    4. Iobroker Problem js controller stürtzt ab
      Fritzk @Glasfaser last edited by
      @glasfaser
      proxio@Haupt-IoBroker:/opt/iobroker$ sudo -H -u iobroker npm cache verify
      [sudo] password for proxio:
      Cache verified and compressed (~/.npm/_cacache)
      Content verified: 2123 (417424771 bytes)
      Content garbage-collected: 80 (30687112 bytes)
      Index entries: 2123
      Finished in 9.154s
      proxio@Haupt-IoBroker:/opt/iobroker$ sudo -H -u iobroker npm cache clean --force
      npm WARN using --force Recommended protections disabled.
      proxio@Haupt-IoBroker:/opt/iobroker$ sudo reboot
      Broadcast message from root@Haupt-IoBroker on pts/4 (Fri 2023-10-06 19:58:27 CEST):
      The system will reboot now!
      login as:
      login as: proxio
      proxio@192.168.178.124's password:
      Linux Haupt-IoBroker 6.2.16-5-pve #1 SMP PREEMPT_DYNAMIC PVE 6.2.16-6 (2023-07-25T15:33Z) x86_64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Fri Oct  6 20:03:58 2023 from 192.168.178.151
      proxio@Haupt-IoBroker:~$ cd /opt/iobroker
      proxio@Haupt-IoBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
      up to date in 3s
      296 packages are looking for funding
        run `npm fund` for details
      • Glasfaser
        Glasfaser @Fritzk last edited by
        @fritzk
        ja ... und was sagt jetzt ioBroker ...
        iob status
          Fritzk @Thomas Braun last edited by
          proxio@Haupt-IoBroker:/opt/iobroker$ systemctl status iobroker
          * iobroker.service - ioBroker Home Automation
               Loaded: loaded (/etc/systemd/system/iobroker.service; enabled; preset: enabled)
               Active: activating (auto-restart) (Result: exit-code) since Fri 2023-10-06 20:09:54 CEST; 1s ago
              Process: 546 ExecStart=/iobroker/start.sh # Ersetzen Sie /path/to/iobroker durch den tats<C3><A4>chlichen Pfad zu Ihrem>
             Main PID: 546 (code=exited, status=203/EXEC)
                  CPU: 809us
            @glasfaser
            proxio@Haupt-IoBroker:/opt/iobroker$ iob status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            sagt noch immer das gleiche.....
            • Glasfaser
              Glasfaser @Fritzk last edited by Glasfaser
              @fritzk
              das finde ich merkwürdig
              /bin/sh: 1: hcitool: not found
              nimm mal den NodeJS Fixer Skript in der Signatur von Thomas
                @glasfaser
                Okay ich probier es mal
                  Thomas Braun Most Active @Fritzk last edited by
                  @fritzk
                  Da stimmt irgendwas mit dem service nicht.
                  Das sollte eigentlich so aussehen.
                  echad@chet:~ $ systemctl status iobroker
                  ● iobroker.service - ioBroker Server
                       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
                       Active: active (running) since Wed 2023-10-04 22:32:41 CEST; 1 day 21h ago
                         Docs: http://iobroker.net
                     Main PID: 136687 (iobroker.js-con)
                        Tasks: 475 (limit: 8754)
                          CPU: 14h 1min 28.002s
                       CGroup: /system.slice/iobroker.service
                  Die Meldung bei dir:
                  schaut auch schräg aus. Seit wann gibt es da deutsche Texte?
                    @fritzk
                    cat /etc/systemd/system/multi-user.target.wants/iobroker.service
                      proxio@Haupt-IoBroker:/opt/iobroker$ cat /etc/systemd/system/multi-user.target.wants/iobroker.service
                      [Unit]
                      Description=ioBroker Server
                      Documentation=http://iobroker.net
                      After=network.target redis.service influxdb.service mysql-server.service mariadb-server.service
                      Wants=redis.service influxdb.service mysql-server.service mariadb-server.service
                      [Service]
                      Type=simple
                      User=iobroker
                      Environment="NODE=$(which node)"
                      ExecStart=/usr/bin/bash -c '${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                      Restart=on-failure
                      RestartSec=3s
                      [Install]
                      WantedBy=multi-user.target
                        @fritzk
                        diff /usr/lib/systemd/system/iobroker.service /etc/systemd/system/multi-user.target.wants/iobroker.service
                        Irgendwie scheint da bei dir noch eine zweite iobroker.service (oder so ähnlich) herumzuschwirren.
                          Fritzk @Thomas Braun last edited by Fritzk
                          bei dieser eingabe tut sich nix....
                          proxio@Haupt-IoBroker:/opt/iobroker$ diff /usr/lib/systemd/system/iobroker.service /etc/systemd/system/multi-user.target.wants/iobroker.service
                            @fritzk sagte in Iobroker Problem js controller stürtzt ab:
                            Das ist richtig. Bzw. es tut sich schon was, aber nichts für dich sichtbares.
                            Schnelltest:
                            eingeben und NICHT per Enter abschießen sondern stattdessen 2x schnell hintereinander die TAB-Taste benutzen.
                              Okay
                              proxio@Haupt-IoBroker:/opt/iobroker$ systemctl status iobroker.service
                              Display all 290 possibilities? (y or n)
                              -.mount                                                            remote-cryptsetup.target
                              -.slice                                                            remote-fs-pre.target
                              NetworkManager.service                                             remote-fs.target
                              apparmor.service                                                   remote-veritysetup.target
                              apt-daily-upgrade.service                                          rescue-ssh.target
                              apt-daily-upgrade.timer                                            rescue.service
                              apt-daily.service                                                  rescue.target
                              apt-daily.timer                                                    rpc-gssd.service
                              auditd.service                                                     rpc-statd-notify.service
                              auth-rpcgss-module.service                                         rpc-statd.service
                              basic.target                                                       rpc-svcgssd.service
                              bluetooth.target                                                   rpc_pipefs.target
                              boot-complete.target                                               rpcbind.service
                              connman.service                                                    rpcbind.socket
                              console-getty.service                                              rpcbind.target
                              container-getty@1.service                                          run-credentials-systemd\x2dsysctl.service.mount
                              container-getty@2.service                                          run-credentials-systemd\x2dsysusers.service.mount
                              cron.service                                                       run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount
                              cryptdisks-early.service                                           run-credentials-systemd\x2dtmpfiles\x2dsetup\x2ddev.service.mount
                              cryptdisks.service                                                 run-rpc_pipefs.mount
                              cryptsetup-pre.target                                              run-user-1000.mount
                              cryptsetup.target                                                  runlevel0.target
                              ctrl-alt-del.target                                                runlevel1.target
                              dbus-org.freedesktop.hostname1.service                             runlevel2.target
                              dbus-org.freedesktop.locale1.service                               runlevel3.target
                              dbus-org.freedesktop.login1.service                                runlevel4.target
                              dbus-org.freedesktop.timedate1.service                             runlevel5.target
                              dbus-org.freedesktop.timesync1.service                             runlevel6.target
                              dbus.service                                                       sendmail.service
                              dbus.socket                                                        session-188.scope
                              debug-shell.service                                                shutdown.target
                              default.target                                                     sigpwr.target
                              dev-.lxc-proc.mount                                                sleep.target
                              dev-.lxc-sys.mount                                                 slices.target
                              dev-full.mount                                                     smartcard.target
                              dev-hugepages.mount                                                sockets.target
                              dev-mqueue.mount                                                   sound.target
                              dev-null.mount                                                     ssh.service
                              dev-ptmx.mount                                                     ssh.socket
                              dev-random.mount                                                   sshd.service
                              dev-tty.mount                                                      sudo.service
                              dev-tty1.mount                                                     suspend-then-hibernate.target
                              dev-tty2.mount                                                     suspend.target
                              dev-ttyUSB0.mount                                                  swap.target
                              dev-urandom.mount                                                  sys-devices-system-cpu.mount
                              dev-zero.mount                                                     sys-devices-virtual-net.mount
                              display-manager.service                                            sys-fs-fuse-connections.mount
                              dpkg-db-backup.service                                             sys-kernel-config.mount
                              dpkg-db-backup.timer                                               sys-kernel-debug.mount
                              e2scrub_all.service                                                sys-kernel-tracing.mount
                              e2scrub_all.timer                                                  sysinit.target
                              e2scrub_reap.service                                               syslog.service
                              emergency.service                                                  syslog.socket
                              emergency.target                                                   system-container\x2dgetty.slice
                              exim4.service                                                      system-modprobe.slice
                              exit.target                                                        system-postfix.slice
                              factory-reset.target                                               system-systemd\x2dcryptsetup.slice
                              final.target                                                       system-update-cleanup.service
                              first-boot-complete.target                                         system-update-pre.target
                              fstrim.service                                                     system-update.target
                              fstrim.timer                                                       system.slice
                              getty-pre.target                                                   systemd-ask-password-console.path
                              getty-static.service                                               systemd-ask-password-console.service
                              getty.target                                                       systemd-ask-password-wall.path
                              graphical.target                                                   systemd-ask-password-wall.service
                              gssproxy.service                                                   systemd-binfmt.service
                              halt.target                                                        systemd-boot-check-no-failures.service
                              hibernate.target                                                   systemd-exit.service
                              home.mount                                                         systemd-firstboot.service
                              hwclock.service                                                    systemd-fsck-root.service
                              hybrid-sleep.target                                                systemd-fsckd.service
                              ifupdown-pre.service                                               systemd-fsckd.socket
                              ifupdown-wait-online.service                                       systemd-halt.service
                              init.scope                                                         systemd-hibernate.service
                              initrd-cleanup.service                                             systemd-hostnamed.service
                              initrd-fs.target                                                   systemd-hwdb-update.service
                              initrd-parse-etc.service                                           systemd-hybrid-sleep.service
                              initrd-root-device.target                                          systemd-initctl.service
                              initrd-root-fs.target                                              systemd-initctl.socket
                              initrd-switch-root.service                                         systemd-journal-flush.service
                              initrd-switch-root.target                                          systemd-journald-audit.socket
                              initrd-udevadm-cleanup-db.service                                  systemd-journald-dev-log.socket
                              initrd-usr-fs.target                                               systemd-journald.service
                              initrd.target                                                      systemd-journald.socket
                              integritysetup-pre.target                                          systemd-kexec.service
                              integritysetup.target                                              systemd-localed.service
                              iobroker.service                                                   systemd-logind.service
                              kexec.target                                                       systemd-machine-id-commit.service
                              kmod-static-nodes.service                                          systemd-modules-load.service
                              kmod.service                                                       systemd-network-generator.service
                              local-fs-pre.target                                                systemd-networkd-wait-online.service
                              local-fs.target                                                    systemd-networkd.service
                              logrotate.service                                                  systemd-networkd.socket
                              logrotate.timer                                                    systemd-oomd.service
                              machine.slice                                                      systemd-pcrphase-initrd.service
                              man-db.service                                                     systemd-pcrphase-sysinit.service
                              man-db.timer                                                       systemd-pcrphase.service
                              modprobe@dm_mod.service                                            systemd-poweroff.service
                              modprobe@drm.service                                               systemd-pstore.service
                              modprobe@efi_pstore.service                                        systemd-quotacheck.service
                              modprobe@fuse.service                                              systemd-random-seed.service
                              modprobe@loop.service                                              systemd-reboot.service
                              multi-user.target                                                  systemd-remount-fs.service
                              network-online.target                                              systemd-repart.service
                              network-pre.target                                                 systemd-rfkill.service
                              network.target                                                     systemd-rfkill.socket
                              networking.service                                                 systemd-suspend-then-hibernate.service
                              nfs-client.target                                                  systemd-suspend.service
                              nfs-common.service                                                 systemd-sysctl.service
                              nfs-idmapd.service                                                 systemd-sysext.service
                              nfs-server.service                                                 systemd-sysusers.service
                              nfs-utils.service                                                  systemd-time-wait-sync.service
                              nftables.service                                                   systemd-timedated.service
                              nss-lookup.target                                                  systemd-timesyncd.service
                              nss-user-lookup.target                                             systemd-tmpfiles-clean.service
                              pam_namespace.service                                              systemd-tmpfiles-clean.timer
                              paths.target                                                       systemd-tmpfiles-setup-dev.service
                              plymouth-quit-wait.service                                         systemd-tmpfiles-setup.service
                              plymouth-start.service                                             systemd-udev-settle.service
                              portmap.service                                                    systemd-udev-trigger.service
                              postfix-resolvconf.path                                            systemd-udevd-control.socket
                              postfix-resolvconf.service                                         systemd-udevd-kernel.socket
                              postfix.service                                                    systemd-udevd.service
                              postfix@-.service                                                  systemd-update-done.service
                              poweroff.target                                                    systemd-update-utmp-runlevel.service
                              printer.target                                                     systemd-update-utmp.service
                              proc-cpuinfo.mount                                                 systemd-user-sessions.service
                              proc-diskstats.mount                                               systemd-vconsole-setup.service
                              proc-fs-nfsd.mount                                                 systemd-volatile-root.service
                              proc-loadavg.mount                                                 time-set.target
                              proc-meminfo.mount                                                 time-sync.target
                              proc-slabinfo.mount                                                timers.target
                              proc-stat.mount                                                    tmp.mount
                              proc-swaps.mount                                                   udev.service
                              proc-sys-fs-binfmt_misc.automount                                  umount.target
                              proc-sys-fs-binfmt_misc.mount                                      urandom.service
                              proc-sys-net.mount                                                 usb-gadget.target
                              proc-sysrq\x2dtrigger.mount                                        user-1000.slice
                              proc-uptime.mount                                                  user-runtime-dir@1000.service
                              procps.service                                                     user.slice
                              quotaon.service                                                    user@1000.service
                              rc-local.service                                                   var-lib-nfs-rpc_pipefs.mount
                              rc.service                                                         veritysetup-pre.target
                              rcS.service                                                        veritysetup.target
                              reboot.target                                                      x11-common.service
                                   Active: inactive (dead) (Result: exit-code) since Fri 2023-10-06 20:18:53 CEST; 27min ago
                                 Duration: 846us
                                 Main PID: 777 (code=exited, status=203/EXEC)
                                      CPU: 780us
                                sudo systemctl restart iobroker.service
                                  ....er mag einfach nicht mehr
                                  proxio@Haupt-IoBroker:/opt/iobroker$ sudo systemctl restart iobroker.service
                                  proxio@Haupt-IoBroker:/opt/iobroker$ iobroker status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  • Glasfaser
                                    @fritzk
                                    Was war mit dem NodeJS Fixer !?
                                      @glasfaser
                                      Hat leider auch nicht geholfen
                                      ioBroker nodejs fixer 2023-10-03
                                      Recommended nodejs-version is: 18.18.0
                                      Checking your installation now. Please be patient!
                                      Your current setup is:
                                      /usr/bin/nodejs         v18.18.0
                                      /usr/bin/node           v18.18.0
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      /usr/bin/corepack       0.19.0
                                      We found these nodejs versions available for installation:
                                      nodejs:
                                        Installed: 18.18.0-1nodesource1
                                        Candidate: 18.18.0-1nodesource1
                                        Version table:
                                       *** 18.18.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                              100 /var/lib/dpkg/status
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0+dfsg1-1 500
                                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                      Nothing to do - Your installation is using the correct paths.
                                      Nothing to do - Your version is the recommended one.
                                      You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
                                      Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
                                      • Glasfaser
                                        @fritzk
                                        curl -fsL https://iobroker.net/fix.sh | bash -
                                          @glasfaser
                                          .....hat sich leider auch nix geändert.....werde wahrscheinlich eine Neuinstallation machen müssen....
                                          proxio@Haupt-IoBroker:/opt/iobroker$ curl -fsL https://iobroker.net/fix.sh | bash -
                                          library: loaded
                                          Library version=2022-12-09
                                              Welcome to the ioBroker installation fixer!
                                              Script version: 2023-04-02
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/5)
                                          Get:1 http://security.debian.org bookworm-security InRelease [48.0 kB]
                                          Hit:2 http://deb.debian.org/debian bookworm InRelease
                                          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Get:5 http://security.debian.org bookworm-security/main amd64 Packages [78.6 kB]
                                          Get:6 http://security.debian.org bookworm-security/main Translation-en [45.3 kB]
                                          Fetched 172 kB in 0s (349 kB/s)
                                          Reading package lists... Done
                                          Installed gcc-c++
                                              Checking ioBroker user and directory permissions (2/5)
                                          Created /etc/sudoers.d/iobroker
                                          Fixing directory permissions...
                                              Check and cleanup npm temporary directories (3/5)
                                          Done.
                                              Database maintenance (4/5)
                                          Checking for uncompressed JSONL databases... This might take a while!
                                          Compressing /opt/iobroker/iobroker-data/states.jsonl
                                          Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                          Compressed 2 JSONL files. Done
                                              Checking autostart (5/5)
                                          Enabling autostart...
                                          Autostart enabled!
                                              Your installation was fixed successfully
                                              Run iobroker start to start ioBroker again!
                                          proxio@Haupt-IoBroker:/opt/iobroker$ iobroker start
                                          Objects type: jsonl
                                          States  type: jsonl
                                          • Glasfaser
                                            @fritzk
                                            Gerade noch ein Fragezeichen ...
                                            denn was ich nicht verstehe ... du schreibst
                                            Zitat : .... ich nutze den Befehl .... und dann läuft ioBroker
                                            und du zeigst auch danach
                                            *** ioBroker-Installation ***
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            3934
