    4. Iobroker Problem js controller stürtzt ab
      Fritzk @Glasfaser last edited by
      @glasfaser
      Hat leider auch nicht geholfen
      ioBroker nodejs fixer 2023-10-03
      Recommended nodejs-version is: 18.18.0
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      Nothing to do - Your installation is using the correct paths.
      Nothing to do - Your version is the recommended one.
      You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
      Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
      • Glasfaser
        Glasfaser @Fritzk last edited by
        @fritzk
        curl -fsL https://iobroker.net/fix.sh | bash -
          @glasfaser
          .....hat sich leider auch nix geändert.....werde wahrscheinlich eine Neuinstallation machen müssen....
          proxio@Haupt-IoBroker:/opt/iobroker$ curl -fsL https://iobroker.net/fix.sh | bash -
          library: loaded
          Library version=2022-12-09
              Welcome to the ioBroker installation fixer!
              Script version: 2023-04-02
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          [sudo] password for proxio:
          Get:1 http://security.debian.org bookworm-security InRelease [48.0 kB]
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Get:5 http://security.debian.org bookworm-security/main amd64 Packages [78.6 kB]
          Get:6 http://security.debian.org bookworm-security/main Translation-en [45.3 kB]
          Fetched 172 kB in 0s (349 kB/s)
          Reading package lists... Done
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          proxio@Haupt-IoBroker:/opt/iobroker$ iobroker start
          proxio@Haupt-IoBroker:/opt/iobroker$ iobroker status
          iobroker is not running on this host.
          Objects type: jsonl
          States  type: jsonl
          • Glasfaser
            @fritzk
            Gerade noch ein Fragezeichen ...
            denn was ich nicht verstehe ... du schreibst
            Zitat : .... ich nutze den Befehl .... und dann läuft ioBroker
            und du zeigst auch danach
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
              Thomas Braun Most Active @Fritzk last edited by
              @fritzk
              systemctl list-unit-files
              Achtung, sind mehrere Seiten.
                @glasfaser
                wenn ich das in Putty eingebe
                cd /opt/iobroker
                node node_modules/iobroker.js-controller/controller.js --logs
                dann startet er und läuft ganz normal
                Darf dann aber in putty nix mehr machen. sobald ich die Eingabetaste drücke oder die ssh Verbindung beende, stürtzt er wieder ab.
                Warum weshalb das so ist.....ist mir ein großes Rätsel.
                Das letzte was ich gemacht habe wo er noch in Ordnung war, ich hab mir Material Design Widget installiert für meine Vis und Tag darauf hab ich gemerkt das der Admin nicht mehr erreichbar ist und nixmehr funktioniert...
                  Fritzk @Thomas Braun last edited by
                  Okay hier alles komplett
                  proxio@Haupt-IoBroker:/opt/iobroker$ systemctl list-unit-files
                  UNIT FILE                              STATE           PRESET
                  proc-sys-fs-binfmt_misc.automount      static          -
                  dev-hugepages.mount                    static          -
                  dev-mqueue.mount                       static          -
                  proc-fs-nfsd.mount                     static          -
                  proc-sys-fs-binfmt_misc.mount          disabled        disabled
                  run-rpc_pipefs.mount                   generated       -
                  sys-fs-fuse-connections.mount          static          -
                  sys-kernel-config.mount                masked          enabled
                  sys-kernel-debug.mount                 masked          enabled
                  sys-kernel-tracing.mount               static          -
                  var-lib-nfs-rpc_pipefs.mount           static          -
                  postfix-resolvconf.path                enabled         enabled
                  systemd-ask-password-console.path      static          -
                  systemd-ask-password-wall.path         static          -
                  session-188.scope                      transient       -
                  apt-daily-upgrade.service              static          -
                  apt-daily.service                      static          -
                  auth-rpcgss-module.service             static          -
                  autovt@.service                        alias           -
                  console-getty.service                  enabled-runtime disabled
                  container-getty@.service               indirect        enabled
                  cron.service                           enabled         enabled
                  cryptdisks-early.service               masked          enabled
                  cryptdisks.service                     masked          enabled
                  dbus-org.freedesktop.hostname1.service alias           -
                  dbus-org.freedesktop.locale1.service   alias           -
                  dbus-org.freedesktop.login1.service    alias           -
                  dbus-org.freedesktop.timedate1.service alias           -
                  dbus-org.freedesktop.timesync1.service alias           -
                  dbus.service                           static          -
                  debug-shell.service                    disabled        disabled
                  dpkg-db-backup.service                 static          -
                  e2scrub@.service                       static          -
                  e2scrub_all.service                    static          -
                  e2scrub_fail@.service                  static          -
                  e2scrub_reap.service                   enabled         enabled
                  emergency.service                      static          -
                  fstrim.service                         static          -
                  getty-static.service                   static          -
                  getty@.service                         disabled        enabled
                  hwclock.service                        masked          enabled
                  ifup@.service                          static          -
                  ifupdown-pre.service                   static          -
                  ifupdown-wait-online.service           enabled         enabled
                  initrd-cleanup.service                 static          -
                  initrd-parse-etc.service               static          -
                  initrd-switch-root.service             static          -
                  initrd-udevadm-cleanup-db.service      static          -
                  iobroker.service                       enabled         enabled
                  kmod-static-nodes.service              static          -
                  kmod.service                           alias           -
                  logrotate.service                      static          -
                  man-db.service                         static          -
                  modprobe@.service                      static          -
                  networking.service                     enabled         enabled
                  nfs-common.service                     masked          enabled
                  nfs-idmapd.service                     static          -
                  nfs-utils.service                      static          -
                  nftables.service                       enabled         enabled
                  pam_namespace.service                  static          -
                  portmap.service                        alias           -
                  postfix-resolvconf.service             enabled         enabled
                  postfix.service                        enabled         enabled
                  postfix@.service                       indirect        enabled
                  procps.service                         alias           -
                  quotaon.service                        static          -
                  rc-local.service                       static          -
                  rc.service                             masked          enabled
                  rcS.service                            masked          enabled
                  rescue.service                         static          -
                  rpc-gssd.service                       static          -
                  rpc-statd-notify.service               static          -
                  rpc-statd.service                      static          -
                  rpc-svcgssd.service                    static          -
                  rpcbind.service                        enabled         enabled
                  serial-getty@.service                  disabled        enabled
                  ssh.service                            enabled         enabled
                  sshd.service                           alias           -
                  sudo.service                           masked          enabled
                  system-update-cleanup.service          static          -
                  systemd-ask-password-console.service   static          -
                  systemd-ask-password-wall.service      static          -
                  systemd-backlight@.service             static          -
                  systemd-binfmt.service                 static          -
                  systemd-boot-check-no-failures.service disabled        disabled
                  systemd-exit.service                   static          -
                  systemd-firstboot.service              static          -
                  systemd-fsck-root.service              static          -
                  systemd-fsck@.service                  static          -
                  systemd-fsckd.service                  static          -
                  systemd-halt.service                   static          -
                  systemd-hibernate-resume@.service      static          -
                  systemd-hibernate.service              static          -
                  systemd-hostnamed.service              static          -
                  systemd-hybrid-sleep.service           static          -
                  systemd-initctl.service                static          -
                  systemd-journal-flush.service          static          -
                  systemd-journald.service               static          -
                  systemd-journald@.service              static          -
                  systemd-kexec.service                  static          -
                  systemd-localed.service                static          -
                  systemd-logind.service                 static          -
                  systemd-machine-id-commit.service      static          -
                  systemd-modules-load.service           static          -
                  systemd-network-generator.service      enabled         enabled
                  systemd-networkd-wait-online.service   disabled        disabled
                  systemd-networkd-wait-online@.service  disabled        enabled
                  systemd-networkd.service               disabled        disabled
                  systemd-pcrphase-initrd.service        static          -
                  systemd-pcrphase-sysinit.service       static          -
                  systemd-pcrphase.service               static          -
                  systemd-poweroff.service               static          -
                  systemd-pstore.service                 enabled         enabled
                  systemd-quotacheck.service             static          -
                  systemd-random-seed.service            static          -
                  systemd-reboot.service                 static          -
                  systemd-remount-fs.service             enabled-runtime enabled
                  systemd-repart.service                 static          -
                  systemd-rfkill.service                 static          -
                  systemd-suspend-then-hibernate.service static          -
                  systemd-suspend.service                static          -
                  systemd-sysctl.service                 static          -
                  systemd-sysext.service                 enabled         enabled
                  systemd-sysusers.service               static          -
                  systemd-time-wait-sync.service         disabled        disabled
                  systemd-timedated.service              static          -
                  systemd-timesyncd.service              enabled         enabled
                  systemd-tmpfiles-clean.service         static          -
                  systemd-tmpfiles-setup-dev.service     static          -
                  systemd-tmpfiles-setup.service         static          -
                  systemd-udev-settle.service            static          -
                  systemd-udev-trigger.service           static          -
                  systemd-udevd.service                  static          -
                  systemd-update-utmp-runlevel.service   static          -
                  systemd-update-utmp.service            static          -
                  systemd-user-sessions.service          static          -
                  systemd-volatile-root.service          static          -
                  udev.service                           alias           -
                  urandom.service                        generated       -
                  user-runtime-dir@.service              static          -
                  user@.service                          static          -
                  x11-common.service                     masked          enabled
                  machine.slice                          static          -
                  system-systemd\x2dcryptsetup.slice     static          -
                  user.slice                             static          -
                  dbus.socket                            static          -
                  rpcbind.socket                         enabled         enabled
                  ssh.socket                             enabled         enabled
                  syslog.socket                          static          -
                  systemd-fsckd.socket                   static          -
                  systemd-initctl.socket                 static          -
                  systemd-journald-audit.socket          masked          enabled
                  systemd-journald-dev-log.socket        static          -
                  systemd-journald-varlink@.socket       static          -
                  systemd-journald.socket                static          -
                  systemd-journald@.socket               static          -
                  systemd-networkd.socket                enabled         enabled
                  systemd-rfkill.socket                  static          -
                  systemd-udevd-control.socket           static          -
                  systemd-udevd-kernel.socket            static          -
                  basic.target                           static          -
                  blockdev@.target                       static          -
                  bluetooth.target                       static          -
                  boot-complete.target                   static          -
                  cryptsetup-pre.target                  static          -
                  cryptsetup.target                      static          -
                  ctrl-alt-del.target                    alias           -
                  default.target                         alias           -
                  emergency.target                       static          -
                  exit.target                            disabled        disabled
                  factory-reset.target                   static          -
                  final.target                           static          -
                  first-boot-complete.target             static          -
                  getty-pre.target                       static          -
                  getty.target                           static          -
                  graphical.target                       static          -
                  halt.target                            disabled        disabled
                  hibernate.target                       static          -
                  hybrid-sleep.target                    static          -
                  initrd-fs.target                       static          -
                  initrd-root-device.target              static          -
                  initrd-root-fs.target                  static          -
                  initrd-switch-root.target              static          -
                  initrd-usr-fs.target                   static          -
                  initrd.target                          static          -
                  integritysetup-pre.target              static          -
                  integritysetup.target                  static          -
                  kexec.target                           disabled        disabled
                  local-fs-pre.target                    static          -
                  local-fs.target                        static          -
                  multi-user.target                      static          -
                  network-online.target                  static          -
                  network-pre.target                     static          -
                  network.target                         static          -
                  nfs-client.target                      enabled         enabled
                  nss-lookup.target                      static          -
                  nss-user-lookup.target                 static          -
                  paths.target                           static          -
                  poweroff.target                        disabled        disabled
                  printer.target                         static          -
                  reboot.target                          enabled         enabled
                  remote-cryptsetup.target               enabled         enabled
                  remote-fs-pre.target                   static          -
                  remote-fs.target                       enabled         enabled
                  remote-veritysetup.target              enabled         enabled
                  rescue-ssh.target                      static          -
                  rescue.target                          static          -
                  rpc_pipefs.target                      generated       -
                  rpcbind.target                         static          -
                  runlevel0.target                       alias           -
                  runlevel1.target                       alias           -
                  runlevel2.target                       alias           -
                  runlevel3.target                       alias           -
                  runlevel4.target                       alias           -
                  runlevel5.target                       alias           -
                  runlevel6.target                       alias           -
                  shutdown.target                        static          -
                  sigpwr.target                          static          -
                  slices.target                          static          -
                  smartcard.target                       static          -
                  sockets.target                         static          -
                  sound.target                           static          -
                  suspend-then-hibernate.target          static          -
                  suspend.target                         static          -
                  swap.target                            static          -
                  sysinit.target                         static          -
                  system-update-pre.target               static          -
                  system-update.target                   static          -
                  time-set.target                        static          -
                  time-sync.target                       static          -
                  timers.target                          static          -
                  umount.target                          static          -
                  usb-gadget.target                      static          -
                  veritysetup-pre.target                 static          -
                  veritysetup.target                     static          -
                  apt-daily-upgrade.timer                enabled         enabled
                  apt-daily.timer                        enabled         enabled
                  dpkg-db-backup.timer                   enabled         enabled
                  e2scrub_all.timer                      enabled         enabled
                  fstrim.timer                           enabled         enabled
                  logrotate.timer                        enabled         enabled
                  man-db.timer                           enabled         enabled
                  systemd-tmpfiles-clean.timer           static          -
                  244 unit files listed.
                    @fritzk sagte in Iobroker Problem js controller stürtzt ab:
                    Das ist so, weil der Prozess abgebrochen wird, wenn der entsprechende user sich ausloggt.
                    Deswegen wird sowas auch "anders" gestartet, mittlerweile per systemd. Das ist aber bei dir 'kaputt'.
                      @fritzk
                      systemctl list-units --failed --no-pager
                        proxio@Haupt-IoBroker:/opt/iobroker$ systemctl list-units --failed --no-pager
                          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                        * networking.service   loaded failed failed Raise network interfaces
                        LOAD   = Reflects whether the unit definition was properly loaded.
                        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                        SUB    = The low-level unit activation state, values depend on unit type.
                        2 loaded units listed.
                          networking
                          Starte das mal neu
                          sudo systemctl restart networking.service
                            proxio@Haupt-IoBroker:/opt/iobroker$ sudo systemctl restart networking.service
                            Job for networking.service failed because the control process exited with error code.
                            See "systemctl status networking.service" and "journalctl -xeu networking.service" for details.
                                proxio@Haupt-IoBroker:/opt/iobroker$ systemctl status networking.service
                                x networking.service - Raise network interfaces
                                     Loaded: loaded (/lib/systemd/system/networking.service; enabled; preset: enabled)
                                     Active: failed (Result: exit-code) since Fri 2023-10-06 21:58:16 CEST; 3min 40s ago
                                       Docs: man:interfaces(5)
                                    Process: 5671 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
                                    Process: 5698 ExecStopPost=/usr/bin/touch /run/network/restart-hotplug (code=exited, status=0/SUCCESS)
                                   Main PID: 5671 (code=exited, status=1/FAILURE)
                                        CPU: 46ms
                                  @fritzk
                                  Meiner Meinung nach sollte der Service laufen. Aber mit Proxmox kenn ich mich nicht aus.
                                  Verabschiede mich dann aus dem Thread.
                                    Okay ich danke dir für deine Hilfe. Werde jetzt dann auch mal aufgeben. Ich probier morgen mal eine komplette Neuinstallation. vielleicht och ohne Proxmox
                                    • O
                                      oxident last edited by oxident
                                      Möchte mich hier auch mal reinhängen. Prinzipiell läuft meine Installation als Proxmox-Container stressfrei, jedoch wird auch bei mir minütlich (!) das syslog mit folgender Meldung geflutet:
                                      Nov 15 17:49:01 iobroker bash[768020]: URIError: URI malformed
                                      Nov 15 17:49:01 iobroker bash[768020]:     at decodeURI (<anonymous>)
                                      Nov 15 17:49:01 iobroker bash[768020]:     at /opt/iobroker/node_modules/iobroker.web/main.js:1637:31
                                      Nov 15 17:49:01 iobroker bash[768020]:     at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                                      Nov 15 17:49:01 iobroker bash[768020]:     at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
                                      Nov 15 17:49:01 iobroker bash[768020]:     at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
                                      Nov 15 17:49:01 iobroker bash[768020]:     at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
                                      Nov 15 17:49:01 iobroker bash[768020]:     at next (/opt/iobroker/node_modules/express/lib/router/index.js:280:10)
                                      Nov 15 17:49:01 iobroker bash[768020]:     at getSocketIoFile (/opt/iobroker/node_modules/iobroker.web/main.js:1010:9)
                                      Nov 15 17:49:01 iobroker bash[768020]:     at /opt/iobroker/node_modules/iobroker.web/main.js:1154:44
                                      Im ioBroker sind aber keinerlei Fehlermeldungen zu finden. Wenn ich das richtig interpretiere, dann versucht der Web-Adapter eine URL aufzurufen?
                                      3933
