    4. iobroker zeschossen
    iobroker zeschossen
      Thomas Braun Most Active @Krisiun last edited by
      @krisiun
      apt list --upgradable
      Krisiun 1 Reply Last reply Reply Quote 0
      • Krisiun
        Krisiun @Thomas Braun last edited by
        @thomas-braun sagte in iobroker zeschossen:
        krisiun@Marek2:~$ apt list --upgradable
        Listing... Done
        nodejs/nodistro 18.18.0-1nodesource1 amd64 [upgradable from: 12.22.9~dfsg-1ubuntu3]
        N: There are 24 additional versions. Please use the '-a' switch to see them
          @krisiun
          Dann jetzt endlich
          sudo apt full-upgrade
          sudo apt autoremove
          • Krisiun
            Nr 1
            krisiun@Marek2:~$ sudo apt full-upgrade
            Reading package lists... Done
            Building dependency tree... Done
            Calculating upgrade... Done
            The following packages were automatically installed and are no longer required:
              javascript-common libc-ares2 libffi7 libjs-highlight.js libllvm13 libnode72 libpython2-dev libpython2-stdlib
              libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal python2.7
              python2.7-dev python2.7-minimal
            Use 'sudo apt autoremove' to remove them.
            The following packages will be upgraded:
              nodejs
            1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Need to get 0 B/29.5 MB of archives.
            After this operation, 188 MB of additional disk space will be used.
            Do you want to continue? [Y/n] y
            (Reading database ... 48341 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
            Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
            dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
             trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
            Errors were encountered while processing:
            needrestart is being skipped since dpkg has failed
            E: Sub-process /usr/bin/dpkg returned an error code (1)
            Krisiun Thomas Braun OliverIO 3 Replies Last reply Reply Quote 0
            • Krisiun
              Krisiun @Krisiun last edited by
              @krisiun
              Nr 2
              krisiun@Marek2:~$ sudo apt autoremove
              The following packages will be REMOVED:
                javascript-common libffi7 libjs-highlight.js libllvm13 libpython2-dev libpython2-stdlib libpython2.7
              0 upgraded, 0 newly installed, 16 to remove and 1 not upgraded.
              After this operation, 135 MB disk space will be freed.
              Removing javascript-common (11+nmu1) ...
              Removing libffi7:amd64 (3.3-5ubuntu1) ...
              Removing libjs-highlight.js (9.18.5+dfsg1-1) ...
              Removing libllvm13:amd64 (1:13.0.1-2ubuntu2.2) ...
              Removing python2-dev (2.7.18-3) ...
              Removing libpython2-dev:amd64 (2.7.18-3) ...
              Removing python2 (2.7.18-3) ...
              Removing libpython2-stdlib:amd64 (2.7.18-3) ...
              Removing python2.7-dev (2.7.18-13ubuntu1.1) ...
              Removing libpython2.7-dev:amd64 (2.7.18-13ubuntu1.1) ...
              Removing libpython2.7:amd64 (2.7.18-13ubuntu1.1) ...
              Removing python2.7 (2.7.18-13ubuntu1.1) ...
              Removing libpython2.7-stdlib:amd64 (2.7.18-13ubuntu1.1) ...
              Removing python2-minimal (2.7.18-3) ...
              Removing python2.7-minimal (2.7.18-13ubuntu1.1) ...
              Unlinking and removing bytecode for runtime python2.7
              Removing libpython2.7-minimal:amd64 (2.7.18-13ubuntu1.1) ...
              Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
              Processing triggers for man-db (2.10.2-1) ...
              Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
              Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
              Scanning processes...
              Scanning candidates...
              Scanning processor microcode...
              Scanning linux images...
              Failed to retrieve available kernel versions.
              Failed to check for processor microcode upgrades.
              No services need to be restarted.
              No containers need to be restarted.
              User sessions running outdated binaries:
               krisiun @ /dev/tty1: bash[5843]
               root @ /dev/pts/0: apt[6559,6667], sh[6672]
               root @ /dev/tty1: bash[5801], init[5800], su[5842]
              No VM guests are running outdated hypervisor (qemu) binaries on this host.
                @krisiun sagte in iobroker zeschossen:
                libnode72
                sudo apt purge libnode72 node-*
                • Krisiun
                  Die ausgabe ist zu groß kann ich nicht schicken aber ich schicke Die die letzte Zeile da ist denke ich ein fehler
                    @krisiun
                    Nee, kann ich nicht.
                    • Krisiun
                      Leider
                      • OliverIO
                        OliverIO @Krisiun last edited by
                        @krisiun
                        zu wsl unter windows würde gern auf die faq von microsoft hinweisen.
                        du kannst da gern experimentieren, allerdings ist wsl eigentlich nur zu linux-entwicklung unter windows gedacht und nicht um da einen server dauerhaft laufen zu lassen.
                        https://learn.microsoft.com/en-us/windows/wsl/faq#can-i-use-wsl-for-production-scenarios--
                        • Krisiun
                          Krisiun @OliverIO last edited by
                          @oliverio
                          OK also es wird nix?
                            Leider
                            ...nicht vollständig.
                            • Krisiun
                              krisiun@Marek2:~$ sudo apt purge libnode72
                              The following package was automatically installed and is no longer required:
                                libc-ares2
                              Use 'sudo apt autoremove' to remove it.
                              The following additional packages will be installed:
                                nodejs
                                libnode72*
                                nodejs
                              1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                              After this operation, 147 MB of additional disk space will be used.
                              (Reading database ... 47321 files and directories currently installed.)
                                libnode72
                                sudo apt remove libnode72
                                • OliverIO
                                  @krisiun
                                  zum probieren schon,
                                  aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
                                  daher, kauf dir lieber eine raspi.
                                  die sind nicht so teuer.
                                  denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
                                  wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
                                  und kannst dich langsam in das thema linux einlesen.
                                  ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
                                  da kommen dann eher 100W und höher auf.
                                  10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
                                  100w
                                  24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
                                  Fürs Jahr kannst dir das ja selber ausrechnen.
                                  Krisiun Great SUN 2 Replies Last reply Reply Quote 0
                                  • Krisiun
                                    krisiun@Marek2:~$ sudo apt remove libnode72
                                      libc-ares2
                                      nodejs
                                      libnode72
                                      nodejs
                                    • Krisiun
                                      @oliverio sagte in iobroker zeschossen:
                                      @krisiun
                                      100w
                                      Danke für den Tipp aber ich habe schon einen
                                      Krisiun bahnuhr 2 Replies Last reply Reply Quote 0
                                      • Krisiun
                                        @krisiun
                                        100w
                                        Das hier läuft nur sporadisch nicht ständig
                                        • bahnuhr
                                          bahnuhr Forum Testing Most Active @Krisiun last edited by
                                          habe schon einen
                                          hoffentlich was ordentliches mit viel Speicher
                                            @krisiun
                                            apt policy nodejs
                                            23992
