    4. iobroker zeschossen
    iobroker zeschossen
    • Krisiun
      Krisiun @Thomas Braun last edited by
      Kann aber trotzdem den iob nicht starten. Gleiche Fehler.
      krisiun@Marek2:/root$ iobroker start
      /usr/bin/node: 1: cannot create : Permission denied
      /usr/bin/node: 2: : not found
      /usr/bin/node: 4: Syntax error: Unterminated quoted string
        Thomas Braun Most Active @Krisiun last edited by Thomas Braun
        @krisiun
        NICHT SO SCHNELL!
        Du bist ja auch noch nicht fertig...
        sudo apt update
        cd
        sagt?
        Krisiun 1 Reply Last reply Reply Quote 0
        • Krisiun
          krisiun@Marek2:/root$ sudo apt update
          Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
          Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
          Get:4 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
          Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Err:4 https://dl.yarnpkg.com/debian stable InRelease
            The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
          Err:6 https://deb.nodesource.com/node_18.x nodistro InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
          Fetched 17.1 kB in 4s (4719 B/s)
          Reading package lists... Done
          Building dependency tree... Done
          1 package can be upgraded. Run 'apt list --upgradable' to see it.
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
          W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
          W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
          W: Some index files failed to download. They have been ignored, or old ones used instead.
            @krisiun
            Du solltest doch yarn löschen...
            sudo rm /etc/apt/sources.list.d/yar*
            • Krisiun
              Dann sag mir bitte, bitte wie? Sorry aber das ist mir auch schon unangenehm dass ich das nicht schnalle
                @krisiun
                Dann
                sudo rm `sudo find / -name nodesource.gpg`
                sudo rm `sudo find / -name nodesource.key`
                sudo apt install -y ca-certificates curl gnupg
                sudo mkdir -p /etc/apt/keyrings
                curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                sudo apt update
                  @krisiun sagte in iobroker zeschossen:
                  Steht doch da.
                  • Krisiun
                    Ich bin dabei aber ich kanns nicht finden
                    Thomas Braun bahnuhr 2 Replies Last reply Reply Quote 0
                      Was? Dein Terminal?
                      • Krisiun
                        wo ich das löschen kann
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @Krisiun last edited by
                          Du sollst da nichts finden.
                          Sondern dich per putty (oder was du auch immer nimmst) einloggen.
                          Und dann in der konsole den Befehl eingeben.
                          Mehr nicht.
                            @krisiun
                            MIT DEM BEFEHL:
                            Klickst du da mit einem Filebrowser wild durch die Gegend? Lass das!
                            Krisiun 2 Replies Last reply Reply Quote 0
                            • Krisiun
                              krisiun@Marek2:/root$ sudo rm /etc/apt/sources.list.d/yar*
                              rm: cannot remove '/etc/apt/sources.list.d/yar*': No such file or directory
                              • Krisiun
                                Ist wohl wieder falsch?
                                  @krisiun
                                  cd
                                  ls -lAh /etc/apt/sources.list.d/
                                  • Krisiun
                                    krisiun@Marek2:/root$ ls -lAh /etc/apt/sources.list.d/
                                    total 0
                                    -rw-r--r-- 1 root root 100 Oct  8 21:12 nodesource.list
                                    -rw-r--r-- 1 root root 202 Nov 22  2022 nodesource.list.distUpgrade
                                    -rw-r--r-- 1 root root 109 Oct  8 21:11 nodesource.list.save
                                      @krisiun
                                      cd
                                      sudo rm /etc/apt/sources.list.d/nodesource.list.*
                                      sudo apt update
                                        Homoran Global Moderator Administrators @Krisiun last edited by
                                        Hab alles gemacht
                                        zeigen!
                                        incl. Eingabe
                                        • Krisiun
                                          krisiun@Marek2:/root$ cd
                                          krisiun@Marek2:~$ sudo rm /etc/apt/sources.list.d/nodesource.list.*
                                          krisiun@Marek2:~$ sudo apt update
                                          Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
                                          Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                                          Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                                          Err:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                                            @krisiun
                                            Wir nähern uns langsam an...
                                            sudo apt update
                                            24260
