    4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
      Jan1 @Thomas Braun last edited by
      lang:
      Skript v.2023-06-20
      *** BASE SYSTEM ***
      Static hostname: Beelink
      Icon name: computer-desktop
      Chassis: desktop
      Machine ID: a5e8094cdcde4fafa3a8b051d1ec8c4f
      Boot ID: 3aad6de0f1d34b3499c96bc95c9d693f
      Operating System: Ubuntu 22.04.3 LTS
      Kernel: Linux 5.15.0-84-generic
      Architecture: x86-64
      Hardware Vendor: AZW
      Hardware Model: MINI S
      model name : Intel(R) Celeron(R) N5095 @ 2.00GHz
      Docker : false
      Virtualization : none
      Kernel : x86_64
      Userland : amd64
      Systemuptime and Load:
      09:09:36 up 8 days, 17:58, 2 users, load average: 0.17, 0.62, 0.57
      CPU threads: 4
      *** Time and Time Zones ***
      Local time: Tue 2023-10-03 09:09:36 CEST
      Universal time: Tue 2023-10-03 07:09:36 UTC
      RTC time: Tue 2023-10-03 07:09:36
      NTP service: active
      RTC in local TZ: no
      *** User and Groups ***
      jan
      /home/jan
      jan adm cdrom sudo dip plugdev lxd iobroker
      *** X-Server-Setup ***
      X-Server: false
      Desktop:
      Terminal: tty
      Boot Target: multi-user.target
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 7.7G 1.9G 2.6G 1.0M 3.3G 5.5G
      Swap: 4.1G 0B 4.1G
      Total: 11G 1.9G 6.6G
           7717 M total memory
           1884 M used memory
           1181 M active memory
           3515 M inactive memory
           2553 M free memory
            592 M buffer memory
           2687 M swap cache
           4095 M total swap
              0 M used swap
           4095 M free swap
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      tmpfs tmpfs 772M 1.6M 771M 1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4 232G 12G 210G 6% /
      tmpfs tmpfs 3.8G 0 3.8G 0% /dev/shm
      tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
      /dev/sda2 ext4 2.0G 130M 1.7G 8% /boot
      /dev/sda1 vfat 1.1G 6.1M 1.1G 1% /boot/efi
      tmpfs tmpfs 772M 4.0K 772M 1% /run/user/1000
      [Sun Sep 24 15:10:48 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun Sep 24 15:10:48 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
      [Sun Sep 24 15:10:49 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime
      |-/snap/core20/1974 /dev/loop0 squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/2015 /dev/loop1 squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/24322 /dev/loop2 squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/19993 /dev/loop3 squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/20092 /dev/loop4 squashfs ro,nodev,relatime,errors=continue
      -/boot /dev/sda2 ext4 rw,relatime -/boot/efi /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
      /var:
      960M /var/
      643M /var/lib
      435M /var/lib/snapd
      226M /var/lib/snapd/seed/snaps
      Archived and active journals take up 200.0M in the file system.
      /opt/iobroker/backups:
      2.7M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      319M /opt/iobroker/iobroker-data/
      196M /opt/iobroker/iobroker-data/files
      58M /opt/iobroker/iobroker-data/backup-objects
      52M /opt/iobroker/iobroker-data/files/javascript.admin
      43M /opt/iobroker/iobroker-data/files/iot.admin
      33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      30M /opt/iobroker/iobroker-data/states.jsonl
      22M /opt/iobroker/iobroker-data/objects.jsonl
      21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js.map
      8.5M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      *** NodeJS-Installation ***
      /usr/bin/nodejs v18.18.0
      /usr/bin/node v18.18.0
      /usr/bin/npm 9.8.1
      /usr/bin/npx 9.8.1
      nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
      *** 18.18.0-1nodesource1 500
      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
      100 /var/lib/dpkg/status
      18.17.1-1nodesource1 500
      18.17.0-1nodesource1 500
      18.16.1-1nodesource1 500
      18.16.0-1nodesource1 500
      18.15.0-1nodesource1 500
      18.14.2-1nodesource1 500
      18.14.1-1nodesource1 500
      18.14.0-1nodesource1 500
      18.13.0-1nodesource1 500
      18.12.0-1nodesource1 500
      18.11.0-1nodesource1 500
      18.10.0-1nodesource1 500
      18.9.1-1nodesource1 500
      18.9.0-1nodesource1 500
      18.8.0-1nodesource1 500
      18.7.0-1nodesource1 500
      18.6.0-1nodesource1 500
      18.5.0-1nodesource1 500
      18.4.0-1nodesource1 500
      18.3.0-1nodesource1 500
      18.2.0-1nodesource1 500
      18.1.0-1nodesource1 500
      18.0.0-1nodesource1 500
      12.22.9~dfsg-1ubuntu3 500
      500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication: enabled
      Persistent activation: disabled
      Objects: jsonl on 127.0.0.1
      States: jsonl on 127.0.0.1
      Core adapters versions
      js-controller: 5.0.12
      admin: 6.10.4
      javascript: 7.1.4
      Adapters from github: 1
      Adapter State
      • system.adapter.admin.0 : admin : Beelink - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      • system.adapter.alexa2.0 : alexa2 : Beelink - enabled
      • system.adapter.backitup.0 : backitup : Beelink - enabled
        system.adapter.ble.0 : ble : Beelink - disabled
        system.adapter.bosch-ebike.0 : bosch-ebike : Beelink - disabled
      • system.adapter.denon.0 : denon : Beelink - enabled
      • system.adapter.enigma2.0 : enigma2 : Beelink - enabled
        system.adapter.feiertage.0 : feiertage : Beelink - enabled
        system.adapter.firetv.0 : firetv : Beelink - disabled
      • system.adapter.fritzdect.0 : fritzdect : Beelink - enabled
      • system.adapter.google-sharedlocations.0 : google-sharedlocations: Beelink - enabled
      • system.adapter.harmony.0 : harmony : Beelink - enabled
      • system.adapter.history.0 : history : Beelink - enabled
        system.adapter.ical.0 : ical : Beelink - enabled
      • system.adapter.info.0 : info : Beelink - enabled
      • system.adapter.iot.0 : iot : Beelink - enabled
      • system.adapter.iqontrol.0 : iqontrol : Beelink - enabled
      • system.adapter.javascript.0 : javascript : Beelink - enabled
      • system.adapter.milight-smart-light.0 : milight-smart-light : Beelink - enabled
      • system.adapter.node-red.0 : node-red : Beelink - enabled, port: 1880, bind: 0.0.0.0 (SSL)
        system.adapter.openweathermap.0 : openweathermap : Beelink - enabled
      • system.adapter.simple-api.0 : simple-api : Beelink - enabled, port: 8087, bind: 0.0.0.0, run as: admin
      • system.adapter.sonoff.0 : sonoff : Beelink - enabled, port: 1883, bind: 0.0.0.0
      • system.adapter.tankerkoenig.0 : tankerkoenig : Beelink - enabled
      • system.adapter.telegram.0 : telegram : Beelink - enabled, port: 8443, bind: 0.0.0.0
      • system.adapter.tr-064.0 : tr-064 : Beelink - enabled
        system.adapter.vw-connect.0 : vw-connect : Beelink - disabled
      • system.adapter.web.0 : web : Beelink - enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      • system.adapter.wled.0 : wled : Beelink - enabled
      • system.adapter.ws.0 : ws : Beelink - enabled, port: 8084, bind: 0.0.0.0, run as: admin
      • system.adapter.zigbee.0 : zigbee : Beelink - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_ac906d74b593eb11b6e91b4f3d98b6d1-if00-port0
      • instance is alive
      ioBroker-Repositories
      Stable (default): http://iobroker.live/repo/sources-dist.json
      latest : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): latest
      Installed ioBroker-Instances
      Used repository: latest
      Adapter "admin" : 6.10.4 , installed 6.10.4
      Adapter "alexa2" : 3.25.2 , installed 3.25.2
      Adapter "backitup" : 2.8.2 , installed 2.8.2
      Adapter "ble" : 0.13.4 , installed 0.13.4
      Adapter "bosch-ebike" : 0.1.0 , installed 0.1.0
      Adapter "denon" : 1.15.4 , installed 1.15.4
      Adapter "enigma2" : 2.0.5 , installed 2.0.5
      Adapter "feiertage" : 1.1.4 , installed 1.1.4
      Adapter "firetv" : 2.0.2 , installed 2.0.2
      Adapter "fritzdect" : 2.4.1 , installed 2.4.1
      Adapter "harmony" : 1.2.2 , installed 1.2.2
      Adapter "history" : 3.0.0 , installed 3.0.0
      Adapter "ical" : 1.13.3 , installed 1.13.3
      Adapter "info" : 2.0.0 , installed 2.0.0
      Adapter "iot" : 2.0.11 , installed 2.0.11
      Adapter "iqontrol" : 2.3.0 , installed 2.3.0
      Adapter "javascript" : 7.1.4 , installed 7.1.4
      Controller "js-controller": 5.0.12 , installed 5.0.12
      Adapter "milight-smart-light": 1.2.2, installed 1.2.2
      Adapter "node-red" : 4.0.3 , installed 4.0.3
      Adapter "openweathermap": 0.4.4 , installed 0.4.4
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "socketio" : 6.5.6 , installed 6.5.6
      Adapter "sonoff" : 3.0.3 , installed 3.0.3
      Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
      Adapter "telegram" : 1.16.0 , installed 1.16.0
      Adapter "tr-064" : 4.2.18 , installed 4.2.18
      Adapter "vw-connect" : 0.1.3 , installed 0.1.3
      Adapter "web" : 6.1.3 , installed 6.1.3
      Adapter "wled" : 0.7.1 , installed 0.7.1
      Adapter "ws" : 2.5.6 , installed 2.5.6
      Adapter "zigbee" : 1.8.24 , installed 1.8.24
      Objects and States
      Objects: 12158
      States: 12432
      Failed to start apt-news.service: Unit apt-news.service not found.
      Failed to start esm-cache.service: Unit esm-cache.service not found.
      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 102 25838 679/systemd-resolve
      tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 34028519 618348/iobroker.js-
      tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 34030025 618348/iobroker.js-
      tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 34032965 619352/io.sonoff.0
      tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 34031992 619100/node-red
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 28524 779/sshd: /usr/sbin
      tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 1534 1/init
      tcp6 0 0 :::8082 :::* LISTEN 1001 34036863 620794/io.web.0
      tcp6 0 0 :::8081 :::* LISTEN 1001 34031239 618375/io.admin.0
      tcp6 0 0 :::8087 :::* LISTEN 1001 34034525 620467/io.simple-ap
      tcp6 0 0 :::8084 :::* LISTEN 1001 34037039 621134/io.ws.0
      tcp6 0 0 :::4400 :::* LISTEN 1001 34033617 620405/io.milight-s
      tcp6 0 0 :::22 :::* LISTEN 0 28526 779/sshd: /usr/sbin
      tcp6 0 0 :::111 :::* LISTEN 0 19531 1/init
      tcp6 0 0 :::80 :::* LISTEN 1001 34031994 619100/node-red
      tcp6 0 0 :::61991 :::* LISTEN 1001 34035062 619505/io.harmony.0
      udp 0 0 127.0.0.53:53 0.0.0.0:* 102 25837 679/systemd-resolve
      udp 0 0 192.168.100.10:68 0.0.0.0:* 101 27734519 677/systemd-network
      udp 0 0 0.0.0.0:111 0.0.0.0:* 0 1535 1/init
      udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 34035063 619505/io.harmony.0
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 34036106 621084/io.wled.0
      udp 0 0 192.168.100.10:5353 0.0.0.0:* 1001 34032202 619372/io.tr-064.0
      udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 34031995 619100/node-red
      udp 0 0 0.0.0.0:55606 0.0.0.0:* 1001 34033614 620405/io.milight-s
      udp6 0 0 :::111 :::* 0 20769 1/init
      udp6 0 0 fe80::7e83:34ff:feb:546 :::* 101 27736182 677/systemd-network
      2023-10-03 09:10:05.823 - info: admin.0 (618375) ==> Connected system.user.admin from ::ffff:192.168.100.16
      2023-10-03 09:10:06.517 - info: host.Beelink Updating repository "latest" under "http://iobroker.live/repo/sources-dist-latest.json"
      kurz:
                          v.2023-06-20
              Chassis: desktop
      Installation:           native
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                             /usr/bin/npm            9.8.1
                             /usr/bin/npx            9.8.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.7G        2.0G        2.4G        1.0M        3.3G        5.4G
      Swap:           4.1G          0B        4.1G
      Total:           11G        2.0G        6.5G
      Active iob-Instances:   25
      ioBroker Core:          js-controller           5.0.12
                             admin                   6.10.4
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : Beelink                                  -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : Beelink                                  -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      Objects:                12158
      States:                 12432
      Size of iob-Database:
      31M     /opt/iobroker/iobroker-data/states.jsonl
        crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
        @thomas-braun hab gerade mal nachgesehen, alles in Ordnung
        Allerdings nicht cifs auf Fritte, sondern
        • Auf Usb an der Fritte per ftp
        • auf OMV VM per cifs
        Und natürlich auch keinen Raspberry
          Radi @Thomas Braun last edited by
          @thomas-braun Bei mir läuft der IOBroker auf einer VM unter Proxmox. Auch bei mir sind die Backups seit der Installation von node 18.18.0 zu klein. Dies gilt für alle erstellten Backups( Homematic, IOBroker, Redis und History). Im Anhang die Langversion der Ausgabe von iob diag.
          Skript v.2023-06-20
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-vm
                     Chassis: vm
                  Machine ID: 0b042677bfcf43ac87065ffc8cb9f7a8
                     Boot ID: 74e1ad1dc2db45f7a0733269c4cfe04c
              Virtualization: kvm
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.10.0-25-amd64
          model name      : Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : amd64
           09:54:29 up 3 days, 21:32,  1 user,  load average: 0.84, 0.89, 0.77
          CPU threads: 24
                         Local time: Tue 2023-10-03 09:54:29 CEST
                     Universal time: Tue 2023-10-03 07:54:29 UTC
                           RTC time: Tue 2023-10-03 07:54:30
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          /home/iobroker
          iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev redis
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.9G        6.1G        617M        0.0K        1.2G        1.5G
          Swap:           974M        483M        491M
          Total:          8.9G        6.6G        1.1G
                   7942 M total memory
                   6129 M used memory
                   1597 M active memory
                   5173 M inactive memory
                    617 M free memory
                    374 M buffer memory
                    822 M swap cache
                    974 M total swap
                    483 M used swap
                    491 M free swap
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     795M  612K  794M   1% /run
          /dev/sda1      ext4      125G   71G   49G  60% /
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     795M     0  795M   0% /run/user/1000
          [sudo] password for iobroker:
          [Fri Sep 29 12:22:17 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Fri Sep 29 12:22:17 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          803M    /var/
          426M    /var/cache
          419M    /var/cache/apt
          351M    /var/cache/apt/archives
          205M    /var/log
          Archived and active journals take up 64.0M in the file system.
          4.0K    /opt/iobroker/backups/
          64G     /opt/iobroker/iobroker-data/
          63G     /opt/iobroker/iobroker-data/history
          546M    /opt/iobroker/iobroker-data/files
          214M    /opt/iobroker/iobroker-data/history/20230329
          201M    /opt/iobroker/iobroker-data/history/20230328
          74M     /opt/iobroker/iobroker-data/objects.jsonl
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
          18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
           *** 18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          npm ERR! code ELSPROBLEMS
          npm ERR! invalid: nodemailer@6.9.1 /opt/iobroker/node_modules/nodemailer
          npm ERR! missing: dewpoint@^1.0.0, required by iobroker.javascript@7.1.4
          npm ERR! missing: noble@^1.9.1, required by iobroker.javascript@7.1.4
          npm ERR! missing: react@^18.2.0, required by iobroker.javascript@7.1.4
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-03T07_54_52_538Z-debug-0.log
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          States:                     redis on 127.0.0.1
          admin:          6.10.1
          javascript:     7.1.4
          Adapters from github:   13
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
            system.adapter.boschindego.0            : boschindego           : iobroker                                 - disabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
            system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
            system.adapter.devices.0                : devices               : iobroker                                 - disabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          + system.adapter.drag-indicator.0         : drag-indicator        : iobroker                                 -  enabled
          + system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.goodwe.0                 : goodwe                : iobroker                                 -  enabled
          + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.hm-rpc.4                 : hm-rpc                : iobroker                                 - disabled, port: 0
            system.adapter.hm-rpc.5                 : hm-rpc                : iobroker                                 - disabled, port: 0
          + system.adapter.hoover.0                 : hoover                : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          + system.adapter.lgtv11.0                 : lgtv11                : iobroker                                 -  enabled, port: 8080
            system.adapter.material.0               : material              : iobroker                                 - disabled
          + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
          + system.adapter.mihome.0                 : mihome                : iobroker                                 -  enabled, port: 9898, bind: 192.168.69.159
          + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
            system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
          + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
          + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
          + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
          + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
          + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
          + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
          + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
          + system.adapter.ph803w.0                 : ph803w                : iobroker                                 -  enabled
          + system.adapter.pid.0                    : pid                   : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
            system.adapter.pylontech.0              : pylontech             : iobroker                                 - disabled, port: 23
          + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
          + system.adapter.rtl_433.0                : rtl_433               : iobroker                                 -  enabled
            system.adapter.rtspStream.0             : rtspStream            : iobroker                                 - disabled, port: 8082
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            system.adapter.schoolfree.0             : schoolfree            : iobroker                                 - disabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 -  enabled
            system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1500, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
          + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
          + system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB1
          + instance is alive
          sources       : conf/sources-dist.json
          online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
          beta          : http://iobroker.live/repo/sources-dist-latest.json
          Active repo(s): stable
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.10.1
          Adapter    "apcups"       : 1.0.15   , installed 1.0.15
          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
          Adapter    "device-watcher": 2.9.3   , installed 2.9.3
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "drag-indicator": 2.1.0   , installed 2.1.0
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "ems-esp"      : 2.4.1    , installed 2.4.1
          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
          Adapter    "hass"         : 1.4.0    , installed 1.4.0
          Adapter    "history"      : 2.2.6    , installed 2.2.6
          Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "hoover"       : 0.0.7    , installed 0.1.1
          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "iot"          : 1.14.5   , installed 1.14.5
          Adapter    "km200"        : 2.0.3    , installed 2.0.3
          Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
          Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "midea"        : 0.0.7    , installed 0.0.7
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "moma"         : 1.2.9    , installed 1.2.9
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
          Adapter    "onvif"        : 1.0.5    , installed 1.0.5
          Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
          Adapter    "parser"       : 1.3.2    , installed 1.3.2
          Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
          Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
          Adapter    "pvforecast"   : 2.8.1    , installed 2.7.1  [Updatable]
          Adapter    "rflink"       : 2.1.6    , installed 2.1.6
          Adapter    "s7"           : 1.3.15   , installed 1.3.15
          Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
          Adapter    "snmp"         : 2.4.11   , installed 2.4.11
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
          Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "statistics"   : 2.3.0    , installed 2.3.0
          Adapter    "text2command" : 3.0.2    , installed 3.0.2
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "unifi"        : 0.6.6    , installed 0.6.6
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.1.2    , installed 6.1.2
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
          Objects and States
          Objects:        72640
          States:         54239
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13741      504/sshd: /usr/sbin
          tcp        0      0 192.168.69.159:2010     0.0.0.0:*               LISTEN      1000       18836      1110/io.hm-rpc.3
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       18864      1262/io.mqtt.0
          tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1000       13939      1388/io.sonoff.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       18865      1262/io.mqtt.0
          tcp        0      0 192.168.69.159:8701     0.0.0.0:*               LISTEN      1000       1360       1091/io.hm-rpc.2
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       14596      582/iobroker.js-con
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        11663      459/redis-server 12
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          18520      1/init
          tcp        0      0 192.168.69.159:2000     0.0.0.0:*               LISTEN      1000       18803      1072/io.hm-rpc.1
          tcp        0      0 192.168.69.159:2001     0.0.0.0:*               LISTEN      1000       18757      1045/io.hm-rpc.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1000       27686      2303/io.socketio.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      1000       30024      2866/io.web.2
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13743      504/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1985       2222/io.simple-api.
          tcp6       0      0 :::8089                 :::*                    LISTEN      1000       25177      2817/io.web.1
          tcp6       0      0 :::8095                 :::*                    LISTEN      1000       30377      3057/io.onvif.0
          tcp6       0      0 ::1:6379                :::*                    LISTEN      108        11664      459/redis-server 12
          tcp6       0      0 :::111                  :::*                    LISTEN      0          11594      1/init
          tcp6       0      0 :::80                   :::*                    LISTEN      0          207        522/apache2
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22164      667/io.admin.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       12784      1431/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       12785      1431/io.tuya.0
          udp        0      0 0.0.0.0:56901           0.0.0.0:*                           1000       16187      1950/io.milight-sma
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13719      404/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18521      1/init
          udp        0      0 0.0.0.0:57485           0.0.0.0:*                           1000       23728      2253/io.snmp.0
          udp        0      0 0.0.0.0:49308           0.0.0.0:*                           1000       19901      1319/io.ph803w.0
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       12625      1148/io.mihome-vacu
          udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       15663      1167/io.mihome-vacu
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       26425      2893/io.wled.0
          udp        0      0 192.168.69.159:5353     0.0.0.0:*                           1000       13993      1410/io.tr-064.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       21219      1361/io.shelly.0
          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1000       9343329    1186/io.mihome.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       27991      2605/io.upnp.0
          udp        0      0 0.0.0.0:55168           0.0.0.0:*                           1000       27340      3370/io.goodwe.0
          udp6       0      0 :::111                  :::*                                0          11597      1/init
          2023-10-03 09:55:00.009  - info: modbus.1 (2033930) terminating
          2023-10-03 09:55:00.010  - info: modbus.1 (2033930) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-10-03 09:55:00.024  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2036184
          2023-10-03 09:55:00.509  - info: modbus.1 (2033930) terminating
          2023-10-03 09:55:00.921  - info: host.iobroker instance system.adapter.modbus.1 scheduled normal terminated and will be restarted on schedule.
          2023-10-03 09:55:00.921  - info: host.iobroker Restart adapter system.adapter.modbus.1 because enabled
          2023-10-03 09:55:01.205  - info: dwd.0 (2036184) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          2023-10-03 09:55:01.661  - info: dwd.0 (2036184) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
          2023-10-03 09:55:01.902  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319701902,"act":-114.17,"set":10,"diff":124.17,"off":0,"err":124.17,"y":100,"lim":true,"dt":5000,"differr":null,"sumerr":9875.83,"supr":false}
          2023-10-03 09:55:02.084  - info: host.iobroker instance system.adapter.modbus.1 started with pid 2036251
          2023-10-03 09:55:02.863  - info: modbus.1 (2036251) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          2023-10-03 09:55:02.911  - info: modbus.1 (2036251) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.18.0, js-controller: 5.0.12
          2023-10-03 09:55:03.260  - info: modbus.1 (2036251) Connected to slave
          2023-10-03 09:55:03.549  - info: dwd.0 (2036184) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-10-03 09:55:04.061  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-10-03 09:55:05.000  - info: javascript.0 (741) script.js.Aktiv.Matrixdisplay: request: http://192.168.69.64/cm?cmnd=DisplayText  Benzin 1.979
          2023-10-03 09:55:06.901  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319706901,"act":-134.95,"set":10,"diff":144.95,"off":0,"err":144.95,"y":100,"lim":true,"dt":4999,"differr":null,"sumerr":9855.05,"supr":false}
          2023-10-03 09:55:08.537  - info: ph803w.0 (1319) PH803W device SDQPhpi0dW53T8zlCyzM2E Error: Error: connect EHOSTUNREACH 192.168.69.117:12416
          2023-10-03 09:55:08.745  - info: reolink.0 (2156) 0
          2023-10-03 09:55:10.000  - info: javascript.0 (741) script.js.Aktiv.Matrixdisplay: request: http://192.168.69.64/cm?cmnd=DisplayText  Diesel 1.949
          2023-10-03 09:55:11.902  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319711902,"act":-134.95,"set":10,"diff":144.95,"off":0,"err":144.95,"y":100,"lim":true,"dt":5001,"differr":null,"sumerr":9855.05,"supr":false}
          2023-10-03 09:55:16.901  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319716901,"act":-134.95,"set":10,"diff":144.95,"off":0,"err":144.95,"y":100,"lim":true,"dt":4999,"differr":null,"sumerr":9855.05,"supr":false}
          2023-10-03 09:55:18.730  - info: reolink.0 (2156) 0
          2023-10-03 09:55:21.589  - info: ph803w.0 (1319) PH803W device SDQPhpi0dW53T8zlCyzM2E Error: Error: connect EHOSTUNREACH 192.168.69.117:12416
          2023-10-03 09:55:21.901  - info: pid.0 (3241) [C-Solar1] update() - {"ts":1696319721901,"act":-128.51,"set":10,"diff":138.51,"off":0,"err":138.51,"y":100,"lim":true,"dt":5000,"differr":null,"sumerr":9861.49,"supr":false}
          iob diag has finished.
            Thomas Braun Most Active @Radi last edited by
            @radi
            Und das Backup wird auf ein fritz.nas geschrieben?
            • MartinP
              MartinP @crunchip last edited by
              @crunchip Ich habe es gar nicht mit CIFS geschafft.
              Iobroker im nicht priorisierten LXC-Container unter Proxmox mit Bullseye.
              martin@iobroker-test-sicher:/etc/apt/sources.list.d$ mount -a
              mount.cifs: permission denied
              martin@iobroker-test-sicher:/etc/apt/sources.list.d$ sudo mount -a
              [sudo] password for martin:
              mount error(1): Operation not permitted
              Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              Ich mache nun lokale Backups auf der virtuellen Platte des Containers, und schiebe diese Backups mit einem Cron Job per rsync auf das Backupsystem.
              Vielleicht liegt es am nicht priorisierten Container ...
                Thomas Braun Most Active @MartinP last edited by
                @martinp sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                Das dürfte nicht betroffen sein. Lokale Backups und Dateioperationen auf dem NAS funktionieren soweit wie wir das sehen. Es geht in erster Linie wohl um Aktionen im gemounteten Dateisystem.
                  Radi @Thomas Braun last edited by Radi
                  @thomas-braun Ja, auf eine USB-Festplatte die per CIFS angebunden ist.
                  Anbei noch ein Screenshot des Verzeichnisses mit dem Inhalt vor und nach Installation von node 18.18.0.0dbbb625-9fd2-4a10-a457-8e289747dd9c-grafik.png
                  • U
                    UV-on-fire @Thomas Braun last edited by
                    Habe eben auf 18.8 akttualisiert und das gleiche Problem.
                    Backup war vorher 11MB jetzt 16kb.
                    Javaskript ebenso von 292k auf 11k geschrumpft.
                    Homematic (Rasberrymatic) 4.7MB auf 64k geschrumpft.
                    Vorhergehende Backups wurden jeweils gestern Nacht automatisch erstellt.
                    Läuft alles auf nem NUC unter Proxmox. Iobroker als LXC, Rasberrymatic als VM.
                    Backup auf Platte am Fritz.nas mit CIFS.
                    kurz:
                    v.2023-06-20
                    Icon name: computer-container
                    Chassis: container
                    Machine ID: c337b259b2a44b9da1e2356e14b395e6
                    Boot ID: 00d0c433c7104a35ba5be38a7e596927
                    Virtualization: lxc
                    Kernel: Linux 5.15.74-1-pve
                    Installation: lxc
                    Kernel: x86_64
                    Userland: amd64
                    User-ID: 1000
                    X-Server: false
                    Boot Target: graphical.target
                    /usr/bin/npm 9.8.1
                    /usr/bin/npx 9.8.1
                    MEMORY:
                    Mem: 4.1G 2.2G 1.2G 0.0K 707M 1.9G
                    Swap: 512M 0B 512M
                    Total: 4.6G 2.2G 1.7G
                    Active iob-Instances: 31
                    Active repo(s): Beta (latest)
                    admin 6.10.4
                    ioBroker Status: iobroker is running on this host.
                    Objects type: jsonl
                    States type: jsonl
                    • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.213, run as: admin
                    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects: 19164
                    States: 17129
                    37M /opt/iobroker/iobroker-data/objects.jsonl
                    26M /opt/iobroker/iobroker-data/states.jsonl
                    lang
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                    model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                    Docker          : false
                    Virtualization  : lxc
                    Kernel          : x86_64
                    Userland        : amd64
                     10:29:21 up 16 min,  1 user,  load average: 0.51, 0.73, 0.80
                    CPU threads: 1
                                   Local time: Tue 2023-10-03 10:29:21 CEST
                               Universal time: Tue 2023-10-03 08:29:21 UTC
                                     RTC time: n/a
                                  NTP service: inactive
                              RTC in local TZ: no
                    uviob
                    /home/uviob
                    uviob sudo iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           512M          0B        512M
                             4096 M total memory
                             2189 M used memory
                              256 M active memory
                             2441 M inactive memory
                             1198 M free memory
                                0 M buffer memory
                              707 M swap cache
                              512 M total swap
                                0 M used swap
                              512 M free swap
                    *** FILESYSTEM ***
                    /dev/mapper/pve-vm--210--disk--1 ext4   9.8G  7.0G  2.4G  76% /
                    none                             tmpfs  492K  4.0K  488K   1% /dev
                    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                    tmpfs                            tmpfs  3.1G  104K  3.1G   1% /run
                    [Mon Jun 12 03:04:37 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jun 12 03:11:35 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Jun 12 03:11:35 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Jun 12 03:15:49 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Tue Jun 13 20:30:24 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Thu Jun 15 20:23:19 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jun 19 03:04:21 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jun 19 03:11:21 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Jun 19 03:11:21 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Jun 19 03:15:36 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jun 26 03:04:03 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jun 26 03:11:06 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Jun 26 03:11:06 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Jun 26 03:15:24 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul  3 03:03:40 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul  3 03:10:43 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Jul  3 03:10:43 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Jul  3 03:15:12 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul 10 03:03:24 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul 10 03:10:31 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Jul 10 03:10:31 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Jul 10 03:15:02 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul 17 11:28:29 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul 17 11:35:18 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Jul 17 11:35:18 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Jul 17 11:39:46 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul 24 03:02:24 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul 24 03:09:12 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Jul 24 03:09:12 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Jul 24 03:13:37 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul 31 03:02:03 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Jul 31 03:08:52 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Jul 31 03:08:52 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Jul 31 03:13:19 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Tue Aug  1 20:05:22 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Aug  7 03:01:49 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Aug  7 03:08:30 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Aug  7 03:08:30 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Aug  7 03:13:06 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Aug 14 03:01:28 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Aug 14 03:08:10 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Aug 14 03:08:10 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Aug 14 03:12:48 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Aug 21 03:01:10 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Aug 21 03:07:52 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Aug 21 03:07:52 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Aug 21 03:12:13 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Thu Aug 24 16:49:41 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Aug 28 03:00:39 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Aug 28 03:07:19 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Aug 28 03:07:19 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Aug 28 03:11:47 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Sep  4 03:00:18 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Sep  4 03:07:01 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Sep  4 03:07:01 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Sep  4 03:11:38 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Sep 11 02:59:58 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Sep 11 03:06:36 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Sep 11 03:06:36 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Sep 11 03:11:11 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Sep 18 02:59:42 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Sep 18 03:06:20 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Sep 18 03:06:20 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Sep 18 03:10:57 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Sep 25 02:59:20 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Sep 25 03:06:31 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Sep 25 03:06:31 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Sep 25 03:11:09 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Oct  2 02:58:56 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Mon Oct  2 03:05:35 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                    [Mon Oct  2 03:05:35 2023] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Mon Oct  2 03:10:13 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Tue Oct  3 10:05:04 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    /      /dev/mapper/pve-vm--210--disk--1 ext4   rw,relatime,stripe=16
                    /var:
                    919M    /var/
                    402M    /var/log
                    401M    /var/log/journal/c337b259b2a44b9da1e2356e14b395e6
                    376M    /var/cache
                    Archived and active journals take up 96.0M in the file system.
                    69M     /opt/iobroker/backups/
                    595M    /opt/iobroker/iobroker-data/
                    453M    /opt/iobroker/iobroker-data/files
                    80M     /opt/iobroker/iobroker-data/files/vis
                    80M     /opt/iobroker/iobroker-data/backup-objects
                    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                    27M     /opt/iobroker/iobroker-data/states.jsonl
                    21M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.22196004.js.map
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                            500 http://security.debian.org bullseye-security/main amd64 Packages
                            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.10.4
                    javascript:     7.1.4
                    Adapters from github:   0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.213, run as: admin
                      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                      system.adapter.bmw.0                    : bmw                   : iobroker                                 - disabled
                      system.adapter.cameras.0                : cameras               : iobroker                                 - disabled, port: 8200, bind: 127.0.0.1
                      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    + system.adapter.fitbit-fitness.0         : fitbit-fitness        : iobroker                                 -  enabled
                      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                    + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                    + system.adapter.hm-rpc.4                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.213
                    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                    + system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 -  enabled
                    + system.adapter.tahoma.0                 : tahoma                : iobroker                                 -  enabled
                      system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
                      system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    Stable (default): http://download.iobroker.net/sources-dist.json
                    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                    Used repository: Beta (latest)
                    Adapter    "bmw"          : 2.6.2    , installed 2.6.2
                    Adapter    "cameras"      : 1.3.0    , installed 1.3.0
                    Adapter    "discovery"    : 4.1.0    , installed 4.1.0
                    Adapter    "fitbit-fitness": 0.4.11  , installed 0.4.11
                    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                    Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                    Adapter    "proxmox"      : 2.1.0    , installed 2.1.0
                    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                    Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                    Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                    Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                    Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                    Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                    Objects and States
                    Objects:        19164
                    States:         17129
                    Hit:1 http://security.debian.org bullseye-security InRelease
                    Hit:2 http://ftp.debian.org/debian bullseye InRelease
                    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          497506546  1/init
                    tcp        0      0 192.168.178.213:8081    0.0.0.0:*               LISTEN      1001       497508582  311/io.admin.0
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        497506990  83/systemd-resolved
                    tcp        0      0 192.168.178.213:8701    0.0.0.0:*               LISTEN      1001       497509579  590/io.hm-rpc.4
                    tcp        0      0 192.168.178.213:1883    0.0.0.0:*               LISTEN      1001       497512724  1428/io.mqtt.0
                    tcp        0      0 192.168.178.213:2001    0.0.0.0:*               LISTEN      1001       497508974  484/io.hm-rpc.0
                    tcp        0      0 192.168.178.213:2010    0.0.0.0:*               LISTEN      1001       497509175  529/io.hm-rpc.2
                    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        497506983  83/systemd-resolved
                    tcp        0      0 192.168.178.213:9292    0.0.0.0:*               LISTEN      1001       497509111  505/io.hm-rpc.1
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       497507075  119/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       497507150  119/iobroker.js-con
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          497507221  297/master
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          497506841  1/init
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          497506554  1/init
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          497507222  297/master
                    tcp6       0      0 :::5355                 :::*                    LISTEN      104        497506986  83/systemd-resolved
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       497521909  2679/io.web.0
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       497519140  2515/io.simple-api.
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        497506989  83/systemd-resolved
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          497506549  1/init
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       497521948  2698/io.wled.0
                    udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1001       497511049  1037/io.tr-064.0
                    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        497506982  83/systemd-resolved
                    udp6       0      0 :::111                  :::*                                0          497506559  1/init
                    udp6       0      0 :::5355                 :::*                                104        497506985  83/systemd-resolved
                    2023-10-03 10:29:40.002  - error: javascript.0 (369) script.js.Materialdesign.Netzwerk: [netzwerkStatus] error: Cannot read properties of null (reading 'common'), stack: TypeError: Cannot read properties of null (reading 'common')
                        at Object.netzwerkStatus (script.js.Materialdesign.Netzwerk:2433:33)
                        at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
                        at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                        at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                        at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                        at listOnTimeout (node:internal/timers:569:17)
                        at processTimers (node:internal/timers:512:7)
                    2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.uptime' not exist!
                    2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.cpu' not exist!
                    2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.mem' not exist!
                    2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.maxmem' not exist!
                    2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.mem_lev' not exist!
                    2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.disk' not exist!
                    2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.maxdisk' not exist!
                    2023-10-03 10:29:43.503  - warn: javascript.0 (369) script.js.Materialdesign.Proxmox: [updateVm - lxc_Proxy] datapoint 'proxmox.0.lxc_Proxy.disk_lev' not exist!
                    2023-10-03 10:29:50.001  - warn: javascript.0 (369) script.js.Materialdesign.Netzwerk: Object "tr-064.0.devices.PC-F8-0D-60-48-43-94" does not exist
                    2023-10-03 10:29:50.002  - error: javascript.0 (369) script.js.Materialdesign.Netzwerk: [netzwerkStatus] error: Cannot read properties of null (reading 'common'), stack: TypeError: Cannot read properties of null (reading 'common')
                    • MartinP
                      MartinP @UV-on-fire last edited by
                      @uv-on-fire Wo ist der Fritz.nas CIFS gemountet? Im Proxmox, und dann durchgereicht auf den LXC Container oder direkt im Linux des LXC Containers?
                      • U
                        UV-on-fire @MartinP last edited by UV-on-fire
                        @martinp
                        Ich meine direkt im Linux. Hab da ne weile herum experimentiert.
                        EDIT: Glaub habe gerade quatsch erzählt. Ich meine für Backitup war es nicht nötig die Platte zu mounten wenn ich mich richtig erinnere. Wo ich ewig rum gemacht habe war das Einbinden der Platte für die eigentlichen Proxmox Backups. War ziemlich viel try and error da ich in Linux nicht wirklich fit bin.
                          @thomas-braun Für mich sieht es so aus, als ob die lokal im IOBroker unter /opt/iobroker/backups abgelegten Files genauso korrupt sind, wie die auf dem FRITZ-Nas abgelegten. Siehe Screenshot aus WinSCP:
                            @radi sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                            Wenn das NAS gerade gemounted ist dann ist das die gleiche Datei.
                              @thomas-braun Okay, dann habe ich gerade wieder etwas dazu gelernt. Hab es gerade noch mal ausprobiert, nach dem umount ist dieses Verzeichnis wieder leer.
                                So ist es richtig.
                                • O S
                                  O S @Thomas Braun last edited by
                                  Habe das gleiche Problem.
                                  Skript v.2023-06-20
                                  *** BASE SYSTEM ***
                                     Static hostname: iobroker6
                                           Icon name: computer
                                          Machine ID: 6cdd9ef1128b465193e49cc4ea80f5af
                                             Boot ID: 41b5da8e46ba4fd897de0fa6a4711922
                                              Kernel: Linux 6.1.21-v8+
                                        Architecture: arm64
                                  Model           : Raspberry Pi 4 Model B Rev 1.2
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                   17:43:34 up  3:51,  1 user,  load average: 0.84, 0.88, 0.88
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  Other values than 0x0 hint to temperature/voltage problems
                                  temp=67.6'C
                                  volt=0.8438V
                                                 Local time: Tue 2023-10-03 17:43:34 CEST
                                             Universal time: Tue 2023-10-03 15:43:34 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        1.8G        1.6G        1.0M        419M        1.9G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        1.8G        1.7G
                                           3793 M total memory
                                           1803 M used memory
                                           1851 M active memory
                                            250 M inactive memory
                                           1570 M free memory
                                             54 M buffer memory
                                            364 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       28G  3.2G   24G  12% /
                                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                  tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                  /dev/sdb1      vfat      255M   31M  225M  13% /boot
                                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                  [Tue Oct  3 13:52:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E5:E6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=85bcf00a-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Tue Oct  3 13:52:18 2023] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Tue Oct  3 13:52:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:18.
                                  [Tue Oct  3 13:52:20 2023] EXT4-fs (sdb2): re-mounted. Quota mode: none.
                                  /       /dev/sdb2 ext4   rw,noatime
                                  `-/boot /dev/sdb1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  535M    /var/
                                  182M    /var/cache
                                  176M    /var/cache/apt
                                  147M    /var/lib
                                  122M    /var/lib/apt/lists
                                  Archived and active journals take up 104.0M in the file system.
                                  165M    /opt/iobroker/iobroker-data/files
                                  34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                  33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                  25M     /opt/iobroker/iobroker-data/objects.jsonl
                                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
                                  8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js
                                  8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
                                  /usr/bin/nodejs         v18.17.1
                                  /usr/bin/node           v18.17.1
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
                                  nodejs:
                                    Installed: 18.17.1-deb-1nodesource1
                                    Candidate: 18.17.1-deb-1nodesource1
                                    Version table:
                                   *** 18.17.1-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                    jsonl on 0.0.0.0
                                  States:                     jsonl on 0.0.0.0
                                  admin:          6.10.1
                                  javascript:     7.1.4
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                  + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
                                    system.adapter.mobile.0                 : mobile                : iobroker                                 -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                                  + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  Active repo(s): Stable (default)
                                  Used repository: Stable (default)
                                  Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                                  Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                  Adapter    "web"          : 6.1.2    , installed 6.1.0  [Updatable]
                                  Objects and States
                                  Objects:        6978
                                  States:         12775
                                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15401      544/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14593      508/iobroker.js-con
                                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15434      508/iobroker.js-con
                                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15751      1171/io.sonoff.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          15403      544/sshd: /usr/sbin
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       300189     15081/io.web.0
                                  tcp6       0      0 :::8085                 :::*                    LISTEN      1001       297932     15070/io.ws.0
                                  tcp6       0      0 :::7777                 :::*                    LISTEN      1001       299942     15273/io.admin.0
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12530      810/dhcpcd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14543      399/avahi-daemon: r
                                  udp        0      0 0.0.0.0:58602           0.0.0.0:*                           108        14545      399/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13024      1148/io.shelly.0
                                  udp6       0      0 :::546                  :::*                                0          15429      810/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        14544      399/avahi-daemon: r
                                  udp6       0      0 :::42372                :::*                                108        14546      399/avahi-daemon: r
                                  2023-10-03 16:48:52.372  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 16:48:53.170  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 16:48:54.431  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 16:49:00.673  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 16:51:14.699  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 16:51:14.699  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0
                                  2023-10-03 16:51:14.701  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin
                                  2023-10-03 16:51:14.701  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot
                                  2023-10-03 17:29:27.500  - warn: octoprint.0 (1324) received 502 response from /api/version with content: "<html><body><h1>502 Bad Gateway</h1>\nThe server returned an invalid or incomplete response.\n</body></html>\n"
                                  2023-10-03 17:30:18.149  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:30:18.677  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot
                                  2023-10-03 17:30:19.290  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:30:20.314  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:30:45.434  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:30:46.614  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:31:00.543  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:40:42.148  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin
                                  2023-10-03 17:40:42.148  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot
                                  2023-10-03 17:40:42.153  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0
                                  2023-10-03 17:40:48.430  - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:40:49.815  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:40:58.838  - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203
                                  2023-10-03 17:42:44.448  - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin
                                  2023-10-03 17:42:44.451  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0
                                  2023-10-03 17:42:44.455  - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flo
                                                       v.2023-06-20
                                           Icon name: computer
                                        Architecture: arm64
                                  Kernel:                 aarch64
                                  Userland:               arm64
                                  User-ID:                1000
                                  X-Server:               false
                                  Boot Target:            multi-user.target
                                  Pending iob updates:    1
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                          /usr/bin/npm            9.6.7
                                                          /usr/bin/npx            9.6.7
                                  MEMORY:
                                  Mem:            3.8G        1.8G        1.3G        1.0M        676M        1.9G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        1.8G        1.4G
                                  Active iob-Instances:   21
                                                          admin                   6.10.1
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                6978
                                  States:                 12775
                                  4.2M    /opt/iobroker/iobroker-data/states.jsonl
                                  Hoffentlich hilft das.
                                    Thomas Braun Most Active @O S last edited by
                                    @o-s sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                                    18.17.1
                                    Mit nodejs 18.17.1 bist du der erste. Bislang ist das nur bei 18.18.0 und nodejs@20 aufgefallen.
                                    • O S
                                      O S last edited by
                                      Copy text starting here:
                                                           v.2023-06-20
                                               Icon name: computer
                                            Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               arm64
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/node           v18.18.0
                                                              /usr/bin/npm            9.8.1
                                                              /usr/bin/npx            9.8.1
                                      MEMORY:
                                      Mem:            3.8G        1.5G        1.3G        1.0M        949M        2.2G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        1.5G        1.4G
                                                              admin                   6.10.1
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                6978
                                      States:                 12775
                                      27M     /opt/iobroker/iobroker-data/objects.jsonl
                                      2.6M    /opt/iobroker/iobroker-data/states.jsonl
                                      [s=]
                                      Skript v.2023-06-20
                                      *** BASE SYSTEM ***
                                      Icon name: computer
                                      Architecture: arm64
                                      Docker : false
                                      Virtualization : none
                                      Kernel : aarch64
                                      Userland : arm64
                                      Systemuptime and Load:
                                      18:48:07 up 4:55, 1 user, load average: 1.04, 1.14, 1.28
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=62.3'C
                                      volt=0.8438V
                                      *** Time and Time Zones ***
                                      Local time: Tue 2023-10-03 18:48:07 CEST
                                      Universal time: Tue 2023-10-03 16:48:07 UTC
                                      RTC time: n/a
                                      NTP service: active
                                      RTC in local TZ: no
                                      *** User and Groups ***
                                      pi
                                      /home/pi
                                      *** X-Server-Setup ***
                                      X-Server: false
                                      Desktop:
                                      Terminal: tty
                                      *** MEMORY ***
                                      total used free shared buff/cache available
                                      Mem: 3.8G 1.5G 1.4G 1.0M 948M 2.2G
                                      Swap: 99M 0B 99M
                                      Total: 3.9G 1.5G 1.5G
                                           3793 M total memory
                                           1492 M used memory
                                           1502 M active memory
                                            766 M inactive memory
                                           1352 M free memory
                                            118 M buffer memory
                                            830 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      Filesystem Type Size Used Avail Use% Mounted on
                                      tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
                                      //fritz.box/fritz.nas/intenso/iobroker cifs 961G 521G 441G 55% /opt/iobroker/backups
                                      Show mounted filesystems (real ones only):
                                      TARGET SOURCE FSTYPE OPTIONS
                                      `-/opt/iobroker/backups //fritz.box/fritz.nas/intenso/iobroker cifs rw,relatime,vers=3.1.1,cache=strict,username=IoBroker2,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                                      /var:
                                      563M /var/
                                      209M /var/cache
                                      204M /var/cache/apt
                                      147M /var/lib
                                      123M /var/lib/apt
                                      /opt/iobroker/backups:
                                      129M /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      203M /opt/iobroker/iobroker-data/
                                      52M /opt/iobroker/iobroker-data/files/javascript.admin
                                      *** NodeJS-Installation ***
                                      /usr/bin/npm 9.8.1
                                      /usr/bin/npx 9.8.1
                                      nodejs:
                                      Installed: 18.18.0-1nodesource1
                                      Candidate: 18.18.0-1nodesource1
                                      Version table:
                                      100 /var/lib/dpkg/status
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States type: jsonl
                                      No configuration change needed.
                                      Multihost discovery server: disabled
                                      Discovery authentication: enabled
                                      Persistent activation: disabled
                                      Core adapters versions
                                      admin: 6.10.1
                                      javascript: 7.1.4
                                      Adapter State
                                      • system.adapter.admin.0 : admin : iobroker - enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                      • system.adapter.alexa2.0 : alexa2 : iobroker - enabled
                                      • system.adapter.backitup.0 : backitup : iobroker - enabled
                                      • system.adapter.discovery.0 : discovery : iobroker - enabled
                                      • system.adapter.fritzbox.0 : fritzbox : iobroker - enabled
                                      • system.adapter.fritzdect.0 : fritzdect : iobroker - enabled
                                      • system.adapter.history.0 : history : iobroker - enabled
                                      • system.adapter.info.0 : info : iobroker - enabled
                                      • system.adapter.iot.0 : iot : iobroker - enabled
                                      • system.adapter.javascript.0 : javascript : iobroker - enabled
                                      • system.adapter.net-tools.0 : net-tools : iobroker - enabled
                                      • system.adapter.octoprint.0 : octoprint : iobroker - enabled
                                      • system.adapter.ping.0 : ping : iobroker - enabled
                                      • system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0
                                      • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0
                                      • system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled
                                      • system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
                                      • system.adapter.tr-064.0 : tr-064 : iobroker - enabled
                                      • system.adapter.ws.0 : ws : iobroker - enabled, port: 8085, bind: 0.0.0.0, run as: admin
                                      • instance is alive
                                      ioBroker-Repositories
                                      Installed ioBroker-Instances
                                      Adapter "alexa2" : 3.25.2 , installed 3.25.2
                                      Adapter "flot" : 1.12.0 , installed 1.12.0
                                      Adapter "info" : 2.0.0 , installed 2.0.0
                                      Adapter "javascript" : 7.1.4 , installed 7.1.4
                                      Controller "js-controller": 5.0.12 , installed 5.0.12
                                      Adapter "net-tools" : 0.2.0 , installed 0.2.0
                                      Adapter "ping" : 1.6.2 , installed 1.6.2
                                      Adapter "simple-api" : 2.7.2 , installed 2.7.2
                                      Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
                                      Adapter "telegram" : 1.16.0 , installed 1.16.0
                                      Adapter "tr-064" : 4.2.18 , installed 4.2.18
                                      Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
                                      Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
                                      Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
                                      Objects and States
                                      Objects: 6978
                                      States: 12775
                                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                                      tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 531479 28146/iobroker.js-c
                                      tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 531484 28146/iobroker.js-c
                                      tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 530826 28332/io.sonoff.0
                                      tcp6 0 0 :::8082 :::* LISTEN 1001 533936 28695/io.web.0
                                      tcp6 0 0 :::8085 :::* LISTEN 1001 534754 28728/io.ws.0
                                      tcp6 0 0 :::7777 :::* LISTEN 1001 531536 28172/io.admin.0
                                      udp 0 0 0.0.0.0:55170 0.0.0.0:* 1001 619670 28311/io.shelly.0
                                      udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 531837 28311/io.shelly.0
                                      2023-10-03 18:12:13.047 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                      2023-10-03 18:12:14.080 - info: net-tools.0 (28559) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.18.0, js-controller: 5.0.12
                                      2023-10-03 18:12:14.436 - info: net-tools.0 (28559) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                                      2023-10-03 18:12:15.808 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                      2023-10-03 18:12:16.743 - info: net-tools.0 (28559) Port scan finished
                                      2023-10-03 18:12:21.610 - info: tankerkoenig.0 (28637) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.18.0, js-controller: 5.0.12
                                      2023-10-03 18:12:21.704 - info: tankerkoenig.0 (28637) Adapter is already in daemon mode
                                      2023-10-03 18:12:21.706 - warn: tankerkoenig.0 (28637) Sync time was too short (5). New sync time is 10 min
                                      2023-10-03 18:12:21.708 - info: tankerkoenig.0 (28637) Sync time set to 10 minutes or 600000 ms
                                      2023-10-03 18:12:24.672 - info: vis.0 (28658) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.0, js-controller: 5.0.12
                                      2023-10-03 18:12:25.224 - info: vis.0 (28658) vis license is OK.
                                      2023-10-03 18:12:28.304 - info: vis.0 (28658) Terminated (NO_ERROR): Without reason
                                      2023-10-03 18:12:29.942 - info: web.0 (28695) starting. Version 6.1.0 in /opt/iobroker/node_modules/iobroker.web, node: v18.18.0, js-controller: 5.0.12
                                      2023-10-03 18:12:30.679 - info: web.0 (28695) socket.io server listening on port 8082
                                      2023-10-03 18:12:30.703 - info: web.0 (28695) http server listening on port 8082
                                      2023-10-03 18:12:32.633 - info: ws.0 (28728) starting. Version 2.5.5 in /opt/iobroker/node_modules/iobroker.ws, node: v18.18.0, js-controller: 5.0.12
                                      2023-10-03 18:12:32.745 - warn: ws.0 (28728) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                                      2023-10-03 18:12:32.772 - info: ws.0 (28728) socket.io server listening on port 8085
                                      2023-10-03 18:12:40.622 - info: info.0 (28749) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.18.0, js-controller: 5.0.12
                                      2023-10-03 18:12:41.016 - info: info.0 (28749) Reading/updating systemdata.
                                      2023-10-03 18:12:45.286 - info: tankerkoenig.0 (28637) Start first request
                                      2023-10-03 18:12:45.312 - info: info.0 (28749) cpu Temp res = {"main":66.218,"cores":[],"max":66.218,"socket":[],"chipset":null}
                                      2023-10-03 18:16:19.824 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                      2023-10-03 18:16:27.936 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                      2023-10-03 18:29:49.271 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
                                      Backitup bei node 18.17.1: 6,7 MB
                                      Backitup bei node 18.18.0: 16 KB
                                      O S 1 Reply Last reply Reply Quote 0
                                      • O S
                                        O S @O S last edited by
                                        @o-s
                                        Besser habe ich es nicht gekonnt!
                                        Gruß Otto
                                          fastfoot last edited by
                                          ui, sind ja doch einige mit Fehlern. Ich bin gerade dabei ein Skript zu schreiben welches neben dem derzeitigen Verfahren(backitup/iobroker cli) auch eine evtl. Lösung anbieten soll. Diese Lösung ist zur Zeit noch nicht wirklich brauchbar da sie mehr Zeit benötigt, dient aber dazu zu prüfen ob der Fehler damit erstmal weg ist. Das Skript erstellt kein Backup sondern nutzt nur dessen Mechanismus, es werden auch keine Änderungen am System vorgenommen, man könnte es also auch in einer Produktivumgebung nutzen
                                          Ich hoffe es finden sich einige die Lust zum Testen haben, am Ende wird das hoffentlich gute Ergebnis als Grundlage für einen PR verwendet welcher dann das Problem im iobroker fixt.
                                          schonmal Danke im Voraus, stay tuned
                                            fastfoot @fastfoot last edited by fastfoot
                                            hier das Skript für diejenigen die testen wollen
                                            • das Skript läuft nur auf Linux Systemen
                                            • das Skript ist für die cifs Verbindung zur Fritz Box konzipiert
                                              • für andere Systeme kann der mount-Befehl aus dem LOG des backitup Adapters gelesen werden
                                            • LXC Container benötigen für cifs den Privileged Mode
                                            • Docker Container benötigen Privileged Mode oder
                                              • cap_add:
                                                • SYS_ADMIN
                                                • DAC_READ_SEARCH
                                            Kleine Anleitung zur Erstellung und Aufruf
                                            • Das Skript muss in /opt/iobroker erstellt werden, wegen der Pfade
                                            • Der Name ist egal, z.B. cifs_test.js, die Endung .js ist wichtig
                                            • Die Einstellungen in den Zeilen 33-37 vornehmen
                                            • Aufruf von der Konsole in /opt/iobroker mit node cifs_test
                                            • umount und mount erfolgen im Skript
                                            "use strict";
                                             * Name:    cifs.js
                                             * Zweck:   Dient ausschliesslich dem Test von Fehlern im Zusammenhang mit
                                             *          cifs(smb) mit Fritz Box, Node >= 18.18.0 und BackitUp-Adapter
                                             *          bzw. iobroker-cli(iob backup)
                                             * Datum:   2023-10-08
                                             * Author:  @fastfoot
                                             * Forum:   https://forum.iobroker.net/post/1054910
                                            const fs_extra_1 = require("fs-extra");
                                            const path_1 = require("path");
                                            const promisify_child_process_1 = require("promisify-child-process");
                                            const { pipeline } = require("node:stream/promises");
                                            const tar_1 = require("tar");
                                            const zlib = require("node:zlib");
                                            const os = require("os");
                                            const { exit } = require("process");
                                            const { createWriteStream } = require("fs");
                                            if (os.platform != "linux") {
                                              console.log("This script can only work under Linux OS, terminating now...");
                                              exit(1);
                                            //                                 fixe Einstellungen, möglichst nicht ändern
                                            const tmpDir = "/opt/iobroker/node_modules"; // simuliert den tmp Ordner des Backitup-Adapters, NICHT ändern!
                                            const targetDir = "/opt/iobroker/backups"; // Standard Ordner für Backup Dateien, NICHT ändern!
                                            const fritzNasShare = "//fritz.box/fritz.nas"; // Standard Share der FritzBox, NICHT ändern!
                                            //                                 Einstellungen
                                            const fritzNasDir = "Backup"; // Individueller Ordner des Fritz!NAS
                                            const fritzPasswd = "iobrokertest"; // Passwort
                                            const fritzUser = "iobroker"; // User
                                            const fritzSMBVers = "3.1.1"; // gültige SMB Version ("1.0","2.0","3.0","3.0.2","3.1.1")oder ""
                                            const noserverinoOpt = true; // Verwendung noserverino Option true/false
                                            //                                           Ab hier Finger weg!
                                            const umountCmd = `sudo umount ${targetDir}`;
                                            const mountCmd = `sudo mount -t cifs -o username=${fritzUser},password=${fritzPasswd}${
                                              noserverinoOpt ? ",noserverino" : ""
                                            },rw,file_mode=0777,dir_mode=0777${
                                              fritzSMBVers ? ",vers=3.1.1" : ""
                                            } ${fritzNasShare}/${fritzNasDir} ${targetDir}`;
                                            test();
                                            async function test() {
                                              console.log("Copy output from below \n\n```");
                                              try {
                                                const { stdout } = await promisify_child_process_1.exec(umountCmd);
                                                console.log(`${targetDir} unmounted`);
                                              } catch (e) {
                                                console.log("umount not possible");
                                              try {
                                                await promisify_child_process_1.exec(mountCmd);
                                                console.log(`${fritzNasShare}/${fritzNasDir} mounted into ${targetDir}\n`);
                                              } catch (e) {
                                                console.log("mount not possible: " + e + "\n");
                                              try {
                                                let res1 = await alternative2(`test_pipeline_compressed_tar.tar.gz`, true);
                                                console.log(`file ${res1} done`);
                                                await countFilesInTar(res1);
                                                res1 = await alternative3(`test_pipeline_compressed_zlib.tar.gz`, false);
                                                res1 = await alternative4(`test_pipeline_uncompressed.tar`, false);
                                                  `ls -lt ${targetDir}/test_*`
                                                console.log(`listing of created files in ${targetDir}\n` + stdout);
                                              } catch (e) {
                                                console.log(e);
                                              console.error("```\n\nEnd of output to copy");
                                            function standard(name, compression) {
                                              return new Promise((resolve, reject) => {
                                                const f = fs_extra_1.createWriteStream(`${targetDir}/${name}`);
                                                f.on("finish", () => {
                                                  resolve(path_1.normalize(name));
                                                f.on("error", (e) => {
                                                  console.error("error! : " + e);
                                                  reject("Fehler im Stream");
                                                try {
                                                  tar_1
                                                    .create({ gzip: compression, cwd: `${tmpDir}/` }, [
                                                      "iobroker.js-controller",
                                                    .pipe(f);
                                                  console.log(`file ${name} created`);
                                                } catch (e) {
                                                  reject(e);
                                            function alternative(name, compression = true) {
                                                try {
                                                  tar_1
                                                    .create(
                                                        //file: `${targetDir}/${name}`,
                                                        file: `${name}`,
                                                        gzip: compression,
                                                        cwd: `${tmpDir}/`,
                                                      ["iobroker.js-controller"]
                                                    .then(async () => {
                                                      await promisify_child_process_1.exec(`mv ${name} ${targetDir}`);
                                                } catch (e) {
                                                  reject(e);
                                            function alternative2(name, compression = true) {
                                              return new Promise(async (resolve, reject) => {
                                                try {
                                                  await pipeline(
                                                    tar_1.create(
                                                        gzip: compression,
                                                        cwd: `${tmpDir}/`,
                                                    //zlib.createGzip(),
                                                    fs_extra_1.createWriteStream(`${targetDir}/${name}`),
                                                  resolve(name);
                                                } catch (e) {
                                                  reject(e);
                                            function alternative3(name, compression = true) {
                                                try {
                                                  await pipeline(
                                                    tar_1.create(
                                                        gzip: compression,
                                                        cwd: `${tmpDir}/`,
                                                    zlib.createGzip(),
                                                  resolve(name);
                                                } catch (e) {
                                                  reject(e);
                                            function alternative4(name, compression = true) {
                                                //const f = fs_extra_1.createWriteStream(`${targetDir}/${name}`);
                                                //f.on("finish", () => {
                                                //  resolve(path_1.normalize(name));
                                                //f.on("error", (e) => {
                                                //  console.error("error! : " + e);
                                                //  reject("Fehler im Stream");
                                                try {
                                                  await pipeline(
                                                    tar_1.create(
                                                        //file: `${name}`,
                                                        gzip: compression,
                                                        cwd: `${tmpDir}/`,
                                                  resolve(name);
                                                } catch (e) {
                                                  reject(e);
                                            async function countFilesInTar(name) {
                                              let { stdout } = await promisify_child_process_1.exec(
                                                `tar -tf ${targetDir}/${name}|wc -l`
                                              console.log(`number of files in ${name}: ${stdout}`);
                                            Bei Fagen, fragen!
                                            R O S 3 Replies Last reply Reply Quote 0
                                            1.4k
                                            204
                                            28083
