    4. Anleitung Zigbee2MQTT Einrichtung im ioBroker
      arteck Developer Most Active @Guest last edited by arteck
      @papa_aus_rastatt sagte in Anleitung Zigbee2MQTT Einrichtung im ioBroker:
      Starting zigbee-herdsman problem : "Failed to initialize NV memory item (id=3, name=STARTUP_OPTION, len=1, status=0)"
      der kann den Spcicher nicht initialisieren .. warum auch immer
        A Former User @arteck last edited by A Former User
        @arteck Guten morgen,
        ich hab den Debug gerade mal ausgeschnitten:
        2023-10-04 07:08:26.755	info	Try to reconnect.
        2023-10-04 07:08:16.750	error	Error herdsman start
        2023-10-04 07:08:16.749	error	Failed to start Zigbee
        2023-10-04 07:08:16.748	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        2023-10-04 07:08:10.595	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
        2023-10-04 07:08:10.594	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
        2023-10-04 07:08:04.592	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
        2023-10-04 07:08:04.591	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
        2023-10-04 07:07:58.588	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
        2023-10-04 07:07:58.586	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
        2023-10-04 07:07:58.584	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
        2023-10-04 07:07:57.579	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
        2023-10-04 07:07:57.578	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
        2023-10-04 07:07:57.576	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
        2023-10-04 07:07:57.575	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
        2023-10-04 07:07:57.572	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_04-07_07_56.tar.gz success
        2023-10-04 07:07:57.092	info	Installed Version: iobroker.zigbee@1.8.24
        2023-10-04 07:07:57.086	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.174.73:8888
        2023-10-04 07:07:57.084	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.174.73:8888","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
        2023-10-04 07:07:56.769	debug	Starting zigbee-herdsman...
        2023-10-04 07:07:56.727	info	Starting Zigbee npm ...
        2023-10-04 07:07:56.724	info	delete old Backup files. keep only last 10
        2023-10-04 07:07:56.637	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.174.73:8888","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":true}}
        2023-10-04 07:07:56.580	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.0, js-controller: 5.0.12
        2023-10-04 07:07:56.041	debug	Plugin sentry Initialize Plugin (enabled=true)
        bin für Vorschläge dankbar.
          A Former User last edited by
          Moin,
          kannst Du auch noch den langen Output posten, von
          iob diag
          VG
          Bernd
            A Former User @Guest last edited by
            @dp20eic ja natürlich, kannst etwas spezifieren, was dich genau interressiert?
              tue uns beiden den gefallen und mach nur das was wir dir sagen egal obs plausiebel für dich ist oder nicht (von debug war nie die Rede)
              wenn @dp20eic langen Output will dann zeigmal ALLES was das iob diag liefert
              ich will die Adapter Einstellungen als screensot sehen..ja alles
              hast den umgestellt ??
                @arteck du meinst so?
                iob diag
                *** ioBroker Diagnosis ***
                Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                https://forum.iobroker.net
                Just copy and paste the Summary Page, including the  characters at start and end.
                It helps us to help you!
                Press any key to continue
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                   Static hostname: app-server1.weinbrecht.lan
                         Icon name: computer
                        Machine ID: f699c63377c1419dbac4c0c664f4b780
                           Boot ID: 2dad0456cb654f80b695eb65355ad96e
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.1.54-v8+
                      Architecture: arm64
                Model		: Raspberry Pi 4 Model B Rev 1.5
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : arm64
                Systemuptime and Load:
                 08:53:22 up 14:16,  1 user,  load average: 0.36, 0.46, 0.50
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                Other values than 0x0 hint to temperature/voltage problems
                temp=32.6'C
                volt=0.9360V
                *** Time and Time Zones ***
                               Local time: Wed 2023-10-04 08:53:22 CEST
                           Universal time: Wed 2023-10-04 06:53:22 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                root
                /root
                root
                *** X-Server-Setup ***
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                Boot Target: 	multi-user.target
                *** MEMORY ***
                Mem:            3.8G        2.0G        534M        114M        1.3G        1.7G
                Swap:             0B          0B          0B
                Total:          3.8G        2.0G        534M
                         3843 M total memory
                         2010 M used memory
                         2643 M active memory
                          476 M inactive memory
                          534 M free memory
                           74 M buffer memory
                         1223 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4      220G  6.6G  204G   4% /
                devtmpfs       devtmpfs  1.9G     0  1.9G   0% /dev
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                tmpfs          tmpfs     769M  9.0M  760M   2% /run
                none           tmpfs     1.9G  2.2M  1.9G   1% /tmp
                tmpfs          tmpfs     1.9G  104M  1.8G   6% /var/cache
                tmpfs          tmpfs     1.9G  200K  1.9G   1% /var/log
                tmpfs          tmpfs     1.9G     0  1.9G   0% /var/tmp
                /dev/sda1      vfat      255M   53M  203M  21% /boot
                tmpfs          tmpfs     385M     0  385M   0% /run/user/0
                [Tue Oct  3 18:37:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=D8:3A:DD:37:E1:5F vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=66aa2880-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Tue Oct  3 18:37:15 2023] EXT4-fs (sda2): mounted filesystem with writeback data mode. Quota mode: none.
                [Tue Oct  3 18:37:15 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Tue Oct  3 18:37:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                Show mounted filesystems (real ones only):
                TARGET  SOURCE    FSTYPE OPTIONS
                /       /dev/sda2 ext4   rw,noatime,nodiratime,discard,nobarrier,stripe=8191
                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                /var:
                421M	/var/
                316M	/var/lib
                158M	/var/lib/influxdb/engine
                154M	/var/lib/influxdb/engine/data/a9866606e533e3f8/autogen
                Archived and active journals take up 8.0M in the file system.
                /opt/iobroker/backups:
                29M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                439M	/opt/iobroker/iobroker-data/
                316M	/opt/iobroker/iobroker-data/files
                147M	/opt/iobroker/iobroker-data/files/vis-2
                75M	/opt/iobroker/iobroker-data/files/vis-2/static
                74M	/opt/iobroker/iobroker-data/files/vis-2/static/js
                46M	/opt/iobroker/iobroker-data/objects.jsonl
                33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js.map
                19M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.d3c12542.js.map
                17M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.b6e16d06.js.map
                *** NodeJS-Installation ***
                /usr/bin/nodejs 	v18.18.0
                /usr/bin/node 		v18.18.0
                /usr/bin/npm 		10.1.0
                /usr/bin/npx 		10.1.0
                nodejs:
                  Installed: 18.18.0-1nodesource1
                  Candidate: 18.18.0-1nodesource1
                  Version table:
                 *** 18.18.0-1nodesource1 500
                        100 /var/lib/dpkg/status
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.12~dfsg-1~deb11u3 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                No problems detected
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                No configuration change needed.
                Multihost discovery server: disabled
                Discovery authentication:   enabled
                Persistent activation:      disabled
                Objects:                    jsonl on 127.0.0.1
                States:                     jsonl on 127.0.0.1
                Core adapters versions
                admin: 		6.10.4
                javascript: 	7.1.4
                Adapters from github: 	1
                Adapter State
                + system.adapter.accuweather.0            : accuweather           : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.admin.0                  : admin                 : app-server1.weinbrecht.lan               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.apsystems-ecu.0          : apsystems-ecu         : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.backitup.0               : backitup              : app-server1.weinbrecht.lan               -  enabled
                  system.adapter.cloud.0                  : cloud                 : app-server1.weinbrecht.lan               - disabled
                  system.adapter.feiertage.0              : feiertage             : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.influxdb.0               : influxdb              : app-server1.weinbrecht.lan               -  enabled, port: 8086
                + system.adapter.info.0                   : info                  : app-server1.weinbrecht.lan               -  enabled
                  system.adapter.iot.0                    : iot                   : app-server1.weinbrecht.lan               - disabled
                + system.adapter.javascript.0             : javascript            : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : app-server1.weinbrecht.lan               -  enabled, port: 54321
                + system.adapter.modbus.0                 : modbus                : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.sonoff.0                 : sonoff                : app-server1.weinbrecht.lan               -  enabled, port: 1883, bind: 192.168.174.12
                + system.adapter.telegram.0               : telegram              : app-server1.weinbrecht.lan               -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.tr-064.0                 : tr-064                : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.tuya.0                   : tuya                  : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.vaillant.0               : vaillant              : app-server1.weinbrecht.lan               -  enabled
                  system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : app-server1.weinbrecht.lan               - disabled
                  system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : app-server1.weinbrecht.lan               - disabled
                  system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: app-server1.weinbrecht.lan               - disabled
                + system.adapter.vis-2.0                  : vis-2                 : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.web.0                    : web                   : app-server1.weinbrecht.lan               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.wifilight.0              : wifilight             : app-server1.weinbrecht.lan               -  enabled
                + system.adapter.zigbee.0                 : zigbee                : app-server1.weinbrecht.lan               -  enabled, port: tcp://192.168.174.73:8888
                + instance is alive
                ioBroker-Repositories
                Active repo(s): beta
                Installed ioBroker-Instances
                Used repository: beta
                Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
                Adapter    "admin"        : 6.10.4   , installed 6.10.4
                Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                Adapter    "backitup"     : 2.8.2    , installed 2.8.2
                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                Adapter    "fritzdect"    : 2.4.1    , installed 2.4.1
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                Controller "js-controller": 5.0.12   , installed 5.0.12
                Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                Adapter    "socketio"     : 6.5.6    , installed 6.5.6
                Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                Adapter    "vaillant"     : 0.2.0    , installed 0.2.0
                Adapter    "vis-2"        : 2.3.0    , installed 2.3.0
                Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                Adapter    "web"          : 6.1.3    , installed 6.1.3
                Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                Adapter    "ws"           : 2.5.6    , installed 2.5.6
                Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                Objects and States
                Objects: 	6543
                States: 	6142
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 192.168.174.12:1883     0.0.0.0:*               LISTEN      1001       87078      8050/io.sonoff.0
                tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        944        320/systemd-resolve
                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        950        320/systemd-resolve
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       62525      4511/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61674      4511/iobroker.js-co
                tcp        0      0 192.168.178.12:22       0.0.0.0:*               LISTEN      0          998        394/sshd: /usr/sbin
                tcp        0      0 192.168.178.12:80       0.0.0.0:*               LISTEN      0          13414      493/nginx: master p
                tcp        0      0 192.168.174.12:22       0.0.0.0:*               LISTEN      0          996        394/sshd: /usr/sbin
                tcp        0      0 192.168.178.12:443      0.0.0.0:*               LISTEN      0          13412      493/nginx: master p
                tcp6       0      0 :::3000                 :::*                    LISTEN      111        13546      525/grafana
                tcp6       0      0 :::5355                 :::*                    LISTEN      102        947        320/systemd-resolve
                tcp6       0      0 fd00::da3a:ddff:fe3:443 :::*                    LISTEN      0          13413      493/nginx: master p
                tcp6       0      0 fd00::da3a:ddff:fe37:80 :::*                    LISTEN      0          13415      493/nginx: master p
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62602      4550/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       88461      8156/io.web.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      110        13436      466/influxd
                udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        949        320/systemd-resolve
                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       78573      8014/io.mihome-vacu
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       88475      8084/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       88476      8084/io.tuya.0
                udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        943        320/systemd-resolve
                udp6       0      0 fe80::da3a:ddff:fe3:546 :::*                                101        481293     179/systemd-network
                udp6       0      0 :::5355                 :::*                                102        946        320/systemd-resolve
                2023-10-04 08:47:37.093  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
                2023-10-04 08:49:07.681  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
                2023-10-04 08:49:07.682  - error: zigbee.0 (49242) Failed to start Zigbee
                2023-10-04 08:49:07.683  - error: zigbee.0 (49242) Error herdsman start
                2023-10-04 08:49:17.685  - info: zigbee.0 (49242) Try to reconnect.
                2023-10-04 08:49:17.686  - info: zigbee.0 (49242) Starting Zigbee  npm ...
                2023-10-04 08:49:17.693  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
                2023-10-04 08:51:42.121  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                2023-10-04 08:51:42.123  - error: zigbee.0 (49242) Failed to start Zigbee
                2023-10-04 08:51:42.124  - error: zigbee.0 (49242) Error herdsman start
                2023-10-04 08:51:52.129  - info: zigbee.0 (49242) Try to reconnect.
                2023-10-04 08:51:52.131  - info: zigbee.0 (49242) Starting Zigbee  npm ...
                2023-10-04 08:51:52.138  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
                2023-10-04 08:53:13.428  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
                2023-10-04 08:53:13.429  - error: zigbee.0 (49242) Failed to start Zigbee
                2023-10-04 08:53:13.430  - error: zigbee.0 (49242) Error herdsman start
                2023-10-04 08:53:23.432  - info: zigbee.0 (49242) Try to reconnect.
                2023-10-04 08:53:23.433  - info: zigbee.0 (49242) Starting Zigbee  npm ...
                2023-10-04 08:53:23.442  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
                2023-10-04 08:53:48.737  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
                2023-10-04 08:53:48.755  - error: zigbee.0 (49242) Failed to start Zigbee
                2023-10-04 08:53:48.756  - error: zigbee.0 (49242) Error herdsman start
                2023-10-04 08:53:58.759  - info: zigbee.0 (49242) Try to reconnect.
                2023-10-04 08:53:58.760  - info: zigbee.0 (49242) Starting Zigbee  npm ...
                2023-10-04 08:53:58.777  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
                iob diag has finished.
                Press any key for a summary
                Copy text starting here:
                		     v.2023-06-20
                         Icon name: computer
                      Architecture: arm64
                Installation: 		native
                Kernel: 		aarch64
                Userland: 		arm64
                Timezone: 		Europe/Berlin (CEST, +0200)
                User-ID: 		0
                X-Server: 		false
                Pending OS-Updates: 	0
                Pending iob updates: 	0
                Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.0
                			/usr/bin/npm 		10.1.0
                			/usr/bin/npx 		10.1.0
                Recommended versions are nodejs 18.x.y and npm 9.x.y
                MEMORY:
                Mem:            3.8G        2.1G        456M        114M        1.3G        1.6G
                Swap:             0B          0B          0B
                Total:          3.8G        2.1G        456M
                Active iob-Instances: 	21
                ioBroker Core: 		js-controller 		5.0.12
                			admin 			6.10.4
                ioBroker Status: 	iobroker is running on this host.
                Objects type: jsonl
                States  type: jsonl
                Objects: 		6543
                States: 		6142
                Size of iob-Database:
                9.6M	/opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===
                arteck ? 2 Replies Last reply Reply Quote 0
                  @papa_aus_rastatt
                    @arteck Ich habe scheinbar die Anleitung nicht richtig verstanden. In was müsste das geändert werden?
                    https://zigbee.blakadder.com/Sonoff_ZBBridge-P.html
                      Moin,
                      da ist einiges, was man verbessern könnte/muss.
                      Es fehlt ein User, der nicht root ist, denn wenn Du mit root arbeitest, dann kann man ganz schnell mal ungewollt etwas zerschießen, also leg Dir einen persönlichen User an, installier sudo und gib Deinem persönlichen User, zusätzlich die Gruppen sudo und iobroker.
                      root
                      /root
                      root
                      Memory ist aktuell noch kein Problem, könnte aber zu einem werden, wenn Du Dein System ausbaust.
                      *** MEMORY ***
                      Ansonsten sehe ich da erst einmal nichts, was auf Probleme hinsichtlich zigbee hindeuten würde.
                      VG
                      Bernd
                        A Former User @Guest last edited by A Former User
                        Moin,
                        wollte ich gestern schon, anmerken, hab es im Trubel aber verpennt.
                        VG
                        Bernd
                        Edit
                        hatte heute Morgen wohl zittrige Hände, oder den Schlaf noch nicht aus den Augen gerieben, falsches Bild, ersetzt, siehe auch Beitrag https://forum.iobroker.net/topic/68795/anleitung-zigbee2mqtt-einrichtung-im-iobroker/21?_=1696399590830 von @arteck
                          änder das mal nach ezsp und im adapter auch..aus meinem ersten screenshot..
                          der Sender muss zum adaptereinstellung passen.. da der Coordinator mehrere simulieren kann. musst du schauen..
                          am besten .. was wir im Adapter haben. und dann im coordinator einstellen
                          zigate würde auch gehen... dann bei uns auch zigate einstellen
                            @arteck
                            ezsp dürfte auch nicht gehen, ich habe hier ja die PRO-Ausführung, nicht die normale.
                            https://zigbee.blakadder.com/Sonoff_ZBBridge.html
                            11883
