    4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
      Thomas Braun Most Active @Jan1 last edited by
      @jan1
      Ah! Kannst du uns näheres zu deinem Setup sagen?
      iob diag
      wäre gut...
        Jan1 @Thomas Braun last edited by
        lang:
        Skript v.2023-06-20
        *** BASE SYSTEM ***
        Static hostname: Beelink
        Icon name: computer-desktop
        Chassis: desktop
        Machine ID: a5e8094cdcde4fafa3a8b051d1ec8c4f
        Boot ID: 3aad6de0f1d34b3499c96bc95c9d693f
        Operating System: Ubuntu 22.04.3 LTS
        Kernel: Linux 5.15.0-84-generic
        Architecture: x86-64
        Hardware Vendor: AZW
        Hardware Model: MINI S
        model name : Intel(R) Celeron(R) N5095 @ 2.00GHz
        Docker : false
        Virtualization : none
        Kernel : x86_64
        Userland : amd64
        Systemuptime and Load:
        09:09:36 up 8 days, 17:58, 2 users, load average: 0.17, 0.62, 0.57
        CPU threads: 4
        *** Time and Time Zones ***
        Local time: Tue 2023-10-03 09:09:36 CEST
        Universal time: Tue 2023-10-03 07:09:36 UTC
        RTC time: Tue 2023-10-03 07:09:36
        NTP service: active
        RTC in local TZ: no
        *** User and Groups ***
        jan
        /home/jan
        jan adm cdrom sudo dip plugdev lxd iobroker
        *** X-Server-Setup ***
        X-Server: false
        Desktop:
        Terminal: tty
        Boot Target: multi-user.target
        *** MEMORY ***
        total used free shared buff/cache available
        Mem: 7.7G 1.9G 2.6G 1.0M 3.3G 5.5G
        Swap: 4.1G 0B 4.1G
        Total: 11G 1.9G 6.6G
             7717 M total memory
             1884 M used memory
             1181 M active memory
             3515 M inactive memory
             2553 M free memory
              592 M buffer memory
             2687 M swap cache
             4095 M total swap
                0 M used swap
             4095 M free swap
        *** FILESYSTEM ***
        Filesystem Type Size Used Avail Use% Mounted on
        tmpfs tmpfs 772M 1.6M 771M 1% /run
        /dev/mapper/ubuntu--vg-ubuntu--lv ext4 232G 12G 210G 6% /
        tmpfs tmpfs 3.8G 0 3.8G 0% /dev/shm
        tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
        /dev/sda2 ext4 2.0G 130M 1.7G 8% /boot
        /dev/sda1 vfat 1.1G 6.1M 1.1G 1% /boot/efi
        tmpfs tmpfs 772M 4.0K 772M 1% /run/user/1000
        [Sun Sep 24 15:10:48 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sun Sep 24 15:10:48 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
        [Sun Sep 24 15:10:49 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET SOURCE FSTYPE OPTIONS
        / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime
        |-/snap/core20/1974 /dev/loop0 squashfs ro,nodev,relatime,errors=continue
        |-/snap/core20/2015 /dev/loop1 squashfs ro,nodev,relatime,errors=continue
        |-/snap/lxd/24322 /dev/loop2 squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/19993 /dev/loop3 squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/20092 /dev/loop4 squashfs ro,nodev,relatime,errors=continue
        -/boot /dev/sda2 ext4 rw,relatime -/boot/efi /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        /var:
        960M /var/
        643M /var/lib
        435M /var/lib/snapd
        226M /var/lib/snapd/seed/snaps
        Archived and active journals take up 200.0M in the file system.
        /opt/iobroker/backups:
        2.7M /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        319M /opt/iobroker/iobroker-data/
        196M /opt/iobroker/iobroker-data/files
        58M /opt/iobroker/iobroker-data/backup-objects
        52M /opt/iobroker/iobroker-data/files/javascript.admin
        43M /opt/iobroker/iobroker-data/files/iot.admin
        33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        30M /opt/iobroker/iobroker-data/states.jsonl
        22M /opt/iobroker/iobroker-data/objects.jsonl
        21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js.map
        8.5M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        *** NodeJS-Installation ***
        /usr/bin/nodejs v18.18.0
        /usr/bin/node v18.18.0
        /usr/bin/npm 9.8.1
        /usr/bin/npx 9.8.1
        nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
        *** 18.18.0-1nodesource1 500
        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
        100 /var/lib/dpkg/status
        18.17.1-1nodesource1 500
        18.17.0-1nodesource1 500
        18.16.1-1nodesource1 500
        18.16.0-1nodesource1 500
        18.15.0-1nodesource1 500
        18.14.2-1nodesource1 500
        18.14.1-1nodesource1 500
        18.14.0-1nodesource1 500
        18.13.0-1nodesource1 500
        18.12.0-1nodesource1 500
        18.11.0-1nodesource1 500
        18.10.0-1nodesource1 500
        18.9.1-1nodesource1 500
        18.9.0-1nodesource1 500
        18.8.0-1nodesource1 500
        18.7.0-1nodesource1 500
        18.6.0-1nodesource1 500
        18.5.0-1nodesource1 500
        18.4.0-1nodesource1 500
        18.3.0-1nodesource1 500
        18.2.0-1nodesource1 500
        18.1.0-1nodesource1 500
        18.0.0-1nodesource1 500
        12.22.9~dfsg-1ubuntu3 500
        500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication: enabled
        Persistent activation: disabled
        Objects: jsonl on 127.0.0.1
        States: jsonl on 127.0.0.1
        Core adapters versions
        js-controller: 5.0.12
        admin: 6.10.4
        javascript: 7.1.4
        Adapters from github: 1
        Adapter State
        • system.adapter.admin.0 : admin : Beelink - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        • system.adapter.alexa2.0 : alexa2 : Beelink - enabled
        • system.adapter.backitup.0 : backitup : Beelink - enabled
          system.adapter.ble.0 : ble : Beelink - disabled
          system.adapter.bosch-ebike.0 : bosch-ebike : Beelink - disabled
        • system.adapter.denon.0 : denon : Beelink - enabled
        • system.adapter.enigma2.0 : enigma2 : Beelink - enabled
          system.adapter.feiertage.0 : feiertage : Beelink - enabled
          system.adapter.firetv.0 : firetv : Beelink - disabled
        • system.adapter.fritzdect.0 : fritzdect : Beelink - enabled
        • system.adapter.google-sharedlocations.0 : google-sharedlocations: Beelink - enabled
        • system.adapter.harmony.0 : harmony : Beelink - enabled
        • system.adapter.history.0 : history : Beelink - enabled
          system.adapter.ical.0 : ical : Beelink - enabled
        • system.adapter.info.0 : info : Beelink - enabled
        • system.adapter.iot.0 : iot : Beelink - enabled
        • system.adapter.iqontrol.0 : iqontrol : Beelink - enabled
        • system.adapter.javascript.0 : javascript : Beelink - enabled
        • system.adapter.milight-smart-light.0 : milight-smart-light : Beelink - enabled
        • system.adapter.node-red.0 : node-red : Beelink - enabled, port: 1880, bind: 0.0.0.0 (SSL)
          system.adapter.openweathermap.0 : openweathermap : Beelink - enabled
        • system.adapter.simple-api.0 : simple-api : Beelink - enabled, port: 8087, bind: 0.0.0.0, run as: admin
        • system.adapter.sonoff.0 : sonoff : Beelink - enabled, port: 1883, bind: 0.0.0.0
        • system.adapter.tankerkoenig.0 : tankerkoenig : Beelink - enabled
        • system.adapter.telegram.0 : telegram : Beelink - enabled, port: 8443, bind: 0.0.0.0
        • system.adapter.tr-064.0 : tr-064 : Beelink - enabled
          system.adapter.vw-connect.0 : vw-connect : Beelink - disabled
        • system.adapter.web.0 : web : Beelink - enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
        • system.adapter.wled.0 : wled : Beelink - enabled
        • system.adapter.ws.0 : ws : Beelink - enabled, port: 8084, bind: 0.0.0.0, run as: admin
        • system.adapter.zigbee.0 : zigbee : Beelink - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_ac906d74b593eb11b6e91b4f3d98b6d1-if00-port0
        • instance is alive
        ioBroker-Repositories
        Stable (default): http://iobroker.live/repo/sources-dist.json
        latest : http://iobroker.live/repo/sources-dist-latest.json
        Active repo(s): latest
        Installed ioBroker-Instances
        Used repository: latest
        Adapter "admin" : 6.10.4 , installed 6.10.4
        Adapter "alexa2" : 3.25.2 , installed 3.25.2
        Adapter "backitup" : 2.8.2 , installed 2.8.2
        Adapter "ble" : 0.13.4 , installed 0.13.4
        Adapter "bosch-ebike" : 0.1.0 , installed 0.1.0
        Adapter "denon" : 1.15.4 , installed 1.15.4
        Adapter "enigma2" : 2.0.5 , installed 2.0.5
        Adapter "feiertage" : 1.1.4 , installed 1.1.4
        Adapter "firetv" : 2.0.2 , installed 2.0.2
        Adapter "fritzdect" : 2.4.1 , installed 2.4.1
        Adapter "harmony" : 1.2.2 , installed 1.2.2
        Adapter "history" : 3.0.0 , installed 3.0.0
        Adapter "ical" : 1.13.3 , installed 1.13.3
        Adapter "info" : 2.0.0 , installed 2.0.0
        Adapter "iot" : 2.0.11 , installed 2.0.11
        Adapter "iqontrol" : 2.3.0 , installed 2.3.0
        Adapter "javascript" : 7.1.4 , installed 7.1.4
        Controller "js-controller": 5.0.12 , installed 5.0.12
        Adapter "milight-smart-light": 1.2.2, installed 1.2.2
        Adapter "node-red" : 4.0.3 , installed 4.0.3
        Adapter "openweathermap": 0.4.4 , installed 0.4.4
        Adapter "simple-api" : 2.7.2 , installed 2.7.2
        Adapter "socketio" : 6.5.6 , installed 6.5.6
        Adapter "sonoff" : 3.0.3 , installed 3.0.3
        Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
        Adapter "telegram" : 1.16.0 , installed 1.16.0
        Adapter "tr-064" : 4.2.18 , installed 4.2.18
        Adapter "vw-connect" : 0.1.3 , installed 0.1.3
        Adapter "web" : 6.1.3 , installed 6.1.3
        Adapter "wled" : 0.7.1 , installed 0.7.1
        Adapter "ws" : 2.5.6 , installed 2.5.6
        Adapter "zigbee" : 1.8.24 , installed 1.8.24
        Objects and States
        Objects: 12158
        States: 12432
        Failed to start apt-news.service: Unit apt-news.service not found.
        Failed to start esm-cache.service: Unit esm-cache.service not found.
        Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
        Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
        tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 102 25838 679/systemd-resolve
        tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 34028519 618348/iobroker.js-
        tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 34030025 618348/iobroker.js-
        tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 34032965 619352/io.sonoff.0
        tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 34031992 619100/node-red
        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 28524 779/sshd: /usr/sbin
        tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 1534 1/init
        tcp6 0 0 :::8082 :::* LISTEN 1001 34036863 620794/io.web.0
        tcp6 0 0 :::8081 :::* LISTEN 1001 34031239 618375/io.admin.0
        tcp6 0 0 :::8087 :::* LISTEN 1001 34034525 620467/io.simple-ap
        tcp6 0 0 :::8084 :::* LISTEN 1001 34037039 621134/io.ws.0
        tcp6 0 0 :::4400 :::* LISTEN 1001 34033617 620405/io.milight-s
        tcp6 0 0 :::22 :::* LISTEN 0 28526 779/sshd: /usr/sbin
        tcp6 0 0 :::111 :::* LISTEN 0 19531 1/init
        tcp6 0 0 :::80 :::* LISTEN 1001 34031994 619100/node-red
        tcp6 0 0 :::61991 :::* LISTEN 1001 34035062 619505/io.harmony.0
        udp 0 0 127.0.0.53:53 0.0.0.0:* 102 25837 679/systemd-resolve
        udp 0 0 192.168.100.10:68 0.0.0.0:* 101 27734519 677/systemd-network
        udp 0 0 0.0.0.0:111 0.0.0.0:* 0 1535 1/init
        udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 34035063 619505/io.harmony.0
        udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 34036106 621084/io.wled.0
        udp 0 0 192.168.100.10:5353 0.0.0.0:* 1001 34032202 619372/io.tr-064.0
        udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 34031995 619100/node-red
        udp 0 0 0.0.0.0:55606 0.0.0.0:* 1001 34033614 620405/io.milight-s
        udp6 0 0 :::111 :::* 0 20769 1/init
        udp6 0 0 fe80::7e83:34ff:feb:546 :::* 101 27736182 677/systemd-network
        2023-10-03 09:10:05.823 - info: admin.0 (618375) ==> Connected system.user.admin from ::ffff:192.168.100.16
        2023-10-03 09:10:06.517 - info: host.Beelink Updating repository "latest" under "http://iobroker.live/repo/sources-dist-latest.json"
        kurz:
                            v.2023-06-20
                Chassis: desktop
        Installation:           native
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                               /usr/bin/npm            9.8.1
                               /usr/bin/npx            9.8.1
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            7.7G        2.0G        2.4G        1.0M        3.3G        5.4G
        Swap:           4.1G          0B        4.1G
        Total:           11G        2.0G        6.5G
        Active iob-Instances:   25
        ioBroker Core:          js-controller           5.0.12
                               admin                   6.10.4
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : Beelink                                  -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.web.0                    : web                   : Beelink                                  -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
        Objects:                12158
        States:                 12432
        Size of iob-Database:
        31M     /opt/iobroker/iobroker-data/states.jsonl
          crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
          @thomas-braun hab gerade mal nachgesehen, alles in Ordnung
          Allerdings nicht cifs auf Fritte, sondern
          • Auf Usb an der Fritte per ftp
          • auf OMV VM per cifs
          Und natürlich auch keinen Raspberry
            Radi @Thomas Braun last edited by
            @thomas-braun Bei mir läuft der IOBroker auf einer VM unter Proxmox. Auch bei mir sind die Backups seit der Installation von node 18.18.0 zu klein. Dies gilt für alle erstellten Backups( Homematic, IOBroker, Redis und History). Im Anhang die Langversion der Ausgabe von iob diag.
            Skript v.2023-06-20
            *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer-vm
                       Chassis: vm
                    Machine ID: 0b042677bfcf43ac87065ffc8cb9f7a8
                       Boot ID: 74e1ad1dc2db45f7a0733269c4cfe04c
                Virtualization: kvm
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 5.10.0-25-amd64
            model name      : Common KVM processor
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : amd64
             09:54:29 up 3 days, 21:32,  1 user,  load average: 0.84, 0.89, 0.77
            CPU threads: 24
                           Local time: Tue 2023-10-03 09:54:29 CEST
                       Universal time: Tue 2023-10-03 07:54:29 UTC
                             RTC time: Tue 2023-10-03 07:54:30
                          NTP service: active
                      RTC in local TZ: no
            iobroker
            /home/iobroker
            iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev redis
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            7.9G        6.1G        617M        0.0K        1.2G        1.5G
            Swap:           974M        483M        491M
            Total:          8.9G        6.6G        1.1G
                     7942 M total memory
                     6129 M used memory
                     1597 M active memory
                     5173 M inactive memory
                      617 M free memory
                      374 M buffer memory
                      822 M swap cache
                      974 M total swap
                      483 M used swap
                      491 M free swap
            *** FILESYSTEM ***
            udev           devtmpfs  3.9G     0  3.9G   0% /dev
            tmpfs          tmpfs     795M  612K  794M   1% /run
            /dev/sda1      ext4      125G   71G   49G  60% /
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs     795M     0  795M   0% /run/user/1000
            [sudo] password for iobroker:
            [Fri Sep 29 12:22:17 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Fri Sep 29 12:22:17 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
            /var:
            803M    /var/
            426M    /var/cache
            419M    /var/cache/apt
            351M    /var/cache/apt/archives
            205M    /var/log
            Archived and active journals take up 64.0M in the file system.
            4.0K    /opt/iobroker/backups/
            64G     /opt/iobroker/iobroker-data/
            63G     /opt/iobroker/iobroker-data/history
            546M    /opt/iobroker/iobroker-data/files
            214M    /opt/iobroker/iobroker-data/history/20230329
            201M    /opt/iobroker/iobroker-data/history/20230328
            74M     /opt/iobroker/iobroker-data/objects.jsonl
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
             *** 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
            npm ERR! code ELSPROBLEMS
            npm ERR! invalid: nodemailer@6.9.1 /opt/iobroker/node_modules/nodemailer
            npm ERR! missing: dewpoint@^1.0.0, required by iobroker.javascript@7.1.4
            npm ERR! missing: noble@^1.9.1, required by iobroker.javascript@7.1.4
            npm ERR! missing: react@^18.2.0, required by iobroker.javascript@7.1.4
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-03T07_54_52_538Z-debug-0.log
            ioBroker Status
            Objects type: jsonl
            States  type: redis
            States:                     redis on 127.0.0.1
            admin:          6.10.1
            javascript:     7.1.4
            Adapters from github:   13
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
              system.adapter.boschindego.0            : boschindego           : iobroker                                 - disabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
              system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
              system.adapter.devices.0                : devices               : iobroker                                 - disabled
              system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
            + system.adapter.drag-indicator.0         : drag-indicator        : iobroker                                 -  enabled
            + system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
            + system.adapter.goodwe.0                 : goodwe                : iobroker                                 -  enabled
            + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              system.adapter.hm-rpc.4                 : hm-rpc                : iobroker                                 - disabled, port: 0
              system.adapter.hm-rpc.5                 : hm-rpc                : iobroker                                 - disabled, port: 0
            + system.adapter.hoover.0                 : hoover                : iobroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
            + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
            + system.adapter.lgtv11.0                 : lgtv11                : iobroker                                 -  enabled, port: 8080
              system.adapter.material.0               : material              : iobroker                                 - disabled
            + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
            + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
            + system.adapter.mihome.0                 : mihome                : iobroker                                 -  enabled, port: 9898, bind: 192.168.69.159
            + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
              system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
            + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
            + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
            + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
            + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
            + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
            + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
            + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
            + system.adapter.ph803w.0                 : ph803w                : iobroker                                 -  enabled
            + system.adapter.pid.0                    : pid                   : iobroker                                 -  enabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
            + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
              system.adapter.pylontech.0              : pylontech             : iobroker                                 - disabled, port: 23
            + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
            + system.adapter.rtl_433.0                : rtl_433               : iobroker                                 -  enabled
              system.adapter.rtspStream.0             : rtspStream            : iobroker                                 - disabled, port: 8082
            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
              system.adapter.schoolfree.0             : schoolfree            : iobroker                                 - disabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
            + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 -  enabled
              system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1500, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
            + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
            + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
              system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
              system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
              system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
              system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
            + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
            + system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
            + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB1
            + instance is alive
            sources       : conf/sources-dist.json
            online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
            beta          : http://iobroker.live/repo/sources-dist-latest.json
            Active repo(s): stable
            Used repository: stable
            Adapter    "admin"        : 6.10.1   , installed 6.10.1
            Adapter    "apcups"       : 1.0.15   , installed 1.0.15
            Adapter    "backitup"     : 2.8.1    , installed 2.8.1
            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
            Adapter    "device-reminder": 1.2.9  , installed 1.2.9
            Adapter    "device-watcher": 2.9.3   , installed 2.9.3
            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
            Adapter    "drag-indicator": 2.1.0   , installed 2.1.0
            Adapter    "email"        : 1.2.0    , installed 1.2.0
            Adapter    "ems-esp"      : 2.4.1    , installed 2.4.1
            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
            Adapter    "hass"         : 1.4.0    , installed 1.4.0
            Adapter    "history"      : 2.2.6    , installed 2.2.6
            Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
            Adapter    "hoover"       : 0.0.7    , installed 0.1.1
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "iot"          : 1.14.5   , installed 1.14.5
            Adapter    "km200"        : 2.0.3    , installed 2.0.3
            Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
            Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "midea"        : 0.0.7    , installed 0.0.7
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
            Adapter    "moma"         : 1.2.9    , installed 1.2.9
            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
            Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
            Adapter    "onvif"        : 1.0.5    , installed 1.0.5
            Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
            Adapter    "parser"       : 1.3.2    , installed 1.3.2
            Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
            Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
            Adapter    "pvforecast"   : 2.8.1    , installed 2.7.1  [Updatable]
            Adapter    "rflink"       : 2.1.6    , installed 2.1.6
            Adapter    "s7"           : 1.3.15   , installed 1.3.15
            Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
            Adapter    "shelly"       : 6.4.1    , installed 6.4.1
            Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
            Adapter    "snmp"         : 2.4.11   , installed 2.4.11
            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
            Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
            Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
            Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
            Adapter    "statistics"   : 2.3.0    , installed 2.3.0
            Adapter    "text2command" : 3.0.2    , installed 3.0.2
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "tuya"         : 3.14.2   , installed 3.14.2
            Adapter    "unifi"        : 0.6.6    , installed 0.6.6
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
            Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.1.2    , installed 6.1.2
            Adapter    "wled"         : 0.6.7    , installed 0.6.7
            Adapter    "ws"           : 2.5.5    , installed 2.5.5
            Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
            Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
            Objects and States
            Objects:        72640
            States:         54239
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Pending Updates: 0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13741      504/sshd: /usr/sbin
            tcp        0      0 192.168.69.159:2010     0.0.0.0:*               LISTEN      1000       18836      1110/io.hm-rpc.3
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       18864      1262/io.mqtt.0
            tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1000       13939      1388/io.sonoff.0
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       18865      1262/io.mqtt.0
            tcp        0      0 192.168.69.159:8701     0.0.0.0:*               LISTEN      1000       1360       1091/io.hm-rpc.2
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       14596      582/iobroker.js-con
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        11663      459/redis-server 12
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          18520      1/init
            tcp        0      0 192.168.69.159:2000     0.0.0.0:*               LISTEN      1000       18803      1072/io.hm-rpc.1
            tcp        0      0 192.168.69.159:2001     0.0.0.0:*               LISTEN      1000       18757      1045/io.hm-rpc.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       27686      2303/io.socketio.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      1000       30024      2866/io.web.2
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13743      504/sshd: /usr/sbin
            tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1985       2222/io.simple-api.
            tcp6       0      0 :::8089                 :::*                    LISTEN      1000       25177      2817/io.web.1
            tcp6       0      0 :::8095                 :::*                    LISTEN      1000       30377      3057/io.onvif.0
            tcp6       0      0 ::1:6379                :::*                    LISTEN      108        11664      459/redis-server 12
            tcp6       0      0 :::111                  :::*                    LISTEN      0          11594      1/init
            tcp6       0      0 :::80                   :::*                    LISTEN      0          207        522/apache2
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22164      667/io.admin.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       12784      1431/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       12785      1431/io.tuya.0
            udp        0      0 0.0.0.0:56901           0.0.0.0:*                           1000       16187      1950/io.milight-sma
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13719      404/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18521      1/init
            udp        0      0 0.0.0.0:57485           0.0.0.0:*                           1000       23728      2253/io.snmp.0
            udp        0      0 0.0.0.0:49308           0.0.0.0:*                           1000       19901      1319/io.ph803w.0
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       12625      1148/io.mihome-vacu
            udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       15663      1167/io.mihome-vacu
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       26425      2893/io.wled.0
            udp        0      0 192.168.69.159:5353     0.0.0.0:*                           1000       13993      1410/io.tr-064.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       21219      1361/io.shelly.0
            udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1000       9343329    1186/io.mihome.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       27991      2605/io.upnp.0
            udp        0      0 0.0.0.0:55168           0.0.0.0:*                           1000       27340      3370/io.goodwe.0
            udp6       0      0 :::111                  :::*                                0          11597      1/init
            2023-10-03 09:55:00.009  - info: modbus.1 (2033930) terminating
            2023-10-03 09:55:00.010  - info: modbus.1 (2033930) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-10-03 09:55:00.024  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2036184
            2023-10-03 09:55:00.509  - info: modbus.1 (2033930) terminating
            2023-10-03 09:55:00.921  - info: host.iobroker instance system.adapter.modbus.1 scheduled normal terminated and will be restarted on schedule.
            2023-10-03 09:55:00.921  - info: host.iobroker Restart adapter system.adapter.modbus.1 because enabled
            2023-10-03 09:55:01.205  - info: dwd.0 (2036184) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2023-10-03 09:55:01.661  - info: dwd.0 (2036184) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
            2023-10-03 09:55:01.902  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319701902,"act":-114.17,"set":10,"diff":124.17,"off":0,"err":124.17,"y":100,"lim":true,"dt":5000,"differr":null,"sumerr":9875.83,"supr":false}
            2023-10-03 09:55:02.084  - info: host.iobroker instance system.adapter.modbus.1 started with pid 2036251
            2023-10-03 09:55:02.863  - info: modbus.1 (2036251) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2023-10-03 09:55:02.911  - info: modbus.1 (2036251) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.18.0, js-controller: 5.0.12
            2023-10-03 09:55:03.260  - info: modbus.1 (2036251) Connected to slave
            2023-10-03 09:55:03.549  - info: dwd.0 (2036184) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-10-03 09:55:04.061  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-10-03 09:55:05.000  - info: javascript.0 (741) script.js.Aktiv.Matrixdisplay: request: http://192.168.69.64/cm?cmnd=DisplayText  Benzin 1.979
            2023-10-03 09:55:06.901  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319706901,"act":-134.95,"set":10,"diff":144.95,"off":0,"err":144.95,"y":100,"lim":true,"dt":4999,"differr":null,"sumerr":9855.05,"supr":false}
            2023-10-03 09:55:08.537  - info: ph803w.0 (1319) PH803W device SDQPhpi0dW53T8zlCyzM2E Error: Error: connect EHOSTUNREACH 192.168.69.117:12416
            2023-10-03 09:55:08.745  - info: reolink.0 (2156) 0
            2023-10-03 09:55:10.000  - info: javascript.0 (741) script.js.Aktiv.Matrixdisplay: request: http://192.168.69.64/cm?cmnd=DisplayText  Diesel 1.949
            2023-10-03 09:55:11.902  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319711902,"act":-134.95,"set":10,"diff":144.95,"off":0,"err":144.95,"y":100,"lim":true,"dt":5001,"differr":null,"sumerr":9855.05,"supr":false}
            2023-10-03 09:55:16.901  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319716901,"act":-134.95,"set":10,"diff":144.95,"off":0,"err":144.95,"y":100,"lim":true,"dt":4999,"differr":null,"sumerr":9855.05,"supr":false}
            2023-10-03 09:55:18.730  - info: reolink.0 (2156) 0
            2023-10-03 09:55:21.589  - info: ph803w.0 (1319) PH803W device SDQPhpi0dW53T8zlCyzM2E Error: Error: connect EHOSTUNREACH 192.168.69.117:12416
            2023-10-03 09:55:21.901  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319721901,"act":-128.51,"set":10,"diff":138.51,"off":0,"err":138.51,"y":100,"lim":true,"dt":5000,"differr":null,"sumerr":9861.49,"supr":false}
            iob diag has finished.
              Thomas Braun Most Active @Radi last edited by
              @radi
              Und das Backup wird auf ein fritz.nas geschrieben?
              • MartinP
                MartinP @crunchip last edited by
                @crunchip Ich habe es gar nicht mit CIFS geschafft.
                Iobroker im nicht priorisierten LXC-Container unter Proxmox mit Bullseye.
                martin@iobroker-test-sicher:/etc/apt/sources.list.d$ mount -a
                mount.cifs: permission denied
                martin@iobroker-test-sicher:/etc/apt/sources.list.d$ sudo mount -a
                [sudo] password for martin:
                mount error(1): Operation not permitted
                Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                Ich mache nun lokale Backups auf der virtuellen Platte des Containers, und schiebe diese Backups mit einem Cron Job per rsync auf das Backupsystem.
                Vielleicht liegt es am nicht priorisierten Container ...
                  Thomas Braun Most Active @MartinP last edited by
                  @martinp sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                  Das dürfte nicht betroffen sein. Lokale Backups und Dateioperationen auf dem NAS funktionieren soweit wie wir das sehen. Es geht in erster Linie wohl um Aktionen im gemounteten Dateisystem.
                    Radi @Thomas Braun last edited by Radi
                    @thomas-braun Ja, auf eine USB-Festplatte die per CIFS angebunden ist.
                    Anbei noch ein Screenshot des Verzeichnisses mit dem Inhalt vor und nach Installation von node 18.18.0.0dbbb625-9fd2-4a10-a457-8e289747dd9c-grafik.png
                    • U
                      UV-on-fire @Thomas Braun last edited by
                      Habe eben auf 18.8 akttualisiert und das gleiche Problem.
                      Backup war vorher 11MB jetzt 16kb.
                      Javaskript ebenso von 292k auf 11k geschrumpft.
                      Homematic (Rasberrymatic) 4.7MB auf 64k geschrumpft.
                      Vorhergehende Backups wurden jeweils gestern Nacht automatisch erstellt.
                      Läuft alles auf nem NUC unter Proxmox. Iobroker als LXC, Rasberrymatic als VM.
                      Backup auf Platte am Fritz.nas mit CIFS.
                      kurz:
                      v.2023-06-20
                      Icon name: computer-container
                      Chassis: container
                      Machine ID: c337b259b2a44b9da1e2356e14b395e6
                      Boot ID: 00d0c433c7104a35ba5be38a7e596927
                      Virtualization: lxc
                      Kernel: Linux 5.15.74-1-pve
                      Installation: lxc
                      Kernel: x86_64
                      Userland: amd64
                      User-ID: 1000
                      X-Server: false
                      Boot Target: graphical.target
                      /usr/bin/npm 9.8.1
                      /usr/bin/npx 9.8.1
                      MEMORY:
                      Mem: 4.1G 2.2G 1.2G 0.0K 707M 1.9G
                      Swap: 512M 0B 512M
                      Total: 4.6G 2.2G 1.7G
                      Active iob-Instances: 31
                      Active repo(s): Beta (latest)
                      admin 6.10.4
                      ioBroker Status: iobroker is running on this host.
                      Objects type: jsonl
                      States type: jsonl
                      • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.213, run as: admin
                      • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      Objects: 19164
                      States: 17129
                      37M /opt/iobroker/iobroker-data/objects.jsonl
                      26M /opt/iobroker/iobroker-data/states.jsonl
                      lang
                      Skript v.2023-06-20
                      *** BASE SYSTEM ***
                                 Chassis: container
                          Virtualization: lxc
                      model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : amd64
                       10:29:21 up 16 min,  1 user,  load average: 0.51, 0.73, 0.80
                      CPU threads: 1
                                     Local time: Tue 2023-10-03 10:29:21 CEST
                                 Universal time: Tue 2023-10-03 08:29:21 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      uviob
                      /home/uviob
                      uviob sudo iobroker
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Swap:           512M          0B        512M
                               4096 M total memory
                               2189 M used memory
                                256 M active memory
                               2441 M inactive memory
                               1198 M free memory
                                  0 M buffer memory
                                707 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      *** FILESYSTEM ***
                      /dev/mapper/pve-vm--210--disk--1 ext4   9.8G  7.0G  2.4G  76% /
                      none                             tmpfs  492K  4.0K  488K   1% /dev
                      tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                      tmpfs                            tmpfs  3.1G  104K  3.1G   1% /run
                      [Mon Jun 12 03:04:37 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jun 12 03:11:35 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Jun 12 03:11:35 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Jun 12 03:15:49 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Tue Jun 13 20:30:24 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Thu Jun 15 20:23:19 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jun 19 03:04:21 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jun 19 03:11:21 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Jun 19 03:11:21 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Jun 19 03:15:36 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jun 26 03:04:03 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jun 26 03:11:06 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Jun 26 03:11:06 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Jun 26 03:15:24 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul  3 03:03:40 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul  3 03:10:43 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Jul  3 03:10:43 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Jul  3 03:15:12 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul 10 03:03:24 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul 10 03:10:31 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Jul 10 03:10:31 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Jul 10 03:15:02 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul 17 11:28:29 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul 17 11:35:18 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Jul 17 11:35:18 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Jul 17 11:39:46 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul 24 03:02:24 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul 24 03:09:12 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Jul 24 03:09:12 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Jul 24 03:13:37 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul 31 03:02:03 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Jul 31 03:08:52 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Jul 31 03:08:52 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Jul 31 03:13:19 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Tue Aug  1 20:05:22 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Aug  7 03:01:49 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Aug  7 03:08:30 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Aug  7 03:08:30 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Aug  7 03:13:06 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Aug 14 03:01:28 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Aug 14 03:08:10 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Aug 14 03:08:10 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Aug 14 03:12:48 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Aug 21 03:01:10 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Aug 21 03:07:52 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Aug 21 03:07:52 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Aug 21 03:12:13 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Thu Aug 24 16:49:41 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Aug 28 03:00:39 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Aug 28 03:07:19 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Aug 28 03:07:19 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Aug 28 03:11:47 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Sep  4 03:00:18 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Sep  4 03:07:01 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Sep  4 03:07:01 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Sep  4 03:11:38 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Sep 11 02:59:58 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Sep 11 03:06:36 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Sep 11 03:06:36 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Sep 11 03:11:11 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Sep 18 02:59:42 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Sep 18 03:06:20 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Sep 18 03:06:20 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Sep 18 03:10:57 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Sep 25 02:59:20 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Sep 25 03:06:31 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Sep 25 03:06:31 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Sep 25 03:11:09 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Oct  2 02:58:56 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mon Oct  2 03:05:35 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                      [Mon Oct  2 03:05:35 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Oct  2 03:10:13 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Tue Oct  3 10:05:04 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      /      /dev/mapper/pve-vm--210--disk--1 ext4   rw,relatime,stripe=16
                      /var:
                      919M    /var/
                      402M    /var/log
                      401M    /var/log/journal/c337b259b2a44b9da1e2356e14b395e6
                      376M    /var/cache
                      Archived and active journals take up 96.0M in the file system.
                      69M     /opt/iobroker/backups/
                      595M    /opt/iobroker/iobroker-data/
                      453M    /opt/iobroker/iobroker-data/files
                      80M     /opt/iobroker/iobroker-data/files/vis
                      80M     /opt/iobroker/iobroker-data/backup-objects
                      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                      27M     /opt/iobroker/iobroker-data/states.jsonl
                      21M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.22196004.js.map
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                              500 http://security.debian.org bullseye-security/main amd64 Packages
                              500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.10.4
                      javascript:     7.1.4
                      Adapters from github:   0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.213, run as: admin
                        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                        system.adapter.bmw.0                    : bmw                   : iobroker                                 - disabled
                        system.adapter.cameras.0                : cameras               : iobroker                                 - disabled, port: 8200, bind: 127.0.0.1
                        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      + system.adapter.fitbit-fitness.0         : fitbit-fitness        : iobroker                                 -  enabled
                        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                      + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                      + system.adapter.hm-rpc.4                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                        system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.213
                      + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                      + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                      + system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 -  enabled
                      + system.adapter.tahoma.0                 : tahoma                : iobroker                                 -  enabled
                        system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
                        system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      Used repository: Beta (latest)
                      Adapter    "bmw"          : 2.6.2    , installed 2.6.2
                      Adapter    "cameras"      : 1.3.0    , installed 1.3.0
                      Adapter    "discovery"    : 4.1.0    , installed 4.1.0
                      Adapter    "fitbit-fitness": 0.4.11  , installed 0.4.11
                      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                      Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                      Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                      Adapter    "proxmox"      : 2.1.0    , installed 2.1.0
                      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                      Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                      Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                      Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                      Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                      Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                      Objects and States
                      Objects:        19164
                      States:         17129
                      Hit:1 http://security.debian.org bullseye-security InRelease
                      Hit:2 http://ftp.debian.org/debian bullseye InRelease
                      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          497506546  1/init
                      tcp        0      0 192.168.178.213:8081    0.0.0.0:*               LISTEN      1001       497508582  311/io.admin.0
                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        497506990  83/systemd-resolved
                      tcp        0      0 192.168.178.213:8701    0.0.0.0:*               LISTEN      1001       497509579  590/io.hm-rpc.4
                      tcp        0      0 192.168.178.213:1883    0.0.0.0:*               LISTEN      1001       497512724  1428/io.mqtt.0
                      tcp        0      0 192.168.178.213:2001    0.0.0.0:*               LISTEN      1001       497508974  484/io.hm-rpc.0
                      tcp        0      0 192.168.178.213:2010    0.0.0.0:*               LISTEN      1001       497509175  529/io.hm-rpc.2
                      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        497506983  83/systemd-resolved
                      tcp        0      0 192.168.178.213:9292    0.0.0.0:*               LISTEN      1001       497509111  505/io.hm-rpc.1
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       497507075  119/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       497507150  119/iobroker.js-con
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          497507221  297/master
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          497506841  1/init
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          497506554  1/init
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          497507222  297/master
                      tcp6       0      0 :::5355                 :::*                    LISTEN      104        497506986  83/systemd-resolved
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       497521909  2679/io.web.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       497519140  2515/io.simple-api.
                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        497506989  83/systemd-resolved
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          497506549  1/init
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       497521948  2698/io.wled.0
                      udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1001       497511049  1037/io.tr-064.0
                      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        497506982  83/systemd-resolved
                      udp6       0      0 :::111                  :::*                                0          497506559  1/init
                      udp6       0      0 :::5355                 :::*                                104        497506985  83/systemd-resolved
                      2023-10-03 10:29:40.002  - error: javascript.0 (369) script.js.Materialdesign.Netzwerk: [netzwerkStatus] error: Cannot read properties of null (reading 'common'), stack: TypeError: Cannot read properties of null (reading 'common')
                          at Object.netzwerkStatus (script.js.Materialdesign.Netzwerk:2433:33)
                          at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
                          at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                          at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                          at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                          at listOnTimeout (node:internal/timers:569:17)
                          at processTimers (node:internal/timers:512:7)
                      2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.uptime' not exist!
                      2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.cpu' not exist!
                      2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.mem' not exist!
                      2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.maxmem' not exist!
                      2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.mem_lev' not exist!
                      2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.disk' not exist!
                      2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.maxdisk' not exist!
                      2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.disk_lev' not exist!
                      2023-10-03 10:29:50.001  - warn: javascript.0 (369) script.js.Materialdesign.Netzwerk: Object "tr-064.0.devices.PC-F8-0D-60-48-43-94" does not exist
                      2023-10-03 10:29:50.002  - error: javascript.0 (369) script.js.Materialdesign.Netzwerk: [netzwerkStatus] error: Cannot read properties of null (reading 'common'), stack: TypeError: Cannot read properties of null (reading 'common')
                      • MartinP
                        MartinP @UV-on-fire last edited by
                        @uv-on-fire Wo ist der Fritz.nas CIFS gemountet? Im Proxmox, und dann durchgereicht auf den LXC Container oder direkt im Linux des LXC Containers?
                        • U
                          UV-on-fire @MartinP last edited by UV-on-fire
                          @martinp
                          Ich meine direkt im Linux. Hab da ne weile herum experimentiert.
                          EDIT: Glaub habe gerade quatsch erzählt. Ich meine für Backitup war es nicht nötig die Platte zu mounten wenn ich mich richtig erinnere. Wo ich ewig rum gemacht habe war das Einbinden der Platte für die eigentlichen Proxmox Backups. War ziemlich viel try and error da ich in Linux nicht wirklich fit bin.
                            @thomas-braun Für mich sieht es so aus, als ob die lokal im IOBroker unter /opt/iobroker/backups abgelegten Files genauso korrupt sind, wie die auf dem FRITZ-Nas abgelegten. Siehe Screenshot aus WinSCP:
                              @radi sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                              Wenn das NAS gerade gemounted ist dann ist das die gleiche Datei.
                                @thomas-braun Okay, dann habe ich gerade wieder etwas dazu gelernt. Hab es gerade noch mal ausprobiert, nach dem umount ist dieses Verzeichnis wieder leer.
                                  So ist es richtig.
                                  • O S
                                    O S @Thomas Braun last edited by
                                    Habe das gleiche Problem.
                                    Skript v.2023-06-20
                                    *** BASE SYSTEM ***
                                       Static hostname: iobroker6
                                             Icon name: computer
                                            Machine ID: 6cdd9ef1128b465193e49cc4ea80f5af
                                               Boot ID: 41b5da8e46ba4fd897de0fa6a4711922
                                                Kernel: Linux 6.1.21-v8+
                                          Architecture: arm64
                                    Model           : Raspberry Pi 4 Model B Rev 1.2
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     17:43:34 up  3:51,  1 user,  load average: 0.84, 0.88, 0.88
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    Other values than 0x0 hint to temperature/voltage problems
                                    temp=67.6'C
                                    volt=0.8438V
                                                   Local time: Tue 2023-10-03 17:43:34 CEST
                                               Universal time: Tue 2023-10-03 15:43:34 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.8G        1.8G        1.6G        1.0M        419M        1.9G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        1.8G        1.7G
                                             3793 M total memory
                                             1803 M used memory
                                             1851 M active memory
                                              250 M inactive memory
                                             1570 M free memory
                                               54 M buffer memory
                                              364 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       28G  3.2G   24G  12% /
                                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                    tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                    /dev/sdb1      vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                    [Tue Oct  3 13:52:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E5:E6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=85bcf00a-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Tue Oct  3 13:52:18 2023] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Tue Oct  3 13:52:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:18.
                                    [Tue Oct  3 13:52:20 2023] EXT4-fs (sdb2): re-mounted. Quota mode: none.
                                    /       /dev/sdb2 ext4   rw,noatime
                                    `-/boot /dev/sdb1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    535M    /var/
                                    182M    /var/cache
                                    176M    /var/cache/apt
                                    147M    /var/lib
                                    122M    /var/lib/apt/lists
                                    Archived and active journals take up 104.0M in the file system.
                                    165M    /opt/iobroker/iobroker-data/files
                                    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                    25M     /opt/iobroker/iobroker-data/objects.jsonl
                                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
                                    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js
                                    8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
                                    /usr/bin/nodejs         v18.17.1
                                    /usr/bin/node           v18.17.1
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    nodejs:
                                      Installed: 18.17.1-deb-1nodesource1
                                      Candidate: 18.17.1-deb-1nodesource1
                                      Version table:
                                     *** 18.17.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                    jsonl on 0.0.0.0
                                    States:                     jsonl on 0.0.0.0
                                    admin:          6.10.1
                                    javascript:     7.1.4
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
                                      system.adapter.mobile.0                 : mobile                : iobroker                                 -  enabled
                                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                                    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    Active repo(s): Stable (default)
                                    Used repository: Stable (default)
                                    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                                    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                    Adapter    "web"          : 6.1.2    , installed 6.1.0  [Updatable]
                                    Objects and States
                                    Objects:        6978
                                    States:         12775
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15401      544/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14593      508/iobroker.js-con
                                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15434      508/iobroker.js-con
                                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15751      1171/io.sonoff.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15403      544/sshd: /usr/sbin
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       300189     15081/io.web.0
                                    tcp6       0      0 :::8085                 :::*                    LISTEN      1001       297932     15070/io.ws.0
                                    tcp6       0      0 :::7777                 :::*                    LISTEN      1001       299942     15273/io.admin.0
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12530      810/dhcpcd
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14543      399/avahi-daemon: r
                                    udp        0      0 0.0.0.0:58602           0.0.0.0:*                           108        14545      399/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13024      1148/io.shelly.0
                                    udp6       0      0 :::546                  :::*                                0          15429      810/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        14544      399/avahi-daemon: r
                                    udp6       0      0 :::42372                :::*                                108        14546      399/avahi-daemon: r
                                    2023-10-03 16:48:52.372  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 16:48:53.170  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 16:48:54.431  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 16:49:00.673  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 16:51:14.699  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 16:51:14.699  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0
                                    2023-10-03 16:51:14.701  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin
                                    2023-10-03 16:51:14.701  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot
                                    2023-10-03 17:29:27.500  - warn: octoprint.0 (1324) received 502 response from /api/version with content: "<html><body><h1>502 Bad Gateway</h1>\nThe server returned an invalid or incomplete response.\n</body></html>\n"
                                    2023-10-03 17:30:18.149  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:30:18.677  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot
                                    2023-10-03 17:30:19.290  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:30:20.314  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:30:45.434  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:30:46.614  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:31:00.543  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:40:42.148  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin
                                    2023-10-03 17:40:42.148  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot
                                    2023-10-03 17:40:42.153  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0
                                    2023-10-03 17:40:48.430  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:40:49.815  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:40:58.838  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                    2023-10-03 17:42:44.448  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin
                                    2023-10-03 17:42:44.451  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0
                                    2023-10-03 17:42:44.455  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flo
                                                         v.2023-06-20
                                             Icon name: computer
                                          Architecture: arm64
                                    Kernel:                 aarch64
                                    Userland:               arm64
                                    User-ID:                1000
                                    X-Server:               false
                                    Boot Target:            multi-user.target
                                    Pending iob updates:    1
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                            /usr/bin/npm            9.6.7
                                                            /usr/bin/npx            9.6.7
                                    MEMORY:
                                    Mem:            3.8G        1.8G        1.3G        1.0M        676M        1.9G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        1.8G        1.4G
                                    Active iob-Instances:   21
                                                            admin                   6.10.1
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                6978
                                    States:                 12775
                                    4.2M    /opt/iobroker/iobroker-data/states.jsonl
                                    Hoffentlich hilft das.
                                      Thomas Braun Most Active @O S last edited by
                                      @o-s sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                                      18.17.1
                                      Mit nodejs 18.17.1 bist du der erste. Bislang ist das nur bei 18.18.0 und nodejs@20 aufgefallen.
                                      • O S
                                        O S last edited by
                                        Copy text starting here:
                                                             v.2023-06-20
                                                 Icon name: computer
                                              Architecture: arm64
                                        Kernel:                 aarch64
                                        Userland:               arm64
                                        User-ID:                1000
                                        X-Server:               false
        /usr/bin/node           v18.18.0
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
                                        MEMORY:
                                        Mem:            3.8G        1.5G        1.3G        1.0M        949M        2.2G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        1.5G        1.4G
        admin                   6.10.1
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                6978
                                        States:                 12775
                                        27M     /opt/iobroker/iobroker-data/objects.jsonl
                                        2.6M    /opt/iobroker/iobroker-data/states.jsonl
                                        [s=]
                                        Skript v.2023-06-20
                                        *** BASE SYSTEM ***
                                        Icon name: computer
                                        Architecture: arm64
                                        Docker : false
                                        Virtualization : none
                                        Kernel : aarch64
                                        Userland : arm64
                                        Systemuptime and Load:
                                        18:48:07 up 4:55, 1 user, load average: 1.04, 1.14, 1.28
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        temp=62.3'C
                                        volt=0.8438V
                                        *** Time and Time Zones ***
                                        Local time: Tue 2023-10-03 18:48:07 CEST
                                        Universal time: Tue 2023-10-03 16:48:07 UTC
                                        RTC time: n/a
                                        NTP service: active
                                        RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        *** X-Server-Setup ***
                                        X-Server: false
                                        Desktop:
                                        Terminal: tty
                                        *** MEMORY ***
                                        total used free shared buff/cache available
                                        Mem: 3.8G 1.5G 1.4G 1.0M 948M 2.2G
                                        Swap: 99M 0B 99M
                                        Total: 3.9G 1.5G 1.5G
                                             3793 M total memory
                                             1492 M used memory
                                             1502 M active memory
                                              766 M inactive memory
                                             1352 M free memory
                                              118 M buffer memory
                                              830 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        Filesystem Type Size Used Avail Use% Mounted on
                                        tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
                                        //fritz.box/fritz.nas/intenso/iobroker cifs 961G 521G 441G 55% /opt/iobroker/backups
                                        Show mounted filesystems (real ones only):
                                        TARGET SOURCE FSTYPE OPTIONS
                                        `-/opt/iobroker/backups //fritz.box/fritz.nas/intenso/iobroker cifs rw,relatime,vers=3.1.1,cache=strict,username=IoBroker2,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                                        /var:
                                        563M /var/
                                        209M /var/cache
                                        204M /var/cache/apt
                                        147M /var/lib
                                        123M /var/lib/apt
                                        /opt/iobroker/backups:
                                        129M /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        203M /opt/iobroker/iobroker-data/
                                        52M /opt/iobroker/iobroker-data/files/javascript.admin
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm 9.8.1
                                        /usr/bin/npx 9.8.1
                                        nodejs:
                                        Installed: 18.18.0-1nodesource1
                                        Candidate: 18.18.0-1nodesource1
                                        Version table:
                                        100 /var/lib/dpkg/status
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States type: jsonl
                                        No configuration change needed.
                                        Multihost discovery server: disabled
                                        Discovery authentication: enabled
                                        Persistent activation: disabled
                                        Core adapters versions
                                        admin: 6.10.1
                                        javascript: 7.1.4
                                        Adapter State
                                        • system.adapter.admin.0 : admin : iobroker - enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                        • system.adapter.alexa2.0 : alexa2 : iobroker - enabled
                                        • system.adapter.backitup.0 : backitup : iobroker - enabled
                                        • system.adapter.discovery.0 : discovery : iobroker - enabled
                                        • system.adapter.fritzbox.0 : fritzbox : iobroker - enabled
                                        • system.adapter.fritzdect.0 : fritzdect : iobroker - enabled
                                        • system.adapter.history.0 : history : iobroker - enabled
                                        • system.adapter.info.0 : info : iobroker - enabled
                                        • system.adapter.iot.0 : iot : iobroker - enabled
                                        • system.adapter.javascript.0 : javascript : iobroker - enabled
                                        • system.adapter.net-tools.0 : net-tools : iobroker - enabled
                                        • system.adapter.octoprint.0 : octoprint : iobroker - enabled
                                        • system.adapter.ping.0 : ping : iobroker - enabled
                                        • system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0
                                        • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0
                                        • system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled
                                        • system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
                                        • system.adapter.tr-064.0 : tr-064 : iobroker - enabled
                                        • system.adapter.ws.0 : ws : iobroker - enabled, port: 8085, bind: 0.0.0.0, run as: admin
                                        • instance is alive
                                        ioBroker-Repositories
                                        Installed ioBroker-Instances
                                        Adapter "alexa2" : 3.25.2 , installed 3.25.2
                                        Adapter "flot" : 1.12.0 , installed 1.12.0
                                        Adapter "info" : 2.0.0 , installed 2.0.0
                                        Adapter "javascript" : 7.1.4 , installed 7.1.4
                                        Controller "js-controller": 5.0.12 , installed 5.0.12
                                        Adapter "net-tools" : 0.2.0 , installed 0.2.0
                                        Adapter "ping" : 1.6.2 , installed 1.6.2
                                        Adapter "simple-api" : 2.7.2 , installed 2.7.2
                                        Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
                                        Adapter "telegram" : 1.16.0 , installed 1.16.0
                                        Adapter "tr-064" : 4.2.18 , installed 4.2.18
                                        Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
                                        Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
                                        Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
                                        Objects and States
                                        Objects: 6978
                                        States: 12775
                                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                                        tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 531479 28146/iobroker.js-c
                                        tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 531484 28146/iobroker.js-c
                                        tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 530826 28332/io.sonoff.0
                                        tcp6 0 0 :::8082 :::* LISTEN 1001 533936 28695/io.web.0
                                        tcp6 0 0 :::8085 :::* LISTEN 1001 534754 28728/io.ws.0
                                        tcp6 0 0 :::7777 :::* LISTEN 1001 531536 28172/io.admin.0
                                        udp 0 0 0.0.0.0:55170 0.0.0.0:* 1001 619670 28311/io.shelly.0
                                        udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 531837 28311/io.shelly.0
                                        2023-10-03 18:12:13.047 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                        2023-10-03 18:12:14.080 - info: net-tools.0 (28559) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.18.0, js-controller: 5.0.12
                                        2023-10-03 18:12:14.436 - info: net-tools.0 (28559) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                                        2023-10-03 18:12:15.808 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                        2023-10-03 18:12:16.743 - info: net-tools.0 (28559) Port scan finished
                                        2023-10-03 18:12:21.610 - info: tankerkoenig.0 (28637) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.18.0, js-controller: 5.0.12
                                        2023-10-03 18:12:21.704 - info: tankerkoenig.0 (28637) Adapter is already in daemon mode
                                        2023-10-03 18:12:21.706 - warn: tankerkoenig.0 (28637) Sync time was too short (5). New sync time is 10 min
                                        2023-10-03 18:12:21.708 - info: tankerkoenig.0 (28637) Sync time set to 10 minutes or 600000 ms
                                        2023-10-03 18:12:24.672 - info: vis.0 (28658) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.0, js-controller: 5.0.12
                                        2023-10-03 18:12:25.224 - info: vis.0 (28658) vis license is OK.
                                        2023-10-03 18:12:28.304 - info: vis.0 (28658) Terminated (NO_ERROR): Without reason
                                        2023-10-03 18:12:29.942 - info: web.0 (28695) starting. Version 6.1.0 in /opt/iobroker/node_modules/iobroker.web, node: v18.18.0, js-controller: 5.0.12
                                        2023-10-03 18:12:30.679 - info: web.0 (28695) socket.io server listening on port 8082
                                        2023-10-03 18:12:30.703 - info: web.0 (28695) http server listening on port 8082
                                        2023-10-03 18:12:32.633 - info: ws.0 (28728) starting. Version 2.5.5 in /opt/iobroker/node_modules/iobroker.ws, node: v18.18.0, js-controller: 5.0.12
                                        2023-10-03 18:12:32.745 - warn: ws.0 (28728) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                                        2023-10-03 18:12:32.772 - info: ws.0 (28728) socket.io server listening on port 8085
                                        2023-10-03 18:12:40.622 - info: info.0 (28749) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.18.0, js-controller: 5.0.12
                                        2023-10-03 18:12:41.016 - info: info.0 (28749) Reading/updating systemdata.
                                        2023-10-03 18:12:45.286 - info: tankerkoenig.0 (28637) Start first request
                                        2023-10-03 18:12:45.312 - info: info.0 (28749) cpu Temp res = {"main":66.218,"cores":[],"max":66.218,"socket":[],"chipset":null}
                                        2023-10-03 18:16:19.824 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                        2023-10-03 18:16:27.936 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                        2023-10-03 18:29:49.271 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                        Backitup bei node 18.17.1: 6,7 MB
                                        Backitup bei node 18.18.0: 16 KB
                                        O S 1 Reply Last reply Reply Quote 0
                                        • O S
                                          O S @O S last edited by
                                          @o-s
                                          Besser habe ich es nicht gekonnt!
                                          Gruß Otto
                                            fastfoot last edited by
                                            ui, sind ja doch einige mit Fehlern. Ich bin gerade dabei ein Skript zu schreiben welches neben dem derzeitigen Verfahren(backitup/iobroker cli) auch eine evtl. Lösung anbieten soll. Diese Lösung ist zur Zeit noch nicht wirklich brauchbar da sie mehr Zeit benötigt, dient aber dazu zu prüfen ob der Fehler damit erstmal weg ist. Das Skript erstellt kein Backup sondern nutzt nur dessen Mechanismus, es werden auch keine Änderungen am System vorgenommen, man könnte es also auch in einer Produktivumgebung nutzen
                                            Ich hoffe es finden sich einige die Lust zum Testen haben, am Ende wird das hoffentlich gute Ergebnis als Grundlage für einen PR verwendet welcher dann das Problem im iobroker fixt.
                                            schonmal Danke im Voraus, stay tuned
                                            1.4k
                                            204
                                            28083
