    5. 15 Minuten Timer ohne Funktion...
      Dragon last edited by
      Leider weiterhin keine Lösung in Sicht.
      • DJMarc75
        DJMarc75 @Dragon last edited by DJMarc75
        @dragon
        Mal ein neues Skript erstellen, importieren, Datenpunkte anpassen und das "alte" ausschalten:
         <variables>
           <variable id="p266Yw/wiuv}`n4IAI@w">Luefter_GaesteWC</variable>
           <variable type="interval" id="LuefterGast">LuefterGast</variable>
         </variables>
         <block type="on_ext" id="kJsA#^t?i(cUO:[X)7j|" x="37" y="438">
           <value name="OID0">
             <shadow type="field_oid" id="5no8j(G1eYIzjY4baUP.">
             <block type="controls_if" id="6pq[QkbmHPVeVb;AiHb?">
                 <block type="on_source" id="9|A0fsw!3Wg@W/Fd+{Bb">
                 <block type="variables_set" id="#GLJ,^*,X2dXLH[oWjgr">
                   <field name="VAR" id="p266Yw/wiuv}`n4IAI@w">Luefter_GaesteWC</field>
                     <block type="get_value" id="Hcdrs]ckEU8^8d%L:X~j">
                       <field name="OID">ID auswählen</field>
                     <block type="update" id="SAjv,/2/;i[DW/[fE5WD">
                         <block type="variables_get" id="D1E-!k?}^yP4*Y+U@`cY">
                         <block type="timeouts_setinterval" id="=XRGPjY)tfh{@lc3F*,g">
                           <field name="NAME">LuefterGast</field>
                           <field name="INTERVAL">5</field>
                             <block type="math_change" id="(DduzWz:KD]#0Bp[i5Eg">
                               <value name="DELTA">
                                 <shadow type="math_number" id="5v_i#;D3c)VvY5fRNl66">
                                   <field name="NUM">-1</field>
                                 <block type="controls_if" id="SsRd5GL1J1.Nvvl:oCJy">
                                     <block type="logic_compare" id="eEXF]vyCL#!#]C/Ch45e">
                                       <field name="OP">LTE</field>
                                         <block type="variables_get" id="J5G[GL?|3h;b(dA(D[t=">
                                         <block type="math_number" id="b!F-G#WO-+|Z?zd[s^rI">
                                           <field name="NUM">0</field>
                                     <block type="control" id="_K%l!.]RK]xZmk]I~FW4">
                                         <block type="logic_boolean" id="#cOcl)PSmULKD%;?`v4w">
                                         <block type="timeouts_clearinterval" id="pIC_B;muNiEoMh0jfiBs">
                                     <block type="update" id="D#Oc!kdASe6PKAv`}uvv">
                                         <block type="variables_get" id="=7Axkk{;s`}P4#[8kp[N">
               <statement name="ELSE">
                 <block type="timeouts_clearinterval" id="wkTiVAFR6S`-:_xvb)rW">
                     <block type="update" id="fJ8yHIoG}Y/a7!?#F]-(">
                         <block type="math_number" id="{_E:{a.6#GOE?7p1I!21">
          Dragon @DJMarc75 last edited by
          @djmarc75
          Ich sehe beim besten willen keinen Unterschied. Was hast du anders gemacht?
          • DJMarc75
            @dragon sagte in 15 Minuten Timer ohne Funktion...:
            in Bezug zu welchem Deiner Versuche?
            k.A.
            Funktioniert es jetzt ?
              @djmarc75 Ja es funktioniert jetzt. ABer iwenn ich vergleiche nutzt du exakt die gleichen Blöcke...
              • DJMarc75
                @dragon Wo hast Du denn "Dein" Skript abgelegt? Hoffentlich nicht unter "global"
                  @djmarc75 Der Skriptadapter hat eine Ordnerstruktur
                  Homoran DJMarc75 2 Replies Last reply Reply Quote 0
                    Homoran Global Moderator Administrators @Dragon last edited by
                    ??? ja!
                    und wo in drr Struktur liegt das Skript?
                    @djmarc75 sagte in 15 Minuten Timer ohne Funktion...:
                    • DJMarc75
                      richtig wäre alle Skripte unter common abzulegen.
                      nicht so richtig wäre etwas unter global abzulegen, wobei man den Ordner nur sieht wenn man den Expertenmodus anktiviert
                      Aber wie der Name "Expertenmodus" schon sagt sollte man wissen was man tut ! 😉
                        Dragon @Homoran last edited by
                        • DJMarc75
                          @dragon alles richtig ! 👍
                          1385
