    4. VIS 2 update auf 2.3.0 keine Widgets mehr
      edi1975 @Feuersturm last edited by
      @feuersturm
      2023-10-04 21:05:48.555  - warn: host.iobroker startInstance cannot find adapter "vis-2@2.2.7". Try to install it... 4 attempt
      2023-10-04 21:05:48.555  - info: host.iobroker iobroker install vis-2@2.2.7 using installedVersion
      2023-10-04 21:05:48.689  - info: zigbee2mqtt.0 (122916) MQTT publish: topic 'zigbee2mqtt/Steckdose Gewekshaus', payload '{"child_lock":"UNLOCK","current":0,"energy":24.48,"indicator_mode":"off/on","last_seen":"2023-10-04T21:05:37+02:00","linkquality":83,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":231}'
      2023-10-04 21:05:48.702  - info: zigbee2mqtt.0 (122916) MQTT publish: topic 'zigbee2mqtt/Steckdose Gewekshaus', payload '{"child_lock":"UNLOCK","current":0,"energy":24.48,"indicator_mode":"off/on","last_seen":"2023-10-04T21:05:37+02:00","linkquality":83,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":231}'
      2023-10-04 21:05:50.188  - info: web.0 (122776) ==> Connected system.user.admin from ::ffff:192.168.178.12
      2023-10-04 21:05:52.132  - error: host.iobroker iobroker npm-install: host.iobroker Unknown packetName vis-2. Please install packages from outside the repository using npm!
      2023-10-04 21:05:53.180  - info: host.iobroker iobroker npm-install: exit 12
      2023-10-04 21:05:53.484  - error: host.iobroker Cannot download and install adapter "vis-2@2.2.7". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        edi1975 @Feuersturm last edited by edi1975
        @feuersturm
        host.iobroker
        2023-10-04 21:05:53.484	error	Cannot download and install adapter "vis-2@2.2.7". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        host.iobroker
        2023-10-04 21:05:52.132	error	iobroker npm-install: host.iobroker Unknown packetName vis-2. Please install packages from outside the repository using npm!
        • Feuersturm
          Feuersturm @edi1975 last edited by Feuersturm
          @edi1975 Lösch doch einfach mal deinen vis-2 Adapter und installiere ihn so über den Admin (falls du im stable repository unterwegs bist, alternativ bei den Adaptern einfach nach vis-2 suchen)
          Was sagt die Langfassung von iob diag auf der Konsole?
          • Glasfaser
            Glasfaser @edi1975 last edited by
            @edi1975 sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
            Falscher Befehl !
            So :
            Wie wird es aktualisiert?
            Wenn es im Rahmen der Tests neue Versionen gibt werden diese ebenfalls manuell installiert. Die Befehle sind dann (hier am Beispiel des Haupt-Paketes - ist dann identisch für die anderen):
            cd /opt/iobroker
            npm i iobroker.vis-2-beta@latest
            iob upload vis-2-beta
            Feuersturm sigi234 2 Replies Last reply Reply Quote 0
            • Feuersturm
              Feuersturm @Glasfaser last edited by
              @glasfaser sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
              Falscher Befehl !
              vis-2-beta wird doch nicht mehr weiter entwickelt. Die Entwicklung findet jetzt über den vis-2 Adapter statt (siehe https://forum.iobroker.net/topic/67676/vis-2-0-neuer-adapter-als-beta)
              Glasfaser 1 Reply Last reply Reply Quote 1
                sigi234 Forum Testing Most Active @Glasfaser last edited by sigi234
                Falscher Befehl !
                So :
                Auch Falsch!
                Zitat:
                Damit gesagt ist vis-2 als neuer Adapter seit ein paar Tagen im beta Repository und vis2-beta ist nicht mehr verfügbar und bekommt auch keine Updates mehr.
                • Glasfaser
                  Glasfaser @Feuersturm last edited by
                  @feuersturm
                  @sigi234
                  OK , habe nur die Fehlermeldung von @edi1975 gesehen mit :
                  und da ich noch nicht vis-2 nutze , habe ich noch die Alpha im Kopf gehabt 😉
                    @feuersturm
                    Gelöscht neu installiert und ist alles wider da.
                    Warum Backup Wiederherstellung hat nicht das Geschäft?
                    Danke für Hilfe.
                    • Feuersturm
                      Gute Frage. Hierzu müsste man tiefer abtauchen. Wie hast du dein Backup gemacht, wie hast du es zurück gespielt. War das Backup auf der gleichen Version vom js-controller?
                      E 2 Replies Last reply Reply Quote 0
                        @feuersturm
                        über Backup Adapter
                          @feuersturm sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
                          Ja
                          • Feuersturm
                            @edi1975 Dann solltest du mal deine Backups testen ob sie sich wiederherstellen lassen oder ob du das Problem reproduzieren kannst.
                              @feuersturm
                              Was ist mit mein ioBroker los?
                              Backup gemacht und sofort wiederherstellt wenn ist fertig alle Adapter sin rot außer Admin und Backup.
                              In Protokolle kommen Meldungen das Adapter nicht gefunden und wird installiert nach lange zeit alles grün außer in VIS-2 alle Wigets sind noch nicht da. Ich habe kein Lust wider ioBroker von 0 anfangen.
                              host.iobroker 2023-10-05 21:13:33.944	warn	startInstance cannot find adapter "heos@2.1.0". Try to install it... 1 attempt
                              host.iobroker 2023-10-05 21:14:21.651	warn	startInstance cannot find adapter "iot@2.0.11". Try to install it... 1 attempt
                              host.iobroker 2023-10-05 21:13:57.892	warn	startInstance cannot find adapter "info@2.0.0". Try to install it... 1 attempt
                              host.iobroker 2023-10-05 21:18:30.082	warn	startInstance cannot find adapter "vis-2-widgets-energy@0.3.8". Try to install it... 1 attempt
                              host.iobroker 2023-10-05 21:19:33.215	warn	startInstance cannot find adapter "vis-2@2.3.0". Try to install it... 1 attempt
                              host.iobroker 2023-10-05 21:28:41.005	warn	startInstance cannot find adapter "web@6.1.2". Try to install it... 1 attempt
                              Feuersturm Glasfaser 2 Replies Last reply Reply Quote 0
                              • Feuersturm
                                @edi1975 Was mit deinem ioBroker los ist weiß ich nicht, die 🔮 ist kaputt 😉
                                Bitte wie oben schon einmal angefordert einmal die Langfassung von iob diag hier in Codetags posten. Dazu auf der SSH Konsole einfach folgendes eingeben:
                                iob diag
                                Eine Wiederherstellung kann lange Zeit >1h in Anspruch nehmen, hier einfach das System in Ruhe lassen und warten bis keine regelmäßigen Updates mehr im Log kommen.
                                Wenn es danach nicht funktioniert, bitte hier mal ein vollständigs Log posten. 4 Zeilen helfen da leider nicht weiter.
                                Ich kann heute Abend parallel mal bei mir testen, ob sich mein System mit vis-2 wieder sauber wiederherstellen lässt.
                                • Glasfaser
                                  Nur eine Empfehlung,
                                  man sollte nicht auf einem produktiven ioBroker es gleich damit versuchen ,
                                  Vis-2 war Alpha , dann aktuell jetzt in Beta also kann immer noch etwas passieren / nicht richtig laufen .
                                  Und wie ich sehe , hast du sonst alles in Stable !
                                    iob diag
                                    OK Repositories ist jetzt auf Beta deswegen Updates zeigt.
                                    *** ioBroker Diagnosis ***
                                    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                    Just copy and paste the Summary Page, including the ``` characters at start and end.
                                    It helps us to help you!
                                    Press any key to continue
                                    Skript v.2023-06-20
                                    *** BASE SYSTEM ***
                                       Static hostname: iobroker
                                             Icon name: computer
                                            Machine ID: 14803bb7a50c4def81086c9b741cdd12
                                               Boot ID: bca142a15bfd4377aef46189724c0809
                                      Operating System: Debian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 6.1.21-v8+
                                          Architecture: arm64
                                    Model		: Raspberry Pi 4 Model B Rev 1.4
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    Systemuptime and Load:
                                     20:08:39 up 23:37,  3 users,  load average: 1.04, 0.85, 0.78
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    Other values than 0x0 hint to temperature/voltage problems
                                    temp=47.7'C
                                    volt=0.9160V
                                    *** Time and Time Zones ***
                                                   Local time: Fri 2023-10-06 20:08:39 CEST
                                               Universal time: Fri 2023-10-06 18:08:39 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** User and Groups ***
                                    edi_admin
                                    /home/edi_admin
                                    edi_admin adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                    *** X-Server-Setup ***
                                    X-Server: 	true
                                    Desktop:
                                    Terminal: 	tty
                                    Boot Target: 	graphical.target
                                    *** MEMORY ***
                                    Mem:            7.8G        3.4G        325M         51M        4.1G        4.2G
                                    Swap:            99M          0B         99M
                                    Total:          7.9G        3.4G        425M
                                             7811 M total memory
                                             3422 M used memory
                                             4783 M active memory
                                             2274 M inactive memory
                                              325 M free memory
                                              295 M buffer memory
                                             3767 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    Filesystem                      Type      Size  Used Avail Use% Mounted on
                                    /dev/root                       ext4      117G  8.3G  103G   8% /
                                    devtmpfs                        devtmpfs  3.6G     0  3.6G   0% /dev
                                    tmpfs                           tmpfs     3.9G     0  3.9G   0% /dev/shm
                                    tmpfs                           tmpfs     1.6G  1.3M  1.6G   1% /run
                                    tmpfs                           tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                                    /dev/sda1                       vfat      251M   31M  220M  13% /boot
                                    tmpfs                           tmpfs     782M   24K  782M   1% /run/user/1000
                                    //192.168.178.7/Backup-ioBroker cifs      2.7T  1.6T  1.2T  58% /opt/iobroker/backups
                                    Show mounted filesystems (real ones only):
                                    TARGET                  SOURCE                          FSTYPE OPTIONS
                                    /                       /dev/sda2                       ext4   rw,noatime,stripe=8191
                                    |-/boot                 /dev/sda1                       vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    `-/opt/iobroker/backups //192.168.178.7/Backup-ioBroker cifs   rw,relatime,vers=3.1.1,cache=strict,username=edi_admin,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.7,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                                    /var:
                                    1.6G	/var/
                                    994M	/var/log
                                    969M	/var/log/journal/14803bb7a50c4def81086c9b741cdd12
                                    288M	/var/cache
                                    Archived and active journals take up 968.0M in the file system.
                                    /opt/iobroker/backups:
                                    1.1G	/opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    697M	/opt/iobroker/iobroker-data/
                                    565M	/opt/iobroker/iobroker-data/files
                                    174M	/opt/iobroker/iobroker-data/files/vis-2
                                    90M	/opt/iobroker/iobroker-data/files/vis
                                    82M	/opt/iobroker/iobroker-data/files/vis/widgets
                                    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                    19M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.d3c12542.js.map
                                    18M	/opt/iobroker/iobroker-data/files/s7.admin/static/js/main.59233a80.js.map
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs 	v18.17.1
                                    /usr/bin/node 		v18.17.1
                                    /usr/bin/npm 		9.6.7
                                    /usr/bin/npx 		9.6.7
                                    nodejs:
                                      Installed: 18.17.1-deb-1nodesource1
                                      Candidate: 18.17.1-deb-1nodesource1
                                      Version table:
                                     *** 18.17.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                            100 /var/lib/dpkg/status
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u3 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    No problems detected
                                    Errors in npm tree: 0
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    No configuration change needed.
                                    Multihost discovery server: disabled
                                    Discovery authentication:   enabled
                                    Persistent activation:      disabled
                                    Objects:                    jsonl on 127.0.0.1
                                    States:                     jsonl on 127.0.0.1
                                    Core adapters versions
                                    js-controller: 	5.0.12
                                    admin: 		6.10.2
                                    javascript: 	7.1.4
                                    Adapters from github: 	2
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                                    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                                    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                                      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                    + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
                                    + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
                                    + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
                                    + system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
                                    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                    + system.adapter.heos.0                   : heos                  : iobroker                                 -  enabled
                                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
                                      system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
                                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                      system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                                    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 1080, bind: 0.0.0.0
                                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.26
                                    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 192.168.178.26
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                                      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                                      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                                      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                                    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                                      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
                                      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                                      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                                      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                                      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                                    + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
                                    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): beta
                                    Installed ioBroker-Instances
                                    Used repository: beta
                                    Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
                                    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                                    Adapter    "awtrix-light" : 0.9.1    , installed 0.8.0  [Updatable]
                                    Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
                                    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
                                    Adapter    "denon"        : 1.15.4   , installed 1.15.4
                                    Adapter    "discovery"    : 4.1.0    , installed 4.0.0  [Updatable]
                                    Adapter    "doorbird"     : 1.3.0    , installed 1.2.4  [Updatable]
                                    Adapter    "ems-esp"      : 2.4.1    , installed 2.4.1
                                    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                                    Adapter    "fhem"         : 2.0.5    , installed 2.0.5
                                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                    Adapter    "heos"         : 2.1.0    , installed 2.1.0
                                    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                    Controller "js-controller": 5.0.12   , installed 5.0.12
                                    Adapter    "lightcontrol" : 0.4.0    , installed 0.4.0
                                    Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                                    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.4  [Updatable]
                                    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                                    Adapter    "s7"           : 1.3.15   , installed 1.3.15
                                    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                                    Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
                                    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                                    Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
                                    Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
                                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
                                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                                    Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                    Adapter    "vis-2"        : 2.3.0    , installed 2.3.0
                                    Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                                    Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                                    Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                                    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                                    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                    Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
                                    Adapter    "wled"         : 0.7.1    , installed 0.7.0  [Updatable]
                                    Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
                                    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                                    Adapter    "zigbee2mqtt"  : 2.13.2   , installed 2.13.1 [Updatable]
                                    Objects and States
                                    Objects: 	10532
                                    States: 	9152
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:5 http://giteduberger.fr rpimonitor/ InRelease
                                    Get:6 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
                                    Update rpimonitor Packages Status
                                    Fetched 4586 B in 2s (2356 B/s)
                                    Reading package lists...
                                    Pending Updates: 25
                                    *** Listening Ports ***
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14269      621/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          16462      677/perl
                                    tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1001       50949      11834/io.sainlogic.
                                    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14323      608/vncserver-x11-c
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       39707      7652/io.mqtt.0
                                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       38242      7247/node-red
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37337      6556/iobroker.js-co
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35603      6556/iobroker.js-co
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          147718     26659/cupsd
                                    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       899600     127695/sshd: edi_ad
                                    tcp        0      0 192.168.178.26:1882     0.0.0.0:*               LISTEN      1001       44141      9171/io.shelly.0
                                    tcp        0      0 192.168.178.26:1884     0.0.0.0:*               LISTEN      1001       43482      9234/io.sonoff.0
                                    tcp        0      0 0.0.0.0:8100            0.0.0.0:*               LISTEN      1001       44736      9976/io.doorbird.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14271      621/sshd: /usr/sbin
                                    tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       899599     127695/sshd: edi_ad
                                    tcp6       0      0 :::61991                :::*                    LISTEN      1001       48183      10269/io.harmony.0
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          147717     26659/cupsd
                                    tcp6       0      0 :::5900                 :::*                    LISTEN      0          14322      608/vncserver-x11-c
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53283      11962/io.simple-api
                                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       52686      12069/io.socketio.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       60297      14019/io.web.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35664      6581/io.admin.0
                                    udp        0      0 0.0.0.0:48671           0.0.0.0:*                           1001       46507      10341/io.heos.0
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16587      504/dhcpcd
                                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       48184      10269/io.harmony.0
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          146869     26662/cups-browsed
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       60919      14089/io.wled.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12112      442/avahi-daemon: r
                                    udp        0      0 0.0.0.0:34211           0.0.0.0:*                           108        12114      442/avahi-daemon: r
                                    udp6       0      0 :::33872                :::*                                108        12115      442/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        12113      442/avahi-daemon: r
                                    2023-10-06 20:10:05.069  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:05.079  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:06.067  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:06.072  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:06.080  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:07.063  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:07.066  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:07.075  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:07.078  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:07.085  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.064  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.065  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.081  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.085  - info: web.0 (14019) ==> Connected system.user.admin from undefined
                                    2023-10-06 20:10:08.089  - info: web.0 (14019) <== Disconnect system.user.admin from undefined
                                    2023-10-06 20:10:08.186  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.188  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.190  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.192  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.193  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.195  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.196  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.197  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:08.200  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                                    2023-10-06 20:10:10.107  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                                    iob diag has finished.
                                    Press any key for a summary
                                    Copy text starting here:
                                    		     v.2023-06-20
                                             Icon name: computer
                                          Architecture: arm64
                                    Installation: 		native
                                    Kernel: 		aarch64
                                    Userland: 		arm64
                                    Timezone: 		Europe/Berlin (CEST, +0200)
                                    User-ID: 		1000
                                    X-Server: 		true
                                    Pending OS-Updates: 	25
                                    Pending iob updates: 	13
                                    Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.1
                                    			/usr/bin/npm 		9.6.7
                                    			/usr/bin/npx 		9.6.7
                                    Recommended versions are nodejs 18.x.y and npm 9.x.y
                                    MEMORY:
                                    Mem:            7.8G        3.6G        847M         51M        3.3G        4.0G
                                    Swap:            99M          0B         99M
                                    Total:          7.9G        3.6G        947M
                                    Active iob-Instances: 	41
                                    ioBroker Core: 		js-controller 		5.0.12
                                    			admin 			6.10.2
                                    ioBroker Status: 	iobroker is running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects: 		10532
                                    States: 		9152
                                    Size of iob-Database:
                                    25M	/opt/iobroker/iobroker-data/objects.jsonl
                                    2.2M	/opt/iobroker/iobroker-data/states.jsonl
                                    === Mark text until here for copying ===
                                      Thomas Braun Most Active @edi1975 last edited by
                                      X-Server: true
                                      Ausschalten.
                                      Pending Updates: 25
                                      Updaten
                                      • Glasfaser
                                        Glasfaser last edited by Glasfaser
                                        X-Server: true
                                        vncserver-x11-c
                                        cups-browsed
                                        wofür !?
                                          edi1975 @Glasfaser last edited by
                                          vncserver-x11-c
                                          also angeschlossen ist noch monitor deswegen Desktop, und vnc für zugriff wen monitor ist aus. Updates weil jetzt ist auf Beta umgeschaltet, aber das hat nichts zu tun mit meinem Problem meine ich so.
                                          Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                                          • Glasfaser
                                            Glasfaser @edi1975 last edited by Glasfaser
                                            @edi1975
                                            iob upload all
                                            einmal durchlaufen lassen ,
                                            dann
                                            sudo reboot
                                            was ist dann !?
                                            1323
