    4. Tasmota Steckdose > ESP Matrix Display
      berndsolar13 @Wal last edited by
      @wal
      kein Stress, hab die Teile noch nicht mal bestellt 😉
      Wal 2 Replies Last reply Reply Quote 0
      • Wal
        Wal Developer @berndsolar13 last edited by
        @berndsolar13 ,
        die Anzeige vom Hichi geht schon, jetzt muss ich noch die Steckdose einbinden.
          @wal sagte in Tasmota Steckdose > ESP Matrix Display:
          @berndsolar13 ,
          cool, was würde bei -150 oder + 500 passieren ? Wandert es dann ?
          • Wal
            @berndsolar13 ,
            bin fertig geht. 😉
            firmware.bin.gz Firmware für die Steckdose
            Vorher die tasmota-minimal flashen sonst ist sie zu groß.
            Script für das Display:
            >D
            g:to=0
            >S
            if upsecs%10==0 {
              ->DisplayText %to% kWh
            >W
            Total{m} %to% kWh
            Script für die Steckdose:
            >D
            g:to=0
            >T
            to=ENERGY#Total
            >S
            if upsecs%10==0 {
              print %to%
            Die Daten für ENERGY->Total werden gesendet, kannst du aber für deine Steckdose anpassen.
            15:53:22.878 MQT: tele/Wohnen.Fernseher/STATE = {"Time":"2023-10-02T15:53:22","Uptime":"0T00:24:43","UptimeSec":1483,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"1GBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":66,"Signal":-67,"LinkCount":1,"Downtime":"0T00:00:07"}}
            15:53:22.909 MQT: tele/Wohnen.Fernseher/SENSOR = {"Time":"2023-10-02T15:53:22","ENERGY":{"TotalStartTime":"2023-09-18T20:12:07","Total":5.629,"Yesterday":0.717,"Today":0.008,"Period":0,"Power":1,"ApparentPower":19,"ReactivePower":19,"Factor":0.04,"Voltage":233,"Current":0.081}}
            15:53:28.900 5.63
            15:53:32.889 MQT: tele/Wohnen.Fernseher/STATE = {"Time":"2023-10-02T15:53:32","Uptime":"0T00:24:53","UptimeSec":1493,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"1GBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:07"}}
            15:53:32.923 MQT: tele/Wohnen.Fernseher/SENSOR = {"Time":"2023-10-02T15:53:32","ENERGY":{"TotalStartTime":"2023-09-18T20:12:07","Total":5.629,"Yesterday":0.717,"Today":0.008,"Period":0,"Power":1,"ApparentPower":19,"ReactivePower":19,"Factor":0.04,"Voltage":232,"Current":0.080}}
            15:53:38.873 5.63
            15:53:42.877 MQT: tele/Wohnen.Fernseher/STATE = {"Time":"2023-10-02T15:53:42","Uptime":"0T00:25:03","UptimeSec":1503,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"1GBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":66,"Signal":-67,"LinkCount":1,"Downtime":"0T00:00:07"}}
            15:53:42.907 MQT: tele/Wohnen.Fernseher/SENSOR = {"Time":"2023-10-02T15:53:42","ENERGY":{"TotalStartTime":"2023-09-18T20:12:07","Total":5.629,"Yesterday":0.717,"Today":0.008,"Period":0,"Power":1,"ApparentPower":19,"ReactivePower":19,"Factor":0.04,"Voltage":233,"Current":0.081}}
            15:53:48.907 5.63
            15:53:52.911 MQT: tele/Wohnen.Fernseher/STATE = {"Time":"2023-10-02T15:53:52","Uptime":"0T00:25:13","UptimeSec":1513,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"1GBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":66,"Signal":-67,"LinkCount":1,"Downtime":"0T00:00:07"}}
            15:53:52.942 MQT: tele/Wohnen.Fernseher/SENSOR = {"Time":"2023-10-02T15:53:52","ENERGY":{"TotalStartTime":"2023-09-18T20:12:07","Total":5.629,"Yesterday":0.717,"Today":0.008,"Period":0,"Power":1,"ApparentPower":19,"ReactivePower":19,"Factor":0.04,"Voltage":233,"Current":0.080}}
            15:53:58.970 5.63
            15:54:02.908 MQT: tele/Wohnen.Fernseher/STATE = {"Time":"2023-10-02T15:54:02","Uptime":"0T00:25:23","UptimeSec":1523,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"1GBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":66,"Signal":-67,"LinkCount":1,"Downtime":"0T00:00:07"}}
            15:54:02.941 MQT: tele/Wohnen.Fernseher/SENSOR = {"Time":"2023-10-02T15:54:02","ENERGY":{"TotalStartTime":"2023-09-18T20:12:07","Total":5.629,"Yesterday":0.717,"Today":0.008,"Period":0,"Power":1,"ApparentPower":18,"ReactivePower":19,"Factor":0.04,"Voltage":231,"Current":0.080}}
            • Wal
              @berndsolar13 sagte in Tasmota Steckdose > ESP Matrix Display:
              Ja
                @wal
                supi 🙂
                Die 2 Scripte oben gebe ich unter Konsole > Scripte ein.
                Einmal in der Steckdose 1x im Wemos wo das Display dran hängt.
                Wo genau hast du nun die IP des Wemos eingegeben ?
                Die Steckdose weiß doch nicht wem sie es schicken muss 😳
                • Wal
                  @berndsolar13 ,
                  das ist ja das schöne, braucht man nicht.
                  die Daten werden soweit ich weiß über UDP gesendet und jedes Gerät kann sich die Daten nehmen, du kannst 100 Displays dranhängen.
                    @wal
                    achso, und darüber hab ich mir vorher Tagelang Gedanken gemacht.
                    Vielen Dank, dann werde ich die Sachen heute bestellen und dann berichten, oder fragen 😄
                    • Wal
                      Wal Developer @berndsolar13 last edited by Wal
                      @berndsolar13 ,
                      nimm für das Display ein ESP32 falls das Script mal grösser wird, da kann ich dir auch die Firmware senden.
                      firmware.bin
                      edit: habe so etwas
                      B Ralla66 2 Replies Last reply Reply Quote 0
                        @wal
                        wollte eigentlich 5 Wemos für 20 Euro kaufen, weil ich das Display auch haben wollte, + 1 Wlan Verstärker aus dem Wemos machen und 1 Ultraschall Entfernungsmesser und noch 1 zum üben.
                        Die 5 Wemos hätten 20 Euro gekostet, das Ding da oben kostet schon 15 😄
                        Mehr muss das Ding eh nicht können, er will nur den Wert was das Balkonkraftwerk liefert.
                        Ich werde erstmal mit dem Wemos testen, und wenn ich später bischen Erfahrung mit den Dingern habe, kann ich zumindest meines Upgraden 😉
                        Wegen dem Scrollen oben, das Balkonkraftwerk wird maximal 3 Stellen schicken, gehen ja nur 800 Watt. Wenn man hinten das W weg lassen würde, dann würde es nicht mehr scrollen, richtig ?
                        Flashen geht mit Tamotizer oder wie sich das Ding nennt richtig ?
                        Wal 1 Reply Last reply Reply Quote 1
                        • Ralla66
                          Ralla66 Most Active @Wal last edited by Ralla66
                          @wal
                          habe auch mal 8x8 Matrix bestellt. Wurde was in Tasmota per Console eingegeben ?
                          Displayart, Row oder ähnliches ?
                          Gruß Ralf
                          • Wal
                            Wal Developer @Ralla66 last edited by
                            @ralla66 ,
                            ja, man muss die Höhe und Breite sowie Displayart eingeben.
                            • Wal
                              @berndsolar13 ,
                              du kannst das Leerzeichen vor dem 'W' weglassen oder beides.
                                @wal
                                genau so hab ich mir das vorgestellt, Top 🙂
                                  @Wal
                                  hab heute mal die Tasmota Steckdose geflasht, erst über Minimal und dann mit deiner Datei.
                                  Ergebnis sieht man im Bild, die Konsole schickt alle 10 Sekunden den Live Power Wert.
                                  Der Teil scheint also zu klappen 🙂
                                  Die Wemos + LED Matrix + Jumper Kabel werde ich nachher bestellen.
                                  Vielleicht kann ist am Wochenende das Ergebnis posten.
                                  Ich werde vermutlich 3 Varianten testen.
                                  1. deine Tasmota Easy Variante
                                  2. die mit der ESP Easy Software mit MQTT
                                  3. eine Push Variante wo man einfach nur einen Get oder Post Befehl an den Wemos schickt. Es gibt eine Display Matrix Firmware die beim Aufrufen der oberfläche ein Input Feld hat, wo man einen Text eingeben kann, und wenn man auf Senden klickt, erscheint der Text dort.
                                    Warum, die Idee ist, dann verschiedene Werte dort hin zu senden, Also quasi alle 10 Sek irgendwas anderes. Ob das sinnvoll ist wird sich zeigen. Ich hab hier bei meinem Iobroker System ja einige Werte ich die da hin senden könnte. Quasi 6 Stück jeweils einen pro 10 Sekunden
                                    0, 10, 20, 30, 40, 50
                                    Wollte bei mir die Lange Varinte bauen mit 2 oder 3 von den Dingern. Da ist dann platz für mehr Text.
                                  Alternativ 2 übereinander. Oben permanent den Livewert darunter dann den Wert vom Wechselrichter. Im Wechel (Live, Heute, Gesamt) Aber das ist ein anderes Thema. Hier gehts ja um Steckdose > Display 🙂
                                  • Wal
                                    @berndsolar13 ,
                                    Version 3 geht auch mit Version 1, du musst nur das Teil mit ioBroker verbinden.
                                    Dann erscheint im Sonoff Adapter ein Objekt DisplayText und alles was du da eingibst erscheint im Display.
                                    Du musst nur das Script ändern, da der Text dann alle 10sec überschrieben wird.
                                    Edit: Du kannst auch von mehreren Geräten globale Variablen erzeugen und im Display im Intervall anzeigen lassen.
                                      @wal
                                      Globale Variablen klingt interessant.
                                      Stelle ich mir das so vor ?
                                      Hirchi Tamsota Sensor erstellt aktueller Zählerwert globlvariable1 = "-123" (Wert des aktuellen Verbrauchs des Hauses mit -123, da BKW mehr produziert wie gebraucht wird
                                      Steckdose am BKW = globlvariable2 = "357" (357 Watt aktuell produziert)
                                      Steckdose am Gefrierschrank = globlvariable3 = "75" (der verbraucht gerade 75 Watt)
                                      Ultraschall Sensor globlvariable4 = "45" (Wasserstand im Tank noch 45 cm)
                                      Und dann lasse ich mir die 4 abwechselnd im Display anzeigen ? Wäre cool aber irgendwie muss ich da doch noch eine Info mit schicken, damit ich weiß was was ist 😄 die 45 könnten ja auch der aktuelle Bezug aus dem Stromnetz sein
                                      Die Sachen sind (dann) alle im Iobroker im Sonoff Adapter, ich denke da wäre der Push darüber sinnvoller.
                                      Denn da kann ich dann bestimmt auch den "Absender" mit nennen.
                                      Stelle mir das so vor:
                                      1. Zähler: -125 W
                                      2. BWK: 385 W
                                      3. Gefrier: 70 W
                                      4. Wasser: 45 cm
                                      Das wäre dann die Traumlösung 😉 Aber das ist nicht mehr das Thema des Beitrags 😉 Dafür wohl besser einen Extra aufmachen oder ?
                                      Bestellt habe ich heute 5 Wemos D1, 1 Paket Jumper Kabel, 3 LED Matrix (bei 3 kostet eins nur 6.5 €) und 2 Ultraschall Sensoren, die aus China, Preis 1.25 € kommen aber erst in 3 Wochen 😉
                                        Flugschüler last edited by Flugschüler
                                        Ich hab dieses Projekt umgesetzt. Funktioniert bei mir super. https://forum.iobroker.net/topic/12811/esp-matrix-anzeige-fully-iobroker-steuerbar
                                        Aber da brauchst du halt einen iobroker.
                                          berndsolar13 @Flugschüler last edited by
                                          @flugschüler
                                          Ja, das Projekt war der Ursprung meiner Idee 😉
                                          Für die "mein Vater Variante" ist die Tasmota zu Tasmota Kommunikation einfacher.
                                          Für mein Projekt werde ich die Steuerung über den iobroaker machen, da dort eh alle Werte schon vorhanden sind. Hab ja den Sonoff Adapter drin, und den Deye Adaper von Rene55
                                          • Wal
                                            @berndsolar13 ,
                                            ESPAnzeige
                                            >D
                                            g:var1=0
                                            g:var2=0
                                            g:var3=0
                                            g:var4=0
                                            ESPZähler
                                            >D
                                            g:var1=0
                                            ESPBKW
                                            >D
                                            g:var2=0
                                            ESPGefrier
                                            >D
                                            g:var3=0
                                            ESPWasser
                                            >D
                                            g:var4=0
                                            1.0k
                                            178
                                            30932
