    4. Smartmeter ZPA GH305 per Weidmann IR-Lesekopf anschließen
      ja @Homoran last edited by
      @homoran ok, probieren wir das. Wäre toll, wenn du oder jemand anderes dort irgendwas findet. 🙂
      Hier kommt das Log. Die Instanz und der Adapter stehen auf Debug. Am Beginn habe ich den Adapter einmal neu gestartet.
      2023-10-08 11:56:15.771 - debug: host.ja-20bws3wy01 object change system.adapter.smartmeter.0 (from: system.adapter.admin.0)
      2023-10-08 11:56:15.771 - info: host.ja-20bws3wy01 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
      2023-10-08 11:56:15.781 - info: smartmeter.0 (4050) Got terminate signal TERMINATE_YOURSELF
      2023-10-08 11:56:15.783 - info: host.ja-20bws3wy01 stopInstance system.adapter.smartmeter.0 send kill signal
      2023-10-08 11:56:15.782 - info: smartmeter.0 (4050) terminating
      2023-10-08 11:56:15.783 - debug: smartmeter.0 (4050) Plugin sentry destroyed
      2023-10-08 11:56:15.783 - info: smartmeter.0 (4050) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-10-08 11:56:16.285 - info: smartmeter.0 (4050) terminating
      2023-10-08 11:56:16.317 - info: host.ja-20bws3wy01 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-08 11:56:18.792 - debug: host.ja-20bws3wy01 added notifications configuration of system.adapter.smartmeter.0
      2023-10-08 11:56:18.792 - debug: host.ja-20bws3wy01 startInstance smartmeter.0 loglevel=debug, compact=false
      2023-10-08 11:56:18.804 - info: host.julian-20bws3wy01 instance system.adapter.smartmeter.0 started with pid 4182
      2023-10-08 11:56:19.536 - debug: smartmeter.0 (4182) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-10-08 11:56:19.553 - debug: smartmeter.0 (4182) Objects client ready ... initialize now
      2023-10-08 11:56:19.554 - debug: smartmeter.0 (4182) Objects create System PubSub Client
      2023-10-08 11:56:19.555 - debug: smartmeter.0 (4182) Objects create User PubSub Client
      2023-10-08 11:56:19.565 - debug: smartmeter.0 (4182) Objects client initialize lua scripts
      2023-10-08 11:56:19.570 - debug: smartmeter.0 (4182) Objects connected to redis: 127.0.0.1:9001
      2023-10-08 11:56:19.580 - debug: smartmeter.0 (4182) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-10-08 11:56:19.583 - debug: smartmeter.0 (4182) States create System PubSub Client
      2023-10-08 11:56:19.584 - debug: smartmeter.0 (4182) States create User PubSub Client
      2023-10-08 11:56:19.589 - debug: smartmeter.0 (4182) States connected to redis: 127.0.0.1:9000
      2023-10-08 11:56:19.604 - debug: smartmeter.0 (4182) Plugin sentry Initialize Plugin (enabled=true)
      2023-10-08 11:56:19.755 - info: smartmeter.0 (4182) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v20.7.0, js-controller: 5.0.12
      2023-10-08 11:56:19.768 - debug: smartmeter.0 (4182) SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"0","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DQ00LLOG-if00-port0","transportSerialBaudrate":9600,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false}
      2023-10-08 11:56:19.769 - debug: smartmeter.0 (4182) CREATE SERIALPORT: 9600 8 1 none
      2023-10-08 11:56:19.772 - debug: smartmeter.0 (4182) SET MESSAGE TIMEOUT TIMER: 120000
      2023-10-08 11:56:19.785 - debug: smartmeter.0 (4182) connected set to false
      2023-10-08 11:57:52.966 - debug: host.ja-20bws3wy01 Incoming Host message getLogFile
      2023-10-08 11:58:16.879 - debug: host.ja-20bws3wy01 Incoming Host message getLogFile
      2023-10-08 11:58:19.773 - debug: smartmeter.0 (4182) MESSAGE TIMEOUT TRIGGERED
      2023-10-08 11:58:19.775 - debug: smartmeter.0 (4182) Error: No or too long answer from Serial Device after last request.
      2023-10-08 11:58:19.777 - warn: smartmeter.0 (4182) No or too long answer from Serial Device after last request.
      2023-10-08 11:58:19.777 - debug: smartmeter.0 (4182) Error: No or too long answer from Serial Device after last request.
      2023-10-08 11:58:19.778 - debug: smartmeter.0 (4182) Transport Reset!! Restart = true
      2023-10-08 11:58:19.779 - debug: smartmeter.0 (4182) SCHEDULE NEXT RUN IN 0s
      2023-10-08 11:58:19.782 - debug: smartmeter.0 (4182) CREATE SERIALPORT: 9600 8 1 none
      2023-10-08 11:58:19.784 - debug: smartmeter.0 (4182) SET MESSAGE TIMEOUT TIMER: 120000
      Plattform Info:
         Plattform: linux
         Betriebssystem: linux
         Architektur: x64
         CPUs: 4
         Geschwindigkeit: 2501 MHz
         Modell: Intel(R) Core(TM) i5-5300U CPU @ 2.30GHz
         RAM: 7.4 GB
         System-Betriebszeit: 00:17:00
         Node.js: v20.7.0
         time: 1696759282384
         timeOffset: -120
         NPM: 10.1.0
         Adapter-Anzahl: 504
         Datenträgergröße: 931.5 GB
         Freier Festplattenspeicher: 371.7 GB
         Aktive Instanzen: 4
         Pfad: /opt/iobroker/
         Betriebszeit: 00:16:54
         aktiv:
        Homoran Global Moderator Administrators @ja last edited by Homoran
        wenn ich das richtig sehe, wird zwischen hier
        @ja sagte in Smartmeter ZPA GH305 per Weidmann IR-Lesekopf anschließen:
        und hier
        nichts abgerufen, sondern direkt wieder die Verbindung geschlossen.
        Also kommt der Adapter nicht einmal dazu etwas auszuwerten.
        du müsstest noch die aktuelle
        @homoran sagte in Smartmeter ZPA GH305 per Weidmann IR-Lesekopf anschließen:
        Konfiguration zeigen
        von der Instanz
          @homoran said in Smartmeter ZPA GH305 per Weidmann IR-Lesekopf anschließen:
          Was meinst du genau damit?
          Ich hätte noch die "Smartmeter Adapter Einstellungen" im Angebot? Ist es das?
          Allgemeine Einstellungen
          Datenabfrageintervall: <leer>
          Datenübertragung: Serielle Daten werden nur gelesen
          Daten-Protokoll: Smart Message Language 1.0.3/1.0.4
          Sprache der Datenpunktnamen: Englisch
          Einstellungen Datenübertragung
          Serielles Gerät: Name: /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DQ00LLOG-if00-port0 (/dev/ttyUSB0)
          Serielles Gerät: Baudrate: <leer> baud
          Serielles Gerät: Data-Bits: Standard Protokoll/Übertragung
          Serielles Gerät: Stop-Bits:  Standard Protokoll/Übertragung
          Serielles Gerät: Parität: Standard Protokoll/Übertragung
          Wartezeit auf serielle Antwort: <leer>
          Einstellungen Datenprotokoll
          SML: CRC-Prüfsummenfehler ignorieren <nicht aktiviert>
          Kodierung der SML Daten: Binärdaten (Standard)
            Ja, es wirkt so, als sei gar nichts angeschlossen. Ich bekomme auch die gleichen Fehlermeldungen, egal, ob ich das Kabel dran habe oder nicht.
            Ich würde ja auf einen Hardwarefehler tippen, wenn nicht über die Konsole Daten ausgegeben werden würden (und das auch nur, wenn das Kabel tatsächlich dran hängt).
            Kann es mit Rechten zusammen hängen? Also das iobroker die Daten aus irgendwelchen Gründen nicht abrufen darf bzw. das OS seitig unterbunden wird?
              Ist es das?
              als Screenshot bitte
                @homoran Kein Problem.
                  da will ich drauf hinaus!
                  und auch das irritiert mich, genauso wie die Hyroglyphen
                  In der Anleitung hab ich nichts von verschlüsselten Daten gefunden.
                    @ja wo hast du diesen Pfad her?
                    hast du ggf. den udev bug?
                    Stell mal auf benutzerdefiniert und dann diesen Pfad ein
                    wieso englisch?
                      @homoran Den Pfad habe ich nicht selbst eingegeben. Ich habe ursprünglich auf "benutzerdefiniert" gestellt und dann den Pfad /dev/ttyUSB0 eingegeben. Das ging nicht anders, da USB-Pfade in der vorgegebenen Liste nicht auftauchen. Der lange Name muss dann von irgendwo abgerufen worden sein.
                      Hab das gerade nochmal durchgespielt - ändert nix 😞
                      Ob Englisch oder Deutsch ist mir gleich, macht aber leider auch keinen Unterschied bezogen auf den Fehler.
                        Was ist der udev bug?
                          Thomas Braun Most Active @ja last edited by Thomas Braun
                          @ja
                          Und geh auf nodejs@18, die
                          Node.js: v20.7.0
                          ist für den ioBroker noch nicht empfohlen.
                          sudo apt update
                          apt policy udev
                          sagt?
                            @thomas-braun sagte in Smartmeter ZPA GH305 per Weidmann IR-Lesekopf anschließen:
                            Adlerauge!
                            soweit wenn man zwischen den Zeilen lesen muss
                            statt das iob diag direkt zu bekommen
                              Chrisham @Homoran last edited by
                              @homoran Hallo zusammen,
                              dieser Thread scheint noch relativ "jung" zu sein, ich beschäftige mich mit ähnlichem Setup, allerdings gibts bei mir schon viel früher Probleme.
                              1.) Also das Smart-Meter als USB-Verbindung scheint erkannt zu werden, sowohl auf Host-Ebene (DSM-Linux), also auch innerhalb des Docker-Containers vom IOBroker:
                              2.) Aber der Test gemäß https://shop.weidmann-elektronik.de/media/files_public/9d73b590bf0752a5beff32d229d4497d/HowToRaspberryPi.pdf liefert bei mir gar keine Reaktion:
                              3.) Um Gerätedefekt auszuschließen, habe ich an PC mit Windows angeschlossen und der von Weidmann gelieferten Test-SW getestet, dies scheint erfolgreich zu sein:
                              4.) Aber auf Linux-Ebene bzw. im Iobroker-Docker scheint es keine Kommunikation zu geben, demzufolge natürlich auch im Smartmeter-Adapter diese Logs:
                              2023-11-21 00:26:23.545 - debug: smartmeter.0 (19527) MESSAGE TIMEOUT TRIGGERED
                              2023-11-21 00:26:23.545 - debug: smartmeter.0 (19527) Error: No or too long answer from Serial Device after last request.
                              2023-11-21 00:26:23.545 - warn: smartmeter.0 (19527) No or too long answer from Serial Device after last request.
                              2023-11-21 00:26:23.546 - debug: smartmeter.0 (19527) Error: No or too long answer from Serial Device after last request.
                              2023-11-21 00:26:23.546 - debug: smartmeter.0 (19527) Transport Reset!! Restart = true
                              2023-11-21 00:26:23.546 - debug: smartmeter.0 (19527) SERIALPORT CLOSE
                              2023-11-21 00:26:23.547 - debug: smartmeter.0 (19527) SCHEDULE NEXT RUN IN 30s
                              2023-11-21 00:26:53.547 - debug: smartmeter.0 (19527) CREATE SERIALPORT: 9600 8 1 none
                              2023-11-21 00:26:53.548 - debug: smartmeter.0 (19527) SERIALPORT OPEN
                              2023-11-21 00:26:53.550 - debug: smartmeter.0 (19527) SET MESSAGE TIMEOUT TIMER: 120000
                              Das ist die Adatper-Config:
                              Fehlen noch Infos?
                              Habt ihr eine idee?
                              C Homoran 2 Replies Last reply Reply Quote 0
                                Chrisham @Chrisham last edited by
                                @chrisham IOB Diag:
                                                        v.2023-10-10
                                model name      : Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
                                Kernel          : x86_64
                                Userland        : amd64
                                Docker          : v9.0.1
                                Installation:           Docker
                                Kernel:                 x86_64
                                Userland:               amd64
                                Timezone:               Etc/UTC
                                User-ID:                0
                                X-Server:               false
                                Pending OS-Updates:     0
                                Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                                Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                                Pending iob updates:    5
                                Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                        /usr/bin/node           v18.18.2
                                                        /usr/bin/npm            9.8.1
                                                        /usr/bin/npx            9.8.1
                                                        /usr/bin/corepack       0.19.0
                                Recommended versions are nodejs 18.18.2 and npm 9.8.1
                                MEMORY:
                                Mem:            3.9G        2.5G        305M         30M        1.4G        1.4G
                                Swap:           4.5G        1.3G        3.3G
                                Total:          8.5G        3.8G        3.6G
                                Active iob-Instances:   21
                                Active repo(s): stable
                                ioBroker Core:          js-controller           4.0.24
                                                        admin                   6.10.1
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : iobroker-9                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : iobroker-9                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                11019
                                States:                 10971
                                Size of iob-Database:
                                15M     /opt/iobroker/iobroker-data/objects.jsonl
                                12M     /opt/iobroker/iobroker-data/states.jsonl
                                === Mark text until here for copying ===
                                root@iobroker-9:/opt/iobroker#
                                  Homoran Global Moderator Administrators @Chrisham last edited by
                                  @chrisham sagte in Smartmeter ZPA GH305 per Weidmann IR-Lesekopf anschließen:
                                  Habt ihr eine idee?
                                  kenne ich mich nicht aus.
                                  Sorry
                                    @homoran ok, Problem ist gelöst, im Falle Linux war es einfaches Verkabelungsproblem vom Zähler zum NAS.
                                    1591
