    4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
      Thomas Braun Most Active @fastfoot last edited by
      @fastfoot
      echad@chet:/opt/iobroker $ tar -tf backups/test_nocompression.tar
      echad@chet:/opt/iobroker $ ls -lAh backups/
      total 36M
      -rwxrwxrwx 1 root root    0 Oct  4 18:16 01_FREIGABE_FRITZ_NAS
      -rwxrwxrwx 1 root root  16K Oct  4 18:46 2023_10_04-18_46_20_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  16K Oct  4 19:08 2023_10_04-19_07_57_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  16K Oct  4 19:11 2023_10_04-19_11_08_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root    0 Oct  4 19:26 historyDB_2023_10_04-19_26_02_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root    0 Oct  4 20:05 historyDB_2023_10_04-20_04_52_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  16K Oct  4 20:07 historyDB_2023_10_04-20_06_45_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  29M Oct  4 20:24 historyDB_2023_10_04-20_23_55_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root    0 Oct  4 19:26 iobroker_2023_10_04-19_25_51_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root    0 Oct  4 20:05 iobroker_2023_10_04-20_04_41_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  16K Oct  4 20:06 iobroker_2023_10_04-20_06_34_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root 5.8M Oct  4 20:23 iobroker_2023_10_04-20_23_39_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root    0 Oct  4 19:26 javascripts_2023_10_04-19_26_28_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root    0 Oct  4 20:05 javascripts_2023_10_04-20_05_20_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  14K Oct  4 20:07 javascripts_2023_10_04-20_07_12_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  73K Oct  4 20:24 javascripts_2023_10_04-20_24_23_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root 151K Oct  4 20:41 test_alternative.tar.gz
      -rwxrwxrwx 1 root root 247K Oct  4 20:41 test_nocompression.tar
      -rwxrwxrwx 1 root root  16K Oct  4 20:41 test_standard.tar.gz
      -rwxrwxrwx 1 root root    0 Oct  4 19:26 zigbee.0_2023_10_04-19_26_28_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root    0 Oct  4 20:05 zigbee.0_2023_10_04-20_05_19_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  955 Oct  4 20:07 zigbee.0_2023_10_04-20_07_11_chet_backupiobroker.tar.gz
      -rwxrwxrwx 1 root root  969 Oct  4 20:24 zigbee.0_2023_10_04-20_24_22_chet_backupiobroker.tar.gz
        fastfoot @Thomas Braun last edited by
        @thomas-braun gibts ja gar nicht, gar kein output? mach mal -tvf
          @fastfoot
          Nö, nix:
          echad@chet:/opt/iobroker $ tar -tvf backups/test_nocompression.tar
            @thomas-braun ok, verbucht als Fehler der tar Implementation. Müsste eh 800Kb gross sein so wie unter 18.17. Damit wäre aber auch gzip ausgeschlossen weil es mit und ohne nicht klappt. Bleibt der pipe() Mechanismus. Jetzt erstell Du mal ein issue bei node und erkläre denen das 🙂
            welche fritz box hast du denn? evtl liegt es tatsächlich an der smb implementierung, bin ratlos
            • simatec
              simatec Developer Most Active @fastfoot last edited by simatec
              @fastfoot sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
              @simatec sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
              @thomas-braun dann kann eigentlich auch der js-controller ausgeschlossen werden
              das verstehe ich jetzt nicht iob backup macht doch der js-controller, auch die Datei in node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js deutet auf den controller?
              Aber der js-controller hat nix mit den Backup Optionen wie JavaScript Influx usw. zu tun.
                Ist eine FRITZ!Box 6660 Cable mit FRITZ!OS:7.57-Version aktuell.
                  Könnte schwierig werden.
                    fastfoot @simatec last edited by
                    Aber der js-controller hat nix mit den Backup Optionen wie JavaScript Influenza usw. zu tun.
                    ja das stimmt natürlich, aber wenn wir es schaffen die iobroker backups zuverlässig zu schreiben dann wäre das auch die Lösung für den Rest.
                      @thomas-braun sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                      ich arbeite dran das zu vermeiden:-) weiss auch nicht wie man so ein issue formulieren sollte
                      Thomas Braun 3 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @fastfoot last edited by Thomas Braun
                        @fastfoot
                        Ey, euer tar macht komische Dinge seit 18.18.0, aber nur auf ein per CIFS gemountetes FritzNAS? Und das auch nicht bei jedem/immer.
                        Ich glaube das wird nicht weiter beachtet werden...
                          @fastfoot
                          Mit welchem js-Kommando wird denn das nocompression.tar getart?
                          Ich verhedder mich schon dabei im Skript zu lesen...
                            @fastfoot
                            Der Vollständigkeit halber.
                            Skript V2 mit nodejs 20.8.0:
                            /opt/iobroker/backups unmounted
                            //fritz.box/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet mounted into /opt/iobroker/backups
                            file test_standard.tar.gz created
                            file test_standard.tar.gz done
                            number of files in test_standard.tar.gz: 0
                            file test_nocompression.tar created
                            file test_nocompression.tar done
                            number of files in test_nocompression.tar: 0
                            file test_alternative.tar.gz created
                            file test_alternative.tar.gz done
                            number of files in test_alternative.tar.gz: 115
                            listing of created files in /opt/iobroker/backups
                            -rwxrwxrwx 1 root root 154384 Oct  4 22:42 /opt/iobroker/backups/test_alternative.tar.gz
                            -rwxrwxrwx 1 root root 252928 Oct  4 22:42 /opt/iobroker/backups/test_nocompression.tar
                            -rwxrwxrwx 1 root root  16384 Oct  4 22:42 /opt/iobroker/backups/test_standard.tar.gz
                            Was ist denn test_alternative.tar.gz genau?
                            Das scheint ja zu funktionieren.
                            Ist das der Schlingel?
                            echad@chet:/opt/iobroker $ npm ls tar
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├─┬ iobroker.echarts@1.5.4
                            │ └─┬ canvas@2.11.2
                            │   └─┬ @mapbox/node-pre-gyp@1.0.11
                            │     └── tar@6.1.15 deduped
                            ├─┬ iobroker.js-controller@5.0.12
                            │ └── tar@6.1.15
                            └─┬ iobroker.zigbee@1.8.24
                            F simatec 2 Replies Last reply Reply Quote 0
                              @thomas-braun die alternative function macht das erstellen und kopieren was funktioniert. denke nicht dass es das tar ist. das nocompression wird mit standard und 2tem parameter false aufgerufen.
                              • simatec
                                simatec Developer Most Active @Thomas Braun last edited by simatec
                                @thomas-braun Jaein… js-controller nutzt tar direkt.
                                Backitup nutzt allerdings tar-fs ….
                                tar-fs hat aber wiederum tar mit integriert…
                                Nur um die Verwirrung mal komplett zu machen 😂
                                https://www.npmjs.com/package/tar
                                  Thomas Braun Most Active @simatec last edited by Thomas Braun
                                  😞 Jetzt weiß ich gar nicht mehr wie ich den Pudding an die Wand nageln soll...
                                  Das bekomme ich nie verständlich und wasserdicht in ein Issue gegossen.
                                    nee, das mit dem issue sollte ein Gag sein. Ich arbeite an V3!
                                      Thomas Braun Most Active last edited by
                                      @fastfoot
                                      Ich muss morgen mal direkt mit tar experimentieren.
                                      Aber wenn es am deb-Paket liegen sollte, warum rappelte es erst ab nodejs 18.18.0?
                                        tar -cvzf test.tar.gz ./node_modules/iobroker.js-controller
                                        • simatec
                                          Eventuell mit Sekundenkleber versuchen 😊
                                          • simatec
                                            Das hat nichts mit dem Deb-Packet zu tun... Es handelt sich um das Paket node-tar.
                                            Der Name ist etwas verwirrend, hat aber keine Verbindung zum DEB Paket
                                            1.2k
                                            204
                                            28152
