    4. VIS 2 update auf 2.3.0 keine Widgets mehr
      edi1975 @Feuersturm last edited by
      @feuersturm sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
      iob diag
      OK Repositories ist jetzt auf Beta deswegen Updates zeigt.
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
              Machine ID: 14803bb7a50c4def81086c9b741cdd12
                 Boot ID: bca142a15bfd4377aef46189724c0809
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       20:08:39 up 23:37,  3 users,  load average: 1.04, 0.85, 0.78
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=47.7'C
      volt=0.9160V
      *** Time and Time Zones ***
                     Local time: Fri 2023-10-06 20:08:39 CEST
                 Universal time: Fri 2023-10-06 18:08:39 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      edi_admin
      /home/edi_admin
      edi_admin adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	true
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            7.8G        3.4G        325M         51M        4.1G        4.2G
      Swap:            99M          0B         99M
      Total:          7.9G        3.4G        425M
               7811 M total memory
               3422 M used memory
               4783 M active memory
               2274 M inactive memory
                325 M free memory
                295 M buffer memory
               3767 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      Filesystem                      Type      Size  Used Avail Use% Mounted on
      /dev/root                       ext4      117G  8.3G  103G   8% /
      devtmpfs                        devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs                           tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                           tmpfs     1.6G  1.3M  1.6G   1% /run
      tmpfs                           tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      /dev/sda1                       vfat      251M   31M  220M  13% /boot
      tmpfs                           tmpfs     782M   24K  782M   1% /run/user/1000
      //192.168.178.7/Backup-ioBroker cifs      2.7T  1.6T  1.2T  58% /opt/iobroker/backups
      Show mounted filesystems (real ones only):
      TARGET                  SOURCE                          FSTYPE OPTIONS
      /                       /dev/sda2                       ext4   rw,noatime,stripe=8191
      |-/boot                 /dev/sda1                       vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/opt/iobroker/backups //192.168.178.7/Backup-ioBroker cifs   rw,relatime,vers=3.1.1,cache=strict,username=edi_admin,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.7,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
      /var:
      1.6G	/var/
      994M	/var/log
      969M	/var/log/journal/14803bb7a50c4def81086c9b741cdd12
      288M	/var/cache
      Archived and active journals take up 968.0M in the file system.
      /opt/iobroker/backups:
      1.1G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      697M	/opt/iobroker/iobroker-data/
      565M	/opt/iobroker/iobroker-data/files
      174M	/opt/iobroker/iobroker-data/files/vis-2
      90M	/opt/iobroker/iobroker-data/files/vis
      82M	/opt/iobroker/iobroker-data/files/vis/widgets
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.d3c12542.js.map
      18M	/opt/iobroker/iobroker-data/files/s7.admin/static/js/main.59233a80.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.17.1
      /usr/bin/node 		v18.17.1
      /usr/bin/npm 		9.6.7
      /usr/bin/npx 		9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller: 	5.0.12
      admin: 		6.10.2
      javascript: 	7.1.4
      Adapters from github: 	2
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
      + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
      + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
      + system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.heos.0                   : heos                  : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
        system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 1080, bind: 0.0.0.0
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.26
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 192.168.178.26
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "awtrix-light" : 0.9.1    , installed 0.8.0  [Updatable]
      Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
      Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
      Adapter    "denon"        : 1.15.4   , installed 1.15.4
      Adapter    "discovery"    : 4.1.0    , installed 4.0.0  [Updatable]
      Adapter    "doorbird"     : 1.3.0    , installed 1.2.4  [Updatable]
      Adapter    "ems-esp"      : 2.4.1    , installed 2.4.1
      Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
      Adapter    "fhem"         : 2.0.5    , installed 2.0.5
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "heos"         : 2.1.0    , installed 2.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "lightcontrol" : 0.4.0    , installed 0.4.0
      Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
      Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.4  [Updatable]
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "s7"           : 1.3.15   , installed 1.3.15
      Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
      Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
      Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
      Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-2"        : 2.3.0    , installed 2.3.0
      Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
      Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
      Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
      Adapter    "wled"         : 0.7.1    , installed 0.7.0  [Updatable]
      Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
      Adapter    "zigbee2mqtt"  : 2.13.2   , installed 2.13.1 [Updatable]
      Objects and States
      Objects: 	10532
      States: 	9152
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 http://giteduberger.fr rpimonitor/ InRelease
      Get:6 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
      Update rpimonitor Packages Status
      Fetched 4586 B in 2s (2356 B/s)
      Reading package lists...
      Pending Updates: 25
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14269      621/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          16462      677/perl
      tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1001       50949      11834/io.sainlogic.
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14323      608/vncserver-x11-c
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       39707      7652/io.mqtt.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       38242      7247/node-red
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37337      6556/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35603      6556/iobroker.js-co
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          147718     26659/cupsd
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       899600     127695/sshd: edi_ad
      tcp        0      0 192.168.178.26:1882     0.0.0.0:*               LISTEN      1001       44141      9171/io.shelly.0
      tcp        0      0 192.168.178.26:1884     0.0.0.0:*               LISTEN      1001       43482      9234/io.sonoff.0
      tcp        0      0 0.0.0.0:8100            0.0.0.0:*               LISTEN      1001       44736      9976/io.doorbird.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14271      621/sshd: /usr/sbin
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       899599     127695/sshd: edi_ad
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       48183      10269/io.harmony.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          147717     26659/cupsd
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          14322      608/vncserver-x11-c
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53283      11962/io.simple-api
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       52686      12069/io.socketio.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       60297      14019/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35664      6581/io.admin.0
      udp        0      0 0.0.0.0:48671           0.0.0.0:*                           1001       46507      10341/io.heos.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16587      504/dhcpcd
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       48184      10269/io.harmony.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          146869     26662/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       60919      14089/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12112      442/avahi-daemon: r
      udp        0      0 0.0.0.0:34211           0.0.0.0:*                           108        12114      442/avahi-daemon: r
      udp6       0      0 :::33872                :::*                                108        12115      442/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12113      442/avahi-daemon: r
      2023-10-06 20:10:05.069  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:05.079  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:06.067  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:06.072  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:06.080  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:07.063  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:07.066  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:07.075  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:07.078  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:07.085  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.064  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.065  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.081  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.085  - info: web.0 (14019) ==> Connected system.user.admin from undefined
      2023-10-06 20:10:08.089  - info: web.0 (14019) <== Disconnect system.user.admin from undefined
      2023-10-06 20:10:08.186  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.188  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.190  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.192  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.193  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.195  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.196  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.197  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:08.200  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
      2023-10-06 20:10:10.107  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
      iob diag has finished.
      Press any key for a summary
      Copy text starting here:
      		     v.2023-06-20
               Icon name: computer
            Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		arm64
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		1000
      X-Server: 		true
      Pending OS-Updates: 	25
      Pending iob updates: 	13
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.1
      			/usr/bin/npm 		9.6.7
      			/usr/bin/npx 		9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        3.6G        847M         51M        3.3G        4.0G
      Swap:            99M          0B         99M
      Total:          7.9G        3.6G        947M
      Active iob-Instances: 	41
      ioBroker Core: 		js-controller 		5.0.12
      			admin 			6.10.2
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		10532
      States: 		9152
      Size of iob-Database:
      25M	/opt/iobroker/iobroker-data/objects.jsonl
      2.2M	/opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
        Thomas Braun Most Active @edi1975 last edited by
        @edi1975 sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
        X-Server: true
        Ausschalten.
        Pending Updates: 25
        Updaten
        • Glasfaser
          Glasfaser last edited by Glasfaser
          X-Server: true
          vncserver-x11-c
          cups-browsed
          wofür !?
            edi1975 @Glasfaser last edited by
            @glasfaser sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
            vncserver-x11-c
            also angeschlossen ist noch monitor deswegen Desktop, und vnc für zugriff wen monitor ist aus. Updates weil jetzt ist auf Beta umgeschaltet, aber das hat nichts zu tun mit meinem Problem meine ich so.
            Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Glasfaser @edi1975 last edited by Glasfaser
              @edi1975
              iob upload all
              einmal durchlaufen lassen ,
              dann
              sudo reboot
              was ist dann !?
                Auf einem Server wird beides nicht benötigt. VNC schon gerade gar nicht.
                  @glasfaser
                  durchgeführt aber ioBroker funktioniert jetzt, mein plan ist Proxmox VM alles neu Installieren und immer snapshot machen und Backup dort wird alles klappen, Backup von ioBroker hat mich schon mehr Mals enttäuscht.
                  Glasfaser Thomas Braun Feuersturm 3 Replies Last reply Reply Quote 0
                  • Glasfaser
                    ist deine Entscheidung ... aber falsch ...
                    So schleppst du immer Fehler mit
                    nutze BackitUp
                      Konkret? Hier hat das immer funktioniert. (Habs aber auch nur zweimal wirklich gebraucht, glaube ich.)
                      • Feuersturm
                        Feuersturm @edi1975 last edited by
                        @edi1975 Ich hab jetzt mal auf meinem Testsystem ein Backup via Konsole durchgeführt und auch einen restore über die Konsole gestartet. Nachdem ich alle Instanzen wieder gestartet habe ließ sich auch vis-2 (editor + runtime) ohne Probleme starten.
                        1322
