    4. Nach Update läuft nichts mehr!
      SpeedyBlade @Homoran last edited by
      es handelt sich hier um einen PI3plus
      piuser@RaspberryPi3B1GB:/opt/iobroker $ iob status
      Objects type: jsonl
      States  type: jsonl
        Thomas Braun Most Active @SpeedyBlade last edited by
        @speedyblade sagte in Nach Update läuft nichts mehr!:
        Prima, läuft doch.
          SpeedyBlade @Thomas Braun last edited by
          jetzt wieder
          hat mir aber nicht alle Adapter nach dem update installiert
          Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
            @speedyblade
            iob update
            sagt? Besser noch die Langfassung von
            iob diag
              piuser@RaspberryPi3B1GB:/opt/iobroker $ iob update
              Used repository: stable
              Adapter    "admin"        : 6.10.1   , installed 6.10.1
              Adapter    "backitup"     : 2.8.1    , installed 2.8.1
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
              Adapter    "node-red"     : 4.0.3    , installed 4.0.3
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "web"          : 6.1.2    , installed 6.1.2
              Adapter    "ws"           : 2.5.5    , installed 2.5.5
              *** BASE SYSTEM ***
                 Static hostname: RaspberryPi3B1GB
                       Icon name: computer
                      Machine ID: 0a3492672676440e91094afe51dc1729
                         Boot ID: 014394ca8eed41a288a0b89111927ea2
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 3 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               17:14:12 up  3:13,  1 user,  load average: 0.61, 0.57, 0.66
              CPU threads: 4
              Raspberry only:
              throttled=0x50000
              Other values than 0x0 hint to temperature/voltage problems
              temp=62.3'C
              volt=1.3062V
              *** Time and Time Zones ***
                             Local time: Sun 2023-10-01 17:14:12 CEST
                         Universal time: Sun 2023-10-01 15:14:12 UTC
                               RTC time: n/a
                              Time zone: Europe/Vienna (CEST, +0200)
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              piuser
              /home/piuser
              piuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            909M        387M        227M        0.0K        294M        458M
              Swap:            99M         20M         79M
              Total:          1.0G        407M        306M
                        909 M total memory
                        387 M used memory
                        445 M active memory
                        110 M inactive memory
                        227 M free memory
                         16 M buffer memory
                        277 M swap cache
                         99 M total swap
                         20 M used swap
                         79 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4      294G  2.9G  279G   2% /
              devtmpfs       devtmpfs  325M     0  325M   0% /dev
              tmpfs          tmpfs     455M     0  455M   0% /dev/shm
              tmpfs          tmpfs     182M  980K  181M   1% /run
              /dev/sda1      vfat      255M   31M  225M  13% /boot
              tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
              [Sun Oct  1 14:00:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=86e36461-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
              [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): write access will be enabled during recovery
              [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): recovery complete
              [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sun Oct  1 14:00:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
              [Sun Oct  1 14:00:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
              Show mounted filesystems (real ones only):
              TARGET  SOURCE    FSTYPE OPTIONS
              /       /dev/sda2 ext4   rw,noatime
              `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              570M    /var/
              234M    /var/cache
              228M    /var/cache/apt
              147M    /var/lib
              128M    /var/cache/apt/archives
              Archived and active journals take up 88.0M in the file system.
              /opt/iobroker/backups:
              1.4M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              70M     /opt/iobroker/iobroker-data/
              52M     /opt/iobroker/iobroker-data/files
              30M     /opt/iobroker/iobroker-data/files/web.admin/static
              29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
              8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
              6.5M    /opt/iobroker/iobroker-data/objects.jsonl
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              4.4M    /opt/iobroker/iobroker-data/objects.json.migrated
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.0
              /usr/bin/node           v18.18.0
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Installed: 18.18.0-1nodesource1
                Candidate: 18.18.0-1nodesource1
                Version table:
               *** 18.18.0-1nodesource1 1001
                      100 /var/lib/dpkg/status
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              No configuration change needed.
              Multihost discovery server: disabled
              Discovery authentication:   enabled
              Persistent activation:      disabled
              Objects:                    jsonl on 127.0.0.1
              States:                     jsonl on 127.0.0.1
              Core adapters versions
              js-controller:  5.0.12
              admin:          6.10.1
              javascript:     "javascript" not found
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : RaspberryPi3B1GB                         -  enabled
                system.adapter.discovery.0              : discovery             : RaspberryPi3B1GB                         - disabled
              + system.adapter.doorbird.0               : doorbird              : RaspberryPi3B1GB                         -  enabled
              + system.adapter.harmony.0                : harmony               : RaspberryPi3B1GB                         -  enabled
                system.adapter.mqtt.0                   : mqtt                  : RaspberryPi3B1GB                         - disabled, port: 1883, bind: 0.0.0.0
                system.adapter.node-red.0               : node-red              : RaspberryPi3B1GB                         - disabled, port: 1885, bind: 0.0.0.0
                system.adapter.rpi2.0                   : rpi2                  : RaspberryPi3B1GB                         - disabled
                system.adapter.socketio.0               : socketio              : RaspberryPi3B1GB                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                system.adapter.web.0                    : web                   : RaspberryPi3B1GB                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Objects and States
              Objects:        832
              States:         677
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:58193           0.0.0.0:*               LISTEN      107        52343      14782/rpc.statd
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50821      14679/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50816      14679/iobroker.js-c
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14409      517/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          52321      1/init
              tcp6       0      0 :::39761                :::*                    LISTEN      107        52347      14782/rpc.statd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49916      14706/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          14411      517/sshd: /usr/sbin
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       52553      15043/io.harmony.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          51296      1/init
              udp        0      0 127.0.0.1:966           0.0.0.0:*                           0          52337      14782/rpc.statd
              udp        0      0 0.0.0.0:44571           0.0.0.0:*                           108        14352      388/avahi-daemon: r
              udp        0      0 0.0.0.0:38950           0.0.0.0:*                           107        52341      14782/rpc.statd
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       52554      15043/io.harmony.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1767       574/dhcpcd
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51292      1/init
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14350      388/avahi-daemon: r
              udp6       0      0 :::56729                :::*                                108        14353      388/avahi-daemon: r
              udp6       0      0 :::41434                :::*                                107        52345      14782/rpc.statd
              udp6       0      0 :::111                  :::*                                0          51300      1/init
              udp6       0      0 :::5353                 :::*                                108        14351      388/avahi-daemon: r
              2023-10-01 17:09:12.284  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.WOHNZIMMER.Off" has to be type "number" but received type "string"
              2023-10-01 17:09:12.287  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PowerOff" has to be type "number" but received type "string"
              2023-10-01 17:09:12.289  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionDown" has to be type "number" but received type "string"
              2023-10-01 17:09:12.292  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionLeft" has to be type "number" but received type "string"
              2023-10-01 17:09:12.294  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionRight" has to be type "number" but received type "string"
              2023-10-01 17:09:12.296  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionUp" has to be type "number" but received type "string"
              2023-10-01 17:09:12.298  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Select" has to be type "number" but received type "string"
              2023-10-01 17:09:12.301  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Stop" has to be type "number" but received type "string"
              2023-10-01 17:09:12.303  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Play" has to be type "number" but received type "string"
              2023-10-01 17:09:12.306  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Rewind" has to be type "number" but received type "string"
              2023-10-01 17:09:12.308  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Pause" has to be type "number" but received type "string"
              2023-10-01 17:09:12.311  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.FastForward" has to be type "number" but received type "string"
              2023-10-01 17:09:12.327  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Back" has to be type "number" but received type "string"
              2023-10-01 17:09:12.329  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Search" has to be type "number" but received type "string"
              2023-10-01 17:09:12.333  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Cross" has to be type "number" but received type "string"
              2023-10-01 17:09:12.336  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Circle" has to be type "number" but received type "string"
              2023-10-01 17:09:12.339  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Square" has to be type "number" but received type "string"
              2023-10-01 17:09:12.342  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Triangle" has to be type "number" but received type "string"
              2023-10-01 17:09:12.345  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Info" has to be type "number" but received type "string"
              2023-10-01 17:09:12.348  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Next_Video" has to be type "number" but received type "string"
              2023-10-01 17:09:12.351  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Options" has to be type "number" but received type "string"
              2023-10-01 17:09:12.354  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Previous_Video" has to be type "number" but received type "string"
              2023-10-01 17:09:12.356  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PS" has to be type "number" but received type "string"
              2023-10-01 17:09:12.359  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Share" has to be type "number" but received type "string"
              2023-10-01 17:13:46.508  - error: host.RaspberryPi3B1GB cannot call visUtils: Not exists
                @speedyblade
                Starte die Kiste mal ordentlich!!! neu.
                sudo reboot
                  Homoran Global Moderator Administrators @SpeedyBlade last edited by
                  was fehlt?
                      hastcdu während der rebuilds den iob in Ruhe gelassen?
                        jup...nichts daran gemacht
                          Homoran Global Moderator Administrators @SpeedyBlade last edited by Homoran
                          @speedyblade und sicher dass die alle im Backup drin sind?
                          edit:
                          klar! sonst sähest du sie nicht im admin
                          edit2
                          was macht enum zwischen den Instanzen?
                          da ist wirklich was krumm
                            Wildbill @Homoran last edited by Wildbill
                            @homoran enum taucht bei den Objekten auf, wenn man den Expertenmodus aktiviert.
                            Gruss, Jürgen
                            EDIT: Denn der Screenshot zeigt einen Ausschnitt aus der Objektseite, nicht der Instanzenseite.
                              Homoran Global Moderator Administrators @Wildbill last edited by
                              @wildbill sagte in Nach Update läuft nichts mehr!:
                              soweit zu abgeschnittenen Informationen!
                              @SpeedyBlade
                              bitte Instanzen zeigen.
                              Vollständig, nichts abschneiden.
                                ich werde den neu aufsetzen...
                                hab nun noch einmal das backup aufgespielt
                                das war ein testgerät, aber gut zu wissen, dass ein backup nicht so sauber durchläuft, wie es soll
                                danke euch dennoch
                                  Generell schon. Ist ein individuelles Problem.
                                    hey
                                    @thomas-braun sagte in Nach Update läuft nichts mehr!:
                                    Das Dateisystem hat 'nen Treffer.
                                    und die letzten Fragen sind auch noch unbeantwortet
                                        @speedyblade danke!
                                        dann bleibt doch wieder die Frage was im Backup drin ist.
                                        (und der Header fehlt immer noch)
                                        help wanted iobroker update js controller update json npm
                                        18
                                        416
                                        56154
