    4. [Adapter] cloudfreie Auslesung von Deye-Invertern
    • Alexander Aschenbrenner
      Alexander Aschenbrenner @Rene55 last edited by
      @rene55
        "ipaddress": "192.168.200.95",
        "port": 8899,
        "pollInterval": 60,
        "registers": [
            "registerStart": 0,
            "registerEnd": 40
            "registerStart": 59,
            "registerEnd": 90
            "registerStart": 109,
            "registerEnd": 112
            "registerStart": 150,
            "registerEnd": 153
        "coils": [
            "register": 0,
            "rules": 1,
            "key": "DT",
            "name": "Device Type",
            "unit": "",
            "factor": 0
            "register": 2,
            "rules": 7,
            "key": "COMM_PTC_v1",
            "name": "Communication Protocol Version",
            "unit": "",
            "factor": 0
            "register": 3,
            "rules": 5,
            "key": "SN1",
            "name": "Inverter Serial Number",
            "unit": "",
            "factor": 0
            "register": 13,
            "rules": 7,
            "key": "DC_M_FV",
            "name": "Control Board Firmware",
            "unit": "",
            "factor": 0
            "register": 14,
            "rules": 7,
            "key": "AC_VER",
            "name": "Communication Board Firmware",
            "unit": "",
            "factor": 0
            "register": 16,
            "rules": 3,
            "key": "RP",
            "name": "Rated Power",
            "unit": "W",
            "factor": 1
            "register": 18,
            "rules": 8,
            "key": "NOMP",
            "name": "Number of MPPT Path",
            "unit": "",
            "factor": 0
            "register": 18,
            "rules": 9,
            "key": "NOP",
            "name": "Number of Phases",
            "unit": "",
            "factor": 0
            "register": 21,
            "rules": 1,
            "key": "SScT",
            "name": "Startup Self-checking Time",
            "unit": "",
            "factor": 0
            "register": 40,
            "rules": 1,
            "key": "Power_Reg",
            "name": "Active Power Regulation",
            "unit": "%",
            "factor": 0,
            "nullable": true
            "register": 59,
            "rules": 1,
            "key": "ST_w1",
            "name": "Running Status",
            "unit": "",
            "factor": 0
            "register": 60,
            "rules": 1,
            "key": "Etdy_ge0",
            "name": "Production Today",
            "unit": "kWh",
            "factor": 1
            "register": 63,
            "rules": 1,
            "key": "Et_ge0",
            "name": "Production Total",
            "unit": "kWh",
            "factor": 1,
            "nullable": true
            "register": 65,
            "rules": 1,
            "key": "Etdy_ge1",
            "name": "Production Today PV1",
            "unit": "kWh",
            "factor": 1
            "register": 66,
            "rules": 1,
            "key": "Etdy_ge2",
            "name": "Production Today PV2",
            "unit": "kWh",
            "factor": 1
            "register": 69,
            "rules": 3,
            "key": "Et_ge1",
            "name": "Production Total PV1",
            "unit": "kWh",
            "factor": 1
            "register": 71,
            "rules": 3,
            "key": "Et_ge2",
            "name": "Production Total PV2",
            "unit": "kWh",
            "factor": 1,
            "nullable": false
            "register": 73,
            "rules": 1,
            "key": "AV1",
            "name": "AC Voltage 1",
            "unit": "V",
            "factor": 1
            "register": 79,
            "rules": 1,
            "key": "AC_Fo1",
            "name": "AC Frequency 1",
            "unit": "Hz",
            "factor": 2
            "register": 86,
            "rules": 3,
            "key": "Apo_t1",
            "name": "Total AC Output Power (Active)",
            "unit": "W",
            "factor": 1
            "register": 90,
            "rules": 6,
            "key": "AC_RDT_T1",
            "name": "AC Radiator Temp",
            "unit": "°C",
            "factor": 2,
            "nullable": false
            "register": 109,
            "rules": 1,
            "key": "DV1",
            "name": "DC Voltage PV1",
            "unit": "V",
            "factor": 1,
            "nullable": false
            "register": 110,
            "rules": 1,
            "key": "DC1",
            "name": "DC Current PV1",
            "unit": "A",
            "factor": 1
            "register": 111,
            "rules": 1,
            "key": "DV2",
            "name": "DC Voltage PV2",
            "unit": "V",
            "factor": 1
            "register": 112,
            "rules": 1,
            "key": "DC2",
            "name": "DC Current PV2",
            "unit": "A",
            "factor": 1,
            "nullable": false
            "register": 150,
            "rules": 1,
            "key": "GV_uL",
            "name": "Grid Voltage Upper Limit",
            "unit": "V",
            "factor": 1,
            "nullable": false
            "register": 151,
            "rules": 1,
            "key": "GV_lL",
            "name": "Grid Voltage Lower Limit",
            "unit": "V",
            "factor": 1,
            "nullable": false
            "register": 152,
            "rules": 1,
            "key": "GF_uL",
            "name": "Grid Frequency Upper Limit",
            "unit": "Hz",
            "factor": 2,
            "nullable": true
            "register": 153,
            "rules": 1,
            "key": "GF_lL",
            "name": "Grid Frequency Lower Limit",
            "unit": "Hz",
            "factor": 2,
            "nullable": true
        "computes": [
            "values": "DV1*DC1",
            "key": "DP1",
            "name": "DC Power PV1",
            "unit": "W",
            "factor": 0
            "values": "DV2*DC2",
            "key": "DP2",
            "name": "DC Power PV2",
            "unit": "W",
            "factor": 0
            "values": "Power_Reg*RP",
            "key": "LP",
            "name": "Limited Power",
            "unit": "W",
            "factor": 2
        "logger": 3904723806
      • Rene55
        Rene55 @Alexander Aschenbrenner last edited by
        @alexander-aschenbrenner Es ist zum Mäusemelken! Datei eingespielt - alles funktioniert ohne RangeError.
        Mag der Geier wissen, woran das liegt. Ich warte weiter auf mein Relais.
        Alexander Aschenbrenner 2 Replies Last reply Reply Quote 0
          @rene55 evtl. weil durch das Relais auch noch Daten übertragen werden!?
          2023-10-06 13_13_39-SOLARMAN Smart.png 2023-10-06 13_14_36-SOLARMAN Smart.png
            @rene55 wenn's dir hilft kann ich dir auch den Port für den Deye öffnen!? Weiteres dann per PN.
            • Rene55
              @alexander-aschenbrenner Es kann gut sein, dass die neue Firmware auch Daten vom Relais überträgt. Deswegen sollte aber das grundsätzliche Vorgehen, dass wir die (schon bekannten) Register auslesen, nicht völlig verändert sein.
              Ja, wenn ich direkt den WR auslesen könnte, könnte schon helfen. Hab ich zwar noch nie gemacht - aber ein Versuch wäre es ja Wert.
              Alexander Aschenbrenner 1 Reply Last reply Reply Quote 0
                @rene55 hab dir eine Email geschickt.
                • Rene55
                  @alexander-aschenbrenner Danke Alexander. Ich hab gerade mal versucht - klappt so nicht. Error: getaddrinfo ENOTFOUND http://alexxxxxx
                    @rene55 schade. Dann schließe ich den Port wieder, oder fällt dir noch was ein?
                    • Rene55
                      @alexander-aschenbrenner Nee, leider nicht. Da hab ich dann doch zuwenig Ahnung vom Netzwerken und vom Freigeben insbesondere. Wäre ja auch zu einfach gewesen.
                      Alexander Aschenbrenner 3 Replies Last reply Reply Quote 0
                        @rene55 Servus, hast Email. So klappt es bei meinem Testsystem.
                          @rene55 und hier bekomme ich eine andere Fehlermeldung.
                          2023-10-07 09:37:33.832 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! dc
                          2023-10-07 09:37:35.507 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! be
                          2023-10-07 09:37:35.510 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! be
                          2023-10-07 09:37:35.608 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! 74
                          2023-10-07 09:37:36.208 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! 58
                          2023-10-07 09:37:37.407 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! dc
                          2023-10-07 09:37:38.007 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! be
                          2023-10-07 09:37:38.608 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! be
                          2023-10-07 09:37:39.206 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! 74
                          2023-10-07 09:37:39.810 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! 59
                          2023-10-07 09:37:41.007 - error: deyeidc.0 (27888) Error: Frame CheckSum faulty! dc
                            @rene55 funktioniert die Verbindung?
                            • Rene55
                              @alexander-aschenbrenner Ähm. Hast du den Port (neu) freigeschaltet? Dann versuche ich es noch einmal.
                                Alexander Aschenbrenner @Rene55 last edited by Alexander Aschenbrenner
                                @rene55 Hab dir per Email die IP Adresse geschickt, bei mir ging es damit. Hab einen externen ioBroker per LTE am laufen, dieser baut die Verbindung auf. Sollte dann bei dir auch klappen. 👍
                                Wenn nötig kann ich später den Wechselrichter per Netzteil speisen. Melde dich einfach.
                                • Rene55
                                  @alexander-aschenbrenner Hab die Mail gerade erst gescheckt. Tatsache: Damit bekomme ich Daten - und die Fehler 😕 . Kannst du mir den Zugang so lassen, bis ich was gefunden habe? Du hast die Konfiguration ja gesichert - falls ich anndere Einstellungen machen muss.
                                    @rene55 ja, passt. Tob dich aus.
                                    • Rene55
                                      @alexander-aschenbrenner Ich hatte einige Mühe, den Ablauf gebremst zu kriegen. Aktuell holt der ja gefühlt alle paar Sekunden Daten ab, kein Wunder, dass der sich verschluckt. Ganz kurios ist die erste Antwort vom WR - völlig neues Verhalten.
                                      Aktuell komm ich nicht mehr drauf. Stimmt die IP noch? Scheint Sonne?
                                        @rene55 sollte noch funktionieren.
                                        Rene55 2 Replies Last reply Reply Quote 0
                                        • Rene55
                                          2023-10-07 16:17:56.587 - error: deyeidc.0 (17729) Error during connection: Error: read ECONNRESET
                                          2023-10-07 16:17:56.587 - debug: deyeidc.0 (17729) Connection closed
                                          Manchmal komm ich noch durch. Kannst du evtl. deine Instanz ausschalten? Mit zweien drauf runhacken ist eh nicht so gut.
                                            @rene55 OK, mache gerade einen Restart und schalte meine Instanz aus.
                                            1158
                                            365073
