      DPO99 last edited by
      @simatec
      Fehler trat heute leider wieder auf. Sehr komisch...schreiben kann er die Backups aber löschen teilweise nicht...
      2023-10-01 23:00:10.034 - debug: backitup.0 (929) The local storage check was completed successfully. On the host "iobroker" are currently 24128 MB free space available!
      2023-10-01 23:00:10.036 - debug: backitup.0 (929) Backup has started ...
      2023-10-01 23:00:20.037 - debug: backitup.0 (929) [iobroker/mount] noserverino option: false
      2023-10-01 23:00:20.038 - debug: backitup.0 (929) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
      2023-10-01 23:00:20.234 - debug: backitup.0 (929) [iobroker/mount] mount successfully completed
      2023-10-01 23:00:20.236 - debug: backitup.0 (929) [iobroker/mount] done
      2023-10-01 23:00:23.555 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3030 states saved
      2023-10-01 23:00:26.328 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3545 objects saved
      2023-10-01 23:00:30.484 - debug: backitup.0 (929) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_01-23_00_20_backupiobroker.tar.gz
      2023-10-01 23:00:34.701 - debug: backitup.0 (929) [iobroker/iobroker] done
      2023-10-01 23:00:35.604 - debug: backitup.0 (929) [iobroker/historyDB] compress from historyDB started ...
      2023-10-01 23:00:38.610 - debug: backitup.0 (929) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_10_01-23_00_35_backupiobroker.tar.gz
      2023-10-01 23:00:38.611 - debug: backitup.0 (929) [iobroker/historyDB] done
      2023-10-01 23:00:39.523 - debug: backitup.0 (929) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      2023-10-01 23:00:39.646 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
      2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
      2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
      2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
      2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Schaltung_openDTU
      2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Notabschaltung___Alarm
      2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
      2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
      2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akku_Balancing
      2023-10-01 23:00:39.649 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Luftentfeuchter
      2023-10-01 23:00:39.649 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Raspberry_PI
      2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: OpenDTU
      2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HM_WR_Keller
      2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akkuladung_100
      2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Jahresverbrauch
      2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: TEST
      2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Test_Hama
      2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HM_WR_Garage
      2023-10-01 23:00:39.771 - debug: backitup.0 (929) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      2023-10-01 23:00:39.801 - debug: backitup.0 (929) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      2023-10-01 23:00:39.802 - debug: backitup.0 (929) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_01-23_00_39_backupiobroker.tar.gz
      2023-10-01 23:00:39.802 - debug: backitup.0 (929) [iobroker/javascripts] done
      2023-10-01 23:00:40.555 - debug: backitup.0 (929) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
      2023-10-01 23:00:40.555 - debug: backitup.0 (929) [iobroker/cifs] done
      2023-10-01 23:00:41.157 - error: backitup.0 (929) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      2023-10-01 23:00:41.158 - debug: backitup.0 (929) [iobroker/clean] done
      2023-10-01 23:00:42.364 - debug: backitup.0 (929) [iobroker/historyHTML] new history html values created
      2023-10-01 23:00:42.421 - debug: backitup.0 (929) [iobroker/historyHTML] done
      2023-10-01 23:00:42.611 - debug: backitup.0 (929) [iobroker/historyJSON] new history json values created
      2023-10-01 23:00:42.612 - debug: backitup.0 (929) [iobroker/historyJSON] done
      2023-10-01 23:00:42.781 - debug: backitup.0 (929) [iobroker/umount] mount activ, umount is started ...
      2023-10-01 23:00:47.829 - debug: backitup.0 (929) [iobroker/umount] umount successfully completed
      2023-10-01 23:00:47.830 - debug: backitup.0 (929) [iobroker/umount] done
      2023-10-01 23:00:47.980 - debug: backitup.0 (929) [iobroker] exec: done
      • simatec
        simatec Developer Most Active @DPO99 last edited by
        @dpo99 Was hast du für ein NAS?
          DPO99 @simatec last edited by DPO99
          @simatec
          Synology DS220+. Hat Backitup ggf ein Problem, wenn der Speicher aus dem Standby nicht 100% online ist? Ich schalte den um 23h ein (zeitgleich startet auch das Backup). Aber schreiben konnte er ja immer...hm
          Thomas Braun Siggi0904 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @DPO99 last edited by
            @dpo99 sagte in Test Adapter ioBroker.backitup v2.8.x:
            Dann mach das mal um ein paar Minuten versetzt...
            • Siggi0904
              Siggi0904 @DPO99 last edited by
              @dpo99 naja, gib dem NAS nach dem Hochfahren ruhig 15-30 Minuten.
              Denn nach dem Aufwachen hat das NAS viel zu tun.
              • I
                ichderarnd last edited by ichderarnd
                Mir ist heute aufgefallen, dass backitup in meiner Umgebung seit einem Monat keine Sicherungen mehr ablegt. Sicherungsziel ist eine Freigabe auf einem Windows 10 PC (also kein Fritzbox Problem). Der Befehl, den backitup für das Mounten des Verzeichnisses erstellt lautet:
                sudo mount -t cifs -o username=PiBackup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //srv02/Backups/ioBroker /opt/iobroker/backups
                Wenn ich den identischen Befehl in der Shell mit dem Passwort z.B. '$passwort$' statt der **** ausführe, funktioniert das Mounten.
                Ich habe dann in den ioBroker backitup Einstellungen als Passwort spaßeshalber mal das Passwort mit den Anführungszeichen eingegeben und siehe da, es funktioniert wieder.
                Hat sich an dieser Stelle in letzter Zeit etwas im Adapter geändert? Ich vermute, das $ im Passwort ist Ursache des Problems. Aber Sonderzeichen im Passwort sollten ja möglich sein.
                Ich habe jetzt nicht probiert, über das Passwort Code zu injezieren. Würde vermutlich möglich sein.
                  DPO99 @Thomas Braun last edited by
                  Habe das Backup mal versetzt (kurze Korrektur noch, der Speicher ist nicht AUS sondern immer im Standby). Um 23h wird er dennoch jeden Tag aufgeweckt, sollte er im Standy sein. Fehler trat leider trotzdem auf:
                  2023-10-03 23:10:10.038 - debug: backitup.0 (495265) The local storage check was completed successfully. On the host "iobroker" are currently 24113 MB free space available!
                  2023-10-03 23:10:10.113 - debug: backitup.0 (495265) Backup has started ...
                  2023-10-03 23:10:10.124 - debug: backitup.0 (495265) [iobroker/mount] mount activ... umount is started before mount!!
                  2023-10-03 23:10:10.189 - debug: backitup.0 (495265) [iobroker/mount] umount successfully completed
                  2023-10-03 23:10:20.113 - debug: backitup.0 (495265) [iobroker/mount] noserverino option: false
                  2023-10-03 23:10:20.114 - debug: backitup.0 (495265) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
                  2023-10-03 23:10:20.263 - debug: backitup.0 (495265) [iobroker/mount] mount successfully completed
                  2023-10-03 23:10:20.266 - debug: backitup.0 (495265) [iobroker/mount] done
                  2023-10-03 23:10:23.725 - debug: backitup.0 (495265) [iobroker/iobroker] host.iobroker 3044 states saved
                  2023-10-03 23:10:26.296 - debug: backitup.0 (495265) [iobroker/iobroker] host.iobroker 3561 objects saved
                  2023-10-03 23:10:30.405 - debug: backitup.0 (495265) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_03-23_10_20_backupiobroker.tar.gz
                  2023-10-03 23:10:32.496 - debug: backitup.0 (495265) [iobroker/iobroker] done
                  2023-10-03 23:10:33.401 - debug: backitup.0 (495265) [iobroker/historyDB] compress from historyDB started ...
                  2023-10-03 23:10:37.349 - debug: backitup.0 (495265) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_10_03-23_10_33_backupiobroker.tar.gz
                  2023-10-03 23:10:37.350 - debug: backitup.0 (495265) [iobroker/historyDB] done
                  2023-10-03 23:10:38.270 - debug: backitup.0 (495265) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                  2023-10-03 23:10:38.402 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
                  2023-10-03 23:10:38.405 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
                  2023-10-03 23:10:38.406 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
                  2023-10-03 23:10:38.406 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
                  2023-10-03 23:10:38.407 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Schaltung_openDTU
                  2023-10-03 23:10:38.408 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Notabschaltung___Alarm
                  2023-10-03 23:10:38.408 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
                  2023-10-03 23:10:38.409 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
                  2023-10-03 23:10:38.409 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Akku_Balancing
                  2023-10-03 23:10:38.410 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Luftentfeuchter
                  2023-10-03 23:10:38.411 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Raspberry_PI
                  2023-10-03 23:10:38.411 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: OpenDTU
                  2023-10-03 23:10:38.412 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: HM_WR_Keller
                  2023-10-03 23:10:38.412 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Akkuladung_100
                  2023-10-03 23:10:38.421 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Jahresverbrauch
                  2023-10-03 23:10:38.423 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: TEST
                  2023-10-03 23:10:38.424 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Test_Hama
                  2023-10-03 23:10:38.436 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: HM_WR_Garage
                  2023-10-03 23:10:38.555 - debug: backitup.0 (495265) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                  2023-10-03 23:10:38.583 - debug: backitup.0 (495265) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                  2023-10-03 23:10:38.584 - debug: backitup.0 (495265) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_03-23_10_38_backupiobroker.tar.gz
                  2023-10-03 23:10:38.584 - debug: backitup.0 (495265) [iobroker/javascripts] done
                  2023-10-03 23:10:39.337 - debug: backitup.0 (495265) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
                  2023-10-03 23:10:39.337 - debug: backitup.0 (495265) [iobroker/cifs] done
                  2023-10-03 23:10:39.941 - error: backitup.0 (495265) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                  2023-10-03 23:10:39.941 - debug: backitup.0 (495265) [iobroker/clean] done
                  2023-10-03 23:10:41.167 - debug: backitup.0 (495265) [iobroker/historyHTML] new history html values created
                  2023-10-03 23:10:41.229 - debug: backitup.0 (495265) [iobroker/historyHTML] done
                  2023-10-03 23:10:41.418 - debug: backitup.0 (495265) [iobroker/historyJSON] new history json values created
                  2023-10-03 23:10:41.419 - debug: backitup.0 (495265) [iobroker/historyJSON] done
                  2023-10-03 23:10:41.589 - debug: backitup.0 (495265) [iobroker/umount] mount activ, umount is started ...
                  2023-10-03 23:10:46.641 - debug: backitup.0 (495265) [iobroker/umount] umount successfully completed
                  2023-10-03 23:10:46.642 - debug: backitup.0 (495265) [iobroker/umount] done
                  2023-10-03 23:10:46.794 - debug: backitup.0 (495265) [iobroker] exec: done
                  • simatec
                    @dpo99 Kann dein NAS WOL? Vielleicht sollte das deine Lösung sein.
                    Backitup kann über WOL dein NAS wecken...
                    Homoran D 2 Replies Last reply Reply Quote 0
                      Homoran Global Moderator Administrators @simatec last edited by
                      @simatec
                      Ist inzwischen das CCU Backup nicht mehr über backitup abrufbar?
                      hab in Doku und Forum nichts gefunden und erst mal eigenen Thread aufgemacht
                      https://forum.iobroker.net/topic/68753/backitup-findet-ccu-backups-nicht-mehr/1
                      • simatec
                        @homoran sagte in Test Adapter ioBroker.backitup v2.8.x:
                        War schon immer so Rainer 😉
                        https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#restore
                          @simatec
                          Die DS220+ kann WOL aber ich glaube nicht, dass das das Problem ist. Die Backups können ja geschrieben werden, nur löschen ist ein Problem. Zusätzlich befindet sich der NAS ja nur im Standby. Also sobald ein Request an die IP geht, startet der Speicher ja. Ich lege das Backup jetzt testweise mal noch auf eine ganz andere Zeit, nicht, dass der Speicher genau um 23:00/23:10 irgendwie anderweitig beschäftigt ist (aber das ist auch nur fischen im trüben).
                          • simatec
                            @dpo99 Ich würde an deiner Stelle mal NFS versuchen. Dein NAS kann das und es macht hier in deiner Config mehr Sinn.. Denke da ist irgendwas in deiner Config auf dem NAS krum, dass Backitup nicht ausreichend Rechte hat.
                              @simatec
                              Ich habe mal eine zweite Instanz erstellt und die Backups sind nun in 2 Ordnern aber im CIFS und NFS Pfad dann jeweils gleich. Dann kann ich mal beobachten, ob sich beide identisch verhalten oder nur eine Verbindung quatsch macht.
                                DPO99 @DPO99 last edited by DPO99
                                @simatec
                                Beim prüfen der Einstellungen bin ich im Reiter "Extra-Einstellungen" mal wieder über den Punkt "Anzahl der History Einträge" gestolpert. Habe dazu leider keine Infos finden können. Was genau sagt denn der Eintrag (0-50) hier eigentlich aus? Danke!
                                • simatec
                                  @dpo99 die sind für den History State und haben nur eine Relevanz für VIS und das Tab Menü
                                    @simatec
                                    Irgendwie steckt der Wurm drin.....wollte das ganze ja jetzt mit 2 Instanzen testen aber plötzlich läuft das NFS nicht mehr....ist das so korrekt? Mir scheint, als ob er da auf einen falschen Pfad mounten will...
                                    backitup.1 2023-10-06 07:56:55.612	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                                    backitup.1 2023-10-06 07:56:55.605	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                                    backitup.1 2023-10-06 07:56:05.606	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                                    backitup.12023-10-06 07:56:05.599	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                                    backitup.1 2023-10-06 07:55:29.831	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                                    backitup.1 2023-10-06 07:55:29.823	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                                    backitup.1 2023-10-06 07:55:12.698	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                                    backitup.1 2023-10-06 07:55:12.691	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                                    backitup.1 2023-10-06 07:54:45.483	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                                    backitup.1 2023-10-06 07:54:45.476	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                                    Nach X Versuchen hat er es dann geschafft und korrekt gemountet:
                                    backitup.1 2023-10-06 08:00:35.812	debug	mount successfully completed
                                    backitup.1 2023-10-06 08:00:35.745	debug	device is busy... wait 2 Minutes!!
                                    backitup.1 2023-10-06 08:00:35.696	debug	Backup list be read ...
                                    backitup.1 2023-10-06 08:00:35.681	debug	nfs-mount command: "sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backups"
                                    backitup.1 2023-10-06 08:00:32.442	debug	The local storage check was completed successfully. On the host "iobroker" are currently 24114 MB free space available!
                                    Ist es ein Problem, wenn es parallel 2 Instanzen mit einmal CIFS und NFS gibt? Ich habe manchmal das gefühl, dass da nach dem Anzeigen der vorhandenen Backups ein "unmount" fehlt.
                                    Gleiches "unmountproblem" passiert dann auch in der .0, wenn ich vorher in der .1 die aktuellen Backups eingesehen habe:
                                    backitup.0 2023-10-06 08:03:20.209	debug	mount successfully completed
                                    backitup.0 2023-10-06 08:03:20.075	debug	Backup list be read ...
                                    backitup.0 2023-10-06 08:03:20.065	debug	cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5Backup_IoBroker/Backup /opt/iobroker/backups"
                                    backitup.0 2023-10-06 08:03:20.065	debug	noserverino option: false
                                    backitup.0 2023-10-06 08:02:31.832	error	[iobroker] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                    backitup.0 2023-10-06 08:02:31.831	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                    backitup.0 2023-10-06 08:02:31.830	error	[iobroker/mount] mount error(16): Device or resource busy
                                    backitup.0 2023-10-06 08:02:31.830	error	[iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups
                                    backitup.0 2023-10-06 08:02:31.829	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                    backitup.0 2023-10-06 08:02:31.828	error	[iobroker/mount] mount error(16): Device or resource busy
                                    backitup.0 2023-10-06 08:02:31.827	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups
                                    backitup.0 2023-10-06 08:02:31.679	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
                                    • simatec
                                      @dpo99 Ein gleichzeitiges Mount macht Probleme... Bitte erst den umount laufen lassen, bevor du versuchst einen weiteren Mount in /opt/iobroker/backups zu setzen
                                      • hg6806
                                        hg6806 Most Active last edited by
                                        Moin!
                                        Ich habe noch einige Verständnisprobleme mit der Speicherung auf Google Drive.
                                        Den Link zum Autorisieren habe ich ausgeführt.
                                        Wie geht es nun weiter?
                                        Welchen Link trage ich unten ein? Den eigenen oder den von der Autorisierung?
                                        Und wie komme ich an die Daten dann wieder ran?
                                        • simatec
                                          simatec Developer Most Active @hg6806 last edited by
                                          @hg6806 Du bekommst nach der Autorisierung einen Token im Browser angezeigt... Dieser muss eingefügt werden.
                                          • hg6806
                                            hg6806 Most Active @simatec last edited by
                                            @simatec
                                            Ok, danke
                                            Und wie und wo sehe ich dann die Backup-Daten?
                                            170
                                            2780
                                            2369137
