    4. FLOT nicht mehr aufrufbar - Warnung im Protokoll
      Keulehd @Homoran last edited by Keulehd
      @homoran Danke das mit der Taste hatte ich übersehen 🙂
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: HomeServer
               Icon name: computer-desktop
                 Chassis: desktop
              Machine ID: 1592eab9854d408bb2ffeca18adb4314
                 Boot ID: d4b9b898a4b24f82aed54e27b09ea7cd
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-25-amd64
            Architecture: x86-64
      model name      : Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       10:30:29 up 16 days, 23:04,  2 users,  load average: 1.48, 1.24, 1.20
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Mon 2023-10-02 10:30:29 CEST
                 Universal time: Mon 2023-10-02 08:30:29 UTC
                       RTC time: Mon 2023-10-02 10:31:39
                    NTP service: active
                RTC in local TZ: yes
      Warning: The system is configured to read the RTC time in the local time zone.
               This mode cannot be fully supported. It will create various problems
               with time zone changes and daylight saving time adjustments. The RTC
               time is never updated, it relies on external facilities to maintain it.
               If at all possible, use RTC in UTC by calling
               'timedatectl set-local-rtc 0'.
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker tty dialout sudo audio video bluetooth
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        5.5G        1.2G        2.0M        1.1G        2.0G
      Swap:           976M        950M         26M
      Total:          8.8G        6.5G        1.3G
               7862 M total memory
               5538 M used memory
               2740 M active memory
               3293 M inactive memory
               1245 M free memory
                311 M buffer memory
                766 M swap cache
                976 M total swap
                950 M used swap
                 26 M free swap
      *** FILESYSTEM ***
      Filesystem                              Type      Size  Used Avail Use% Mounted on
      udev                                    devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs                                   tmpfs     787M  1.5M  785M   1% /run
      /dev/sda5                               ext4      135G   36G   93G  28% /
      tmpfs                                   tmpfs     3.9G   16K  3.9G   1% /dev/shm
      tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      /dev/sda1                               vfat       96M   33M   64M  34% /boot/efi
      tmpfs                                   tmpfs     787M  100K  787M   1% /run/user/1001
      192.168.100.143:/mnt/pools/A/A0/Kameras nfs       5.4T  2.5T  3.0T  45% /media/nas
      [Fri Sep 15 11:26:09 2023] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Sep 15 11:26:14 2023] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems (real ones only):
      TARGET       SOURCE                                  FSTYPE OPTIONS
      /            /dev/sda5                               ext4   rw,relatime,errors=remount-ro
      |-/boot/efi  /dev/sda1                               vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      `-/media/nas 192.168.100.143:/mnt/pools/A/A0/Kameras nfs    rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,soft,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.100.143,mountvers=3,mountport=895,mountproto=udp,local_lock=all,addr=192.168.100.143
      /var:
      28G     /var/
      26G     /var/lib/motioneye/Camera1
      26G     /var/lib
      7.2G    /var/lib/motioneye/Camera1/2023-06-10
      Archived and active journals take up 416.1M in the file system.
      /opt/iobroker/backups:
      94M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      498M    /opt/iobroker/iobroker-data/
      329M    /opt/iobroker/iobroker-data/files
      118M    /opt/iobroker/iobroker-data/backup-objects
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      42M     /opt/iobroker/iobroker-data/files/iot.admin/static
      35M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.b86463fc.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v19.9.0
      /usr/bin/node           v19.9.0
      /usr/bin/npm            9.6.3
      /usr/bin/npx            9.6.3
      nodejs:
        Installed: 19.9.0-deb-1nodesource1
        Candidate: 19.9.0-deb-1nodesource1
        Version table:
       *** 19.9.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_19.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
              500 http://deb.debian.org/debian bullseye-proposed-updates/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : HomeServer                               -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : HomeServer                               - disabled
      + system.adapter.alexa2.0                 : alexa2                : HomeServer                               -  enabled
      + system.adapter.backitup.0               : backitup              : HomeServer                               -  enabled
      + system.adapter.bring.0                  : bring                 : HomeServer                               -  enabled
      + system.adapter.cloud.0                  : cloud                 : HomeServer                               -  enabled
        system.adapter.daswetter.0              : daswetter             : HomeServer                               -  enabled
      + system.adapter.discovery.0              : discovery             : HomeServer                               -  enabled
        system.adapter.dwd.0                    : dwd                   : HomeServer                               -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : HomeServer                               -  enabled
        system.adapter.feiertage.0              : feiertage             : HomeServer                               -  enabled
        system.adapter.flot.0                   : flot                  : HomeServer                               - disabled
      + system.adapter.fritzdect.0              : fritzdect             : HomeServer                               -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : HomeServer                               -  enabled
      + system.adapter.govee.0                  : govee                 : HomeServer                               -  enabled
      + system.adapter.heizoel.0                : heizoel               : HomeServer                               -  enabled
      + system.adapter.history.0                : history               : HomeServer                               -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : HomeServer                               -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : HomeServer                               -  enabled
      + system.adapter.hue.0                    : hue                   : HomeServer                               -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : HomeServer                               -  enabled
        system.adapter.ical.1                   : ical                  : HomeServer                               -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : HomeServer                               -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeServer                               - disabled
      + system.adapter.info.0                   : info                  : HomeServer                               -  enabled
      + system.adapter.iot.0                    : iot                   : HomeServer                               -  enabled
      + system.adapter.javascript.0             : javascript            : HomeServer                               -  enabled
      + system.adapter.linux-control.0          : linux-control         : HomeServer                               -  enabled
      + system.adapter.mediola-gateway.0        : mediola-gateway       : HomeServer                               -  enabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : HomeServer                               -  enabled
        system.adapter.mobile.0                 : mobile                : HomeServer                               - disabled
      + system.adapter.netatmo.0                : netatmo               : HomeServer                               -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : HomeServer                               -  enabled
      + system.adapter.nuki.0                   : nuki                  : HomeServer                               -  enabled
      + system.adapter.nut.0                    : nut                   : HomeServer                               -  enabled
      + system.adapter.parcel.0                 : parcel                : HomeServer                               -  enabled
      + system.adapter.ping.0                   : ping                  : HomeServer                               -  enabled
        system.adapter.scenes.0                 : scenes                : HomeServer                               - disabled
        system.adapter.scheduler.0              : scheduler             : HomeServer                               - disabled
      + system.adapter.shelly.0                 : shelly                : HomeServer                               -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : HomeServer                               -  enabled
      + system.adapter.simple-api.0             : simple-api            : HomeServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeServer                               -  enabled
      + system.adapter.telegram.0               : telegram              : HomeServer                               -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : HomeServer                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : HomeServer                               -  enabled
      + system.adapter.tr-064.0                 : tr-064                : HomeServer                               -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : HomeServer                               -  enabled
      + system.adapter.tuya.0                   : tuya                  : HomeServer                               -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : HomeServer                               -  enabled
      + system.adapter.velux.0                  : velux                 : HomeServer                               -  enabled
        system.adapter.viessmannapi.0           : viessmannapi          : HomeServer                               - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeServer                               - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeServer                               -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeServer                               - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : HomeServer                               - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeServer                               -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeServer                               - disabled
        system.adapter.vis-metro.0              : vis-metro             : HomeServer                               - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomeServer                               - disabled
        system.adapter.vis-weather.0            : vis-weather           : HomeServer                               - disabled
        system.adapter.vis.0                    : vis                   : HomeServer                               -  enabled
      + system.adapter.web.0                    : web                   : HomeServer                               -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : HomeServer                               -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeServer                               -  enabled
      + system.adapter.zigbee.0                 : zigbee                : HomeServer                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b6218f1c57c9eb118db68d4f1d69213e-if00-port0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      live          : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alarm"        : 3.3.12   , installed 3.3.12
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "hue"          : 3.10.0   , installed 3.10.0
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "iot"          : 1.14.5   , installed 2.0.3
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "parcel"       : 0.0.27   , installed 0.0.30
      Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
      Adapter    "velux"        : 0.0.7    , installed 0.0.7
      Adapter    "viessmannapi" : 2.0.9    , installed 2.1.1
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        16232
      States:         13899
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://deb.debian.org/debian bullseye-proposed-updates InRelease
      Get:5 https://deb.nodesource.com/node_19.x bullseye InRelease [4586 B]
      Fetched 4586 B in 0s (11.0 kB/s)
      Reading package lists...
      Pending Updates: 54
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       149471     15332/iobroker.js-c
      tcp        0      0 0.0.0.0:8554            0.0.0.0:*               LISTEN      998        17860      937/monocle-proxy
      tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      998        16298      514/monocle-gateway
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13159      1/init
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          16677      831/motion
      tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          16678      831/motion
      tcp        0      0 192.168.100.146:40499   0.0.0.0:*               LISTEN      1001       19849      1382/rygel
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16432      553/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          28815763   3047962/cupsd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19617265   2068566/io.shelly.0
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      998        16299      514/monocle-gateway
      tcp        0      0 127.0.0.1:44829         0.0.0.0:*               LISTEN      1001       21534      1382/rygel
      tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16224      471/python2
      tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16679      831/motion
      tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          15121      838/upsd
      tcp        0      0 192.168.100.146:3493    0.0.0.0:*               LISTEN      0          15120      838/upsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       151262     15332/iobroker.js-c
      tcp6       0      0 :::5900                 :::*                    LISTEN      1001       20538      1380/gnome-remote-d
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13163      1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          14883      573/apache2
      tcp6       0      0 fe80::921b:eff:fe:42737 :::*                    LISTEN      1001       21536      1382/rygel
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       29522344   3120517/io.web.0
      tcp6       0      0 :::8085                 :::*                    LISTEN      1001       7480811    803666/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16434      553/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          28815762   3047962/cupsd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       157166     16518/io.simple-api
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       7496542    805968/io.terminal.
      tcp6       0      0 ::1:37885               :::*                    LISTEN      1001       19850      1382/rygel
      tcp6       0      0 :::20002                :::*                    LISTEN      1001       29540207   3122606/io.web.1
      tcp6       0      0 :::41767                :::*                    LISTEN      1001       20543      1416/apache2
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13160      1/init
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          28817212   3048024/cups-browse
      udp        0      0 127.0.0.1:54408         0.0.0.0:*                           1001       19814      1382/rygel
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        12258      465/avahi-daemon: r
      udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       19817      1382/rygel
      udp        0      0 192.168.100.146:1900    0.0.0.0:*                           1001       19816      1382/rygel
      udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       19812      1382/rygel
      udp        0      0 127.0.0.1:1900          0.0.0.0:*                           1001       19811      1382/rygel
      udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       19649119   2072136/io.mediola-
      udp        0      0 192.168.100.146:39339   0.0.0.0:*                           1001       19819      1382/rygel
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       23130468   2438157/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       23130469   2438157/io.tuya.0
      udp        0      0 0.0.0.0:47675           0.0.0.0:*                           1001       19649120   2072136/io.mediola-
      udp        0      0 0.0.0.0:35912           0.0.0.0:*                           110        12260      465/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          13166      1/init
      udp6       0      0 fe80::921b:eff:fe45:546 :::*                                0          15918      468/NetworkManager
      udp6       0      0 :::5353                 :::*                                110        12259      465/avahi-daemon: r
      udp6       0      0 ::1:59194               :::*                                1001       19825      1382/rygel
      udp6       0      0 ::1:1900                :::*                                1001       19822      1382/rygel
      udp6       0      0 ff05::c:1900            :::*                                1001       19823      1382/rygel
      udp6       0      0 fe80::921b:eff:fe4:1900 :::*                                1001       19828      1382/rygel
      udp6       0      0 ff02::c:1900            :::*                                1001       19829      1382/rygel
      udp6       0      0 fe80::921b:eff:fe:47046 :::*                                1001       19831      1382/rygel
      udp6       0      0 :::35528                :::*                                110        12261      465/avahi-daemon: r
      2023-10-02 10:30:12.257  - info: host.HomeServer instance system.adapter.ical.0 started with pid 3128425
      2023-10-02 10:30:13.469  - info: tvspielfilm.0 (3128372) Terminated (NO_ERROR): Without reason
      2023-10-02 10:30:13.522  - info: ical.0 (3128425) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v19.9.0, js-controller: 5.0.12
      2023-10-02 10:30:13.982  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      2023-10-02 10:30:14.099  - info: ical.0 (3128425) processing URL:
      2023-10-02 10:30:15.447  - info: ical.0 (3128425) processing URL:
      2023-10-02 10:30:16.287  - info: host.HomeServer instance system.adapter.ical.1 started with pid 3128450
      2023-10-02 10:30:17.200  - info: ical.1 (3128450) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v19.9.0, js-controller: 5.0.12
      2023-10-02 10:30:17.449  - info: daswetter.0 (3128408) still wrong data structure from server received! repaired...
      2023-10-02 10:30:17.942  - info: ical.1 (3128450) processing URL:
      2023-10-02 10:30:19.501  - info: daswetter.0 (3128408) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-10-02 10:30:20.014  - info: daswetter.0 (3128408) cleaned everything up...
      2023-10-02 10:30:20.029  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-02 10:30:20.937  - info: ical.0 (3128425) Terminated (NO_ERROR): Without reason
      2023-10-02 10:30:21.473  - info: host.HomeServer instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-10-02 10:30:23.078  - info: ical.1 (3128450) Terminated (NO_ERROR): Without reason
      2023-10-02 10:30:23.607  - info: host.HomeServer instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
      2023-10-02 10:30:33.947  - info: linux-control.0 (16739) getting data from Debian_11 (192.168.100.146:22)
      2023-10-02 10:30:37.374  - info: linux-control.0 (16739) successful received data from Debian_11 (192.168.100.146:22)
      2023-10-02 10:30:45.373  - info: admin.0 (803666) <== Disconnect system.user.admin from ::ffff:192.168.100.163 admin
      2023-10-02 10:30:46.837  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flotEditDialog
      2023-10-02 10:30:47.216  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flotEdit
      2023-10-02 10:30:48.519  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flot
      2023-10-02 10:30:49.286  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 vis.0
      2023-10-02 10:30:52.809  - info: web.0 (3120517) <== Disconnect system.user.admin from ::ffff:192.168.100.163 vis.0
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @Keulehd last edited by
        @keulehd
        Zusätzlich zum bisherigen:
        Deine Uhr ist falsch gesetzt.
        K 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Keulehd last edited by
          @keulehd dem log nach warst du aber gerade in flot und flot edit ohne Fehler
            Keulehd @Thomas Braun last edited by
            @thomas-braun Im Protokoll stehen aber die richtigen Zeiten ? Wo stelle ich das ein ?
              @homoran Ja aber ich sehe keine Diagramme. Dreht sich nur kurz der blaue Kreis und das war es leider
                @keulehd
                Steht doch da:
                sudo timedatectl set-local-rtc 0
                Und meld dich nicht als 'iobroker' an sondern als der User mit der uid 1000. Wie auch immer der heißt. Und den User packst du dann in die Gruppe 'adm', wenn er da noch nicht drin sein sollte.
                  @keulehd sagte in FLOT nicht mehr aufrufbar - Warnung im Protokoll:
                  aber da ist die von dir angegebene Fehlermeldung
                  socket 1696234046996 changed socket name from selectID to flotEditDialog
                  nicht zu sehen.
                  über welchen Port bist du denn jetzt rein?
                  laut log über web.0, also 8082
                    @thomas-braun Desktop ausschalten ?
                    Updates mache ich
                    nodejs downgrade ? Geht das so einfach ohne was kaputt zu machen ?
                      nodejs downgrade ?
                      Geht z.B. mit dem Skript aus meiner Signatur.
                        nimm das node-fix Skript bei @Thomas-Braun in der Signatur
                          @homoran 8082 ist die VIS
                            Homoran Global Moderator Administrators @Keulehd last edited by Homoran
                            8082 ist die VIS
                            wie soll das gehen?
                            und ja, 8083 ist im Web.0
                            ruf mal <DeineIobIP>:8083 auf
                              8082 ist die VIS
                              Nein, da lauscht schon motion drauf.
                                @thomas-braun So lieben Dank für die Hilfe. nodejs 18.18 sowie alle Updates installiert. Wie sehe ich das mit der falschen Uhrzeit ?
                                  Im
                                  iob diag
                                  steht es drin.
                                    Das kommt beim Aufruf von :8083
                                    FLOT immer noch gleiches Problem nach Downgrade und Updates
                                      und da ist vis und flot!
                                      auch wenn du da auf den Button klickst?
                                        @homoran VIS funktioniert. FLOT nicht. Beim Klicken auf den Button FLOT kommt seit gestern immer noch folgendes Bild:
                                          @homoran Und wieder die Meldung:
                                          web.0
                                          2023-10-02 11:07:57.556 warn socket 1696237677712 changed socket name from selectID to flotEditDialog
                                            @thomas-braun Jetzt hab ich das mit der Uhr irgendwie total verstellt 😞
                                            Local time: Mon 2023-10-02 11:24:01 CEST
                                            Universal time: Mon 2023-10-02 09:24:01 UTC
                                            RTC time: Mon 2023-10-02 09:24:02
                                            NTP service: active
                                            RTC in local TZ: no
                                            Hast Du da noch nen Tipp für mich ?
                                            2799
