuild: exit 0
        2023-10-01 15:22:48.278  - info: host.RaspberryPi3B1GB instance system.adapter.admin.0 started with pid 10379
        2023-10-01 15:22:56.545  - error: host.RaspberryPi3B1GB Caught by controller[0]: node:internal/modules/cjs/loader:1080
        2023-10-01 15:22:56.547  - error: host.RaspberryPi3B1GB Caught by controller[0]:   throw err;
        2023-10-01 15:22:56.548  - error: host.RaspberryPi3B1GB Caught by controller[0]:   ^
        2023-10-01 15:22:56.549  - error: host.RaspberryPi3B1GB Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
        2023-10-01 15:22:56.550  - error: host.RaspberryPi3B1GB Caught by controller[0]: Require stack:
        2023-10-01 15:22:56.551  - error: host.RaspberryPi3B1GB Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
        2023-10-01 15:22:56.552  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        2023-10-01 15:22:56.552  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
        2023-10-01 15:22:56.553  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
        2023-10-01 15:22:56.554  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:119:18)
        2023-10-01 15:22:56.555  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
        2023-10-01 15:22:56.556  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
        2023-10-01 15:22:56.557  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        2023-10-01 15:22:56.558  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
        2023-10-01 15:22:56.560  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
        2023-10-01 15:22:56.563  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) {
        2023-10-01 15:22:56.564  - error: host.RaspberryPi3B1GB Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2023-10-01 15:22:56.564  - error: host.RaspberryPi3B1GB Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
        2023-10-01 15:22:56.565  - error: host.RaspberryPi3B1GB Caught by controller[0]: }
        2023-10-01 15:22:56.566  - error: host.RaspberryPi3B1GB Caught by controller[0]: Node.js v18.18.0
        2023-10-01 15:22:56.568  - error: host.RaspberryPi3B1GB instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2023-10-01 15:22:56.569  - info: host.RaspberryPi3B1GB Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          Thomas Braun Most Active @SpeedyBlade last edited by Thomas Braun
          @speedyblade sagte in Nach Update läuft nichts mehr!:
          throttled=0x50000 Other values than 0x0 hint to temperature/voltage problems temp=63.9'C volt=1.3062V
          Der Kiste ist unwohl. Zu warm, zu viel Strom.
          Das Dateisystem hat 'nen Treffer.
            @speedyblade
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
              piuser@RaspberryPi3B1GB:~ $ cd /opt/iobroker
              npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly
              npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
              npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
              npm WARN deprecated node-pre-gyp@0.14.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
              up to date in 39s
              54 packages are looking for funding
                run `npm fund` for details
                hab netzteil, welches ich spannung einstellen kann
                zeigt mir sauber 5V an
                zu warm, ist auch merkwürdig...liegt direkt vor mir auf dem Tisch
                  @speedyblade
                  Der Code 0X50005 zeigt jedenfalls Probleme in der Spannungsversorgung an.
                  iob status
                  sagt?
                    Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                    @thomas-braun sagte in Nach Update läuft nichts mehr!:
                    @speedyblade
                    iob status
                    sagt?
                    Möglicherweise sind auch hier schon
                    zu wenig.
                    Spätestens der Pi4 braucht mehr.
                    Würde auch die Probleme im FS erklären, wenn es zu under-voltage gekommen war
                      SpeedyBlade @Homoran last edited by
                      es handelt sich hier um einen PI3plus
                      piuser@RaspberryPi3B1GB:/opt/iobroker $ iob status
                      Objects type: jsonl
                      States  type: jsonl
                        Prima, läuft doch.
                          jetzt wieder
                          hat mir aber nicht alle Adapter nach dem update installiert
                          Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                            @speedyblade
                            iob update
                            sagt? Besser noch die Langfassung von
                            iob diag
                              piuser@RaspberryPi3B1GB:/opt/iobroker $ iob update
                              Adapter    "admin"        : 6.10.1   , installed 6.10.1
                              Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                              Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
                              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                              Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                              Adapter    "web"          : 6.1.2    , installed 6.1.2
                              Adapter    "ws"           : 2.5.5    , installed 2.5.5
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                               17:14:12 up  3:13,  1 user,  load average: 0.61, 0.57, 0.66
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x50000
                              temp=62.3'C
                              volt=1.3062V
                                             Local time: Sun 2023-10-01 17:14:12 CEST
                                         Universal time: Sun 2023-10-01 15:14:12 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              piuser
                              /home/piuser
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            909M        387M        227M        0.0K        294M        458M
                              Swap:            99M         20M         79M
                              Total:          1.0G        407M        306M
                                        909 M total memory
                                        387 M used memory
                                        445 M active memory
                                        110 M inactive memory
                                        227 M free memory
                                         16 M buffer memory
                                        277 M swap cache
                                         99 M total swap
                                         20 M used swap
                                         79 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /dev/root      ext4      294G  2.9G  279G   2% /
                              tmpfs          tmpfs     182M  980K  181M   1% /run
                              /var:
                              570M    /var/
                              234M    /var/cache
                              228M    /var/cache/apt
                              147M    /var/lib
                              70M     /opt/iobroker/iobroker-data/
                              52M     /opt/iobroker/iobroker-data/files
                              30M     /opt/iobroker/iobroker-data/files/web.admin/static
                              29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
                              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                              8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                              6.5M    /opt/iobroker/iobroker-data/objects.jsonl
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.10.1
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.doorbird.0               : doorbird              : RaspberryPi3B1GB                         -  enabled
                              + system.adapter.harmony.0                : harmony               : RaspberryPi3B1GB                         -  enabled
                              + instance is alive
                              Objects and States
                              Objects:        832
                              States:         677
                              Hit:1 http://deb.debian.org/debian bullseye InRelease
                              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:58193           0.0.0.0:*               LISTEN      107        52343      14782/rpc.statd
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50821      14679/iobroker.js-c
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50816      14679/iobroker.js-c
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          52321      1/init
                              tcp6       0      0 :::39761                :::*                    LISTEN      107        52347      14782/rpc.statd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49916      14706/io.admin.0
                              tcp6       0      0 :::61991                :::*                    LISTEN      1001       52553      15043/io.harmony.0
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          51296      1/init
                              udp        0      0 127.0.0.1:966           0.0.0.0:*                           0          52337      14782/rpc.statd
                              udp        0      0 0.0.0.0:38950           0.0.0.0:*                           107        52341      14782/rpc.statd
                              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       52554      15043/io.harmony.0
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51292      1/init
                              udp6       0      0 :::41434                :::*                                107        52345      14782/rpc.statd
                              udp6       0      0 :::111                  :::*                                0          51300      1/init
                              2023-10-01 17:09:12.284  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.WOHNZIMMER.Off" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.287  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PowerOff" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.289  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionDown" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.292  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionLeft" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.294  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionRight" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.296  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionUp" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.298  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Select" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.301  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Stop" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.303  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Play" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.306  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Rewind" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.308  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Pause" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.311  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.FastForward" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.327  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Back" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.329  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Search" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.333  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Cross" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.336  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Circle" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.339  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Square" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.342  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Triangle" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.345  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Info" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.348  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Next_Video" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.351  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Options" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.354  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Previous_Video" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.356  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PS" has to be type "number" but received type "string"
                              2023-10-01 17:09:12.359  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Share" has to be type "number" but received type "string"
                              2023-10-01 17:13:46.508  - error: host.RaspberryPi3B1GB cannot call visUtils: Not exists
                                @speedyblade
                                Starte die Kiste mal ordentlich!!! neu.
                                sudo reboot
                                  Homoran Global Moderator Administrators @SpeedyBlade last edited by
                                  was fehlt?
                                      hastcdu während der rebuilds den iob in Ruhe gelassen?
                                        jup...nichts daran gemacht
                                          Homoran Global Moderator Administrators @SpeedyBlade last edited by Homoran
                                          @speedyblade und sicher dass die alle im Backup drin sind?
                                          edit:
                                          klar! sonst sähest du sie nicht im admin
                                          edit2
                                          was macht enum zwischen den Instanzen?
                                          da ist wirklich was krumm
                                            Wildbill @Homoran last edited by Wildbill
                                            @homoran enum taucht bei den Objekten auf, wenn man den Expertenmodus aktiviert.
                                            Gruss, Jürgen
                                            EDIT: Denn der Screenshot zeigt einen Ausschnitt aus der Objektseite, nicht der Instanzenseite.
                                            help wanted iobroker update js controller update json npm
                                            18
                                            416
                                            56167
