    4. ioBroker Docker Synology startet nicht
      Sweatchuck @Glasfaser last edited by Sweatchuck
      @glasfaser
      Unselect
      -----              Welcome to your ioBroker Docker container!              -----
      -----                    Startupscript is now running!                     -----
      -----                          Please be patient!                          -----
      -----                          System Information                          -----
      -----                    arch:                x86_64                       -----
      -----                    hostname:            iobroker                     -----
      -----                          Version Information                         -----
      -----                    image:               v8.1.0                       -----
      -----                    build:               2023-09-21T23:45:32+00:00    -----
      -----                    node:                v18.17.1                     -----
      -----                    npm:                 9.6.7                        -----
      -----                        Environment Variables                         -----
      -----                    AVAHI:               false                        -----
      -----                    DEBUG:               true                         -----
      -----                    PACKAGES:            nano                         -----
      -----                    SETGID:              1000                         -----
      -----                    SETUID:              1000                         -----
      !!!!                            DEBUG LOG ACTIVE                            !!!!
      !!!!               Environment variable DEBUG is set to true.               !!!!
      !!!! This will extend the logging output and may slow down container start. !!!!
      !!!!          Please make sure to deactivate if no longer needed.           !!!!
      !!!!     For more information see ioBroker Docker image documentation:      !!!!
      !!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
      -----                   Step 1 of 5: Preparing container                   -----
      Updating Linux packages on first run... Done.
      PACKAGES is set. Installing the following additional Linux packages: nano
      nano is not installed. Installing... Done.
      Registering maintenance script as command... Done.
      -----             Step 2 of 5: Detecting ioBroker installation             -----
      Existing installation of ioBroker detected in "/opt/iobroker".
      -----             Step 3 of 5: Checking ioBroker installation              -----
      (Re)setting permissions (This might take a while! Please be patient!)... Done.
      Fixing "sudo-bug" by replacing sudo with gosu... Done.
      [DEBUG] Checking multihost settings...
      [DEBUG] No multihost settings detected.
      [DEBUG] Done.
      [DEBUG] Checking custom objects db settings...
      [DEBUG] No custom objects db settings detected.
      [DEBUG] Done.
      [DEBUG] Checking custom states db settings...
      [DEBUG] No custom states db settings detected.
      [DEBUG] Done.
      Checking Database connection... Failed.
      [DEBUG] Error message:
      [DEBUG] node:internal/modules/cjs/loader:1080
      [DEBUG]   throw err;
      [DEBUG]   ^
      [DEBUG]
      [DEBUG] Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      [DEBUG]     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
      [DEBUG]     at Module._load (node:internal/modules/cjs/loader:922:27)
      [DEBUG]     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      [DEBUG]     at node:internal/main/run_main_module:23:47 {
      [DEBUG]   code: 'MODULE_NOT_FOUND',
      BUG]   requireStack: []
      [DEBUG]
      [DEBUG] Node.js v18.17.1
      Please check your configuration and try again.
      For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs).
      [DEBUG] Debug mode prevents the container from exiting on errors.
      [DEBUG] This enables you to investigate or fix your issue on the command line.
      [DEBUG] If you want to stop or restart your container you have to do it manually.
      [DEBUG] IoBroker is not running!
      Diesmal läuft er wohl weiter aber ich komme nicht auf die ioBroker Seite
      Glasfaser 2 Replies Last reply Reply Quote 0
        @glasfaser
        Ja, kein Erfolg.
        Wenn ich eine leeren Ordner anlege z.B. iobroker_data_neu dann funktioniert das ganze wieder…allerdings natürlich ohne meine Daten
        • Glasfaser
          Glasfaser @Sweatchuck last edited by
          @sweatchuck
          OK , der Container startet .
          dann melde dich im Terminal an im Portainer oder im Synology Docker Terminal und
          dann
          cd /opt/iobroker
          und
          sudo -H -u iobroker npm install iobroker.js-controller
          • Glasfaser
            @sweatchuck sagte in ioBroker Docker Synology startet nicht:
            Brauchst kein EDIT im Beitrag machen .. ich habe es schon gesehn , das er läuft !
            siehe oben ..
              @glasfaser
              • Glasfaser
                @sweatchuck
                find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
                dann nochmal versuchen
                • OliverIO
                  OliverIO @Sweatchuck last edited by
                  @oliverio
                  Ich verwende eine Synolgy DS 218+ mit Docker und Portainer.
                  Was genau meinst du?
                  Ich habe da nichts spezielles gemacht.
                  Das Skript meckert darüber das die Verbindung zur Datenbank nicht klappt.
                  Dann zeige mal deine Konfiguration für den Container.
                  Hast du ein docker-compose/stacks?
                    @glasfaser
                    526877D7-9996-474E-8271-D50C80556EE5.jpeg BCAE95E2-A35D-4D95-9B3B-D378D38D49C3.jpeg 556CBEF0-0435-49CB-91BA-E47C52A0793D.jpeg
                    • Glasfaser
                      @sweatchuck
                      Ja ... alles gut .. ist nur Werbung
                      Dann noch zusätzlich
                      pkill -u iobroker
                      iob fix
                      Container neu starten in der Synology Weboberfläche
                        @glasfaser
                        Es geht wieder!!!
                        Wie kann ich dir Danken?
                        Glasfaser 1 Reply Last reply Reply Quote 1
                        • Glasfaser
                          ... damit , das du den Adapter Backitup nutzt !!!!
                            @glasfaser
                            Was war jetzt passiert? Und warum?
                            Nur für mich zur Info
                            • Glasfaser
                              @sweatchuck
                              Kann ich so nicht erkennen bzw. weiß ja nicht was du zuvor genau gemacht hast ,
                              nur das dann der JS-Controller zerschossen wurde.
                                @glasfaser
                                Die javascript-Instanz bleibt rot
                                • Glasfaser
                                  ioBroker log dazu hier posten ...
                                  mit der Aussage kann ich nicht viele anfangen !
                                    @glasfaser
                                    • Glasfaser
                                      @sweatchuck
                                      Stoppe den Adapter , dann lösche die Javascript Instanz , dann den Adapter Javascript , dann wieder den Adapter Javascript installieren und die Instanz dazu .
                                      Könnte jetzt noch dir ein Befehl geben aber mache es erstmal so !
                                        @glasfaser
                                        Adapter läuft wieder.
                                        Allerdings meckert er etwas…
                                        Ich vermute es fehlen NPM Module
                                        • Glasfaser
                                          Glasfaser @Sweatchuck last edited by Glasfaser
                                          @sweatchuck
                                          nicht ganz richtig
                                          es fehlen Datenpunkte // not found
                                          usw,
                                          • Glasfaser
                                            @sweatchuck
                                            Wird durch das Script
                                            erzeugt , die Datenpunkte fehlen dazu ... siehe oben
                                            4304
