    4. kann vis nicht installieren
      LJSven @Homoran last edited by
      sven@tinkerboard:/opt/iobroker$ iob install vis@1.4.10
      NPM version: 9.6.7
      Installing iobroker.vis@1.4.10... (System call)
      npm ERR! code 6
      npm ERR! path /opt/iobroker/node_modules/iobroker.vis
      npm ERR! command failed
      npm ERR! command sh -c node main.js --install
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-01T19_10_20_398Z-debug-0.log
      host.tinkerboard Cannot install iobroker.vis@1.4.10: 6
        Thomas Braun Most Active @LJSven last edited by
        @ljsven sagte in VIS: Keine gültige Lizenz gefunden:
        iob upgrade vis@1.4.10
          Homoran Global Moderator Administrators @LJSven last edited by
          @ljsven ich hab das mal abgetrennt, hat ja mit der Lizenz nichts zu tun
          was sagt iob diag in der Langfassung?
            @thomas-braun dann müsste vis ja schon installiert sein, was angeblich nicht geht.
            das wollte ich erst sehen
              Skript v.2023-06-20
              *** BASE SYSTEM ***
               Static hostname: tinkerboard
                     Icon name: computer
                    Machine ID: affa5e932b3247b79051b4333d4219f7
                       Boot ID: 3ae4f613cf714e029c51e550b44607a3
              Operating System: Armbian 23.8.3 bookworm
                        Kernel: Linux 6.1.50-current-rockchip
                  Architecture: arm
              model name	: ARMv7 Processor rev 1 (v7l)
              Docker          : false
              Virtualization  : none
              Kernel          : armv7l
              Userland        : armhf
              Systemuptime and Load:
               21:24:09 up  6:04,  2 users,  load average: 0.86, 0.50, 0.35
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Sun 2023-10-01 21:24:09 CEST
                         Universal time: Sun 2023-10-01 19:24:09 UTC
                               RTC time: Sun 2023-10-01 19:24:10
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              sven
              /home/sven
              sven tty disk dialout sudo audio video plugdev games users input netdev bluetooth systemd-journal iobroker
              *** X-Server-Setup ***
              X-Server: 	false
              Desktop:
              Terminal: 	tty
              Boot Target: 	graphical.target
              *** MEMORY ***
              Mem:            2.1G        1.4G        358M        2.7M        458M        750M
              Swap:           1.1G        786K        1.0G
              Total:          3.2G        1.4G        1.4G
                       2004 M total memory
                       1288 M used memory
                       1279 M active memory
                        261 M inactive memory
                        342 M free memory
                         48 M buffer memory
                        388 M swap cache
                       1002 M total swap
                          0 M used swap
                       1001 M free swap
              *** FILESYSTEM ***
              udev           devtmpfs  990M     0  990M   0% /dev
              tmpfs          tmpfs     201M  3.1M  198M   2% /run
              /dev/mmcblk1p1 ext4       57G  3.9G   53G   7% /
              tmpfs          tmpfs    1003M     0 1003M   0% /dev/shm
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs    1003M     0 1003M   0% /tmp
              /dev/zram1     ext4       47M  1.9M   42M   5% /var/log
              tmpfs          tmpfs     201M     0  201M   0% /run/user/1000
              [Sun Oct  1 15:19:25 2023] Kernel command line: earlyprintk root=UUID=5171d208-24a4-446e-a0a7-673ec46f0c58 rootwait rootfstype=ext4 splash=verbose console=ttyS2,115200n8 console=tty1 consoleblank=0 loglevel=1 ubootpart=2215e05a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
              [Sun Oct  1 15:19:30 2023] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Quota mode: none.
              [Sun Oct  1 15:19:32 2023] EXT4-fs (mmcblk1p1): re-mounted. Quota mode: none.
              [Sun Oct  1 15:19:35 2023] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
              Show mounted filesystems (real ones only):
              TARGET         SOURCE                   FSTYPE OPTIONS
              /              /dev/mmcblk1p1           ext4   rw,noatime,errors=remount-ro,commit=600
              |-/var/log.hdd /dev/mmcblk1p1[/var/log] ext4   rw,noatime,errors=remount-ro,commit=600
              `-/var/log     /dev/zram1               ext4   rw,relatime,discard
              /var:
              385M	/var/
              226M	/var/cache
              221M	/var/cache/apt
              153M	/var/cache/apt/archives
              151M	/var/lib
              Archived and active journals take up 6.4M in the file system.
              /opt/iobroker/backups:
              24M	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              395M	/opt/iobroker/iobroker-data/
              305M	/opt/iobroker/iobroker-data/files
              52M	/opt/iobroker/iobroker-data/files/javascript.admin
              34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
              33M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
              44M	/opt/iobroker/iobroker-data/objects.jsonl
              21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
              20M	/opt/iobroker/iobroker-data/states.jsonl
              19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
              8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v18.17.1
              /usr/bin/node 		v18.17.1
              /usr/bin/npm 		9.6.7
              /usr/bin/npx 		9.6.7
              nodejs:
                Installed: 18.17.1-deb-1nodesource1
                Candidate: 18.17.1-deb-1nodesource1
                Version table:
               *** 18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bookworm/main armhf Packages
                      100 /var/lib/dpkg/status
                   18.13.0+dfsg1-1 500
                      500 http://deb.debian.org/debian bookworm/main armhf Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              No configuration change needed.
              Multihost discovery server: disabled
              Discovery authentication:   enabled
              Persistent activation:      disabled
              Objects:                    jsonl on 0.0.0.0
              States:                     jsonl on 0.0.0.0
              Core adapters versions
              js-controller: 	5.0.12
              admin: 		6.10.1
              javascript: 	7.1.4
              Adapters from github: 	1
              Adapter State
              + system.adapter.admin.0                  : admin                 : tinkerboard                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : tinkerboard                              -  enabled
                system.adapter.asterisk.0               : asterisk              : raspberrypi                              - disabled, port: 5038
              + system.adapter.backitup.0               : backitup              : tinkerboard                              -  enabled
                system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberryzeropi                          - disabled
                system.adapter.daswetter.0              : daswetter             : tinkerboard                              - disabled
                system.adapter.deconz.0                 : deconz                : tinkerboard                              - disabled, port: 80
                system.adapter.device-reminder.0        : device-reminder       : tinkerboard                              - disabled
                system.adapter.discovery.0              : discovery             : tinkerboard                              - disabled
                system.adapter.email.0                  : email                 : raspberrypi                              - disabled
                system.adapter.enigma2.0                : enigma2               : tinkerboard                              - disabled
                system.adapter.enigma2.1                : enigma2               : tinkerboard                              - disabled
                system.adapter.flot.0                   : flot                  : tinkerboard                              - disabled
                system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
              + system.adapter.geofency.0               : geofency              : raspberrypi                              -  enabled, port: 7999, bind: 0.0.0.0
                system.adapter.history.0                : history               : tinkerboard                              - disabled
                system.adapter.ical.0                   : ical                  : tinkerboard                              -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : tinkerboard                              - disabled
                system.adapter.icons-material-png.0     : icons-material-png    : tinkerboard                              - disabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : tinkerboard                              - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : tinkerboard                              - disabled
                system.adapter.info.0                   : info                  : tinkerboard                              - disabled
              + system.adapter.iot.0                    : iot                   : tinkerboard                              -  enabled
                system.adapter.iqontrol.0               : iqontrol              : tinkerboard                              - disabled
              + system.adapter.javascript.0             : javascript            : tinkerboard                              -  enabled
                system.adapter.lgtv11.0                 : lgtv11                : tinkerboard                              - disabled, port: 8080
              + system.adapter.linkeddevices.0          : linkeddevices         : tinkerboard                              -  enabled
              + system.adapter.mihome.0                 : mihome                : tinkerboard                              -  enabled, port: 9898, bind: 0.0.0.0
              + system.adapter.modbus.0                 : modbus                : tinkerboard                              -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : tinkerboard                              -  enabled, port: 1886, bind: 0.0.0.0
                system.adapter.phantomjs.0              : phantomjs             : tinkerboard                              - disabled
                system.adapter.pvforecast.0             : pvforecast            : tinkerboard                              - disabled
                system.adapter.radar2.0                 : radar2                : raspberryzeropi                          - disabled
                system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
              + system.adapter.scenes.0                 : scenes                : tinkerboard                              -  enabled
              + system.adapter.shelly.0                 : shelly                : tinkerboard                              -  enabled, port: 1888, bind: 0.0.0.0
              + system.adapter.shelly.1                 : shelly                : tinkerboard                              -  enabled, port: 1888, bind: 0.0.0.0
              + system.adapter.simple-api.0             : simple-api            : tinkerboard                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              - disabled
                system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              - disabled
                system.adapter.smartmeter.2             : smartmeter            : raspberrypi                              - disabled
              + system.adapter.smartmeter.3             : smartmeter            : raspberrypi                              -  enabled
              + system.adapter.smartmeter.4             : smartmeter            : raspberrypi                              -  enabled
              + system.adapter.sonoff.0                 : sonoff                : tinkerboard                              -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.sql.0                    : sql                   : tinkerboard                              -  enabled, port: 3306
                system.adapter.tankerkoenig.0           : tankerkoenig          : tinkerboard                              - disabled
              + system.adapter.telegram.0               : telegram              : tinkerboard                              -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                system.adapter.tinker.0                 : tinker                : tinkerboard                              - disabled
                system.adapter.tr-064.0                 : tr-064                : tinkerboard                              - disabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : tinkerboard                              - disabled
                system.adapter.vis-history.0            : vis-history           : tinkerboard                              - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : tinkerboard                              - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : tinkerboard                              - disabled
                system.adapter.vis-metro.0              : vis-metro             : tinkerboard                              - disabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : tinkerboard                              - disabled
                system.adapter.vis.0                    : vis                   : tinkerboard                              -  enabled
              + system.adapter.web.0                    : web                   : tinkerboard                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.wled.0                   : wled                  : tinkerboard                              - disabled
                system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
                system.adapter.yahka.0                  : yahka                 : tinkerboard                              - disabled
              + system.adapter.zigbee.0                 : zigbee                : tinkerboard                              -  enabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Stable (default): http://download.iobroker.net/sources-dist.json
              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
              Active repo(s): Stable (default)
              Installed ioBroker-Instances
              Used repository: Stable (default)
              Adapter    "admin"        : 6.10.1   , installed 6.10.1
              Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
              Adapter    "backitup"     : 2.8.1    , installed 2.8.1
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "deconz"       : 1.3.21   , installed 2.0.5
              Adapter    "device-reminder": 1.2.9  , installed 1.2.9
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "history"      : 2.2.6    , installed 2.2.6
              Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
              Adapter    "iot"          : 1.14.5   , installed 1.14.5
              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
              Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
              Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
              Adapter    "shelly"       : 6.4.1    , installed 6.4.1
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
              Adapter    "sql"          : 2.2.0    , installed 2.2.0
              Adapter    "telegram"     : 1.16.0   , installed 1.16.0
              Adapter    "tinker"       : 1.2.0    , installed 1.2.0
              Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
              Adapter    "web"          : 6.1.2    , installed 6.1.2
              Adapter    "wled"         : 0.6.7    , installed 0.6.7
              Adapter    "ws"           : 2.5.5    , installed 2.5.5
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
              Objects and States
              Objects: 	14809
              States: 	12780
              Hit:1 http://security.debian.org bookworm-security InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 http://deb.debian.org/debian bookworm-backports InRelease
              Hit:6 https://deb.nodesource.com/node_18.x bookworm InRelease
              Hit:5 http://mirror.vinehost.net/armbian/apt bookworm InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17831      1/init
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21509      1081/sshd: /usr/sbi
              tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       23782      1560/io.shelly.1
              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       21271      1526/io.mqtt.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       23878      1598/io.sonoff.0
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       22543      961/iobroker.js-con
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22539      961/iobroker.js-con
              tcp6       0      0 :::111                  :::*                    LISTEN      0          17833      1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          21511      1081/sshd: /usr/sbi
              tcp6       0      0 :::1884                 :::*                    LISTEN      1001       23855      1331/io.javascript.
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       127843     2507/io.simple-api.
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21745      1323/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22018      1662/io.web.0
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17832      1/init
              udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       21207      1473/io.mihome.0
              udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          18367      984/chronyd
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       22845      1541/io.shelly.0
              udp6       0      0 :::111                  :::*                                0          19458      1/init
              udp6       0      0 ::1:323                 :::*                                0          18368      984/chronyd
              udp6       0      0 fe80::79ed:e114:5c1:546 :::*                                0          22533      782/NetworkManager
              2023-10-01 21:12:08.633  - info: vis.0 (4034) vis license is OK.
              2023-10-01 21:12:09.054  - error: vis.0 (4034) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-10-01 21:12:09.055  - error: vis.0 (4034) unhandled promise rejection: Not exists
              2023-10-01 21:12:09.058  - error: vis.0 (4034) Error: Not exists
                  at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
                  at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
                  at process.processImmediate (node:internal/timers:478:21)
              2023-10-01 21:12:09.059  - error: vis.0 (4034) Not exists
              2023-10-01 21:12:09.566  - info: vis.0 (4034) terminating
              2023-10-01 21:12:09.568  - warn: vis.0 (4034) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-10-01 21:15:00.073  - info: host.tinkerboard instance system.adapter.ical.0 started with pid 4046
              2023-10-01 21:15:13.374  - info: host.tinkerboard instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2023-10-01 21:18:44.560  - info: javascript.0 (1331) script.js.common.Sonstige.EG_Aussenbeleuchtung_Haustuer: HT - Beleuchtung über BWM
              2023-10-01 21:23:36.091  - info: vis.0 (4140) Sets unsupported
              2023-10-01 21:23:36.873  - info: vis.0 (4140) starting. Version 1.4.10 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 5.0.12
              2023-10-01 21:23:37.196  - info: vis.0 (4140) vis license is OK.
              2023-10-01 21:23:37.599  - error: vis.0 (4140) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-10-01 21:23:37.600  - error: vis.0 (4140) unhandled promise rejection: Not exists
              2023-10-01 21:23:37.603  - error: vis.0 (4140) Error: Not exists
              2023-10-01 21:23:37.604  - error: vis.0 (4140) Not exists
              2023-10-01 21:23:38.111  - info: vis.0 (4140) terminating
              2023-10-01 21:23:38.112  - warn: vis.0 (4140) Terminated (UNCAUGHT_EXCEPTION): Without reason
                Homoran Global Moderator Administrators @LJSven last edited by Homoran
                @ljsven sagte in kann vis nicht installieren:
                ist installiert!
                also mit
                @thomas-braun sagte in kann vis nicht installieren:
                downgraden, dann per admin wieder upgraden
                danach könntest du den node-fix drüberjagen.
                @Thomas-Braun
                wieso sind die Repos auf Debian und nicht auf Armbian?
                  @homoran sagte in kann vis nicht installieren:
                  sven@tinkerboard:/opt/iobroker$ iob upgrade vis@1.4.10
                  Adapter "vis"            is not installed.
                    @ljsven Ins blaue
                    iob del vis.0
                      @ljsven Ins blaue
                      iob del vis.0
                      Ist dann das ganze File weg?
                        gute Frage!
                        lass es
                          versuch es mal mit einer anderen, niedrigeren Version
                          wenn alle Stricke reissen (iob fix, reboot, Browsercache)
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install iobroker.vis@1.4.10
                            sven@tinkerboard:/opt/iobroker$ iob upgrade vis@1.4.9
                            sven@tinkerboard:/opt/iobroker$ iob upgrade vis@1.4.8
                            sven@tinkerboard:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.vis@1.4.10
                            [sudo] Passwort für sven:
                            npm ERR! code 6
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-01T20_20_04_494Z-debug-0.log
                              @ljsven
                              hab keine Ahnung mehr
                              mach nochmal iob install vis@1.4.10 --debug diesmal mit --debug
                              Vielleicht wird er dann gesprächiger.
                              hier gab es das Problem auch schon
                              https://forum.iobroker.net/post/1042831
                              auch ohne Lösung, aber mit Wunderheilung
                                sven@tinkerboard:/opt/iobroker$ iob install vis@1.4.10 --debug
                                NPM version: 9.6.7
                                npm ERR! code 6
                                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-02T11_03_09_693Z-debug-0.log
                                npm ERR! code 6
                                  LJSven @LJSven last edited by
                                  @Homoran Ich habe Mut zur Lücke bewiesen und den Befehl
                                  iob del vis
                                  ausgeführt. Danach ließ sich der Adapter neu installieren und das File war noch da.
                                  1291
