    4. BackItUp kann alte Backups nicht löschen
      theo996 last edited by theo996
      |Hardwaresystem:| Pi4 |
      |Arbeitsspeicher:| 8GB |
      |Festplattenart:| SSD |
      |Nodejs-Version:| v18.18.0 |
      |NPM-Version:| 9.8.1 |
      ich habe seit ich mit dem iob node fix Skript mein System auf 18.18.0 bekommen habe, Probleme mit BackItUp (v2.8.1).
      Anfängliche mount-Probleme aufs NAS habe ich nach Neuinstallation von BackItUp ausgeräumt, aber es bleibt das Problem, dass es folgende Fehlermeldung beim Backup gibt: "Backup files not deleted from /opt/iobroker/backups because some errors".
      Started iobroker ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false}
      [DEBUG] [mount] - noserverino option: true
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //xxx.xxx.xxx.xxx/Backup_ioBroker /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.raspberrypi 21065 states saved
      [DEBUG] [iobroker] - host.raspberrypi 24156 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_10_07-12_47_12_backupiobroker.tar.gz
      [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
      [DEBUG] [iobroker] - done
      [DEBUG] [cifs] - used copy path: /Backup_ioBroker
      [DEBUG] [cifs] - done
      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [pushover] - [iobroker] used pushover-Instance: pushover.0
      [DEBUG] [pushover] - done
      [DEBUG] [pushover] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_10_07-12_47_12_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"07. Oktober 2023 um 12:47 Uhr"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_10_07-12_47_12_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"07. Oktober 2023 um 12:47 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_10_07-12_47_12_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"07. Oktober 2023 um 12:47 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [umount] - mount activ, umount is started ...
      [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 0
      [/s]
        Thomas Braun Most Active @theo996 last edited by Thomas Braun
        @theo996
        Warte auf nodejs 18.18.1
        Ich vermute, das hat mit der libuv aus 18.18.0 zu tun.
        https://forum.iobroker.net/topic/68779/tester-gesucht-backup-auf-fritz-nas-node-18-18-0?_=1696680468995
          Thomas Braun Most Active last edited by
          @theo996 sagte in BackItUp kann alte Backups nicht löschen:
          Wie sehen die Einstellungen im Adapter denn an Stelle genau aus?
            theo996 @Thomas Braun last edited by
              @theo996
              Die 'noserverino'-Option wird eigentlich nur für Fritz.Nas verwendet. Wenn das da bei dir keines ist, dann schalt die aus.
                Erledigt, aber das hatte ich auch nur eben mal aktiviert um zu schauen, ob es was ändert... hatte es aber nicht.
                • simatec
                  simatec Developer Most Active @theo996 last edited by
                  @theo996 Es gibt aktuell nur 2 Möglichkeiten…
                  Auf Node 18.18.1 warten oder zurück auf 18.17.0 gehen
                    theo996 @simatec last edited by
                    @simatec
                    Ich denke ich werde mich in Geduld üben und auf 18.18.1 warten..
                    Besten Dank für Euer Feedback!
                      @simatec
                      18.18.1 aufgespielt und alles ist wieder fein 🙂
                      backup fehler backup file löschen gelöst
