    4. FLOT nicht mehr aufrufbar - Warnung im Protokoll
      Keulehd @Thomas Braun last edited by Keulehd
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: HomeServer
               Icon name: computer-desktop
                 Chassis: desktop
              Machine ID: 1592eab9854d408bb2ffeca18adb4314
                 Boot ID: d4b9b898a4b24f82aed54e27b09ea7cd
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-25-amd64
            Architecture: x86-64
      model name      : Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       11:40:04 up 17 days, 13 min,  2 users,  load average: 0.90, 1.16, 1.25
      CPU threads: 4
      The systems needs to be REBOOTED!
      *** Time and Time Zones ***
                     Local time: Mon 2023-10-02 11:40:04 CEST
                 Universal time: Mon 2023-10-02 09:40:04 UTC
                       RTC time: Mon 2023-10-02 09:40:05
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker tty dialout sudo audio video bluetooth
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        4.3G        952M        2.0M        2.6G        3.3G
      Swap:           976M        192M        784M
      Total:          8.8G        4.5G        1.7G
               7862 M total memory
               4284 M used memory
               1101 M active memory
               4737 M inactive memory
                952 M free memory
                152 M buffer memory
               2472 M swap cache
                976 M total swap
                192 M used swap
                784 M free swap
      *** FILESYSTEM ***
      Filesystem                              Type      Size  Used Avail Use% Mounted on
      udev                                    devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs                                   tmpfs     787M  1.5M  785M   1% /run
      /dev/sda5                               ext4      135G   37G   92G  29% /
      tmpfs                                   tmpfs     3.9G   16K  3.9G   1% /dev/shm
      tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      /dev/sda1                               vfat       96M   33M   64M  34% /boot/efi
      tmpfs                                   tmpfs     787M  100K  787M   1% /run/user/1001
      192.168.100.143:/mnt/pools/A/A0/Kameras nfs       5.4T  2.5T  3.0T  45% /media/nas
      [Fri Sep 15 11:26:09 2023] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Sep 15 11:26:14 2023] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems (real ones only):
      TARGET       SOURCE                                  FSTYPE OPTIONS
      /            /dev/sda5                               ext4   rw,relatime,errors=remount-ro
      |-/boot/efi  /dev/sda1                               vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      `-/media/nas 192.168.100.143:/mnt/pools/A/A0/Kameras nfs    rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,soft,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.100.143,mountvers=3,mountport=895,mountproto=udp,local_lock=all,addr=192.168.100.143
      /var:
      28G     /var/
      26G     /var/lib/motioneye/Camera1
      26G     /var/lib
      7.2G    /var/lib/motioneye/Camera1/2023-06-10
      Archived and active journals take up 432.1M in the file system.
      /opt/iobroker/backups:
      94M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      488M    /opt/iobroker/iobroker-data/
      329M    /opt/iobroker/iobroker-data/files
      118M    /opt/iobroker/iobroker-data/backup-objects
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      42M     /opt/iobroker/iobroker-data/files/iot.admin/static
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.b86463fc.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
              500 http://deb.debian.org/debian bullseye-proposed-updates/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : HomeServer                               -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : HomeServer                               - disabled
      + system.adapter.alexa2.0                 : alexa2                : HomeServer                               -  enabled
      + system.adapter.backitup.0               : backitup              : HomeServer                               -  enabled
      + system.adapter.bring.0                  : bring                 : HomeServer                               -  enabled
      + system.adapter.cloud.0                  : cloud                 : HomeServer                               -  enabled
        system.adapter.daswetter.0              : daswetter             : HomeServer                               -  enabled
      + system.adapter.discovery.0              : discovery             : HomeServer                               -  enabled
        system.adapter.dwd.0                    : dwd                   : HomeServer                               -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : HomeServer                               -  enabled
        system.adapter.feiertage.0              : feiertage             : HomeServer                               -  enabled
        system.adapter.flot.0                   : flot                  : HomeServer                               - disabled
      + system.adapter.fritzdect.0              : fritzdect             : HomeServer                               -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : HomeServer                               -  enabled
      + system.adapter.govee.0                  : govee                 : HomeServer                               -  enabled
      + system.adapter.heizoel.0                : heizoel               : HomeServer                               -  enabled
      + system.adapter.history.0                : history               : HomeServer                               -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : HomeServer                               -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : HomeServer                               -  enabled
      + system.adapter.hue.0                    : hue                   : HomeServer                               -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : HomeServer                               -  enabled
        system.adapter.ical.1                   : ical                  : HomeServer                               -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : HomeServer                               -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeServer                               - disabled
      + system.adapter.info.0                   : info                  : HomeServer                               -  enabled
      + system.adapter.iot.0                    : iot                   : HomeServer                               -  enabled
      + system.adapter.javascript.0             : javascript            : HomeServer                               -  enabled
      + system.adapter.linux-control.0          : linux-control         : HomeServer                               -  enabled
      + system.adapter.mediola-gateway.0        : mediola-gateway       : HomeServer                               -  enabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : HomeServer                               -  enabled
        system.adapter.mobile.0                 : mobile                : HomeServer                               - disabled
      + system.adapter.netatmo.0                : netatmo               : HomeServer                               -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : HomeServer                               -  enabled
      + system.adapter.nuki.0                   : nuki                  : HomeServer                               -  enabled
      + system.adapter.nut.0                    : nut                   : HomeServer                               -  enabled
      + system.adapter.parcel.0                 : parcel                : HomeServer                               -  enabled
      + system.adapter.ping.0                   : ping                  : HomeServer                               -  enabled
        system.adapter.scenes.0                 : scenes                : HomeServer                               - disabled
        system.adapter.scheduler.0              : scheduler             : HomeServer                               - disabled
      + system.adapter.shelly.0                 : shelly                : HomeServer                               -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : HomeServer                               -  enabled
      + system.adapter.simple-api.0             : simple-api            : HomeServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeServer                               -  enabled
      + system.adapter.telegram.0               : telegram              : HomeServer                               -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : HomeServer                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : HomeServer                               -  enabled
      + system.adapter.tr-064.0                 : tr-064                : HomeServer                               -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : HomeServer                               -  enabled
      + system.adapter.tuya.0                   : tuya                  : HomeServer                               -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : HomeServer                               -  enabled
        system.adapter.velux.0                  : velux                 : HomeServer                               - disabled
        system.adapter.viessmannapi.0           : viessmannapi          : HomeServer                               - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeServer                               - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeServer                               -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeServer                               - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : HomeServer                               - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeServer                               -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeServer                               - disabled
        system.adapter.vis-metro.0              : vis-metro             : HomeServer                               - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomeServer                               - disabled
        system.adapter.vis-weather.0            : vis-weather           : HomeServer                               - disabled
        system.adapter.vis.0                    : vis                   : HomeServer                               -  enabled
      + system.adapter.web.0                    : web                   : HomeServer                               -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : HomeServer                               -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeServer                               -  enabled
      + system.adapter.zigbee.0                 : zigbee                : HomeServer                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b6218f1c57c9eb118db68d4f1d69213e-if00-port0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      live          : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alarm"        : 3.3.12   , installed 3.3.12
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "hue"          : 3.10.0   , installed 3.10.0
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "iot"          : 1.14.5   , installed 2.0.3
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "parcel"       : 0.0.27   , installed 0.0.30
      Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
      Adapter    "velux"        : 0.0.7    , installed 0.0.7
      Adapter    "viessmannapi" : 2.0.9    , installed 2.1.1
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        16242
      States:         13911
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://deb.debian.org/debian bullseye-proposed-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29647184   3146008/iobroker.js
      tcp        0      0 0.0.0.0:8554            0.0.0.0:*               LISTEN      998        17860      937/monocle-proxy
      tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      998        16298      514/monocle-gateway
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13159      1/init
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          16677      831/motion
      tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          16678      831/motion
      tcp        0      0 192.168.100.146:40499   0.0.0.0:*               LISTEN      1001       19849      1382/rygel
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          29632009   3141906/sshd: /usr/
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          29632077   3142007/cupsd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       29650167   3146281/io.shelly.0
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      998        16299      514/monocle-gateway
      tcp        0      0 127.0.0.1:44829         0.0.0.0:*               LISTEN      1001       21534      1382/rygel
      tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16224      471/python2
      tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16679      831/motion
      tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          15121      838/upsd
      tcp        0      0 192.168.100.146:3493    0.0.0.0:*               LISTEN      0          15120      838/upsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29647187   3146008/iobroker.js
      tcp6       0      0 :::5900                 :::*                    LISTEN      1001       20538      1380/gnome-remote-d
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13163      1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          14883      573/apache2
      tcp6       0      0 fe80::921b:eff:fe:42737 :::*                    LISTEN      1001       21536      1382/rygel
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       29653835   3147618/io.web.0
      tcp6       0      0 :::8085                 :::*                    LISTEN      1001       29647269   3146030/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          29632011   3141906/sshd: /usr/
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       29651771   3147490/io.simple-a
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          29632076   3142007/cupsd
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       29658405   3148237/io.terminal
      tcp6       0      0 ::1:37885               :::*                    LISTEN      1001       19850      1382/rygel
      tcp6       0      0 :::20002                :::*                    LISTEN      1001       29658461   3148261/io.web.1
      tcp6       0      0 :::41767                :::*                    LISTEN      1001       20543      1416/apache2
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13160      1/init
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          29638097   3142009/cups-browse
      udp        0      0 0.0.0.0:33524           0.0.0.0:*                           1001       29656139   3147767/io.mediola-
      udp        0      0 127.0.0.1:54408         0.0.0.0:*                           1001       19814      1382/rygel
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        12258      465/avahi-daemon: r
      udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       19817      1382/rygel
      udp        0      0 192.168.100.146:1900    0.0.0.0:*                           1001       19816      1382/rygel
      udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       19812      1382/rygel
      udp        0      0 127.0.0.1:1900          0.0.0.0:*                           1001       19811      1382/rygel
      udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       29656138   3147767/io.mediola-
      udp        0      0 192.168.100.146:39339   0.0.0.0:*                           1001       19819      1382/rygel
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       29650303   3146333/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       29650304   3146333/io.tuya.0
      udp        0      0 0.0.0.0:35912           0.0.0.0:*                           110        12260      465/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          13166      1/init
      udp6       0      0 fe80::921b:eff:fe45:546 :::*                                0          15918      468/NetworkManager
      udp6       0      0 :::5353                 :::*                                110        12259      465/avahi-daemon: r
      udp6       0      0 ::1:59194               :::*                                1001       19825      1382/rygel
      udp6       0      0 ::1:1900                :::*                                1001       19822      1382/rygel
      udp6       0      0 ff05::c:1900            :::*                                1001       19823      1382/rygel
      udp6       0      0 fe80::921b:eff:fe4:1900 :::*                                1001       19828      1382/rygel
      udp6       0      0 ff02::c:1900            :::*                                1001       19829      1382/rygel
      udp6       0      0 fe80::921b:eff:fe:47046 :::*                                1001       19831      1382/rygel
      udp6       0      0 :::35528                :::*                                110        12261      465/avahi-daemon: r
      2023-10-02 11:36:36.503  - info: linux-control.0 (3147786) getting data from Debian_11 (192.168.100.146:22)
      2023-10-02 11:36:38.687  - info: linux-control.0 (3147786) successful received data from Debian_11 (192.168.100.146:22)
      2023-10-02 11:37:13.002  - info: web.1 (3148261) ==> Connected system.user.admin from ::ffff:192.168.100.163
      2023-10-02 11:37:13.348  - info: web.1 (3148261) ==> Connected system.user.admin from ::ffff:192.168.100.163
      2023-10-02 11:37:17.795  - info: web.1 (3148261) ==> Connected system.user.admin from ::ffff:192.168.100.163
      2023-10-02 11:37:25.199  - info: web.1 (3148261) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flot
      2023-10-02 11:37:25.653  - info: web.1 (3148261) ==> Connected system.user.admin from ::ffff:192.168.100.163
      2023-10-02 11:37:32.041  - info: web.1 (3148261) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flot
      2023-10-02 11:37:32.072  - info: web.1 (3148261) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flotEdit
      2023-10-02 11:37:32.075  - info: web.1 (3148261) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flotEditDialog
      2023-10-02 11:38:30.064  - info: hue-extended.0 (3147639) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
      2023-10-02 11:38:45.674  - info: javascript.0 (3146102) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
      2023-10-02 11:40:00.051  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 3156593
      2023-10-02 11:40:00.875  - info: dwd.0 (3156593) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
      2023-10-02 11:40:01.755  - info: dwd.0 (3156593) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-10-02 11:40:02.304  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-02 11:40:04.081  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 3156622
      2023-10-02 11:40:04.934  - info: tvspielfilm.0 (3156622) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
      2023-10-02 11:40:06.970  - info: tvspielfilm.0 (3156622) objects written
      2023-10-02 11:40:08.219  - info: whatsapp-cmb.0 (3146144) Send Die Post war da to +491712121533
      2023-10-02 11:40:17.474  - info: tvspielfilm.0 (3156622) Terminated (NO_ERROR): Without reason
      2023-10-02 11:40:17.989  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      Boote eben mal den Rechner neu
        Thomas Braun Most Active @Keulehd last edited by
        @keulehd
        danach nochmal...
          @keulehd
          iob start flot
            @thomas-braun Gestartet. Gleicher Fehler
            iobroker@HomeServer:~$ iob start flot
            The adapter "flot.0" was started.
            iob diag:
            Skript v.2023-06-20
            *** BASE SYSTEM ***
                       Chassis: desktop
                       Boot ID: ea3d5faa73ee4ab1b51a8d42bc58c08d
                        Kernel: Linux 5.10.0-26-amd64
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
             11:50:58 up 5 min,  2 users,  load average: 1.96, 2.35, 1.20
            CPU threads: 4
                           Local time: Mon 2023-10-02 11:50:58 CEST
                       Universal time: Mon 2023-10-02 09:50:58 UTC
                             RTC time: Mon 2023-10-02 09:50:58
                          NTP service: active
                      RTC in local TZ: no
            iobroker
            /home/iobroker
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            7.9G        3.1G        3.7G        3.0M        1.0G        4.5G
            Swap:           976M          0B        976M
            Total:          8.8G        3.1G        4.7G
                     7862 M total memory
                     3123 M used memory
                      419 M active memory
                     3379 M inactive memory
                     3697 M free memory
                       69 M buffer memory
                      971 M swap cache
                      976 M total swap
                        0 M used swap
                      976 M free swap
            *** FILESYSTEM ***
            tmpfs                                   tmpfs     787M   96K  787M   1% /run/user/1001
            [Mon Oct  2 11:45:11 2023] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Oct  2 11:45:16 2023] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
            /var:
            28G     /var/
            26G     /var/lib
            494M    /opt/iobroker/iobroker-data/
            26M     /opt/iobroker/iobroker-data/objects.jsonl
            21M     /opt/iobroker/iobroker-data/states.jsonl
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.10.1
            javascript:     7.1.4
            Adapter State
              system.adapter.flot.0                   : flot                  : HomeServer                               -  enabled
            + instance is alive
            Objects and States
            Objects:        16242
            States:         13943
            Pending Updates: 0
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12279      1/init
            tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          16022      834/motion
            tcp        0      0 192.168.100.146:42129   0.0.0.0:*               LISTEN      1001       21113      1384/rygel
            tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          16023      834/motion
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14934      544/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15272      512/cupsd
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       24838      2114/io.shelly.0
            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      998        17746      514/monocle-gateway
            tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16980      463/python2
            tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16024      834/motion
            tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          16996      865/upsd
            tcp        0      0 192.168.100.146:3493    0.0.0.0:*               LISTEN      0          16995      865/upsd
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20671      513/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18814      513/iobroker.js-con
            tcp        0      0 0.0.0.0:8554            0.0.0.0:*               LISTEN      998        17156      962/monocle-proxy
            tcp        0      0 127.0.0.1:36939         0.0.0.0:*               LISTEN      1001       20404      1384/rygel
            tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      998        17745      514/monocle-gateway
            tcp6       0      0 :::111                  :::*                    LISTEN      0          12283      1/init
            tcp6       0      0 :::80                   :::*                    LISTEN      0          15641      545/apache2
            tcp6       0      0 :::8083                 :::*                    LISTEN      1001       28210      3484/io.web.0
            tcp6       0      0 :::8085                 :::*                    LISTEN      1001       23684      1195/io.admin.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14936      544/sshd: /usr/sbin
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30799      3346/io.simple-api.
            tcp6       0      0 ::1:45495               :::*                    LISTEN      1001       20407      1384/rygel
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15271      512/cupsd
            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       32583      4162/io.terminal.0
            tcp6       0      0 :::20002                :::*                    LISTEN      1001       33199      4201/io.web.1
            tcp6       0      0 fe80::921b:eff:fe:43939 :::*                    LISTEN      1001       19167      1384/rygel
            tcp6       0      0 :::36235                :::*                    LISTEN      1001       21093      1499/apache2
            tcp6       0      0 :::5900                 :::*                    LISTEN      1001       20286      1382/gnome-remote-d
            udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       20300      1384/rygel
            udp        0      0 192.168.100.146:1900    0.0.0.0:*                           1001       20299      1384/rygel
            udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       20295      1384/rygel
            udp        0      0 127.0.0.1:1900          0.0.0.0:*                           1001       20294      1384/rygel
            udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       31987      3645/io.mediola-gat
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       23912      2189/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       23913      2189/io.tuya.0
            udp        0      0 127.0.0.1:52497         0.0.0.0:*                           1001       20297      1384/rygel
            udp        0      0 192.168.100.146:36627   0.0.0.0:*                           1001       20302      1384/rygel
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12280      1/init
            udp        0      0 0.0.0.0:57463           0.0.0.0:*                           110        13882      449/avahi-daemon: r
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15290      622/cups-browsed
            udp        0      0 0.0.0.0:33641           0.0.0.0:*                           1001       31988      3645/io.mediola-gat
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        13880      449/avahi-daemon: r
            udp6       0      0 ::1:1900                :::*                                1001       20305      1384/rygel
            udp6       0      0 ff05::c:1900            :::*                                1001       20306      1384/rygel
            udp6       0      0 fe80::921b:eff:fe4:1900 :::*                                1001       20311      1384/rygel
            udp6       0      0 ff02::c:1900            :::*                                1001       20312      1384/rygel
            udp6       0      0 fe80::921b:eff:fe:44267 :::*                                1001       20314      1384/rygel
            udp6       0      0 ::1:45064               :::*                                1001       20308      1384/rygel
            udp6       0      0 :::111                  :::*                                0          12286      1/init
            udp6       0      0 fe80::921b:eff:fe45:546 :::*                                0          15778      460/NetworkManager
            udp6       0      0 :::37900                :::*                                110        13883      449/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                110        13881      449/avahi-daemon: r
            2023-10-02 11:50:07.121  - info: tvspielfilm.0 (4181) objects written
            2023-10-02 11:50:07.639  - info: web.1 (4201) socket.io server listening on port 20002
            2023-10-02 11:50:07.641  - info: web.1 (4201) http server listening on port 20002
            2023-10-02 11:50:08.453  - info: daswetter.0 (4113) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2023-10-02 11:50:08.965  - info: daswetter.0 (4113) cleaned everything up...
            2023-10-02 11:50:09.005  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-10-02 11:50:17.628  - info: tvspielfilm.0 (4181) Terminated (NO_ERROR): Without reason
            2023-10-02 11:50:18.147  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
            2023-10-02 11:50:22.093  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Schlafzimmer value: 2%
            2023-10-02 11:50:32.126  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Gästezimmer value: 2%
            2023-10-02 11:50:42.146  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Treppenhaus value: 2%
            2023-10-02 11:50:45.744  - info: host.HomeServer stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
            2023-10-02 11:50:45.747  - info: nuki-extended.0 (2068) Got terminate signal TERMINATE_YOURSELF
            2023-10-02 11:50:45.748  - info: nuki-extended.0 (2068) Adapter stopped und unloaded.
            2023-10-02 11:50:45.749  - info: nuki-extended.0 (2068) terminating
            2023-10-02 11:50:45.750  - info: nuki-extended.0 (2068) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-10-02 11:50:45.788  - info: host.HomeServer stopInstance system.adapter.nuki-extended.0 send kill signal
            2023-10-02 11:50:46.252  - info: nuki-extended.0 (2068) terminating
            2023-10-02 11:50:46.325  - info: host.HomeServer instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-10-02 11:50:48.879  - info: host.HomeServer instance system.adapter.nuki-extended.0 started with pid 4260
            2023-10-02 11:50:49.804  - info: nuki-extended.0 (4260) starting. Version 2.6.5 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v18.18.0, js-controller: 5.0.12
            2023-10-02 11:50:49.892  - info: nuki-extended.0 (4260) Polling Nuki Web API with a frequency of 60s.
            2023-10-02 11:51:12.174  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Wohnzimmer rechts value: 2%
            2023-10-02 11:51:22.187  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Küche links value: 2%
            2023-10-02 11:51:31.084  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
              @keulehd
              Meld dich mit einem andern User an. Es gibt noch einen mit der uid=1000auf dem System. Nimm den.
                @keulehd
                Und schalt den Desktop aus.
                sudo systemctl set-default multi-user.target
                sudo systemctl iosolate multi-user.target
                  Mit den anderen beiden Usern kann ich mich nicht anmelden obwohl die Passwörter korrekt sein müssen. Sagt immer falsches Kennwort
                  Abschaltung Desktop hat der erste Befehl funktioniert. Bei dem zweiten kommt:
                  iobroker@HomeServer:~$ sudo systemctl iosolate multi-user.target
                  Unknown command verb iosolate.
                    @keulehd
                    sudo systemctl isolate multi-user.target
                    Und das mit den Usern würde mir zu denken geben...
                    Setz ein neues Passwort.
                    sudo passwd Username
                      @thomas-braun Danke. Isolate hat funktioniert
                      Mir sind nur 2 User bekannt. Den PC hab ich ja selbst aufgesetzt. Passwort ändern aber nicht möglich
                      iobroker@HomeServer:~$ sudo passwd Daniel
                      passwd: Benutzer »Daniel« ist nicht vorhanden.
                      iobroker@HomeServer:~$ sudo passwd Remote
                      passwd: Benutzer »Remote« ist nicht vorhanden.
                        Thomas Braun Most Active last edited by Thomas Braun
                        @keulehd
                        In
                        cat /etc/passwd | sort
                        stehen die User drin
                          iobroker@HomeServer:~$ cat /etc/passwd | sort
                          _apt❌100:65534::/nonexistent:/usr/sbin/nologin
                          avahi❌110:116:Avahi mDNS daemon,,,:/run/avahi-daemon:/usr/sbin/nologin
                          backup❌34:34:backup:/var/backups:/usr/sbin/nologin
                          bin❌2:2:bin:/bin:/usr/sbin/nologin
                          colord❌114:122:colord colour management daemon,,,:/var/lib/colord:/usr/sbin/nologin
                          daemon❌1:1:daemon:/usr/sbin:/usr/sbin/nologin
                          daniel❌1000:1000:Daniel Hoffmann,,,:/home/daniel:/bin/bash
                          Debian-gdm❌116:124:Gnome Display Manager:/var/lib/gdm3:/bin/false
                          dnsmasq❌109:65534:dnsmasq,,,:/var/lib/misc:/usr/sbin/nologin
                          games❌5:60:games:/usr/games:/usr/sbin/nologin
                          geoclue❌115:123::/var/lib/geoclue:/usr/sbin/nologin
                          gnats❌41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/usr/sbin/nologin
                          iobroker❌1001:1001:iobroker,,,:/home/iobroker:/bin/bash
                          irc❌39:39:ircd:/run/ircd:/usr/sbin/nologin
                          lightdm❌119:125:Light Display Manager:/var/lib/lightdm:/bin/false
                          list❌38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
                          lp❌7:7:lp:/var/spool/lpd:/usr/sbin/nologin
                          mail❌8:8:mail:/var/mail:/usr/sbin/nologin
                          man❌6:12:man:/var/cache/man:/usr/sbin/nologin
                          messagebus❌104:110::/nonexistent:/usr/sbin/nologin
                          monocle❌998:998::/home/monocle:/bin/sh
                          motion❌120:126::/var/lib/motion:/usr/sbin/nologin
                          news❌9:9:news:/var/spool/news:/usr/sbin/nologin
                          nobody❌65534:65534:nobody:/nonexistent:/usr/sbin/nologin
                          nut❌121:127::/var/lib/nut:/usr/sbin/nologin
                          proxy❌13:13:proxy:/bin:/usr/sbin/nologin
                          pulse❌112:118:PulseAudio daemon,,,:/run/pulse:/usr/sbin/nologin
                          remote❌1002:1002:Remote,,,:/home/remote:/bin/bash
                          root❌0:0:root:/root:/bin/bash
                          _rpc❌117:65534::/run/rpcbind:/usr/sbin/nologin
                          rtkit❌107:115:RealtimeKit,,,:/proc:/usr/sbin/nologin
                          saned❌113:121::/var/lib/saned:/usr/sbin/nologin
                          speech-dispatcher❌111:29:Speech Dispatcher,,,:/run/speech-dispatcher:/bin/false
                          sshd❌108:65534::/run/sshd:/usr/sbin/nologin
                          statd❌118:65534::/var/lib/nfs:/usr/sbin/nologin
                          sync❌4:65534:sync:/bin:/bin/sync
                          systemd-coredump❌999:999:systemd Core Dumper:/:/usr/sbin/nologin
                          systemd-network❌101:102:systemd Network Management,,,:/run/systemd:/usr/sbin/nologin
                          systemd-resolve❌102:103:systemd Resolver,,,:/run/systemd:/usr/sbin/nologin
                          systemd-timesync❌105:111:systemd Time Synchronization,,,:/run/systemd:/usr/sbin/nologin
                          sys❌3:3:sys:/dev:/usr/sbin/nologin
                          tss❌103:109:TPM software stack,,,:/var/lib/tpm:/bin/false
                          usbmux❌106:46:usbmux daemon,,,:/var/lib/usbmux:/usr/sbin/nologin
                          uucp❌10:10:uucp:/var/spool/uucp:/usr/sbin/nologin
                          www-data❌33:33:www-data:/var/www:/usr/sbin/nologin
                          Ja genau. Daniel und Remote. Aber es lassen sich keine Passwörter ändern bzw. setzen. Alles sehr suspekt
                            @keulehd sagte in FLOT nicht mehr aufrufbar - Warnung im Protokoll:
                            Richtig, der heißt ja auch 'daniel'
                              @thomas-braun Wer lesen kann ist klar im Vorteil. Sorry 😞
                              iobroker@HomeServer:~$ sudo passwd daniel
                              Geben Sie ein neues Passwort ein:
                              Geben Sie das neue Passwort erneut ein:
                              passwd: Passwort erfolgreich geändert
                              iob diag mit User "daniel":
                              Skript v.2023-06-20
                              *** BASE SYSTEM ***
                                         Chassis: desktop
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                               12:20:21 up 35 min,  2 users,  load average: 1.70, 1.33, 1.42
                              CPU threads: 4
                                             Local time: Mon 2023-10-02 12:20:21 CEST
                                         Universal time: Mon 2023-10-02 10:20:21 UTC
                                               RTC time: Mon 2023-10-02 10:20:21
                                            NTP service: active
                                        RTC in local TZ: no
                              daniel
                              /home/daniel
                              daniel cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              Boot Target:    multi-user.target
                              *** MEMORY ***
                              Mem:            7.9G        3.3G        2.9G        1.0M        1.7G        4.3G
                              Swap:           976M          0B        976M
                              Total:          8.8G        3.3G        3.9G
                                       7862 M total memory
                                       3259 M used memory
                                        625 M active memory
                                       3517 M inactive memory
                                       2890 M free memory
                                        196 M buffer memory
                                       1516 M swap cache
                                        976 M total swap
                                          0 M used swap
                                        976 M free swap
                              *** FILESYSTEM ***
                              tmpfs                                   tmpfs     787M  1.3M  785M   1% /run
                              tmpfs                                   tmpfs     787M   76K  787M   1% /run/user/1000
                              /var:
                              28G     /var/
                              26G     /var/lib
                              Archived and active journals take up 48.0M in the file system.
                              503M    /opt/iobroker/iobroker-data/
                              30M     /opt/iobroker/iobroker-data/states.jsonl
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.10.1
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        16242
                              States:         13909
                              Hit:1 http://deb.debian.org/debian bullseye InRelease
                              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                              Pending Updates: 0
                              2023-10-02 12:15:13.459  - info: tvspielfilm.0 (8249) Terminated (NO_ERROR): Without reason
                              2023-10-02 12:15:13.973  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                              2023-10-02 12:15:16.553  - info: daswetter.0 (8685) still wrong data structure from server received! repaired...
                              2023-10-02 12:15:18.249  - info: daswetter.0 (8685) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                              2023-10-02 12:15:18.763  - info: daswetter.0 (8685) cleaned everything up...
                              2023-10-02 12:15:18.784  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-10-02 12:16:05.624  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                              2023-10-02 12:16:35.704  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                              2023-10-02 12:17:05.780  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                              2023-10-02 12:17:24.481  - info: javascript.0 (1392) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
                              2023-10-02 12:17:35.865  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                              2023-10-02 12:17:36.155  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Velux Dachfenster value: 0%
                              2023-10-02 12:18:05.952  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                              2023-10-02 12:18:36.057  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
                              2023-10-02 12:20:00.044  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 8895
                              2023-10-02 12:20:00.880  - info: dwd.0 (8895) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
                              2023-10-02 12:20:01.817  - info: dwd.0 (8895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2023-10-02 12:20:02.347  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-10-02 12:20:04.074  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 8914
                              2023-10-02 12:20:04.886  - info: tvspielfilm.0 (8914) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
                              2023-10-02 12:20:06.931  - info: tvspielfilm.0 (8914) objects written
                              2023-10-02 12:20:08.593  - info: linux-control.0 (3694) getting data from Debian_11 (192.168.100.146:22)
                              2023-10-02 12:20:10.921  - info: linux-control.0 (3694) successful received data from Debian_11 (192.168.100.146:22)
                              2023-10-02 12:20:17.440  - info: tvspielfilm.0 (8914) Terminated (NO_ERROR): Without reason
                              2023-10-02 12:20:17.955  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                                @keulehd
                                Jetzt haust du den Daniel noch in die Gruppe 'adm' rein
                                sudo usermod -a -G adm daniel
                                Daniel danach ausloggen und wieder einloggen.
                                  @thomas-braun Erledigt
                                  Skript v.2023-06-20
                                  *** BASE SYSTEM ***
                                             Chassis: desktop
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : amd64
                                   12:25:29 up 40 min,  2 users,  load average: 1.26, 1.26, 1.36
                                  CPU threads: 4
                                                 Local time: Mon 2023-10-02 12:25:29 CEST
                                             Universal time: Mon 2023-10-02 10:25:29 UTC
                                                   RTC time: Mon 2023-10-02 10:25:29
                                                NTP service: active
                                            RTC in local TZ: no
                                  daniel
                                  /home/daniel
                                  daniel adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            7.9G        3.2G        2.9G        1.0M        1.7G        4.3G
                                  Swap:           976M          0B        976M
                                  Total:          8.8G        3.2G        3.9G
                                           7862 M total memory
                                           3233 M used memory
                                            632 M active memory
                                           3487 M inactive memory
                                           2912 M free memory
                                            197 M buffer memory
                                           1519 M swap cache
                                            976 M total swap
                                              0 M used swap
                                            976 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  28G     /var/
                                  26G     /var/lib
                                  Archived and active journals take up 1008.3M in the file system.
                                  504M    /opt/iobroker/iobroker-data/
                                  31M     /opt/iobroker/iobroker-data/states.jsonl
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.10.1
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        16242
                                  States:         13909
                                  Pending Updates: 0
                                  2023-10-02 12:21:36.628  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                                  2023-10-02 12:22:06.679  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                                  2023-10-02 12:22:24.473  - info: javascript.0 (1392) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
                                  2023-10-02 12:23:06.948  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
                                  2023-10-02 12:24:07.108  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                                  2023-10-02 12:25:00.066  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 10916
                                  2023-10-02 12:25:00.974  - info: tvspielfilm.0 (10916) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
                                  2023-10-02 12:25:03.015  - info: tvspielfilm.0 (10916) objects written
                                  2023-10-02 12:25:04.095  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 10935
                                  2023-10-02 12:25:04.951  - info: dwd.0 (10935) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
                                  2023-10-02 12:25:05.514  - info: dwd.0 (10935) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2023-10-02 12:25:06.041  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-10-02 12:25:10.922  - info: linux-control.0 (3694) getting data from Debian_11 (192.168.100.146:22)
                                  2023-10-02 12:25:13.082  - info: linux-control.0 (3694) successful received data from Debian_11 (192.168.100.146:22)
                                  2023-10-02 12:25:13.523  - info: tvspielfilm.0 (10916) Terminated (NO_ERROR): Without reason
                                  2023-10-02 12:25:14.054  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                                  2023-10-02 12:25:37.376  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                                    @keulehd
                                    Und in die Gruppe 'iobroker' würde ich den auch setzen. Und dann den User 'iobroker' in Ruhe lassen.
                                      @thomas-braun Auch erledigt
                                      daniel@HomeServer:~$ sudo usermod -a -G iobroker daniel
                                      Nur für mich: Hat das mit dem User "iobroker" einen bestimmten Grund ? Nur zum Verständnis. Danke Dir
                                        @keulehd
                                        Der User iobroker ist eigentlich ein Systemuser (und bekommt in der Standardinstallation erst gar kein Login). Man rödelt mit einem eigenen User durch das System, bei dir halt mit dem 'daniel'.
                                          @thomas-braun Ah alles klar. Den iobroker hab ich bei der Installation angelegt aber spielt in dem Fall ja keine Rolle. System ist nun dank Dir stabil und einigermaßen sauber hergestellt. Danke Dir.
                                          Nun mal schauen wegen FLOT: Weiß nur überhaupt nicht wo ich da anfangen soll. Dachte mit der zweiten web.1 Instanz geht es weil das Problem anscheinend schon etliche hatten und damit behoben haben aber bei mir geht das nicht.
                                            Das ist falsch, der wird vom iobroker-Installer angelegt. Und dann tickt der auch anders als jetzt dein 'iobroker'.
                                            2795
