    4. Iobroker Problem js controller stürtzt ab
      Thomas Braun Most Active @Fritzk last edited by
      @fritzk
      systemctl status iobroker
      • Glasfaser
        Glasfaser @Fritzk last edited by
        @fritzk
        Nochmal
        sudo -H -u iobroker npm cache verify
        sudo -H -u iobroker npm cache clean --force
        sudo reboot
        dann
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
          Fritzk @Glasfaser last edited by
          @glasfaser
          proxio@Haupt-IoBroker:/opt/iobroker$ sudo -H -u iobroker npm cache verify
          [sudo] password for proxio:
          Cache verified and compressed (~/.npm/_cacache)
          Content verified: 2123 (417424771 bytes)
          Content garbage-collected: 80 (30687112 bytes)
          Index entries: 2123
          Finished in 9.154s
          proxio@Haupt-IoBroker:/opt/iobroker$ sudo -H -u iobroker npm cache clean --force
          npm WARN using --force Recommended protections disabled.
          proxio@Haupt-IoBroker:/opt/iobroker$ sudo reboot
          Broadcast message from root@Haupt-IoBroker on pts/4 (Fri 2023-10-06 19:58:27 CEST):
          The system will reboot now!
          login as:
          login as: proxio
          proxio@192.168.178.124's password:
          Linux Haupt-IoBroker 6.2.16-5-pve #1 SMP PREEMPT_DYNAMIC PVE 6.2.16-6 (2023-07-25T15:33Z) x86_64
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Fri Oct  6 20:03:58 2023 from 192.168.178.151
          proxio@Haupt-IoBroker:~$ cd /opt/iobroker
          proxio@Haupt-IoBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
          up to date in 3s
          296 packages are looking for funding
            run `npm fund` for details
          • Glasfaser
            @fritzk
            ja ... und was sagt jetzt ioBroker ...
            iob status
              Fritzk @Thomas Braun last edited by
              proxio@Haupt-IoBroker:/opt/iobroker$ systemctl status iobroker
              * iobroker.service - ioBroker Home Automation
                   Loaded: loaded (/etc/systemd/system/iobroker.service; enabled; preset: enabled)
                   Active: activating (auto-restart) (Result: exit-code) since Fri 2023-10-06 20:09:54 CEST; 1s ago
                  Process: 546 ExecStart=/iobroker/start.sh # Ersetzen Sie /path/to/iobroker durch den tats<C3><A4>chlichen Pfad zu Ihrem>
                 Main PID: 546 (code=exited, status=203/EXEC)
                      CPU: 809us
                @glasfaser
                proxio@Haupt-IoBroker:/opt/iobroker$ iob status
                iobroker is not running on this host.
                Objects type: jsonl
                States  type: jsonl
                sagt noch immer das gleiche.....
                • Glasfaser
                  Glasfaser @Fritzk last edited by Glasfaser
                  @fritzk
                  das finde ich merkwürdig
                  /bin/sh: 1: hcitool: not found
                  nimm mal den NodeJS Fixer Skript in der Signatur von Thomas
                    @glasfaser
                    Okay ich probier es mal
                      @fritzk
                      Da stimmt irgendwas mit dem service nicht.
                      Das sollte eigentlich so aussehen.
                      echad@chet:~ $ systemctl status iobroker
                      ● iobroker.service - ioBroker Server
                           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
                           Active: active (running) since Wed 2023-10-04 22:32:41 CEST; 1 day 21h ago
                             Docs: http://iobroker.net
                         Main PID: 136687 (iobroker.js-con)
                            Tasks: 475 (limit: 8754)
                              CPU: 14h 1min 28.002s
                           CGroup: /system.slice/iobroker.service
                      Die Meldung bei dir:
                      schaut auch schräg aus. Seit wann gibt es da deutsche Texte?
                        @fritzk
                        cat /etc/systemd/system/multi-user.target.wants/iobroker.service
                          proxio@Haupt-IoBroker:/opt/iobroker$ cat /etc/systemd/system/multi-user.target.wants/iobroker.service
                          [Unit]
                          Description=ioBroker Server
                          Documentation=http://iobroker.net
                          After=network.target redis.service influxdb.service mysql-server.service mariadb-server.service
                          Wants=redis.service influxdb.service mysql-server.service mariadb-server.service
                          [Service]
                          Type=simple
                          User=iobroker
                          Environment="NODE=$(which node)"
                          ExecStart=/usr/bin/bash -c '${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                          Restart=on-failure
                          RestartSec=3s
                          [Install]
                          WantedBy=multi-user.target
                            @fritzk
                            diff /usr/lib/systemd/system/iobroker.service /etc/systemd/system/multi-user.target.wants/iobroker.service
                            Irgendwie scheint da bei dir noch eine zweite iobroker.service (oder so ähnlich) herumzuschwirren.
                              Fritzk @Thomas Braun last edited by Fritzk
                              bei dieser eingabe tut sich nix....
                              proxio@Haupt-IoBroker:/opt/iobroker$ diff /usr/lib/systemd/system/iobroker.service /etc/systemd/system/multi-user.target.wants/iobroker.service
                                @fritzk sagte in Iobroker Problem js controller stürtzt ab:
                                Das ist richtig. Bzw. es tut sich schon was, aber nichts für dich sichtbares.
                                Schnelltest:
                                eingeben und NICHT per Enter abschießen sondern stattdessen 2x schnell hintereinander die TAB-Taste benutzen.
                                  Okay
                                  proxio@Haupt-IoBroker:/opt/iobroker$ systemctl status iobroker.service
                                  Display all 290 possibilities? (y or n)
                                  -.mount                                                            remote-cryptsetup.target
                                  -.slice                                                            remote-fs-pre.target
                                  NetworkManager.service                                             remote-fs.target
                                  apparmor.service                                                   remote-veritysetup.target
                                  apt-daily-upgrade.service                                          rescue-ssh.target
                                  apt-daily-upgrade.timer                                            rescue.service
                                  apt-daily.service                                                  rescue.target
                                  apt-daily.timer                                                    rpc-gssd.service
                                  auditd.service                                                     rpc-statd-notify.service
                                  auth-rpcgss-module.service                                         rpc-statd.service
                                  basic.target                                                       rpc-svcgssd.service
                                  bluetooth.target                                                   rpc_pipefs.target
                                  boot-complete.target                                               rpcbind.service
                                  connman.service                                                    rpcbind.socket
                                  console-getty.service                                              rpcbind.target
                                  container-getty@1.service                                          run-credentials-systemd\x2dsysctl.service.mount
                                  container-getty@2.service                                          run-credentials-systemd\x2dsysusers.service.mount
                                  cron.service                                                       run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount
                                  cryptdisks-early.service                                           run-credentials-systemd\x2dtmpfiles\x2dsetup\x2ddev.service.mount
                                  cryptdisks.service                                                 run-rpc_pipefs.mount
                                  cryptsetup-pre.target                                              run-user-1000.mount
                                  cryptsetup.target                                                  runlevel0.target
                                  ctrl-alt-del.target                                                runlevel1.target
                                  dbus-org.freedesktop.hostname1.service                             runlevel2.target
                                  dbus-org.freedesktop.locale1.service                               runlevel3.target
                                  dbus-org.freedesktop.login1.service                                runlevel4.target
                                  dbus-org.freedesktop.timedate1.service                             runlevel5.target
                                  dbus-org.freedesktop.timesync1.service                             runlevel6.target
                                  dbus.service                                                       sendmail.service
                                  dbus.socket                                                        session-188.scope
                                  debug-shell.service                                                shutdown.target
                                  default.target                                                     sigpwr.target
                                  dev-.lxc-proc.mount                                                sleep.target
                                  dev-.lxc-sys.mount                                                 slices.target
                                  dev-full.mount                                                     smartcard.target
                                  dev-hugepages.mount                                                sockets.target
                                  dev-mqueue.mount                                                   sound.target
                                  dev-null.mount                                                     ssh.service
                                  dev-ptmx.mount                                                     ssh.socket
                                  dev-random.mount                                                   sshd.service
                                  dev-tty.mount                                                      sudo.service
                                  dev-tty1.mount                                                     suspend-then-hibernate.target
                                  dev-tty2.mount                                                     suspend.target
                                  dev-ttyUSB0.mount                                                  swap.target
                                  dev-urandom.mount                                                  sys-devices-system-cpu.mount
                                  dev-zero.mount                                                     sys-devices-virtual-net.mount
                                  display-manager.service                                            sys-fs-fuse-connections.mount
                                  dpkg-db-backup.service                                             sys-kernel-config.mount
                                  dpkg-db-backup.timer                                               sys-kernel-debug.mount
                                  e2scrub_all.service                                                sys-kernel-tracing.mount
                                  e2scrub_all.timer                                                  sysinit.target
                                  e2scrub_reap.service                                               syslog.service
                                  emergency.service                                                  syslog.socket
                                  emergency.target                                                   system-container\x2dgetty.slice
                                  exim4.service                                                      system-modprobe.slice
                                  exit.target                                                        system-postfix.slice
                                  factory-reset.target                                               system-systemd\x2dcryptsetup.slice
                                  final.target                                                       system-update-cleanup.service
                                  first-boot-complete.target                                         system-update-pre.target
                                  fstrim.service                                                     system-update.target
                                  fstrim.timer                                                       system.slice
                                  getty-pre.target                                                   systemd-ask-password-console.path
                                  getty-static.service                                               systemd-ask-password-console.service
                                  getty.target                                                       systemd-ask-password-wall.path
                                  graphical.target                                                   systemd-ask-password-wall.service
                                  gssproxy.service                                                   systemd-binfmt.service
                                  halt.target                                                        systemd-boot-check-no-failures.service
                                  hibernate.target                                                   systemd-exit.service
                                  home.mount                                                         systemd-firstboot.service
                                  hwclock.service                                                    systemd-fsck-root.service
                                  hybrid-sleep.target                                                systemd-fsckd.service
                                  ifupdown-pre.service                                               systemd-fsckd.socket
                                  ifupdown-wait-online.service                                       systemd-halt.service
                                  init.scope                                                         systemd-hibernate.service
                                  initrd-cleanup.service                                             systemd-hostnamed.service
                                  initrd-fs.target                                                   systemd-hwdb-update.service
                                  initrd-parse-etc.service                                           systemd-hybrid-sleep.service
                                  initrd-root-device.target                                          systemd-initctl.service
                                  initrd-root-fs.target                                              systemd-initctl.socket
                                  initrd-switch-root.service                                         systemd-journal-flush.service
                                  initrd-switch-root.target                                          systemd-journald-audit.socket
                                  initrd-udevadm-cleanup-db.service                                  systemd-journald-dev-log.socket
                                  initrd-usr-fs.target                                               systemd-journald.service
                                  initrd.target                                                      systemd-journald.socket
                                  integritysetup-pre.target                                          systemd-kexec.service
                                  integritysetup.target                                              systemd-localed.service
                                  iobroker.service                                                   systemd-logind.service
                                  kexec.target                                                       systemd-machine-id-commit.service
                                  kmod-static-nodes.service                                          systemd-modules-load.service
                                  kmod.service                                                       systemd-network-generator.service
                                  local-fs-pre.target                                                systemd-networkd-wait-online.service
                                  local-fs.target                                                    systemd-networkd.service
                                  logrotate.service                                                  systemd-networkd.socket
                                  logrotate.timer                                                    systemd-oomd.service
                                  machine.slice                                                      systemd-pcrphase-initrd.service
                                  man-db.service                                                     systemd-pcrphase-sysinit.service
                                  man-db.timer                                                       systemd-pcrphase.service
                                  modprobe@dm_mod.service                                            systemd-poweroff.service
                                  modprobe@drm.service                                               systemd-pstore.service
                                  modprobe@efi_pstore.service                                        systemd-quotacheck.service
                                  modprobe@fuse.service                                              systemd-random-seed.service
                                  modprobe@loop.service                                              systemd-reboot.service
                                  multi-user.target                                                  systemd-remount-fs.service
                                  network-online.target                                              systemd-repart.service
                                  network-pre.target                                                 systemd-rfkill.service
                                  network.target                                                     systemd-rfkill.socket
                                  networking.service                                                 systemd-suspend-then-hibernate.service
                                  nfs-client.target                                                  systemd-suspend.service
                                  nfs-common.service                                                 systemd-sysctl.service
                                  nfs-idmapd.service                                                 systemd-sysext.service
                                  nfs-server.service                                                 systemd-sysusers.service
                                  nfs-utils.service                                                  systemd-time-wait-sync.service
                                  nftables.service                                                   systemd-timedated.service
                                  nss-lookup.target                                                  systemd-timesyncd.service
                                  nss-user-lookup.target                                             systemd-tmpfiles-clean.service
                                  pam_namespace.service                                              systemd-tmpfiles-clean.timer
                                  paths.target                                                       systemd-tmpfiles-setup-dev.service
                                  plymouth-quit-wait.service                                         systemd-tmpfiles-setup.service
                                  plymouth-start.service                                             systemd-udev-settle.service
                                  portmap.service                                                    systemd-udev-trigger.service
                                  postfix-resolvconf.path                                            systemd-udevd-control.socket
                                  postfix-resolvconf.service                                         systemd-udevd-kernel.socket
                                  postfix.service                                                    systemd-udevd.service
                                  postfix@-.service                                                  systemd-update-done.service
                                  poweroff.target                                                    systemd-update-utmp-runlevel.service
                                  printer.target                                                     systemd-update-utmp.service
                                  proc-cpuinfo.mount                                                 systemd-user-sessions.service
                                  proc-diskstats.mount                                               systemd-vconsole-setup.service
                                  proc-fs-nfsd.mount                                                 systemd-volatile-root.service
                                  proc-loadavg.mount                                                 time-set.target
                                  proc-meminfo.mount                                                 time-sync.target
                                  proc-slabinfo.mount                                                timers.target
                                  proc-stat.mount                                                    tmp.mount
                                  proc-swaps.mount                                                   udev.service
                                  proc-sys-fs-binfmt_misc.automount                                  umount.target
                                  proc-sys-fs-binfmt_misc.mount                                      urandom.service
                                  proc-sys-net.mount                                                 usb-gadget.target
                                  proc-sysrq\x2dtrigger.mount                                        user-1000.slice
                                  proc-uptime.mount                                                  user-runtime-dir@1000.service
                                  procps.service                                                     user.slice
                                  quotaon.service                                                    user@1000.service
                                  rc-local.service                                                   var-lib-nfs-rpc_pipefs.mount
                                  rc.service                                                         veritysetup-pre.target
                                  rcS.service                                                        veritysetup.target
                                  reboot.target                                                      x11-common.service
                                       Active: inactive (dead) (Result: exit-code) since Fri 2023-10-06 20:18:53 CEST; 27min ago
                                     Duration: 846us
                                     Main PID: 777 (code=exited, status=203/EXEC)
                                          CPU: 780us
                                    sudo systemctl restart iobroker.service
                                      ....er mag einfach nicht mehr
                                      proxio@Haupt-IoBroker:/opt/iobroker$ sudo systemctl restart iobroker.service
                                      proxio@Haupt-IoBroker:/opt/iobroker$ iobroker status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      • Glasfaser
                                        @fritzk
                                        Was war mit dem NodeJS Fixer !?
                                          @glasfaser
                                          Hat leider auch nicht geholfen
                                          ioBroker nodejs fixer 2023-10-03
                                          Recommended nodejs-version is: 18.18.0
                                          Checking your installation now. Please be patient!
                                          Your current setup is:
                                          /usr/bin/nodejs         v18.18.0
                                          /usr/bin/node           v18.18.0
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                                          /usr/bin/corepack       0.19.0
                                          We found these nodejs versions available for installation:
                                          nodejs:
                                            Installed: 18.18.0-1nodesource1
                                            Candidate: 18.18.0-1nodesource1
                                            Version table:
                                           *** 18.18.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                                  100 /var/lib/dpkg/status
                                               18.17.1-1nodesource1 1001
                                               18.17.0-1nodesource1 1001
                                               18.16.1-1nodesource1 1001
                                               18.16.0-1nodesource1 1001
                                               18.15.0-1nodesource1 1001
                                               18.14.2-1nodesource1 1001
                                               18.14.1-1nodesource1 1001
                                               18.14.0-1nodesource1 1001
                                               18.13.0+dfsg1-1 500
                                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                               18.13.0-1nodesource1 1001
                                               18.12.0-1nodesource1 1001
                                               18.11.0-1nodesource1 1001
                                               18.10.0-1nodesource1 1001
                                               18.9.1-1nodesource1 1001
                                               18.9.0-1nodesource1 1001
                                               18.8.0-1nodesource1 1001
                                               18.7.0-1nodesource1 1001
                                               18.6.0-1nodesource1 1001
                                               18.5.0-1nodesource1 1001
                                               18.4.0-1nodesource1 1001
                                               18.3.0-1nodesource1 1001
                                               18.2.0-1nodesource1 1001
                                               18.1.0-1nodesource1 1001
                                               18.0.0-1nodesource1 1001
                                          Nothing to do - Your installation is using the correct paths.
                                          Nothing to do - Your version is the recommended one.
                                          You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
                                          Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
                                          • Glasfaser
                                            @fritzk
                                            curl -fsL https://iobroker.net/fix.sh | bash -
                                            3933
