    4. Nach Update läuft nichts mehr!
      SpeedyBlade @Thomas Braun last edited by
         Static hostname: RaspberryPi3B1GB
               Icon name: computer
              Machine ID: 0a3492672676440e91094afe51dc1729
                 Boot ID: 014394ca8eed41a288a0b89111927ea2
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       15:25:26 up  1:24,  1 user,  load average: 1.04, 3.03, 1.99
      CPU threads: 4
      Raspberry only:
      throttled=0x50000
      Other values than 0x0 hint to temperature/voltage problems
      temp=63.9'C
      volt=1.3062V
      *** Time and Time Zones ***
                     Local time: Sun 2023-10-01 15:25:27 CEST
                 Universal time: Sun 2023-10-01 13:25:27 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CEST, +0200)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      piuser
      /home/piuser
      piuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            909M        118M        586M        0.0K        204M        717M
      Swap:            99M         65M         34M
      Total:          1.0G        184M        620M
                909 M total memory
                118 M used memory
                154 M active memory
                 71 M inactive memory
                586 M free memory
                  8 M buffer memory
                195 M swap cache
                 99 M total swap
                 65 M used swap
                 34 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      294G  2.8G  279G   1% /
      devtmpfs       devtmpfs  325M     0  325M   0% /dev
      tmpfs          tmpfs     455M     0  455M   0% /dev/shm
      tmpfs          tmpfs     182M  968K  181M   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
      [Sun Oct  1 14:00:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=86e36461-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): recovery complete
      [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Oct  1 14:00:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sun Oct  1 14:00:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      570M    /var/
      234M    /var/cache
      228M    /var/cache/apt
      147M    /var/lib
      128M    /var/cache/apt/archives
      Archived and active journals take up 88.0M in the file system.
      /opt/iobroker/backups:
      1.4M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      45M     /opt/iobroker/iobroker-data/
      28M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.9M    /opt/iobroker/iobroker-data/objects.jsonl
      4.4M    /opt/iobroker/iobroker-data/objects.json.migrated
      4.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      4.4M    /opt/iobroker/iobroker-data/files/web.admin/static/js/2.d0deddb4.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          5.2.3
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
        system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : RaspberryPi3B1GB                         -  enabled
        system.adapter.discovery.0              : discovery             : RaspberryPi3B1GB                         - disabled
        system.adapter.mqtt.0                   : mqtt                  : RaspberryPi3B1GB                         - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.node-red.0               : node-red              : RaspberryPi3B1GB                         - disabled, port: 1885, bind: 0.0.0.0
        system.adapter.rpi2.0                   : rpi2                  : RaspberryPi3B1GB                         - disabled
        system.adapter.socketio.0               : socketio              : RaspberryPi3B1GB                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : RaspberryPi3B1GB                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 5.2.3  [Updatable]
      Adapter    "backitup"     : 2.8.1    , installed 2.2.3  [Updatable]
      Adapter    "discovery"    : 3.1.0    , installed 2.7.3  [Updatable]
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "mqtt"         : 4.1.1    , installed 2.4.0  [Updatable]
      Adapter    "node-red"     : 4.0.3    , installed 2.4.1  [Updatable]
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
      Adapter    "socketio"     : 6.5.5    , installed 3.1.5  [Updatable]
      Adapter    "web"          : 6.1.2    , installed 3.4.16 [Updatable]
      Objects and States
      Objects:        360
      States:         230
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37390      8921/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37385      8921/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14409      517/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14411      517/sshd: /usr/sbin
      udp        0      0 0.0.0.0:44571           0.0.0.0:*                           108        14352      388/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1767       574/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14350      388/avahi-daemon: r
      udp6       0      0 :::56729                :::*                                108        14353      388/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        14351      388/avahi-daemon: r
      2023-10-01 15:22:47.009  - info: host.RaspberryPi3B1GB iobroker npm-rebuild: Rebuilding native modules done
      2023-10-01 15:22:48.051  - info: host.RaspberryPi3B1GB iobroker npm-rebuild: exit 0
      2023-10-01 15:22:48.278  - info: host.RaspberryPi3B1GB instance system.adapter.admin.0 started with pid 10379
      2023-10-01 15:22:56.545  - error: host.RaspberryPi3B1GB Caught by controller[0]: node:internal/modules/cjs/loader:1080
      2023-10-01 15:22:56.547  - error: host.RaspberryPi3B1GB Caught by controller[0]:   throw err;
      2023-10-01 15:22:56.548  - error: host.RaspberryPi3B1GB Caught by controller[0]:   ^
      2023-10-01 15:22:56.549  - error: host.RaspberryPi3B1GB Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
      2023-10-01 15:22:56.550  - error: host.RaspberryPi3B1GB Caught by controller[0]: Require stack:
      2023-10-01 15:22:56.551  - error: host.RaspberryPi3B1GB Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
      2023-10-01 15:22:56.552  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
      2023-10-01 15:22:56.552  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
      2023-10-01 15:22:56.553  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-10-01 15:22:56.554  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:119:18)
      2023-10-01 15:22:56.555  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
      2023-10-01 15:22:56.556  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-10-01 15:22:56.557  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-10-01 15:22:56.558  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-10-01 15:22:56.560  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
      2023-10-01 15:22:56.563  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) {
      2023-10-01 15:22:56.564  - error: host.RaspberryPi3B1GB Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
      2023-10-01 15:22:56.564  - error: host.RaspberryPi3B1GB Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
      2023-10-01 15:22:56.565  - error: host.RaspberryPi3B1GB Caught by controller[0]: }
      2023-10-01 15:22:56.566  - error: host.RaspberryPi3B1GB Caught by controller[0]: Node.js v18.18.0
      2023-10-01 15:22:56.568  - error: host.RaspberryPi3B1GB instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-10-01 15:22:56.569  - info: host.RaspberryPi3B1GB Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        Thomas Braun Most Active @SpeedyBlade last edited by Thomas Braun
        @speedyblade sagte in Nach Update läuft nichts mehr!:
        throttled=0x50000 Other values than 0x0 hint to temperature/voltage problems temp=63.9'C volt=1.3062V
        Der Kiste ist unwohl. Zu warm, zu viel Strom.
        Das Dateisystem hat 'nen Treffer.
          @speedyblade
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
            piuser@RaspberryPi3B1GB:~ $ cd /opt/iobroker
            npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly
            npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
            npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
            npm WARN deprecated node-pre-gyp@0.14.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
            up to date in 39s
            54 packages are looking for funding
              run `npm fund` for details
              hab netzteil, welches ich spannung einstellen kann
              zeigt mir sauber 5V an
              zu warm, ist auch merkwürdig...liegt direkt vor mir auf dem Tisch
                @speedyblade
                Der Code 0X50005 zeigt jedenfalls Probleme in der Spannungsversorgung an.
                iob status
                sagt?
                  Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                  @thomas-braun sagte in Nach Update läuft nichts mehr!:
                  @speedyblade
                  iob status
                  sagt?
                  Möglicherweise sind auch hier schon
                  zu wenig.
                  Spätestens der Pi4 braucht mehr.
                  Würde auch die Probleme im FS erklären, wenn es zu under-voltage gekommen war
                    SpeedyBlade @Homoran last edited by
                    es handelt sich hier um einen PI3plus
                    piuser@RaspberryPi3B1GB:/opt/iobroker $ iob status
                    Objects type: jsonl
                    States  type: jsonl
                      Prima, läuft doch.
                        jetzt wieder
                        hat mir aber nicht alle Adapter nach dem update installiert
                        Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                          @speedyblade
                          iob update
                          sagt? Besser noch die Langfassung von
                          iob diag
                            piuser@RaspberryPi3B1GB:/opt/iobroker $ iob update
                            Adapter    "admin"        : 6.10.1   , installed 6.10.1
                            Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                            Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
                            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                            Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                            Adapter    "web"          : 6.1.2    , installed 6.1.2
                            Adapter    "ws"           : 2.5.5    , installed 2.5.5
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             17:14:12 up  3:13,  1 user,  load average: 0.61, 0.57, 0.66
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x50000
                            temp=62.3'C
                            volt=1.3062V
                                           Local time: Sun 2023-10-01 17:14:12 CEST
                                       Universal time: Sun 2023-10-01 15:14:12 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            piuser
                            /home/piuser
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            909M        387M        227M        0.0K        294M        458M
                            Swap:            99M         20M         79M
                            Total:          1.0G        407M        306M
                                      909 M total memory
                                      387 M used memory
                                      445 M active memory
                                      110 M inactive memory
                                      227 M free memory
                                       16 M buffer memory
                                      277 M swap cache
                                       99 M total swap
                                       20 M used swap
                                       79 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4      294G  2.9G  279G   2% /
                            tmpfs          tmpfs     182M  980K  181M   1% /run
                            /var:
                            570M    /var/
                            234M    /var/cache
                            228M    /var/cache/apt
                            147M    /var/lib
                            70M     /opt/iobroker/iobroker-data/
                            52M     /opt/iobroker/iobroker-data/files
                            30M     /opt/iobroker/iobroker-data/files/web.admin/static
                            29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
                            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                            6.5M    /opt/iobroker/iobroker-data/objects.jsonl
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.10.1
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.doorbird.0               : doorbird              : RaspberryPi3B1GB                         -  enabled
                            + system.adapter.harmony.0                : harmony               : RaspberryPi3B1GB                         -  enabled
                            + instance is alive
                            Objects and States
                            Objects:        832
                            States:         677
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:58193           0.0.0.0:*               LISTEN      107        52343      14782/rpc.statd
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50821      14679/iobroker.js-c
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50816      14679/iobroker.js-c
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          52321      1/init
                            tcp6       0      0 :::39761                :::*                    LISTEN      107        52347      14782/rpc.statd
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49916      14706/io.admin.0
                            tcp6       0      0 :::61991                :::*                    LISTEN      1001       52553      15043/io.harmony.0
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          51296      1/init
                            udp        0      0 127.0.0.1:966           0.0.0.0:*                           0          52337      14782/rpc.statd
                            udp        0      0 0.0.0.0:38950           0.0.0.0:*                           107        52341      14782/rpc.statd
                            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       52554      15043/io.harmony.0
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51292      1/init
                            udp6       0      0 :::41434                :::*                                107        52345      14782/rpc.statd
                            udp6       0      0 :::111                  :::*                                0          51300      1/init
                            2023-10-01 17:09:12.284  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.WOHNZIMMER.Off" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.287  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PowerOff" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.289  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionDown" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.292  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionLeft" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.294  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionRight" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.296  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionUp" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.298  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Select" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.301  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Stop" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.303  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Play" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.306  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Rewind" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.308  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Pause" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.311  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.FastForward" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.327  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Back" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.329  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Search" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.333  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Cross" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.336  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Circle" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.339  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Square" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.342  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Triangle" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.345  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Info" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.348  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Next_Video" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.351  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Options" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.354  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Previous_Video" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.356  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PS" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.359  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Share" has to be type "number" but received type "string"
                            2023-10-01 17:13:46.508  - error: host.RaspberryPi3B1GB cannot call visUtils: Not exists
                              @speedyblade
                              Starte die Kiste mal ordentlich!!! neu.
                              sudo reboot
                                Homoran Global Moderator Administrators @SpeedyBlade last edited by
                                was fehlt?
                                    hastcdu während der rebuilds den iob in Ruhe gelassen?
                                      jup...nichts daran gemacht
                                        Homoran Global Moderator Administrators @SpeedyBlade last edited by Homoran
                                        @speedyblade und sicher dass die alle im Backup drin sind?
                                        edit:
                                        klar! sonst sähest du sie nicht im admin
                                        edit2
                                        was macht enum zwischen den Instanzen?
                                        da ist wirklich was krumm
                                          Wildbill @Homoran last edited by Wildbill
                                          @homoran enum taucht bei den Objekten auf, wenn man den Expertenmodus aktiviert.
                                          Gruss, Jürgen
                                          EDIT: Denn der Screenshot zeigt einen Ausschnitt aus der Objektseite, nicht der Instanzenseite.
                                            Homoran Global Moderator Administrators @Wildbill last edited by
                                            @wildbill sagte in Nach Update läuft nichts mehr!:
                                            soweit zu abgeschnittenen Informationen!
                                            @SpeedyBlade
                                            bitte Instanzen zeigen.
                                            Vollständig, nichts abschneiden.
                                            help wanted iobroker update js controller update json npm
                                            18
                                            416
                                            56154
