      DPO99 @Thomas Braun last edited by
      Habe das Backup mal versetzt (kurze Korrektur noch, der Speicher ist nicht AUS sondern immer im Standby). Um 23h wird er dennoch jeden Tag aufgeweckt, sollte er im Standy sein. Fehler trat leider trotzdem auf:
      2023-10-03 23:10:10.038 - debug: backitup.0 (495265) The local storage check was completed successfully. On the host "iobroker" are currently 24113 MB free space available!
      2023-10-03 23:10:10.113 - debug: backitup.0 (495265) Backup has started ...
      2023-10-03 23:10:10.124 - debug: backitup.0 (495265) [iobroker/mount] mount activ... umount is started before mount!!
      2023-10-03 23:10:10.189 - debug: backitup.0 (495265) [iobroker/mount] umount successfully completed
      2023-10-03 23:10:20.113 - debug: backitup.0 (495265) [iobroker/mount] noserverino option: false
      2023-10-03 23:10:20.114 - debug: backitup.0 (495265) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
      2023-10-03 23:10:20.263 - debug: backitup.0 (495265) [iobroker/mount] mount successfully completed
      2023-10-03 23:10:20.266 - debug: backitup.0 (495265) [iobroker/mount] done
      2023-10-03 23:10:23.725 - debug: backitup.0 (495265) [iobroker/iobroker] host.iobroker 3044 states saved
      2023-10-03 23:10:26.296 - debug: backitup.0 (495265) [iobroker/iobroker] host.iobroker 3561 objects saved
      2023-10-03 23:10:30.405 - debug: backitup.0 (495265) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_03-23_10_20_backupiobroker.tar.gz
      2023-10-03 23:10:32.496 - debug: backitup.0 (495265) [iobroker/iobroker] done
      2023-10-03 23:10:33.401 - debug: backitup.0 (495265) [iobroker/historyDB] compress from historyDB started ...
      2023-10-03 23:10:37.349 - debug: backitup.0 (495265) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_10_03-23_10_33_backupiobroker.tar.gz
      2023-10-03 23:10:37.350 - debug: backitup.0 (495265) [iobroker/historyDB] done
      2023-10-03 23:10:38.270 - debug: backitup.0 (495265) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      2023-10-03 23:10:38.402 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
      2023-10-03 23:10:38.405 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
      2023-10-03 23:10:38.406 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
      2023-10-03 23:10:38.406 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
      2023-10-03 23:10:38.407 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Schaltung_openDTU
      2023-10-03 23:10:38.408 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Notabschaltung___Alarm
      2023-10-03 23:10:38.408 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
      2023-10-03 23:10:38.409 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
      2023-10-03 23:10:38.409 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Akku_Balancing
      2023-10-03 23:10:38.410 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Luftentfeuchter
      2023-10-03 23:10:38.411 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Raspberry_PI
      2023-10-03 23:10:38.411 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: OpenDTU
      2023-10-03 23:10:38.412 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: HM_WR_Keller
      2023-10-03 23:10:38.412 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Akkuladung_100
      2023-10-03 23:10:38.421 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Jahresverbrauch
      2023-10-03 23:10:38.423 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: TEST
      2023-10-03 23:10:38.424 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Test_Hama
      2023-10-03 23:10:38.436 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: HM_WR_Garage
      2023-10-03 23:10:38.555 - debug: backitup.0 (495265) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      2023-10-03 23:10:38.583 - debug: backitup.0 (495265) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      2023-10-03 23:10:38.584 - debug: backitup.0 (495265) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_03-23_10_38_backupiobroker.tar.gz
      2023-10-03 23:10:38.584 - debug: backitup.0 (495265) [iobroker/javascripts] done
      2023-10-03 23:10:39.337 - debug: backitup.0 (495265) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
      2023-10-03 23:10:39.337 - debug: backitup.0 (495265) [iobroker/cifs] done
      2023-10-03 23:10:39.941 - error: backitup.0 (495265) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      2023-10-03 23:10:39.941 - debug: backitup.0 (495265) [iobroker/clean] done
      2023-10-03 23:10:41.167 - debug: backitup.0 (495265) [iobroker/historyHTML] new history html values created
      2023-10-03 23:10:41.229 - debug: backitup.0 (495265) [iobroker/historyHTML] done
      2023-10-03 23:10:41.418 - debug: backitup.0 (495265) [iobroker/historyJSON] new history json values created
      2023-10-03 23:10:41.419 - debug: backitup.0 (495265) [iobroker/historyJSON] done
      2023-10-03 23:10:41.589 - debug: backitup.0 (495265) [iobroker/umount] mount activ, umount is started ...
      2023-10-03 23:10:46.641 - debug: backitup.0 (495265) [iobroker/umount] umount successfully completed
      2023-10-03 23:10:46.642 - debug: backitup.0 (495265) [iobroker/umount] done
      2023-10-03 23:10:46.794 - debug: backitup.0 (495265) [iobroker] exec: done
      • simatec
        simatec Developer Most Active @DPO99 last edited by
        @dpo99 Kann dein NAS WOL? Vielleicht sollte das deine Lösung sein.
        Backitup kann über WOL dein NAS wecken...
        Homoran D 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @simatec last edited by
          @simatec
          Ist inzwischen das CCU Backup nicht mehr über backitup abrufbar?
          hab in Doku und Forum nichts gefunden und erst mal eigenen Thread aufgemacht
          https://forum.iobroker.net/topic/68753/backitup-findet-ccu-backups-nicht-mehr/1
          • simatec
            @homoran sagte in Test Adapter ioBroker.backitup v2.8.x:
            War schon immer so Rainer 😉
            https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#restore
              DPO99 @simatec last edited by
              @simatec
              Die DS220+ kann WOL aber ich glaube nicht, dass das das Problem ist. Die Backups können ja geschrieben werden, nur löschen ist ein Problem. Zusätzlich befindet sich der NAS ja nur im Standby. Also sobald ein Request an die IP geht, startet der Speicher ja. Ich lege das Backup jetzt testweise mal noch auf eine ganz andere Zeit, nicht, dass der Speicher genau um 23:00/23:10 irgendwie anderweitig beschäftigt ist (aber das ist auch nur fischen im trüben).
              • simatec
                @dpo99 Ich würde an deiner Stelle mal NFS versuchen. Dein NAS kann das und es macht hier in deiner Config mehr Sinn.. Denke da ist irgendwas in deiner Config auf dem NAS krum, dass Backitup nicht ausreichend Rechte hat.
                  @simatec
                  Ich habe mal eine zweite Instanz erstellt und die Backups sind nun in 2 Ordnern aber im CIFS und NFS Pfad dann jeweils gleich. Dann kann ich mal beobachten, ob sich beide identisch verhalten oder nur eine Verbindung quatsch macht.
                    DPO99 @DPO99 last edited by DPO99
                    @simatec
                    Beim prüfen der Einstellungen bin ich im Reiter "Extra-Einstellungen" mal wieder über den Punkt "Anzahl der History Einträge" gestolpert. Habe dazu leider keine Infos finden können. Was genau sagt denn der Eintrag (0-50) hier eigentlich aus? Danke!
                    • simatec
                      @dpo99 die sind für den History State und haben nur eine Relevanz für VIS und das Tab Menü
                        DPO99 @simatec last edited by DPO99
                        @simatec
                        Irgendwie steckt der Wurm drin.....wollte das ganze ja jetzt mit 2 Instanzen testen aber plötzlich läuft das NFS nicht mehr....ist das so korrekt? Mir scheint, als ob er da auf einen falschen Pfad mounten will...
                        backitup.1 2023-10-06 07:56:55.612	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                        backitup.1 2023-10-06 07:56:55.605	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                        backitup.1 2023-10-06 07:56:05.606	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                        backitup.12023-10-06 07:56:05.599	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                        backitup.1 2023-10-06 07:55:29.831	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                        backitup.1 2023-10-06 07:55:29.823	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                        backitup.1 2023-10-06 07:55:12.698	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                        backitup.1 2023-10-06 07:55:12.691	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                        backitup.1 2023-10-06 07:54:45.483	warn	Source cannot be reached: Error: EHOSTDOWN: host is down, scandir '/opt/iobroker/backups'
                        backitup.1 2023-10-06 07:54:45.476	error	Error: Command failed: sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backupsmount.nfs: Host is down
                        Nach X Versuchen hat er es dann geschafft und korrekt gemountet:
                        backitup.1 2023-10-06 08:00:35.812	debug	mount successfully completed
                        backitup.1 2023-10-06 08:00:35.745	debug	device is busy... wait 2 Minutes!!
                        backitup.1 2023-10-06 08:00:35.696	debug	Backup list be read ...
                        backitup.1 2023-10-06 08:00:35.681	debug	nfs-mount command: "sudo mount 192.168.178.5:/volume1/TestIobrokerBackup/Test /opt/iobroker/backups"
                        backitup.1 2023-10-06 08:00:32.442	debug	The local storage check was completed successfully. On the host "iobroker" are currently 24114 MB free space available!
                        Ist es ein Problem, wenn es parallel 2 Instanzen mit einmal CIFS und NFS gibt? Ich habe manchmal das gefühl, dass da nach dem Anzeigen der vorhandenen Backups ein "unmount" fehlt.
                        Gleiches "unmountproblem" passiert dann auch in der .0, wenn ich vorher in der .1 die aktuellen Backups eingesehen habe:
                        backitup.0 2023-10-06 08:03:20.209	debug	mount successfully completed
                        backitup.0 2023-10-06 08:03:20.075	debug	Backup list be read ...
                        backitup.0 2023-10-06 08:03:20.065	debug	cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5Backup_IoBroker/Backup /opt/iobroker/backups"
                        backitup.0 2023-10-06 08:03:20.065	debug	noserverino option: false
                        backitup.0 2023-10-06 08:02:31.832	error	[iobroker] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                        backitup.0 2023-10-06 08:02:31.831	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                        backitup.0 2023-10-06 08:02:31.830	error	[iobroker/mount] mount error(16): Device or resource busy
                        backitup.0 2023-10-06 08:02:31.830	error	[iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups
                        backitup.0 2023-10-06 08:02:31.829	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                        backitup.0 2023-10-06 08:02:31.828	error	[iobroker/mount] mount error(16): Device or resource busy
                        backitup.0 2023-10-06 08:02:31.827	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups
                        backitup.0 2023-10-06 08:02:31.679	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
                        • simatec
                          @dpo99 Ein gleichzeitiges Mount macht Probleme... Bitte erst den umount laufen lassen, bevor du versuchst einen weiteren Mount in /opt/iobroker/backups zu setzen
                          • hg6806
                            hg6806 Most Active last edited by
                            Moin!
                            Ich habe noch einige Verständnisprobleme mit der Speicherung auf Google Drive.
                            Den Link zum Autorisieren habe ich ausgeführt.
                            Wie geht es nun weiter?
                            Welchen Link trage ich unten ein? Den eigenen oder den von der Autorisierung?
                            Und wie komme ich an die Daten dann wieder ran?
                            • simatec
                              simatec Developer Most Active @hg6806 last edited by
                              @hg6806 Du bekommst nach der Autorisierung einen Token im Browser angezeigt... Dieser muss eingefügt werden.
                              • hg6806
                                hg6806 Most Active @simatec last edited by
                                @simatec
                                Ok, danke
                                Und wie und wo sehe ich dann die Backup-Daten?
                                • simatec
                                  simatec Developer Most Active @hg6806 last edited by simatec
                                  @hg6806 Du siehst sie in deinem GDrive Account und in Backitup im Restore Menü
                                    @simatec
                                    Ich habe jetzt mal CIFS und NFS parallel laufen lassen. CIFS (mit SMB3) läuft immer auf Fehler beim löschen. NFS läuft bisher ohne Fehler.
                                    Ich würde es zwar gerne verstehen wollen, wieso es plötzlich (lief ja sehr lange fehlerfrei) nicht mehr über CIFS geht aber gut....habe den User auch mal mit SMB über Windows und Android verbunden, da ist alles kein Problem (löschen und erstellen).
                                    It is what it is....
                                    Dennoch danke für die Unterstützung!
                                    • simatec
                                      @dpo99 Was hast du für eine Node Version laufen?
                                      type -p nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v
                                        @simatec sagte in Test Adapter ioBroker.backitup v2.8.x:
                                        Anbei:
                                        iobroker@iobroker:~ $ type -p nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        /usr/bin/npx
                                        /usr/bin/corepack
                                        v18.18.0
                                        v18.18.0
                                        9.8.1
                                        9.8.1
                                        0.19.0
                                        Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @DPO99 last edited by Thomas Braun
                                          @dpo99
                                          Könnte sein, dass es mit nodejs 18.18.1 wieder funktioniert.
                                          Dürfte in den nächsten Tagen veröffentlicht werden.
                                          • simatec
                                            simatec Developer Most Active @DPO99 last edited by simatec
                                            @dpo99 Ist aktuell ein Bug in node 18.18.0... CIFS ist da von betroffen.
                                            Entweder auf die 18.18.1 warten oder auf 18.17.x zurückgehen
                                            https://github.com/nodejs/node/issues/49911
                                            anomiex created this issue in nodejs/node
                                            closed libuv update in 18.18.0 breaks webpack's `thread-loader` #49911
                                            R D 2 Replies Last reply Reply Quote 0
                                            170
                                            2780
                                            2368761
