    3. Off Topic
    4. Upgrade von Debian 10 'Buster' auf 11 'Bullseye'
      Thomas Braun Most Active @Supernils last edited by
      @supernils
      Vollständig lesen, inkl. der Ergänzungen im letzten Absatz.
      Der ist besonders wichtig für dein 32bit-RaspberryOS.
      https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev?_=1696419855987
        pi@raspberrypi4-iobroker:/etc/apt/sources.list.d $ sudo apt update
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 https://deb.nodesource.com/node_18.x bullseye InRelease
        Get:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease [58.5 kB]
        Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Err:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        Reading package lists... Done
        W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
          @supernils sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
          0E98404D386FA1D9
          Zieh den key rein. Steht glaube ich auch in dem HowTo drin, wie man das macht.
            Supernils @Thomas Braun last edited by
            @thomas-braun Ah verstanden. Hier stimmt doch etwas nicht oder? 🙂
            Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
            Building dependency tree... Done
            39 packages can be upgraded. Run 'apt list --upgradable' to see them.
            pi@raspberrypi4-iobroker:/etc/apt/sources.list.d $ sudo apt -t bullseye-proposed-updates install udev
            udev is already the newest version (247.3-7+rpi1+deb11u2).
            0 upgraded, 0 newly installed, 0 to remove and 55 not upgraded.
              Thomas Braun Most Active @Supernils last edited by Thomas Braun
              @supernils
              apt policy udev
              sagt? Der 'Trick' ist, die "niedrigere" Versionsnummer zu installieren:
              sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
              Danach die frisch angelegte Quelle wieder löschen.
                Supernils @Thomas Braun last edited by Supernils
                @thomas-braun said in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
                pi@raspberrypi4-iobroker:/etc/apt/sources.list.d $ apt policy udev
                udev:
                  Installed: 247.3-7+rpi1+deb11u2
                  Candidate: 247.3-7+rpi1+deb11u2
                  Version table:
                 *** 247.3-7+rpi1+deb11u2 500
                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                        100 /var/lib/dpkg/status
                     247.3-7+deb11u4 500
                        500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
                  @supernils
                  Siehe vorstehende Antwort.
                    @thomas-braun Vielen Dank
                      @supernils
                      udev auf hold gesetzt und die proposed-Quelle wieder gelöscht?
                      sudo apt update
                      sagt nun?
                        sudo apt update
                        pi@raspberrypi4-iobroker:~ $ sudo apt-mark hold udev
                        udev set on hold.
                        pi@raspberrypi4-iobroker:~ $ sudo apt update
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          @supernils
                          Ja, passt.
                            Bibo*13 last edited by
                            Hallo zusammen. Ich benötige Hilfe.
                            Anfangs lief es ganz gut aber dann:
                            nach sudo apt install gcc-8-base
                            kommt das und nach dem : bleibt es stehen
                            was kann ich tun? Der Pi läuft ohne sd-card mit ssd drive
                            Gruß Bibo
                              Thomas Braun Most Active @Bibo*13 last edited by
                              @bibo-13 sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
                              was kann ich tun?
                              Mit der Taste q die Anzeige verlassen.
                                Bibo*13 @Thomas Braun last edited by
                                @thomas-braun Danke. Wie geht es dann weiter?
                                  Thomas Braun Most Active @Bibo*13 last edited by Thomas Braun
                                  @bibo-13
                                  Wie in der Anleitung.
                                  Hättest du überhaupt die Meldung, die eine Installation von gcc-8-base erforderlich macht? Oder einfach mal auf Verdacht installiert?
                                    @thomas-braun ich hatte die Meldung. Deshalb habe ich auch den Befehl ausgeführt.
                                    Im Moment läuft die Inst nach sudo apt update und sudo apt full-upgrade
                                      @thomas-braun Ich bin durch. Das System rennt wieder.
                                      Danke für Deinen Support
                                        mp3junkie last edited by
                                        @thomas-braun sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
                                        Vorsichtshalber schauen wir noch in den dhcpd.service rein.
                                        sudo nano /etc/systemd/system/dhcpcd.service.d/wait.conf
                                        kann es sein, dass die Konfigurationsdatei erst nach dem Upgrade vorhanden ist?
                                          Thomas Braun Most Active @mp3junkie last edited by
                                          @mp3junkie
                                          Möglich. Allerdings ist 'Bullseye' auch bereits abgekündigt, es ergibt also wenig Sinn das heute zu unternehmen.
                                          ? M 2 Replies Last reply Reply Quote 0
                                            A Former User @Thomas Braun last edited by
                                            @Homoran
                                            Man koennte diesen Thread auch schliessen, bzw die Kommentarfunktion rausnehmen.
                                            War damals ne schoene Anleitung, aber in Zeiten von Bookworm nicht mehr notwendig und schon garnicht mehr Sinnvoll.
                                            309
                                            82784
