    3. Off Topic
    4. Upgrade von Debian 10 'Buster' auf 11 'Bullseye'
      Supernils last edited by
      pi@raspberrypi4-iobroker:/etc/apt/sources.list.d $ sudo apt update
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 https://deb.nodesource.com/node_18.x bullseye InRelease
      Get:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease [58.5 kB]
      Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Err:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
      Reading package lists... Done
      W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
      E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
        Thomas Braun Most Active @Supernils last edited by
        @supernils sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
        0E98404D386FA1D9
        Zieh den key rein. Steht glaube ich auch in dem HowTo drin, wie man das macht.
          Supernils @Thomas Braun last edited by
          @thomas-braun Ah verstanden. Hier stimmt doch etwas nicht oder? 🙂
          Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
          Building dependency tree... Done
          39 packages can be upgraded. Run 'apt list --upgradable' to see them.
          pi@raspberrypi4-iobroker:/etc/apt/sources.list.d $ sudo apt -t bullseye-proposed-updates install udev
          udev is already the newest version (247.3-7+rpi1+deb11u2).
          0 upgraded, 0 newly installed, 0 to remove and 55 not upgraded.
            Thomas Braun Most Active @Supernils last edited by Thomas Braun
            @supernils
            apt policy udev
            sagt? Der 'Trick' ist, die "niedrigere" Versionsnummer zu installieren:
            sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
            Danach die frisch angelegte Quelle wieder löschen.
              Supernils @Thomas Braun last edited by Supernils
              @thomas-braun said in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
              pi@raspberrypi4-iobroker:/etc/apt/sources.list.d $ apt policy udev
              udev:
                Installed: 247.3-7+rpi1+deb11u2
                Candidate: 247.3-7+rpi1+deb11u2
                Version table:
               *** 247.3-7+rpi1+deb11u2 500
                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                      100 /var/lib/dpkg/status
                   247.3-7+deb11u4 500
                      500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
                @supernils
                Siehe vorstehende Antwort.
                  @thomas-braun Vielen Dank
                    @supernils
                    udev auf hold gesetzt und die proposed-Quelle wieder gelöscht?
                    sudo apt update
                    sagt nun?
                      sudo apt update
                      pi@raspberrypi4-iobroker:~ $ sudo apt-mark hold udev
                      udev set on hold.
                      pi@raspberrypi4-iobroker:~ $ sudo apt update
                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                        @supernils
                        Ja, passt.
                          Bibo*13 last edited by
                          Hallo zusammen. Ich benötige Hilfe.
                          Anfangs lief es ganz gut aber dann:
                          nach sudo apt install gcc-8-base
                          kommt das und nach dem : bleibt es stehen
                          was kann ich tun? Der Pi läuft ohne sd-card mit ssd drive
                          Gruß Bibo
                            Thomas Braun Most Active @Bibo*13 last edited by
                            @bibo-13 sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
                            was kann ich tun?
                            Mit der Taste q die Anzeige verlassen.
                              Bibo*13 @Thomas Braun last edited by
                              @thomas-braun Danke. Wie geht es dann weiter?
                                Thomas Braun Most Active @Bibo*13 last edited by Thomas Braun
                                @bibo-13
                                Wie in der Anleitung.
                                Hättest du überhaupt die Meldung, die eine Installation von gcc-8-base erforderlich macht? Oder einfach mal auf Verdacht installiert?
                                  @thomas-braun ich hatte die Meldung. Deshalb habe ich auch den Befehl ausgeführt.
                                  Im Moment läuft die Inst nach sudo apt update und sudo apt full-upgrade
                                    @thomas-braun Ich bin durch. Das System rennt wieder.
                                    Danke für Deinen Support
                                      mp3junkie last edited by
                                      @thomas-braun sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
                                      Vorsichtshalber schauen wir noch in den dhcpd.service rein.
                                      sudo nano /etc/systemd/system/dhcpcd.service.d/wait.conf
                                      kann es sein, dass die Konfigurationsdatei erst nach dem Upgrade vorhanden ist?
                                        Thomas Braun Most Active @mp3junkie last edited by
                                        @mp3junkie
                                        Möglich. Allerdings ist 'Bullseye' auch bereits abgekündigt, es ergibt also wenig Sinn das heute zu unternehmen.
                                        ? M 2 Replies Last reply Reply Quote 0
                                          A Former User @Thomas Braun last edited by
                                          @Homoran
                                          Man koennte diesen Thread auch schliessen, bzw die Kommentarfunktion rausnehmen.
                                          War damals ne schoene Anleitung, aber in Zeiten von Bookworm nicht mehr notwendig und schon garnicht mehr Sinnvoll.
                                            mp3junkie @Thomas Braun last edited by
                                            @mp3junkie
                                            Ich bin noch auf Buster unterwegs. Deshalb meine Frage.
                                            Ich wollte zunächst zu Bullseye und dann zu Bookworm.
                                            Schritt für Schritt.
                                            309
                                            82762
