Warema WMS Adapter funktioniert nicht mehr
vielleicht kann mir hier jemand weiter helfen, seit heute ohne mein zutun stellte der Adpater den Betrieb ein uns lässt sich auch nicht mehr in gang bringen.
hier das Protokoll dazu
host.DESKTOP-TUF9MM7
2023-10-07 13:44:55.622 info Restart adapter system.adapter.wmswebcontrol.0 because enabled
2023-10-07 13:44:55.622 error instance system.adapter.wmswebcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
2023-10-07 13:44:55.622 error Caught by controller[0]: Node.js v20.7.0
2023-10-07 13:44:55.622 error Caught by controller[0]: }
2023-10-07 13:44:55.622 error Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
2023-10-07 13:44:55.622 error Caught by controller[0]: at Object.<anonymous> (C:\ioBroker\node_modules\axios-cookiejar-support\lib\index.js:8:40) {
2023-10-07 13:44:55.622 error Caught by controller[0]: at require (node:internal/modules/helpers:130:18)
2023-10-07 13:44:55.622 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1115:19)
2023-10-07 13:44:55.622 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:901:27)
2023-10-07 13:44:55.622 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1034:27)
2023-10-07 13:44:55.622 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:621:31)
2023-10-07 13:44:55.622 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:547:36)
2023-10-07 13:44:55.622 error Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:589:9)
2023-10-07 13:44:55.622 error Caught by controller[0]: at exportsNotFound (node:internal/modules/esm/resolve:259:10)
2023-10-07 13:44:55.622 error Caught by controller[0]: at new NodeError (node:internal/errors:405:5)
2023-10-07 13:44:55.622 error Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/defaults' is not defined by "exports" in C:\ioBroker\node_modules\axios\package.json
2023-10-07 13:44:55.621 error Caught by controller[0]: ^
2023-10-07 13:44:55.621 error Caught by controller[0]: throw e;
2023-10-07 13:44:55.621 error Caught by controller[0]: node:internal/modules/cjs/loader:553Danke im Voraus
@neo8006 sagte in Warema WMS Adapter funktioniert nicht mehr:
Node.js v20.7.0
Zu neu, installier die vorgesehene nodejs@18-Version.
Hallo Thomas, danke für die Antwort, hatte ich schon versucht, leider aber das selbe Fehlerbildhost.DESKTOP-TUF9MM7
2023-10-07 14:36:33.867 info Restart adapter system.adapter.wmswebcontrol.0 because enabled
2023-10-07 14:36:33.867 error instance system.adapter.wmswebcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
2023-10-07 14:36:33.867 error Caught by controller[0]: Node.js v18.18.0
2023-10-07 14:36:33.867 error Caught by controller[0]: }
2023-10-07 14:36:33.866 error Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
2023-10-07 14:36:33.866 error Caught by controller[0]: at Object.<anonymous> (C:\ioBroker\node_modules\axios-cookiejar-support\lib\index.js:8:40) {
2023-10-07 14:36:33.866 error Caught by controller[0]: at require (node:internal/modules/cjs/helpers:119:18)
2023-10-07 14:36:33.866 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
2023-10-07 14:36:33.866 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
2023-10-07 14:36:33.866 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
2023-10-07 14:36:33.866 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:636:31)
2023-10-07 14:36:33.866 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:567:36)
2023-10-07 14:36:33.866 error Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:698:9)
2023-10-07 14:36:33.866 error Caught by controller[0]: at exportsNotFound (node:internal/modules/esm/resolve:362:10)
2023-10-07 14:36:33.866 error Caught by controller[0]: at new NodeError (node:internal/errors:405:5)
2023-10-07 14:36:33.866 error Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/defaults' is not defined by "exports" in C:\ioBroker\node_modules\axios\package.json
2023-10-07 14:36:33.866 error Caught by controller[0]: ^
2023-10-07 14:36:33.866 error Caught by controller[0]: throw e;
2023-10-07 14:36:33.865 error Caught by controller[0]: node:internal/modules/cjs/loader:573
2023-10-07 14:36:33.249 info instance system.adapter.wmswebcontrol.0 started with pid 568 -
wmswebcontrol
Dann mach ein Issue auf.
Oder versuch dein Glück mit der github-Version, da scheint jüngst was passiert zu sein.Und setze Texte aus der Konsole in CodeTags. Kann man besser lesen.
@thomas-braun vielen Danke für den Tipp, über die NPM Version 0.0.6 läufts ohne Probleme!
