    4. FLOT nicht mehr aufrufbar - Warnung im Protokoll
      Thomas Braun Most Active @Keulehd last edited by
      @keulehd
      Desktop ausschalten, Updates einspielen und nodejs@18 installieren.
        Keulehd @Homoran last edited by Keulehd
        @homoran Danke das mit der Taste hatte ich übersehen 🙂
        Skript v.2023-06-20
        *** BASE SYSTEM ***
           Static hostname: HomeServer
                 Icon name: computer-desktop
                   Chassis: desktop
                Machine ID: 1592eab9854d408bb2ffeca18adb4314
                   Boot ID: d4b9b898a4b24f82aed54e27b09ea7cd
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.0-25-amd64
              Architecture: x86-64
        model name      : Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         10:30:29 up 16 days, 23:04,  2 users,  load average: 1.48, 1.24, 1.20
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Mon 2023-10-02 10:30:29 CEST
                   Universal time: Mon 2023-10-02 08:30:29 UTC
                         RTC time: Mon 2023-10-02 10:31:39
                      NTP service: active
                  RTC in local TZ: yes
        Warning: The system is configured to read the RTC time in the local time zone.
                 This mode cannot be fully supported. It will create various problems
                 with time zone changes and daylight saving time adjustments. The RTC
                 time is never updated, it relies on external facilities to maintain it.
                 If at all possible, use RTC in UTC by calling
                 'timedatectl set-local-rtc 0'.
        *** User and Groups ***
        iobroker
        /home/iobroker
        iobroker tty dialout sudo audio video bluetooth
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.9G        5.5G        1.2G        2.0M        1.1G        2.0G
        Swap:           976M        950M         26M
        Total:          8.8G        6.5G        1.3G
                 7862 M total memory
                 5538 M used memory
                 2740 M active memory
                 3293 M inactive memory
                 1245 M free memory
                  311 M buffer memory
                  766 M swap cache
                  976 M total swap
                  950 M used swap
                   26 M free swap
        *** FILESYSTEM ***
        Filesystem                              Type      Size  Used Avail Use% Mounted on
        udev                                    devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs                                   tmpfs     787M  1.5M  785M   1% /run
        /dev/sda5                               ext4      135G   36G   93G  28% /
        tmpfs                                   tmpfs     3.9G   16K  3.9G   1% /dev/shm
        tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
        /dev/sda1                               vfat       96M   33M   64M  34% /boot/efi
        tmpfs                                   tmpfs     787M  100K  787M   1% /run/user/1001
        192.168.100.143:/mnt/pools/A/A0/Kameras nfs       5.4T  2.5T  3.0T  45% /media/nas
        [Fri Sep 15 11:26:09 2023] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
        [Fri Sep 15 11:26:14 2023] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems (real ones only):
        TARGET       SOURCE                                  FSTYPE OPTIONS
        /            /dev/sda5                               ext4   rw,relatime,errors=remount-ro
        |-/boot/efi  /dev/sda1                               vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        `-/media/nas 192.168.100.143:/mnt/pools/A/A0/Kameras nfs    rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,soft,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.100.143,mountvers=3,mountport=895,mountproto=udp,local_lock=all,addr=192.168.100.143
        /var:
        28G     /var/
        26G     /var/lib/motioneye/Camera1
        26G     /var/lib
        7.2G    /var/lib/motioneye/Camera1/2023-06-10
        Archived and active journals take up 416.1M in the file system.
        /opt/iobroker/backups:
        94M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        498M    /opt/iobroker/iobroker-data/
        329M    /opt/iobroker/iobroker-data/files
        118M    /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        42M     /opt/iobroker/iobroker-data/files/iot.admin/static
        35M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.b86463fc.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v19.9.0
        /usr/bin/node           v19.9.0
        /usr/bin/npm            9.6.3
        /usr/bin/npx            9.6.3
        nodejs:
          Installed: 19.9.0-deb-1nodesource1
          Candidate: 19.9.0-deb-1nodesource1
          Version table:
         *** 19.9.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_19.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                500 http://deb.debian.org/debian bullseye-proposed-updates/main amd64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.10.1
        javascript:     7.1.4
        Adapters from github:   3
        Adapter State
        + system.adapter.admin.0                  : admin                 : HomeServer                               -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
          system.adapter.alarm.0                  : alarm                 : HomeServer                               - disabled
        + system.adapter.alexa2.0                 : alexa2                : HomeServer                               -  enabled
        + system.adapter.backitup.0               : backitup              : HomeServer                               -  enabled
        + system.adapter.bring.0                  : bring                 : HomeServer                               -  enabled
        + system.adapter.cloud.0                  : cloud                 : HomeServer                               -  enabled
          system.adapter.daswetter.0              : daswetter             : HomeServer                               -  enabled
        + system.adapter.discovery.0              : discovery             : HomeServer                               -  enabled
          system.adapter.dwd.0                    : dwd                   : HomeServer                               -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : HomeServer                               -  enabled
          system.adapter.feiertage.0              : feiertage             : HomeServer                               -  enabled
          system.adapter.flot.0                   : flot                  : HomeServer                               - disabled
        + system.adapter.fritzdect.0              : fritzdect             : HomeServer                               -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : HomeServer                               -  enabled
        + system.adapter.govee.0                  : govee                 : HomeServer                               -  enabled
        + system.adapter.heizoel.0                : heizoel               : HomeServer                               -  enabled
        + system.adapter.history.0                : history               : HomeServer                               -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : HomeServer                               -  enabled
        + system.adapter.hue-extended.0           : hue-extended          : HomeServer                               -  enabled
        + system.adapter.hue.0                    : hue                   : HomeServer                               -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : HomeServer                               -  enabled
          system.adapter.ical.1                   : ical                  : HomeServer                               -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : HomeServer                               -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeServer                               - disabled
        + system.adapter.info.0                   : info                  : HomeServer                               -  enabled
        + system.adapter.iot.0                    : iot                   : HomeServer                               -  enabled
        + system.adapter.javascript.0             : javascript            : HomeServer                               -  enabled
        + system.adapter.linux-control.0          : linux-control         : HomeServer                               -  enabled
        + system.adapter.mediola-gateway.0        : mediola-gateway       : HomeServer                               -  enabled
        + system.adapter.mielecloudservice.0      : mielecloudservice     : HomeServer                               -  enabled
          system.adapter.mobile.0                 : mobile                : HomeServer                               - disabled
        + system.adapter.netatmo.0                : netatmo               : HomeServer                               -  enabled
        + system.adapter.nuki-extended.0          : nuki-extended         : HomeServer                               -  enabled
        + system.adapter.nuki.0                   : nuki                  : HomeServer                               -  enabled
        + system.adapter.nut.0                    : nut                   : HomeServer                               -  enabled
        + system.adapter.parcel.0                 : parcel                : HomeServer                               -  enabled
        + system.adapter.ping.0                   : ping                  : HomeServer                               -  enabled
          system.adapter.scenes.0                 : scenes                : HomeServer                               - disabled
          system.adapter.scheduler.0              : scheduler             : HomeServer                               - disabled
        + system.adapter.shelly.0                 : shelly                : HomeServer                               -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : HomeServer                               -  enabled
        + system.adapter.simple-api.0             : simple-api            : HomeServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeServer                               -  enabled
        + system.adapter.telegram.0               : telegram              : HomeServer                               -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : HomeServer                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0           : text2command          : HomeServer                               -  enabled
        + system.adapter.tr-064.0                 : tr-064                : HomeServer                               -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : HomeServer                               -  enabled
        + system.adapter.tuya.0                   : tuya                  : HomeServer                               -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : HomeServer                               -  enabled
        + system.adapter.velux.0                  : velux                 : HomeServer                               -  enabled
          system.adapter.viessmannapi.0           : viessmannapi          : HomeServer                               - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeServer                               - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeServer                               -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeServer                               - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : HomeServer                               - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeServer                               -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeServer                               - disabled
          system.adapter.vis-metro.0              : vis-metro             : HomeServer                               - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomeServer                               - disabled
          system.adapter.vis-weather.0            : vis-weather           : HomeServer                               - disabled
          system.adapter.vis.0                    : vis                   : HomeServer                               -  enabled
        + system.adapter.web.0                    : web                   : HomeServer                               -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
        + system.adapter.web.1                    : web                   : HomeServer                               -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeServer                               -  enabled
        + system.adapter.zigbee.0                 : zigbee                : HomeServer                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b6218f1c57c9eb118db68d4f1d69213e-if00-port0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        live          : http://iobroker.live/repo/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 6.10.1   , installed 6.10.1
        Adapter    "alarm"        : 3.3.12   , installed 3.3.12
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
        Adapter    "bring"        : 1.8.1    , installed 1.8.1
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
        Adapter    "history"      : 2.2.6    , installed 2.2.6
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "hue"          : 3.10.0   , installed 3.10.0
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "iot"          : 1.14.5   , installed 2.0.3
        Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "parcel"       : 0.0.27   , installed 0.0.30
        Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
        Adapter    "velux"        : 0.0.7    , installed 0.0.7
        Adapter    "viessmannapi" : 2.0.9    , installed 2.1.1
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Objects and States
        Objects:        16232
        States:         13899
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://deb.debian.org/debian bullseye-proposed-updates InRelease
        Get:5 https://deb.nodesource.com/node_19.x bullseye InRelease [4586 B]
        Fetched 4586 B in 0s (11.0 kB/s)
        Reading package lists...
        Pending Updates: 54
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       149471     15332/iobroker.js-c
        tcp        0      0 0.0.0.0:8554            0.0.0.0:*               LISTEN      998        17860      937/monocle-proxy
        tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      998        16298      514/monocle-gateway
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13159      1/init
        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          16677      831/motion
        tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          16678      831/motion
        tcp        0      0 192.168.100.146:40499   0.0.0.0:*               LISTEN      1001       19849      1382/rygel
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16432      553/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          28815763   3047962/cupsd
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19617265   2068566/io.shelly.0
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      998        16299      514/monocle-gateway
        tcp        0      0 127.0.0.1:44829         0.0.0.0:*               LISTEN      1001       21534      1382/rygel
        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16224      471/python2
        tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16679      831/motion
        tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          15121      838/upsd
        tcp        0      0 192.168.100.146:3493    0.0.0.0:*               LISTEN      0          15120      838/upsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       151262     15332/iobroker.js-c
        tcp6       0      0 :::5900                 :::*                    LISTEN      1001       20538      1380/gnome-remote-d
        tcp6       0      0 :::111                  :::*                    LISTEN      0          13163      1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      0          14883      573/apache2
        tcp6       0      0 fe80::921b:eff:fe:42737 :::*                    LISTEN      1001       21536      1382/rygel
        tcp6       0      0 :::8083                 :::*                    LISTEN      1001       29522344   3120517/io.web.0
        tcp6       0      0 :::8085                 :::*                    LISTEN      1001       7480811    803666/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16434      553/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          28815762   3047962/cupsd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       157166     16518/io.simple-api
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       7496542    805968/io.terminal.
        tcp6       0      0 ::1:37885               :::*                    LISTEN      1001       19850      1382/rygel
        tcp6       0      0 :::20002                :::*                    LISTEN      1001       29540207   3122606/io.web.1
        tcp6       0      0 :::41767                :::*                    LISTEN      1001       20543      1416/apache2
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13160      1/init
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          28817212   3048024/cups-browse
        udp        0      0 127.0.0.1:54408         0.0.0.0:*                           1001       19814      1382/rygel
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        12258      465/avahi-daemon: r
        udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       19817      1382/rygel
        udp        0      0 192.168.100.146:1900    0.0.0.0:*                           1001       19816      1382/rygel
        udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       19812      1382/rygel
        udp        0      0 127.0.0.1:1900          0.0.0.0:*                           1001       19811      1382/rygel
        udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       19649119   2072136/io.mediola-
        udp        0      0 192.168.100.146:39339   0.0.0.0:*                           1001       19819      1382/rygel
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       23130468   2438157/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       23130469   2438157/io.tuya.0
        udp        0      0 0.0.0.0:47675           0.0.0.0:*                           1001       19649120   2072136/io.mediola-
        udp        0      0 0.0.0.0:35912           0.0.0.0:*                           110        12260      465/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          13166      1/init
        udp6       0      0 fe80::921b:eff:fe45:546 :::*                                0          15918      468/NetworkManager
        udp6       0      0 :::5353                 :::*                                110        12259      465/avahi-daemon: r
        udp6       0      0 ::1:59194               :::*                                1001       19825      1382/rygel
        udp6       0      0 ::1:1900                :::*                                1001       19822      1382/rygel
        udp6       0      0 ff05::c:1900            :::*                                1001       19823      1382/rygel
        udp6       0      0 fe80::921b:eff:fe4:1900 :::*                                1001       19828      1382/rygel
        udp6       0      0 ff02::c:1900            :::*                                1001       19829      1382/rygel
        udp6       0      0 fe80::921b:eff:fe:47046 :::*                                1001       19831      1382/rygel
        udp6       0      0 :::35528                :::*                                110        12261      465/avahi-daemon: r
        2023-10-02 10:30:12.257  - info: host.HomeServer instance system.adapter.ical.0 started with pid 3128425
        2023-10-02 10:30:13.469  - info: tvspielfilm.0 (3128372) Terminated (NO_ERROR): Without reason
        2023-10-02 10:30:13.522  - info: ical.0 (3128425) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v19.9.0, js-controller: 5.0.12
        2023-10-02 10:30:13.982  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
        2023-10-02 10:30:14.099  - info: ical.0 (3128425) processing URL:
        2023-10-02 10:30:15.447  - info: ical.0 (3128425) processing URL:
        2023-10-02 10:30:16.287  - info: host.HomeServer instance system.adapter.ical.1 started with pid 3128450
        2023-10-02 10:30:17.200  - info: ical.1 (3128450) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v19.9.0, js-controller: 5.0.12
        2023-10-02 10:30:17.449  - info: daswetter.0 (3128408) still wrong data structure from server received! repaired...
        2023-10-02 10:30:17.942  - info: ical.1 (3128450) processing URL:
        2023-10-02 10:30:19.501  - info: daswetter.0 (3128408) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2023-10-02 10:30:20.014  - info: daswetter.0 (3128408) cleaned everything up...
        2023-10-02 10:30:20.029  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-10-02 10:30:20.937  - info: ical.0 (3128425) Terminated (NO_ERROR): Without reason
        2023-10-02 10:30:21.473  - info: host.HomeServer instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-10-02 10:30:23.078  - info: ical.1 (3128450) Terminated (NO_ERROR): Without reason
        2023-10-02 10:30:23.607  - info: host.HomeServer instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
        2023-10-02 10:30:33.947  - info: linux-control.0 (16739) getting data from Debian_11 (192.168.100.146:22)
        2023-10-02 10:30:37.374  - info: linux-control.0 (16739) successful received data from Debian_11 (192.168.100.146:22)
        2023-10-02 10:30:45.373  - info: admin.0 (803666) <== Disconnect system.user.admin from ::ffff:192.168.100.163 admin
        2023-10-02 10:30:46.837  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flotEditDialog
        2023-10-02 10:30:47.216  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flotEdit
        2023-10-02 10:30:48.519  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flot
        2023-10-02 10:30:49.286  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 vis.0
        2023-10-02 10:30:52.809  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 vis.0
        iob diag has finished.
        Press any key for a summary
          @keulehd
          Zusätzlich zum bisherigen:
          Deine Uhr ist falsch gesetzt.
          K 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @Keulehd last edited by
            @keulehd dem log nach warst du aber gerade in flot und flot edit ohne Fehler
              Keulehd @Thomas Braun last edited by
              @thomas-braun Im Protokoll stehen aber die richtigen Zeiten ? Wo stelle ich das ein ?
                @homoran Ja aber ich sehe keine Diagramme. Dreht sich nur kurz der blaue Kreis und das war es leider
                  @keulehd
                  Steht doch da:
                  sudo timedatectl set-local-rtc 0
                  Und meld dich nicht als 'iobroker' an sondern als der User mit der uid 1000. Wie auch immer der heißt. Und den User packst du dann in die Gruppe 'adm', wenn er da noch nicht drin sein sollte.
                    @keulehd sagte in FLOT nicht mehr aufrufbar - Warnung im Protokoll:
                    aber da ist die von dir angegebene Fehlermeldung
                    socket 1696234046996 changed socket name from selectID to flotEditDialog
                    nicht zu sehen.
                    über welchen Port bist du denn jetzt rein?
                    laut log über web.0, also 8082
                      @thomas-braun Desktop ausschalten ?
                      Updates mache ich
                      nodejs downgrade ? Geht das so einfach ohne was kaputt zu machen ?
                        nodejs downgrade ?
                        Geht z.B. mit dem Skript aus meiner Signatur.
                          nimm das node-fix Skript bei @Thomas-Braun in der Signatur
                            @homoran 8082 ist die VIS
                              Homoran Global Moderator Administrators @Keulehd last edited by Homoran
                              8082 ist die VIS
                              wie soll das gehen?
                              und ja, 8083 ist im Web.0
                              ruf mal <DeineIobIP>:8083 auf
                                8082 ist die VIS
                                Nein, da lauscht schon motion drauf.
                                  @thomas-braun So lieben Dank für die Hilfe. nodejs 18.18 sowie alle Updates installiert. Wie sehe ich das mit der falschen Uhrzeit ?
                                    Im
                                    iob diag
                                    steht es drin.
                                      Das kommt beim Aufruf von :8083
                                      FLOT immer noch gleiches Problem nach Downgrade und Updates
                                        und da ist vis und flot!
                                        auch wenn du da auf den Button klickst?
                                          @homoran VIS funktioniert. FLOT nicht. Beim Klicken auf den Button FLOT kommt seit gestern immer noch folgendes Bild:
                                            @homoran Und wieder die Meldung:
                                            web.0
                                            2023-10-02 11:07:57.556 warn socket 1696237677712 changed socket name from selectID to flotEditDialog
                                            2797
