    4. iobroker zeschossen
    iobroker zeschossen
    • Krisiun
      Krisiun @Thomas Braun last edited by
      @thomas-braun sagte in iobroker zeschossen:
      sudo apt full-upgrade
      Nr 1
      krisiun@Marek2:~$ sudo apt full-upgrade
      Reading package lists... Done
      Building dependency tree... Done
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        javascript-common libc-ares2 libffi7 libjs-highlight.js libllvm13 libnode72 libpython2-dev libpython2-stdlib
        libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal python2.7
        python2.7-dev python2.7-minimal
      Use 'sudo apt autoremove' to remove them.
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 0 B/29.5 MB of archives.
      After this operation, 188 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      (Reading database ... 48341 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
      Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
      dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
       trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
      Errors were encountered while processing:
      needrestart is being skipped since dpkg has failed
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      Krisiun Thomas Braun OliverIO 3 Replies Last reply Reply Quote 0
      • Krisiun
        Krisiun @Krisiun last edited by
        @krisiun
        Nr 2
        krisiun@Marek2:~$ sudo apt autoremove
        The following packages will be REMOVED:
          javascript-common libffi7 libjs-highlight.js libllvm13 libpython2-dev libpython2-stdlib libpython2.7
        0 upgraded, 0 newly installed, 16 to remove and 1 not upgraded.
        After this operation, 135 MB disk space will be freed.
        Removing javascript-common (11+nmu1) ...
        Removing libffi7:amd64 (3.3-5ubuntu1) ...
        Removing libjs-highlight.js (9.18.5+dfsg1-1) ...
        Removing libllvm13:amd64 (1:13.0.1-2ubuntu2.2) ...
        Removing python2-dev (2.7.18-3) ...
        Removing libpython2-dev:amd64 (2.7.18-3) ...
        Removing python2 (2.7.18-3) ...
        Removing libpython2-stdlib:amd64 (2.7.18-3) ...
        Removing python2.7-dev (2.7.18-13ubuntu1.1) ...
        Removing libpython2.7-dev:amd64 (2.7.18-13ubuntu1.1) ...
        Removing libpython2.7:amd64 (2.7.18-13ubuntu1.1) ...
        Removing python2.7 (2.7.18-13ubuntu1.1) ...
        Removing libpython2.7-stdlib:amd64 (2.7.18-13ubuntu1.1) ...
        Removing python2-minimal (2.7.18-3) ...
        Removing python2.7-minimal (2.7.18-13ubuntu1.1) ...
        Unlinking and removing bytecode for runtime python2.7
        Removing libpython2.7-minimal:amd64 (2.7.18-13ubuntu1.1) ...
        Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
        Processing triggers for man-db (2.10.2-1) ...
        Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
        Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
        Scanning processes...
        Scanning candidates...
        Scanning processor microcode...
        Scanning linux images...
        Failed to retrieve available kernel versions.
        Failed to check for processor microcode upgrades.
        No services need to be restarted.
        No containers need to be restarted.
        User sessions running outdated binaries:
         krisiun @ /dev/tty1: bash[5843]
         root @ /dev/pts/0: apt[6559,6667], sh[6672]
         root @ /dev/tty1: bash[5801], init[5800], su[5842]
        No VM guests are running outdated hypervisor (qemu) binaries on this host.
          Thomas Braun Most Active @Krisiun last edited by
          @krisiun sagte in iobroker zeschossen:
          libnode72
          sudo apt purge libnode72 node-*
          Krisiun 1 Reply Last reply Reply Quote 0
          • Krisiun
            Die ausgabe ist zu groß kann ich nicht schicken aber ich schicke Die die letzte Zeile da ist denke ich ein fehler
              @krisiun
              Nee, kann ich nicht.
              • Krisiun
                Leider
                • OliverIO
                  OliverIO @Krisiun last edited by
                  @krisiun
                  zu wsl unter windows würde gern auf die faq von microsoft hinweisen.
                  du kannst da gern experimentieren, allerdings ist wsl eigentlich nur zu linux-entwicklung unter windows gedacht und nicht um da einen server dauerhaft laufen zu lassen.
                  https://learn.microsoft.com/en-us/windows/wsl/faq#can-i-use-wsl-for-production-scenarios--
                  • Krisiun
                    Krisiun @OliverIO last edited by
                    @oliverio
                    OK also es wird nix?
                      Leider
                      ...nicht vollständig.
                      • Krisiun
                        krisiun@Marek2:~$ sudo apt purge libnode72
                        The following package was automatically installed and is no longer required:
                          libc-ares2
                        Use 'sudo apt autoremove' to remove it.
                        The following additional packages will be installed:
                          nodejs
                          libnode72*
                          nodejs
                        1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                        After this operation, 147 MB of additional disk space will be used.
                        (Reading database ... 47321 files and directories currently installed.)
                          libnode72
                          sudo apt remove libnode72
                          • OliverIO
                            @krisiun
                            zum probieren schon,
                            aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
                            daher, kauf dir lieber eine raspi.
                            die sind nicht so teuer.
                            denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
                            wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
                            und kannst dich langsam in das thema linux einlesen.
                            ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
                            da kommen dann eher 100W und höher auf.
                            10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
                            100w
                            24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
                            Fürs Jahr kannst dir das ja selber ausrechnen.
                            Krisiun Great SUN 2 Replies Last reply Reply Quote 0
                            • Krisiun
                              krisiun@Marek2:~$ sudo apt remove libnode72
                                libc-ares2
                                nodejs
                                libnode72
                                nodejs
                              • Krisiun
                                @oliverio sagte in iobroker zeschossen:
                                @krisiun
                                100w
                                Danke für den Tipp aber ich habe schon einen
                                Krisiun bahnuhr 2 Replies Last reply Reply Quote 0
                                • Krisiun
                                  @krisiun
                                  100w
                                  Das hier läuft nur sporadisch nicht ständig
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @Krisiun last edited by
                                    habe schon einen
                                    hoffentlich was ordentliches mit viel Speicher
                                      @krisiun
                                      apt policy nodejs
                                      • Krisiun
                                        Krisiun @bahnuhr last edited by
                                        @bahnuhr
                                        Ja das passt schon. Danke
                                        bahnuhr Thomas Braun 2 Replies Last reply Reply Quote 0
                                        • bahnuhr
                                          @bahnuhr
                                          Und wat für einen ?
                                          • Krisiun
                                            krisiun@Marek2:~$ apt policy nodejs
                                            nodejs:
                                              Installed: 12.22.9~dfsg-1ubuntu3
                                              Candidate: 18.18.0-1nodesource1
                                              Version table:
                                                 18.18.0-1nodesource1 500
                                                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                                 18.17.1-1nodesource1 500
                                                 18.17.0-1nodesource1 500
                                                 18.16.1-1nodesource1 500
                                                 18.16.0-1nodesource1 500
                                                 18.15.0-1nodesource1 500
                                                 18.14.2-1nodesource1 500
                                                 18.14.1-1nodesource1 500
                                                 18.14.0-1nodesource1 500
                                                 18.13.0-1nodesource1 500
                                                 18.12.0-1nodesource1 500
                                                 18.11.0-1nodesource1 500
                                                 18.10.0-1nodesource1 500
                                                 18.9.1-1nodesource1 500
                                                 18.9.0-1nodesource1 500
                                                 18.8.0-1nodesource1 500
                                                 18.7.0-1nodesource1 500
                                                 18.6.0-1nodesource1 500
                                                 18.5.0-1nodesource1 500
                                                 18.4.0-1nodesource1 500
                                                 18.3.0-1nodesource1 500
                                                 18.2.0-1nodesource1 500
                                                 18.1.0-1nodesource1 500
                                                 18.0.0-1nodesource1 500
                                             *** 12.22.9~dfsg-1ubuntu3 500
                                                    500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                                    100 /var/lib/dpkg/status
                                            23992
